Hi everyone. I have an HP laptop which has integrated Intel graphics and dGPU from AMD. I installed Manjaro KDE minimal edition two days back. It comes with the open source drivers for my AMD graphics card. When I list all my devices using the command lspci -v, it is able to detect the AMD graphics card. When I try to list hardware using the command sudo lshw, it lists my dGPU. So far, so good.
However, when I use the command xrandr --listproviders, I get only 1 provider, and that is not my dGPU. vulkaninfo also does not list my AMD graphics card, only the integrated graphics card. (I do have the vulkan-radeon package installed.) As such, even when I try to run a command with DRI_PRIME=1 prefix, I am not able to use my dGPU. I have tried to see if my driver was blacklisted for some reason as mentioned in troubleshooting section of PRIME page of arch linux wiki, and it is not. (Sorry for not including the link. The forum does not allow me to do so, probably because my account is new.) I even tried to install the unstable 5.16 linux kernel and the problem persists, so I don’t think it is an issue specific to the current kernel.
In case it helps, I am also not able to access my AMD graphics card using PRIME switching or otherwise in Fedora 35, EndeavorOS and a vanilla installation of arch that I have tried. However, Pop!_OS seems to have no such issues and I can use my AMD graphics card using PRIME switching. That convinced me it is some issue with the configuration and not some problem with my laptop. (Let me know if I am wrong here.)
Has anyone seen a similar issue and has been able to resolve it? Or has any idea what I can do to make my dGPU work? My main reason for using a dGPU is to run some OpenGL and vulkan based applications on the AMD graphics card, and the OpenGL support for AMD graphics cards on Windows is suboptimal.
Thanks a lot in advance.
An update - switching to kernel 5.10.89-1-MANJARO makes the AMD graphics card available for PRIME switching. Not sure if there is some update in a later revision of the kernel. Pop!_OS 21.10 used kernel version 5.15 as well as far as I know.
cscs
22 January 2022 18:32
3
It would probably be a bit more helpful if you provided some more concrete information, such as the output when you attempt to use DRI_PRIME.
Thanks a lot for taking the time to help me.
On kernel 5.10.89-1-MANJARO:
$ xrandr --listproviders
Providers: number : 2
Provider 0: id: 0x46 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 5 associated providers: 1 name:modesetting
Provider 1: id: 0xcd cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 5 outputs: 0 associated providers: 1 name:AMD Radeon 500 Series @ pci:0000:01:00.0
$ glxinfo | grep "OpenGL renderer"
OpenGL renderer string: Mesa Intel(R) UHD Graphics 620 (KBL GT2)
$ DRI_PRIME=1 glxinfo | grep "OpenGL renderer"
OpenGL renderer string: AMD Radeon 500 Series (POLARIS12, DRM 3.40.0, 5.10.89-1-MANJARO, LLVM 13.0.0)
On 5.15.12-1-MANJARO
Providers: number : 1
Provider 0: id: 0x46 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 5 associated providers: 0 name:modesetting
cscs
22 January 2022 19:26
5
I can certainly see the differences there.
Please also include inxi:
This tutorial is superseded by this one. Remember all Tutorials are wiki posts that can be edited by TL2 (Trust Level 2) members and above.
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to…
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=4e9833af-6f93-438d-8ae7-a1ee7b297e47 rw quiet
udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP EliteBook 840 G5 v: N/A
Mobo: HP model: 83B2 v: KBC Version 04.6C.00 serial: <superuser required>
UEFI: HP v: Q78 Ver. 01.17.00 date: 08/04/2021
ID-1: BAT0 charge: 4.2 Wh (77.8%) condition: 5.4/50.2 Wh (10.8%) volts: 11.1
min: 11.6 model: Hewlett-Packard Primary type: Li-ion serial: <filter>
status: Discharging cycles: 1637
RAM: total: 15.48 GiB used: 1.8 GiB (11.6%)
RAM Report:
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 697 high: 772 min/max: 400/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 749 2: 627 3: 700 4: 772
5: 700 6: 699 7: 633 8: 700 bogomips: 32012
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: AMD Lexa PRO [Radeon 540/540X/550/550X / RX 540X/550/550X]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 01:00.0
chip-ID: 1002:699f class-ID: 0380
Device-3: Cheng Uei Precision Industry (Foxlink) HP HD Camera type: USB
driver: uvcvideo bus-ID: 1-9:6 chip-ID: 05c8:0808 class-ID: 0e02
serial: <filter>
Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.3.2
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: no
Device-1: Intel Ethernet I219-V vendor: Hewlett-Packard driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d8 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
bus-ID: 1-7:4 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 476.94 GiB used: 9.2 GiB (1.9%)
model: MZVLB512HAJQ-000H1 size: 476.94 GiB block-size: physical: 512 B
rev: EXA72H1Q temp: 26.9 C scheme: GPT
ID-1: / raw-size: 54.5 GiB size: 53.35 GiB (97.88%) used: 9.2 GiB (17.2%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 4e9833af-6f93-438d-8ae7-a1ee7b297e47
ID-2: /boot/efi raw-size: 510 MiB size: 509 MiB (99.80%)
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4 label: N/A
uuid: CC92-8F97
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 360 MiB fs: vfat label: SYSTEM
uuid: 4C5C-2E4F
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 128 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 401.44 GiB fs: ntfs
label: Windows uuid: 044EA1894EA17458
ID-4: /dev/nvme0n1p6 maj-min: 259:6 size: 980 MiB fs: ntfs
label: Windows RE tools uuid: AC6CBC256CBBE86A
ID-5: /dev/nvme0n1p7 maj-min: 259:7 size: 19.06 GiB fs: ntfs
label: Recovery Image uuid: 6E209368209335D5
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-1:2 info: Apple Aluminium Keyboard (ANSI) type: Keyboard,HID
driver: apple,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 300mA
chip-ID: 05ac:024f class-ID: 0300
Device-2: 1-2:3 info: HP X500 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 03f0:0941 class-ID: 0301
Device-3: 1-7:4 info: Intel Bluetooth wireless interface type: Bluetooth
Device-4: 1-8:5 info: Validity Sensors type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 138a:00ab
class-ID: ff00 serial: <filter>
Device-5: 1-9:6 info: Cheng Uei Precision Industry (Foxlink) HP HD Camera
type: Video driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05c8:0808 class-ID: 0e02 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 40.0 C pch: 35.5 C mobo: 30.0 C
Processes: 221 Uptime: 3m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1130 lib: 306
Shell: Bash v: 5.1.12 running-in: konsole inxi: 3.3.12
$ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
Zesko
23 January 2022 08:35
9
For Kernel 5.15+ and Radeon RX 500 series:
Try to add amdgpu.dc=0 in the file /etc/default/grub
If you are using KDE kate:
kate /etc/default/grub or sudo nano /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT adds amdgpu.dc=0 then save.
sudo update-grub
then reboot and connect with HDMI.
Thanks a lot for the tip. However, it does not work in my case.
$ cat /proc/cmdline
BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=4e9833af-6f93-438d-8ae7-a1ee7b297e47 rw quiet udev.log_priority=3 amdgpu.dc=0
I am actually getting a different error as reported by journalctl.
Jan 21 22:59:47 tlvm-hpelitebook840g5 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring uvd test failed (-110)
Jan 21 22:59:47 tlvm-hpelitebook840g5 kernel: [drm:amdgpu_device_init.cold [amdgpu]] *ERROR* hw_init of IP block <uvd_v6_0> failed -110
Following the solution to a similar issue seen by someone else https://bugzilla.kernel.org/show_bug.cgi?id=206141#c8 , I tried to disable the blocks that were giving an error. Then I got a different error.
Jan 23 13:12:43 tlvm-hpelitebook840g5 kernel: [drm:amdgpu_device_init.cold [amdgpu]] *ERROR* disabled ip block: 7 <uvd_v6_0>
Jan 23 13:12:43 tlvm-hpelitebook840g5 kernel: [drm:amdgpu_device_init.cold [amdgpu]] *ERROR* disabled ip block: 8 <vce_v3_0>
In this case, using xrandr --listproviders lists two providers, but neither of them is the AMD graphics card and DRI_PRIME=1 still fails to work.
Is there anything else that I can try to solve this issue?
Zesko
23 January 2022 09:48
11
I have no idea.
Just keep Kernel 5.10 if it works with that.
Yeah, I am using the kernel 5.10 for now, but I’d really rather solve this issue and use the latest kernel.
Thanks a lot for your help.
Looking at some other kernel parameters, I found from AMD RX480 amdgpu, drm, no video at modeset / Kernel & Hardware / Arch Linux Forums that adding amdgpu.dpm=0 kernel parameter allowed the detection of the dGPU. I can use DRI_PRIME=1 successfully. So I guess that’s a win.
However, the performance after using it is absolutely horrible; to the point that the integrated Intel GPU performs better. Using the benchmarking tool basemark, the score went from ~9700 (on kernel 5.10) down to ~2600 (on kernel 5.15 with this workaround). So, yeah, this workaround doesn’t really help to solve the problem.
Zesko
23 January 2022 12:52
14
Yes, amdgpu.dpm as Display power management is important for performance of GPU.
