Unable to use capture card
So I have a capture card that I am still having a hard time getting to work in OBS, as well as the V4L2 software. I was wondering what I should do about this.
  Kernel: 5.14.7-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
  root=UUID=c566f63e-195d-452a-b27c-f23929e66e71 rw quiet apparmor=1
  Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop System: Gigabyte product: B550 VISION D v: -CF
  serial: <filter>
  Mobo: Gigabyte model: B550 VISION D serial: <filter>
  BIOS: American Megatrends v: F12 date: 01/18/2021
  RAM: total: 62.75 GiB used: 3.77 GiB (6.0%)
  Info: 8-Core model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3
  family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201009 cache:
  L2: 4 MiB bogomips: 121427
  Speed: 3272 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz):
  1: 3272 2: 2874 3: 3059 4: 2872 5: 2200 6: 2782 7: 2872 8: 2517 9: 2870
  10: 2874 11: 2312 12: 2873 13: 2567 14: 2582 15: 3492 16: 2529
  cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
  flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
  invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
  movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
  overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
  perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rapl rdpid
  rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep
  ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall
  tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vaes vgif
  vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec
  xsaveerptr xsaveopt xsaves
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
  STIBP: always-on, RSB filling
  Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
  vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 56:00.0
  chip-ID: 1002:73bf class-ID: 0300
  Device-2: EVGA EVGA XR1 Capture Box type: USB driver: snd-usb-audio,uvcvideo
  bus-ID: 2-2:2 chip-ID: 3842:3103 class-ID: 0102 serial: <filter>
  loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
  display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4480x2160 s-dpi: 96 s-size: 1185x571mm (46.7x22.5")
  s-diag: 1315mm (51.8")
  Monitor-1: DisplayPort-0 res: 2560x1440 hz: 240 dpi: 109
  size: 597x336mm (23.5x13.2") diag: 685mm (27")
  Monitor-2: DisplayPort-1 res: 1920x1080 hz: 60 dpi: 92
  size: 531x299mm (20.9x11.8") diag: 609mm (24")
  Monitor-3: HDMI-A-0 res: 1920x1080 hz: 60 dpi: 166
  size: 294x165mm (11.6x6.5") diag: 337mm (13.3")
  OpenGL: renderer: AMD Radeon RX 6900 XT (SIENNA_CICHLID DRM 3.42.0
  5.14.7-2-MANJARO LLVM 12.0.1)
  v: 4.6 Mesa 21.2.2 direct render: Yes
  Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
  driver: snd_hda_intel v: kernel bus-ID: 56:00.1 chip-ID: 1002:ab28
  class-ID: 0403
  Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
  driver: snd_hda_intel v: kernel bus-ID: 58:00.4 chip-ID: 1022:1487
  class-ID: 0403
  Device-3: Conexant Systems (Rockwell) Hi-Res Audio type: USB
  driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-8:7 chip-ID: 0572:1b09
  class-ID: 0300 serial: <filter>
  Device-4: EVGA EVGA XR1 Capture Box type: USB driver: snd-usb-audio,uvcvideo
  Device-5: Hori Audio Fighting Board type: USB driver: hid-generic,usbhid
  bus-ID: 5-3.1:5 chip-ID: 0f0d:00aa class-ID: 0300
  Sound Server-1: ALSA v: k5.14.7-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.37 running: yes
  Device-1: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
  port: e000 bus-ID: 51:00.0 chip-ID: 8086:1539 class-ID: 0200
  IF: enp81s0 state: down mac: <filter>
  Device-2: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
  port: d000 bus-ID: 52:00.0 chip-ID: 8086:1539 class-ID: 0200
  IF: enp82s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: d000
  bus-ID: 53:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp83s0 state: down mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
  bus-ID: 1-6.1:6 chip-ID: 8087:0029 class-ID: e001
  Local Storage: total: 20.01 TiB used: 4.8 TiB (24.0%)
  model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
  rev: 2B2QEXM7 temp: 58.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST10000NM001G-2MW103
  size: 9.1 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  type: HDD rpm: 7200 serial: <filter> rev: SN03 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
  model: WD My Book 25EE size: 9.1 TiB block-size: physical: 4096 B
  logical: 512 B type: N/A serial: <filter> rev: 4009 scheme: GPT
  Optical-1: /dev/sr0 vendor: ASUS model: BW-16D1HT rev: 3.10 dev-links: cdrom
  Features: speed: 125 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 732.42 GiB size: 719.86 GiB (98.28%)
  used: 32.48 GiB (4.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  label: N/A uuid: c566f63e-195d-452a-b27c-f23929e66e71
  ID-2: /run/media/wayne/Gaming raw-size: 5.72 TiB size: 5.72 TiB (100.00%)
  used: 1.8 TiB (31.5%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: Gaming
  uuid: 6466086B66083FF2
  ID-3: /run/media/wayne/Linux Data raw-size: 3.31 TiB size: 3.26 TiB (98.40%)
  used: 302.77 GiB (9.1%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
  label: Linux Data uuid: c90b7810-45c2-4f04-8689-cd0254bf3e39
  ID-4: /run/media/wayne/My Book raw-size: 9.1 TiB size: 9.1 TiB (100.00%)
  used: 2.68 TiB (29.4%) fs: ntfs dev: /dev/sdb2 maj-min: 8:18 label: My Book
  uuid: A4D445EBD445BFF2
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: N/A
  uuid: C11E-6C02
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 200 MiB fs: vfat label: WINEFI
  uuid: 64D7-0DE0
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 128 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 1.1 TiB fs: ntfs label: Windows
  uuid: 5D85DC3C2CE42FC7
  ID-5: /dev/sda1 maj-min: 8:1 size: 128 MiB fs: <superuser required>
  ID-6: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
  Hub-2: 1-4:2 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  power: 100mA chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 1-4.4:4 info: Alcor Micro Multi Flash Reader type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 100mA
  chip-ID: 058f:6366 class-ID: 0806 serial: <filter>
  Hub-3: 1-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-6.1:6 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
  class-ID: e001
  Device-2: 1-6.3:8 info: Logitech G502 Proteus Spectrum Optical Mouse
  type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
  speed: 12 Mb/s power: 300mA chip-ID: 046d:c332 class-ID: 0300
  serial: <filter>
  Device-3: 1-7:5 info: Integrated Express ITE Device type: HID
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
  power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-4: 1-8:7 info: Conexant Systems (Rockwell) Hi-Res Audio
  type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 3
  rev: 2.0 speed: 12 Mb/s power: 28mA chip-ID: 0572:1b09 class-ID: 0300
  serial: <filter>
  Hub-4: 1-10:9 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-10.3:10 info: Cooler Master ARGB Box type: HID,Keyboard
  power: 100mA chip-ID: 2516:1011 class-ID: 0300 serial: <filter>
  Device-2: 1-10.4:11 info: Microsoft Xbox One Controller (Firmware 2015)
  type: <vendor specific> driver: xpad interfaces: 3 rev: 2.0 speed: 12 Mb/s
  power: 500mA chip-ID: 045e:02dd class-ID: ff00 serial: <filter>
  Hub-5: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Device-1: 2-2:2 info: EVGA EVGA XR1 Capture Box type: Video,Audio
  driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 3.0 speed: 5 Gb/s
  power: 600mA chip-ID: 3842:3103 class-ID: 0102 serial: <filter>
  Hub-6: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
  Hub-7: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-8: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
  Device-1: 5-2:2 info: Microsoft Natural Ergonomic Keyboard 4000 V1.0
  type: Keyboard,HID driver: microsoft,usbhid interfaces: 2 rev: 2.0
  speed: 1.5 Mb/s power: 100mA chip-ID: 045e:00db class-ID: 0300
  Hub-9: 5-3:3 info: Genesys Logic Hub ports: 2 rev: 2.1 speed: 480 Mb/s
  Device-1: 5-3.1:5 info: Hori Audio Fighting Board type: HID
  power: 500mA chip-ID: 0f0d:00aa class-ID: 0300
  Device-2: 5-4:4 info: Tablet Monitor type: Mouse,HID
  driver: hid-multitouch,uclogic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
  power: 100mA chip-ID: 256c:006d class-ID: 0300
  Hub-10: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1
  speed: 10 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
  Device-1: 6-1:2 info: Western Digital My Book 25EE type: Mass Storage
  driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 8mA
  chip-ID: 1058:25ee class-ID: 0806 serial: <filter>
  Hub-11: 6-3:3 info: Genesys Logic USB3.1 Hub ports: 2 rev: 3.2 speed: 5 Gb/s
  chip-ID: 05e3:0620 class-ID: 0900
  System Temperatures: cpu: 44.1 C mobo: N/A gpu: amdgpu temp: 57.0 C
  mem: 54.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
  Processes: 414 Uptime: 2m wakeups: 0 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1374 lib: 388
  flatpak: 0 Shell: Zsh v: 5.8 default: Bash v: 5.1.8 running-in: konsole
  inxi: 3.3.06
It’s the EVGA XR1 Capture Box.
Is this no help for you?
Considering also this topic
I wonder if you are in the right place to ask questions about that device and how to set it up with OBS … AFAIK none of the team has it and you are the only one in the forum talking about it. Not dismissing your help request, is just a heads-up so you understand that help might not come from forum members.
@anon89812132 That video acts as if there are no fixes or drivers to install. I also mentioned that the V4L2 software wasn’t getting any video. Something else worth mentioning is that Discord also does not pick it up when I am using it as a webcam.
