Unable to search and install packages from AUR using pamac
Hi there!
I’m currently experiencing issues on searching and installing packages from AUR. I installed Manjaro previously, all worked well. I’ve been able to install Visual Studio Code from AUR using pamac install visual-studio-code-bin (AUR repositories installation are already enabled).
Today, I reinstalled Manjaro. I thought all works well just as before. But, when I tried to search & install VSCode from AUR, all I’m getting are these errors:
pamac search visual-studio-code-bin
failed to retrieve some files
Failed to read AUR data from /var/lib/pacman/sync/packages-meta-ext-v1.json.gz : Error opening file /var/lib/pacman/sync/packages-meta-ext-v1.json.gz: No such file or directory
Error: target not found: visual-studio-code-bin
both are getting the same error.
I don’t know what might be the problem, I already followed this same issue posted on this forum https://forum.manjaro.org/t/failed-to-read-aur-data-from-var-tmp-pamac-packages-meta-ext-v1-json-gz/148680. Unfortunately, it didn’t worked for me.
Please keep in mind - the AUR is unsupported - and you are strongly advised to use unstable branch if AUR is a must-use. [Need-To-Know] About Manjaro and AUR
pamac update --aur --force-refresh
Or open the Add & Remove Software app - click the :hamburger: and select Refresh Databases
Refresh the list of mirrors?
I don’t know where to reach that function through the GUI - but somewhere behind the hamburger menu, the three dots.
or in terminal:
sudo pacman-mirrors -f
I also did it already. nothing changed.
Computer/Software engineer advise - restart the system.
Once there were four engineers traveling in a car. While they were traveling to their destination the car stalled on them.
Then the first engineer who was a mechanical engineer said, “don’t worry its probably engine problems. I will just pop open the hood and take a look at the motor”.
Then the second engineer, who was an electrical engineer, said, “no, no, no. It is an electrical problem. Just let me look at the fuse box and I will find the problem”.
The third engineer, who was a chemical engineer, said, “its just a problem with the fuel. Flush out all of the gas and replace it with new gas and you will see that the car will be fine.”
Then the three engineers looked at the fourth who was a computer engineer. And his response was… “Why don’t we just get out of the car, shut all of the doors, and then open them again and get back in and start it!”
Ensure the folder /var/tmp/pamac does not exist.
sudo rm -r /var/tmp/pamac
$ man pamac
SYNOPSIS
      pamac <operation> [options] [targets]
OPERATIONS
      pamac install [options] <package(s)>
          Install packages from repositories, path or url
      pamac build [options] [package(s)]
          Build packages from AUR and install them with their dependencies
I’ve been able to install that AUR package because I edited the /etc/pamac.conf and uncommented the EnableAUR.
Shouldn’t pamac always be run without sudo?
It will prompt for authorization.
This is what I see initially after refreshing the mirrors:
pamac build visual-studio-code-bin
Preparing...
Checking visual-studio-code-bin dependencies...
Resolving dependencies...
Checking inter-conflicts...
To install (1):
  lsof                    4.99.4-1   (Required By: visual-studio-code-bin)  extra  150.4 kB
To build (1):
  visual-studio-code-bin  1.100.3-1                                         AUR
Total download size: 150.4 kB
Total installed size: 381.1 kB
Edit build files : [e]
Apply transaction ? [e/y/N]
That could have also been done through the GUI → enable AUR support
And for the record, refreshing mirrors is unrelated to building an AUR package as it is a requirement for the system to be up-to-date when building a custom package.
yes - my bad - muscle memory
But is has become less important after pamac developer changed the behavior from reading metadata /var/tmp/pamac to using the pacman metadata as a shared resource.
update: I did what y’all recommended. nothing worked out :sob:
Or
sudo pacman -Syu base-devel
git clone https://aur.archlinux.org/visual-studio-code-bin
cd visual-studio-code-bin
makepkg -iscC
Yes - well, maybe :grimacing:
When I did:
I got this response (I do have some, probably outdated, AUR packages installed):
Preparing...
Authenticating as: JE (jo)
Password:
Refreshing core.db...
Refreshing extra.db...
Refreshing multilib.db...
Refreshing core.files...
Refreshing extra.files...
Refreshing multilib.files...
Refreshing AUR...
Nothing to do.
Checking ezra-bible-app-bin dependencies...
Checking nvidia-utils-beta dependencies...
Checking pulseaudio-ctl dependencies...
Checking localepurge dependencies...
Checking scid_vs_pc dependencies...
Checking pinta dependencies...
Checking midori-bin dependencies...
Checking stockfish dependencies...
To install (5):
  autoconf-archive            1:2024.10.16-2  (Required By: pinta)  extra
  dotnet-runtime              9.0.4.sdk105-1  (Required By: pinta)  extra
  netstandard-targeting-pack  9.0.4.sdk105-1  (Required By: pinta)  extra
  dotnet-targeting-pack       9.0.4.sdk105-1  (Required By: pinta)  extra
  dotnet-sdk                  9.0.4.sdk105-1  (Required By: pinta)  extra
To build (8):
  ezra-bible-app-bin          1.17.0-1        (1.16.2-1)            AUR
  localepurge                 0.7.3.11-1      (0.7.3.10-1)          AUR
  nvidia-utils-beta           575.57.08-1     (555.52.04-2)         AUR
  midori-bin                  11.5-1          (11.4.1-1)            AUR
  pinta                       3.0-3           (2.1.2-2)             AUR
  pulseaudio-ctl              1.70-2          (1.70-1)              AUR
  scid_vs_pc                  4.26-1          (4.24-3)              AUR
  stockfish                   1:17.1-1        (1:16.1-1)            AUR
Total installed size: 448.1 MB
You can safe discard the action - but it appears to be the method to update aur data.
That’s what I did.
I didn’t want to update these - it’s in a VM for testing stuff and I will remove them anyway later on.
But after this,
… worked.
It probably would have worked without this prior step.
pamac search --aur visual-studio-code-bin
gives:
    Visual Studio Code (vscode): Editor for building and debugging modern web and cloud applications (official binary version)
What’s the output?
curl --head https://aur.manjaro.org/packages-meta-ext-v1.json.gz
@bochard
You might consider using code (Visual Studio Code) from the official Manjaro repositories;
sudo pacman -S code
The build command alse worked for me, without issue;
