Everytime I run pamac upgrade --aur --force-refresh
I get the following two messages:
Preparing...
Multiple identities can be used for authentication:
1. Medin (medin)
2. Med (med)
Choose identity to authenticate as (1-2): 1
Password:
Refreshing core.db...
Refreshing extra.db...
Refreshing multilib.db...
Refreshing core.files...
Refreshing extra.files...
Refreshing multilib.files...
Refreshing AUR...
Failed to read AUR data from /var/tmp/pamac/packages-meta-ext-v1.json.gz : <data>:40596:543: Parse error: scanner: unterminated string constant
Failed to read AUR data from /var/tmp/pamac/packages-meta-ext-v1.json.gz : <data>:53938:544: Parse error: scanner: unterminated string constant
Nothing to do.
Even purging /var/tmp/pamac/
has no effect.
