Unable to wake from Suspend
Hello guys!
I am running Manjaro Linux on my HP Spectre x360. Since I installed it, I was never able to wake it from suspend. It kinda reacts on keyboard input and shows the screen for a little bit, but i am unable to type something to log in to the screen lock. I have tried to find some possible solutions in the Forum already like: laptop-cant-wake-from-suspend. Others i could not really follow or didn’t think where relevant.
Here is my output for:
inix -Fazy
  Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=47137479-daf4-4aa3-9468-2236f9634ef9 rw quiet apparmor=1
    security=apparmor resume=UUID=0cbff0db-8291-4801-8c08-605c711a30d5
    udev.log_priority=3 mem_sleep_default=deep
  Desktop: Sway v: 1.9 with: waybar tools: swayidle avail: swaylock
    lm: greetd Distro: Manjaro base: Arch Linux
  Type: Convertible System: HP product: HP Spectre x360 2-in-1 Laptop 14-ef0xxx
    v: Type1ProductConfigId serial: <superuser required> Chassis: type: 31
  Mobo: HP model: 893E v: 98.80 serial: <superuser required>
    part-nu: 78S43EA#ABD uuid: <superuser required> UEFI: Insyde v: F.26
    date: 03/28/2024
  ID-1: BAT1 charge: 32.7 Wh (58.6%) condition: 55.8/66.5 Wh (83.9%) volts: 7.7
    min: 7.7 model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
    status: discharging
  Device-1: hid-0018:04F3:2E2D.0006-battery model: ELAN2513:00 04F3:2E2D
    serial: N/A charge: N/A status: N/A
  Device-2: hidpp_battery_0 model: Logitech Marathon Mouse/Performance Plus
    M705 serial: <filter> charge: 55% (should be ignored) rechargeable: yes
    status: discharging
  Info: model: 12th Gen Intel Core i7-1255U bits: 64 type: MST AMCP
    arch: Alder Lake level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
    microcode: 0x433
  Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
    cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
    L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 463 high: 633 min/max: 400/4700:3500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 581 2: 400 3: 400 4: 400
    5: 400 6: 633 7: 400 8: 400 9: 576 10: 574 11: 400 12: 400 bogomips: 62688
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: Hewlett-Packard
    driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
    ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
    chip-ID: 8086:46a8 class-ID: 0300
  Display: wayland server: Xwayland v: 24.1.0 compositor: Sway v: 1.9 driver:
    gpu: i915 display-ID: 1
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x13c0 built: 2021 res: 1920x1280
    hz: 60 dpi: 172 gamma: 1.2 scale: 1 size: 284x189mm (11.18x7.44")
    diag: 341mm (13.4") ratio: 3:2 modes: 1920x1280
  API: EGL Message: EGL data requires eglinfo. Check --recommends.
  Device-1: Intel Alder Lake Imaging Signal Processor vendor: Hewlett-Packard
    driver: N/A bus-ID: 00:05.0 chip-ID: 8086:465d class-ID: 0480
  Device-2: Intel Alder Lake PCH-P High Definition Audio
    vendor: Hewlett-Packard driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:51c8 class-ID: 0401
  API: ALSA v: k6.6.32-1-MANJARO status: kernel-api tools: N/A
  Server-3: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033
    class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.3
    lmp-v: 12 status: discoverable: no pairing: no class-ID: 6c0000
  Local Storage: total: 953.87 GiB used: 41.3 GiB (4.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL21T0HCLR-00BH1
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: HPS3NGXH temp: 28.9 C
    scheme: GPT
  ID-1: / raw-size: 64 GiB size: 62.7 GiB (97.96%) used: 35.13 GiB (56.0%)
    fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
    used: 300 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
  ID-3: /home raw-size: 114.82 GiB size: 111.96 GiB (97.51%)
    used: 6.17 GiB (5.5%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
  ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/nvme0n1p6 maj-min: 259:6
  System Temperatures: cpu: 27.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 0 fan-2: 0
  Memory: total: 16 GiB note: est. available: 15.32 GiB used: 2.55 GiB (16.6%)
  Processes: 293 Power: uptime: 8m states: freeze,mem,disk suspend:
    suspend, test_resume image: 6.12 GiB services: upowerd Init: systemd v: 255
  Packages: pm: pacman pkgs: 870 libs: 221 tools: pacseek,pamac,yay
    Compilers: gcc: 14.1.1 Shell: nu running-in: foot inxi: 3.3.34
This should be around a suspend, followed by a hard reset. (I hope this is okay to post…)
journalctl --boot -2 | sed -n -r "/Starting.+Suspend/,/Finished.+Suspend/p"
Jun 02 15:13:39 kronberger-manjaro systemd[1]: Starting System Suspend...
Jun 02 15:13:39 kronberger-manjaro systemd-sleep[5221]: Performing sleep operation 'suspend'...
Jun 02 15:13:39 kronberger-manjaro kernel: PM: suspend entry (deep)
Jun 02 15:13:39 kronberger-manjaro kernel: PM: suspend exit
Jun 02 15:13:39 kronberger-manjaro kernel: PM: suspend entry (s2idle)
Jun 02 15:13:39 kronberger-manjaro kernel: Filesystems sync: 0.011 seconds
Jun 02 15:13:54 kronberger-manjaro kernel: Freezing user space processes
Jun 02 15:13:54 kronberger-manjaro kernel: Freezing user space processes completed (elapsed 0.002 seconds)
Jun 02 15:13:54 kronberger-manjaro kernel: OOM killer disabled.
Jun 02 15:13:54 kronberger-manjaro kernel: Freezing remaining freezable tasks
Jun 02 15:13:54 kronberger-manjaro kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Jun 02 15:13:54 kronberger-manjaro kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Jun 02 15:13:54 kronberger-manjaro kernel: ------------[ cut here ]------------
Jun 02 15:13:54 kronberger-manjaro kernel: i915 0000:00:02.0: i915 raw-wakerefs=1 wakelocks=1 on cleanup
Jun 02 15:13:54 kronberger-manjaro kernel: WARNING: CPU: 5 PID: 5228 at drivers/gpu/drm/i915/intel_runtime_pm.c:638 intel_runtime_pm_driver_release+0x61/0x70 [i915]
Jun 02 15:13:54 kronberger-manjaro kernel: Modules linked in: snd_seq_dummy rfcomm snd_hrtimer snd_seq snd_seq_device ccm cmac algif_hash algif_skcipher af_alg bnep hid_sensor_custom_intel_hinge hid_sensor_accel_3d hid_sensor_gyro_3d hid_sensor_incl_3d hid_sensor_als btusb hid_sensor_rotation hid_sensor_trigger btrtl industrialio_triggered_buffer btintel kfifo_buf btbcm hid_sensor_iio_common btmtk industrialio hid_sensor_custom bluetooth ecdh_generic hid_sensor_hub intel_ishtp_hid joydev mousedev snd_ctl_led snd_soc_skl_hda_dsp snd_soc_intel_hda_dsp_common snd_soc_hdac_hdmi snd_sof_probes snd_hda_codec_hdmi snd_hda_codec_realtek intel_uncore_frequency snd_hda_codec_generic intel_uncore_frequency_common ledtrig_audio snd_soc_dmic snd_sof_pci_intel_tgl snd_sof_intel_hda_common x86_pkg_temp_thermal soundwire_intel intel_powerclamp snd_sof_intel_hda_mlink coretemp soundwire_cadence snd_sof_intel_hda snd_sof_pci snd_sof_xtensa_dsp kvm_intel snd_sof snd_sof_utils snd_soc_hdac_hda kvm snd_hda_ext_core snd_soc_acpi_intel_match irqbypass crct10dif_pclmul
Jun 02 15:13:54 kronberger-manjaro kernel:  snd_soc_acpi crc32_pclmul soundwire_generic_allocation polyval_clmulni polyval_generic soundwire_bus gf128mul iwlmvm snd_soc_core ghash_clmulni_intel snd_compress sha512_ssse3 ac97_bus sha256_ssse3 snd_pcm_dmaengine sha1_ssse3 mac80211 snd_hda_intel aesni_intel snd_intel_dspcfg snd_intel_sdw_acpi crypto_simd snd_hda_codec hid_multitouch cryptd iTCO_wdt snd_hda_core snd_hwdep rapl intel_pmc_bxt pmt_telemetry processor_thermal_device_pci vfat fat iTCO_vendor_support mei_hdcp mei_pxp intel_rapl_msr pmt_class libarc4 iwlwifi hp_wmi snd_pcm processor_thermal_device intel_cstate ucsi_acpi spi_nor intel_uncore snd_timer processor_thermal_rfim i2c_i801 platform_profile wmi_bmof pcspkr typec_ucsi mtd cfg80211 intel_ish_ipc snd processor_thermal_mbox intel_lpss_pci soundcore i2c_smbus mei_me typec processor_thermal_rapl intel_lpss thunderbolt mei rfkill intel_ishtp idma64 igen6_edac intel_rapl_common intel_vsec roles i2c_hid_acpi intel_skl_int3472_tps68470 int3403_thermal hi556 i2c_hid v4l2_fwnode
Jun 02 15:13:54 kronberger-manjaro kernel:  tps68470_regulator int340x_thermal_zone clk_tps68470 v4l2_async videodev int3400_thermal intel_hid acpi_thermal_rel mc acpi_tad intel_skl_int3472_discrete sparse_keymap soc_button_array acpi_pad mac_hid squashfs crypto_user fuse loop dm_mod nfnetlink bpf_preload ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_logitech_hidpp hid_logitech_dj usbhid i915 serio_raw atkbd i2c_algo_bit rtsx_pci_sdmmc drm_buddy mmc_core ttm libps2 nvme intel_gtt vivaldi_fmap drm_display_helper crc32c_intel nvme_core spi_intel_pci video rtsx_pci i8042 xhci_pci spi_intel cec nvme_common xhci_pci_renesas serio wmi
Jun 02 15:13:54 kronberger-manjaro kernel: CPU: 5 PID: 5228 Comm: kworker/u24:9 Tainted: G        W          6.6.32-1-MANJARO #1 6999a884a429ad5a3f5887eda4aeb7a5975a620e
Jun 02 15:13:54 kronberger-manjaro kernel: Hardware name: HP HP Spectre x360 2-in-1 Laptop 14-ef0xxx/893E, BIOS F.26 03/28/2024
Jun 02 15:13:54 kronberger-manjaro kernel: Workqueue: events_unbound async_run_entry_fn
Jun 02 15:13:54 kronberger-manjaro kernel: RIP: 0010:intel_runtime_pm_driver_release+0x61/0x70 [i915]
Jun 02 15:13:54 kronberger-manjaro kernel: Code: fc 10 48 8b 5f 50 48 85 db 75 03 48 8b 1f e8 a6 2e 26 d6 45 89 e0 89 e9 48 89 da 48 89 c6 48 c7 c7 b8 dd 7b c0 e8 9f 66 9e d5 <0f> 0b 5b 5d 41 5c c3 cc cc cc cc 0f 1f 40 00 90 90 90 90 90 90 90
Jun 02 15:13:54 kronberger-manjaro kernel: RSP: 0018:ffffc90005fafd90 EFLAGS: 00010286
Jun 02 15:13:54 kronberger-manjaro kernel: RAX: 0000000000000000 RBX: ffff8881025dc080 RCX: 0000000000000027
Jun 02 15:13:54 kronberger-manjaro kernel: RDX: ffff88849f9616c8 RSI: 0000000000000001 RDI: ffff88849f9616c0
Jun 02 15:13:54 kronberger-manjaro kernel: RBP: 0000000000000001 R08: ffffffff97d57e60 R09: 0000000000ffff0a
Jun 02 15:13:54 kronberger-manjaro kernel: R10: ffffffffc07bddec R11: 0000000000000001 R12: 0000000000000001
Jun 02 15:13:54 kronberger-manjaro kernel: R13: ffff8881012f2000 R14: ffff88810a912358 R15: ffff888113a6d388
Jun 02 15:13:54 kronberger-manjaro kernel: FS:  0000000000000000(0000) GS:ffff88849f940000(0000) knlGS:0000000000000000
Jun 02 15:13:54 kronberger-manjaro kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jun 02 15:13:54 kronberger-manjaro kernel: CR2: 00007fa7e57f83c0 CR3: 0000000123620000 CR4: 0000000000f50ee0
Jun 02 15:13:54 kronberger-manjaro kernel: PKRU: 55555554
Jun 02 15:13:54 kronberger-manjaro kernel: Call Trace:
Jun 02 15:13:54 kronberger-manjaro kernel:  <TASK>
Jun 02 15:13:54 kronberger-manjaro kernel:  ? intel_runtime_pm_driver_release+0x61/0x70 [i915 82d31d894f7330aa5c6a8b4d9726f591178a86f1]
Jun 02 15:13:54 kronberger-manjaro kernel:  ? __warn+0x81/0x130
Jun 02 15:13:54 kronberger-manjaro kernel:  ? report_bug+0x16f/0x1a0
Jun 02 15:13:54 kronberger-manjaro kernel:  ? handle_bug+0x3c/0x80
Jun 02 15:13:54 kronberger-manjaro kernel:  ? exc_invalid_op+0x17/0x70
Jun 02 15:13:54 kronberger-manjaro kernel:  ? asm_exc_invalid_op+0x1a/0x20
Jun 02 15:13:54 kronberger-manjaro kernel:  i915_drm_suspend_late+0x117/0x130 [i915 82d31d894f7330aa5c6a8b4d9726f591178a86f1]
Jun 02 15:13:54 kronberger-manjaro kernel:  ? __pfx_pci_pm_suspend_late+0x10/0x10
Jun 02 15:13:54 kronberger-manjaro kernel:  dpm_run_callback+0x89/0x1e0
Jun 02 15:13:54 kronberger-manjaro kernel:  __device_suspend_late+0xb7/0x230
Jun 02 15:13:54 kronberger-manjaro kernel:  async_suspend_late+0x1e/0x70
Jun 02 15:13:54 kronberger-manjaro kernel:  async_run_entry_fn+0x31/0x130
Jun 02 15:13:54 kronberger-manjaro kernel:  process_one_work+0x16d/0x330
Jun 02 15:13:54 kronberger-manjaro kernel:  worker_thread+0x273/0x3c0
Jun 02 15:13:54 kronberger-manjaro kernel:  ? __pfx_worker_thread+0x10/0x10
Jun 02 15:13:54 kronberger-manjaro kernel:  kthread+0xe5/0x120
Jun 02 15:13:54 kronberger-manjaro kernel:  ? __pfx_kthread+0x10/0x10
Jun 02 15:13:54 kronberger-manjaro kernel:  ret_from_fork+0x31/0x50
Jun 02 15:13:54 kronberger-manjaro kernel:  ret_from_fork_asm+0x1b/0x30
Jun 02 15:13:54 kronberger-manjaro kernel:  </TASK>
Jun 02 15:13:54 kronberger-manjaro kernel: ---[ end trace 0000000000000000 ]---
Jun 02 15:13:54 kronberger-manjaro kernel: ACPI: EC: interrupt blocked
Jun 02 15:13:54 kronberger-manjaro kernel: ACPI: EC: interrupt unblocked
Jun 02 15:13:54 kronberger-manjaro kernel: nvme nvme0: Shutdown timeout set to 10 seconds
Jun 02 15:13:54 kronberger-manjaro kernel: nvme nvme0: 12/0/0 default/read/poll queues
Jun 02 15:13:54 kronberger-manjaro kernel: i915 0000:00:02.0: [drm] GT0: GuC firmware i915/adlp_guc_70.bin version 70.20.0
Jun 02 15:13:54 kronberger-manjaro kernel: i915 0000:00:02.0: [drm] GT0: HuC firmware i915/tgl_huc.bin version 7.9.3
Jun 02 15:13:54 kronberger-manjaro kernel: i915 0000:00:02.0: [drm] GT0: HuC: authenticated for all workloads
Jun 02 15:13:54 kronberger-manjaro kernel: i915 0000:00:02.0: [drm] GT0: GUC: submission enabled
Jun 02 15:13:54 kronberger-manjaro kernel: i915 0000:00:02.0: [drm] GT0: GUC: SLPC enabled
Jun 02 15:13:54 kronberger-manjaro kernel: i915 0000:00:02.0: [drm] GT0: GUC: RC enabled
Jun 02 15:13:54 kronberger-manjaro kernel: iwlwifi 0000:00:14.3: WRT: Invalid buffer destination
Jun 02 15:13:54 kronberger-manjaro kernel: iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x20
Jun 02 15:13:54 kronberger-manjaro kernel: iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
Jun 02 15:13:54 kronberger-manjaro kernel: iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
Jun 02 15:13:54 kronberger-manjaro kernel: iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
Jun 02 15:13:54 kronberger-manjaro kernel: iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
Jun 02 15:13:54 kronberger-manjaro kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
Jun 02 15:13:54 kronberger-manjaro kernel: OOM killer enabled.
Jun 02 15:13:54 kronberger-manjaro kernel: Restarting tasks ...
Jun 02 15:13:54 kronberger-manjaro kernel: mei_pxp 0000:00:16.0-fbf6fcf1-96cf-4e2e-a6a6-1bab8cbe36b1: bound 0000:00:02.0 (ops i915_pxp_tee_component_ops [i915])
Jun 02 15:13:54 kronberger-manjaro kernel: done.
Jun 02 15:13:54 kronberger-manjaro kernel: random: crng reseeded on system resumption
Jun 02 15:13:54 kronberger-manjaro sway[3169]: 00:26:08.030 [ERROR] [wlr] [libinput] client bug: timer event20 keyboard: scheduled expiry is in the past (-955ms), your system is too slow
Jun 02 15:13:54 kronberger-manjaro sway[3169]: 00:26:08.030 [ERROR] [wlr] [libinput] client bug: timer event20 keyboard: scheduled expiry is in the past (-639ms), your system is too slow
Jun 02 15:13:54 kronberger-manjaro sway[3169]: 00:26:08.030 [ERROR] [wlr] [libinput] client bug: timer event20 keyboard: scheduled expiry is in the past (-612ms), your system is too slow
Jun 02 15:13:54 kronberger-manjaro sway[3169]: 00:26:08.030 [ERROR] [wlr] [libinput] client bug: timer event20 keyboard: scheduled expiry is in the past (-610ms), your system is too slow
Jun 02 15:13:54 kronberger-manjaro sway[3169]: 00:26:08.030 [ERROR] [wlr] [libinput] client bug: timer event20 keyboard: scheduled expiry is in the past (-604ms), your system is too slow
Jun 02 15:13:54 kronberger-manjaro sway[3169]: 00:26:08.030 [ERROR] [wlr] [libinput] WARNING: log rate limit exceeded (5 msgs per 3600000ms). Discarding future messages.
Jun 02 15:13:54 kronberger-manjaro systemd-sleep[5221]: System returned from sleep operation 'suspend'.
Jun 02 15:13:54 kronberger-manjaro bluetoothd[2438]: Controller resume with wake event 0x0
Jun 02 15:13:54 kronberger-manjaro systemd[1]: systemd-suspend.service: Deactivated successfully.
Jun 02 15:13:54 kronberger-manjaro kernel: PM: suspend exit
Jun 02 15:13:54 kronberger-manjaro systemd[1]: Finished System Suspend.
Jun 02 15:14:09 kronberger-manjaro systemd[1]: Starting System Suspend...
Jun 02 15:14:09 kronberger-manjaro systemd-sleep[5469]: Performing sleep operation 'suspend'...
Jun 02 15:14:09 kronberger-manjaro kernel: PM: suspend entry (deep)
Jun 02 15:14:09 kronberger-manjaro kernel: PM: suspend exit
Jun 02 15:14:09 kronberger-manjaro kernel: PM: suspend entry (s2idle)
Is there a way to do a softer reset? And where would I best look for a log, where I can know more about that problem?
Thanks in advance.
Martin
My suspend also didn’t work properly. Let’s try and narrow the logs to be a bit more relevant. Please post the complete output of:
journalctl --unit=suspend.target --no-pager --priority=warning..err
Its just:
╰╴❯ journalctl --unit=suspend.target --no-pager --priority=warning..err
-- No entries --
I did a suspend cycle right before.
Thanks for the help!
OK, let’s leave out the priority part. Please provide the output for:
journalctl --unit=suspend.target --no-pager --boot=-1
This will limit it to be from the previous boot, so any other boots’ messages won’t show up.
There you go:
╰╴❯ journalctl --unit=suspend.target --no-pager --boot=-1
Jun 02 15:49:21 kronberger-manjaro systemd[1]: Reached target Suspend.
Jun 02 15:49:21 kronberger-manjaro systemd[1]: Stopped target Suspend.
And the output for:
systemctl suspend
Do you mean like this?
╰╴❯ journalctl -u systemd-suspend.service
∙ -- Boot d52c239dd27c4469a31597ce7bb88c83 --
Jun 02 15:13:39 kronberger-manjaro systemd-sleep[5221]: Performing sleep operation 'suspend'.>
Jun 02 15:13:54 kronberger-manjaro systemd-sleep[5221]: System returned from sleep operation >
Jun 02 15:13:54 kronberger-manjaro systemd[1]: systemd-suspend.service: Deactivated successfu>
Jun 02 15:14:09 kronberger-manjaro systemd-sleep[5469]: Performing sleep operation 'suspend'.>
-- Boot 38a6281e006b4521913a9f70fa5d6c2c --
Jun 02 15:17:42 kronberger-manjaro systemd[1]: Starting System Suspend...
Jun 02 15:17:42 kronberger-manjaro systemd-sleep[4380]: Performing sleep operation 'suspend'.>
Jun 02 15:18:07 kronberger-manjaro systemd-sleep[4380]: System returned from sleep operation >
Jun 02 15:18:07 kronberger-manjaro systemd[1]: systemd-suspend.service: Deactivated successfu>
Jun 02 15:18:07 kronberger-manjaro systemd[1]: Finished System Suspend.
-- Boot 1516fe99d94642eab4c10355c6fb3aa2 --
Jun 02 15:48:53 kronberger-manjaro systemd[1]: Starting System Suspend...
Jun 02 15:48:53 kronberger-manjaro systemd-sleep[6391]: Performing sleep operation 'suspend'.>
Jun 02 15:49:21 kronberger-manjaro systemd-sleep[6391]: System returned from sleep operation >
Jun 02 15:49:21 kronberger-manjaro systemd[1]: systemd-suspend.service: Deactivated successfu>
Jun 02 15:49:21 kronberger-manjaro systemd[1]: Finished System Suspend.
-- Boot 763a45ecffa64bffb0f59d3e07ae84a6 --
Jun 02 16:14:43 kronberger-manjaro systemd[1]: Starting System Suspend...
Jun 02 16:14:43 kronberger-manjaro systemd-sleep[5706]: Performing sleep operation 'suspend'.>
Jun 02 16:15:10 kronberger-manjaro systemd-sleep[5706]: System returned from sleep operation >
Jun 02 16:15:10 kronberger-manjaro systemd[1]: systemd-suspend.service: Deactivated successfu>
Jun 02 16:15:10 kronberger-manjaro systemd[1]: Finished System Suspend.
Hmmm…
journalctl --pager-end --no-pager --unit=systemd-suspend.service
Hmm i get no entries again…
Well, that just means it doesn’t have any log entries. Please provide the output for:
systemctl status systemd-suspend.service
╰╴❯ systemctl status systemd-suspend.service
○ systemd-suspend.service - System Suspend
     Loaded: loaded (/usr/lib/systemd/system/systemd-suspend.service; static)
     Active: inactive (dead)
       Docs: man:systemd-suspend.service(8)
I’ve just run this command on my PC to test it, and it works, so please provide the output for:
journalctl --unit=systemd-suspend.service --priority=err..warning --boot=-1 --no-pager
No entries. Again.
OK, I’m stumped. All I can recommend is making absolutely sure the service is enabled:
systemctl enable systemd-suspend.service
And/or checking the Arch wiki on the subject:
https://wiki.archlinux.org/title/Power_management/Suspend_and_hibernate#Troubleshooting
And waiting for someone more knowledgeable than i.
Okay, no problem. Thanks for the Support!
I’m not sure this is useful in your case;
sudo systemctl soft-reboot
however, there is also REISUB/REISUO:
It might be worth checking that the unit file actually exists:
ls /etc/systemd/system
ls /etc/systemd/user
…if those paths are correct…
https://bbs.archlinux.org/viewtopic.php?id=284176
That thread suggests that your laptop is affected by the incorrect VBT issue and the only solution is to patch the i915 driver as described there.
Thank you @Mirdarthos,
I followed the thread and found on my system the same responses to your questions (and the same issue) as @kronbergerindustrie.
May be your
is missing a --now, as described f.e. here (section “Update”)?
I tried following the patch. But i don’t have the file named ‘intel_bios.c’.
Did this change somehow? I am dual-booting. Maybe thats the problem.
But i think you are right. I have the same two entries for eDP as described:
	Child device info:
		Device handle: 0x0008 (LFP 1 (eDP))
		Device type: 0x1806 (unknown)
			Internal connector
			DisplayPort output
			Digital output
		I2C speed: 100 kHz (0x00)
		DP onboard redriver:
			present: no
			vswing: 0.4V (0x0)
			pre-emphasis: 0dB (0x0)
		DP ondock redriver:
			present: no
			vswing: 0.4V (0x0)
		HDMI max data rate: <platform max> (0x00)
		HDMI level shifter value: 0x00
		Offset to DTD buffer for edidless CHILD: 0x00
		LTTPR Mode: transparent
		Dual pipe ganged eDP: no
		Compression method CPS: no
		Compression enable: no
		Edidless EFP: no
		Compression structure index: 0
		HDMI Max FRL rate valid: no
		HDMI Max FRL rate: FRL not supported (0x0)
		AIM offset: 0
		DVO Port: DP-A (0x0a)
		AIM I2C pin: 0x00
		AIM Slave address: 0x00
		DDC pin: 0x03
		EDID buffer ptr: 0x00
		DVO config: 0x00
		eDP/DP max lane count: X4
		Use VBT vswing/premph table: no
		HPD sense invert: no
		Iboost enable: no
		Onboard LSPCON: no
		Lane reversal: no
		EFP routed through dock: no
		TMDS compatible? no
		DP compatible? no
		HDMI compatible? no
		Aux channel: AUX-A (0x40)
		Dongle detect: 0x00
		Integrated encoder instead of SDVO: yes
		Hotplug connect status: 0x00
		SDVO stall signal available: no
		Pipe capabilities: 0x00
		DVO wiring: 0x00
		MIPI bridge type: 00 (unknown)
		Device class extension: 0x00
		DVO function: 0x00
		DP port trace length: 0x0
		Thunderbolt port: no
		DP USB type C support: no
		2X DP GPIO index: 0x00
		2X DP GPIO pin number: 0x00
		IBoost level for DP/eDP: 0x00
		IBoost level for HDMI: 0x02
		DP max link rate: <platform max> (0x00)
	Child device info:
		Device handle: 0x0080 (LFP 2 (eDP))
			Internal connector
			DisplayPort output
			Digital output
			present: no
			vswing: 0.4V (0x0)
		DP ondock redriver:
			present: no
			vswing: 0.4V (0x0)
		Edidless EFP: no
		AIM offset: 0
		DVO Port: DP-B (0x07)
		AIM I2C pin: 0x00
		DDC pin: 0x00
		DVO config: 0x00
		Iboost enable: no
		Onboard LSPCON: no
		Lane reversal: no
		TMDS compatible? no
		DP compatible? no
		HDMI compatible? no
		Aux channel: AUX-B (0x10)
		Dongle detect: 0x00
		DVO wiring: 0x00
		DVO function: 0x00
You’re missing something because it should definitely be there in kernel 6.6
