Unable to wake from Suspend
Do you have the resume hook in /etc/mkinitcpio.conf? This is normally used for hibernation. Suspend should work fine without it, but perhaps this might be the source of your issue?
We can check this if you provide the output for:
cat /etc/mkinitcpio.conf
EDIT: Sorry i over read it. There is a resume in HOOKS.
╰╴❯ cat /etc/mkinitcpio.conf
# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run.  Advanced users may wish to specify all system modules
# in this array.  For instance:
#     MODULES=(usbhid xhci_hcd)
MODULES=()
# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image.  This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()
# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way.  This is useful for config files.
FILES=()
# HOOKS
# This is the most important setting in this file.  The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added.  Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
##   This setup specifies all modules in the MODULES setting above.
##   No RAID, lvm2, or encrypted root is needed.
#    HOOKS=(base)
##   This setup will autodetect all modules for your system and should
##   work as a sane default
#    HOOKS=(base udev autodetect modconf block filesystems fsck)
##   This setup will generate a 'full' image which supports most systems.
##   No autodetection is done.
#    HOOKS=(base udev modconf block filesystems fsck)
##   This setup assembles a mdadm array with an encrypted root file system.
##   Note: See 'mkinitcpio -H mdadm_udev' for more information on RAID devices.
#    HOOKS=(base udev modconf keyboard keymap consolefont block mdadm_udev encrypt filesystems fsck)
##   This setup loads an lvm2 volume group.
#    HOOKS=(base udev modconf block lvm2 filesystems fsck)
##   This will create a systemd based initramfs which loads an encrypted root filesystem.
#    HOOKS=(base systemd autodetect modconf kms keyboard sd-vconsole sd-encrypt block filesystems fsck)
##   NOTE: If you have /usr on a separate partition, you MUST include the
#    usr and fsck hooks.
HOOKS=(base udev autodetect kms modconf block keyboard keymap consolefont resume filesystems fsck)
# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
#COMPRESSION="zstd"
# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()
# MODULES_DECOMPRESS
# Decompress kernel modules during initramfs creation.
# Enable to speedup boot process, disable to save RAM
# during early userspace. Switch (yes/no).
#MODULES_DECOMPRESS="yes"
I dare say, this is where this issue stems from: None of these variables are populated. Does a pacnew file still exist in that folder?
cat /etc/mkinitcpio.conf.pacnew
Erm…
I don’t mean to butt in, but it’s right there :point_up_2:
╰╴❯ cat /etc/mkinitcpio.conf.pacnew
# vim:set ft=sh
# MODULES
MODULES=()
# BINARIES
BINARIES=()
# FILES
FILES=()
# HOOKS
# Examples:
#    HOOKS=(base)
HOOKS=(base udev autodetect microcode modconf kms keyboard keymap consolefont block filesystems fsck)
# COMPRESSION
# Use this to compress the initramfs image. By default, zstd compression
# is used for Linux ≥ 5.9 and gzip compression is used for Linux < 5.9.
# Use 'cat' to create an uncompressed image.
#COMPRESSION="zstd"
#COMPRESSION="gzip"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"
# Decompress loadable kernel modules and their firmware during initramfs
# creation. Switch (yes/no).
# Enable to allow further decreasing image size when using high compression
# (e.g. xz -9e or zstd --long --ultra -22) at the expense of increased RAM usage
# at early boot.
# Note that any compressed files will be placed in the uncompressed early CPIO
# to avoid double compression.
#MODULES_DECOMPRESS="no"
Thanks!
Just noticed, i apparently missed it.
Hooks in your /etc/mkinicpio.conf:
Hooks in your /etc/mkinitcpio.conf.pacnew (for comparison):
In case it’s needed:
You probably have many new .pacnew files to handle, so see:
https://wiki.archlinux.org/title/Pacman/Pacnew_and_Pacsave#.pacnew
