Unable to satisfy dependency 'nvidia-utils=550.90.07'
LANG= LC_ALL= pamac update -a                                                             1 ✘
Preparing...
Sincronización de bases de datos de paquetes...
Refreshing AUR...
Warning: ignoring package replacement (cpufrequtils-008-3 => cpupower-6.9-1)
Resolving dependencies...
Warning: cannot resolve "nvidia-utils=550.90.07", a dependency of "linux66-nvidia"
Warning: cannot resolve "nvidia-utils=550.90.07", a dependency of "linux68-nvidia"
Warning: cannot resolve "nvidia-utils=550.90.07", a dependency of "linux69-nvidia"
Error: Failed to prepare transaction:
could not satisfy dependencies:
- unable to satisfy dependency 'nvidia-utils=550.90.07' required by linux66-nvidia
More with the same problem, being addressed here
Please search the forum - several topics already exist - with solution.
sudo mhwd-kernel -i linux66 rmc
Maybe I’m a bit clumsy, I don’t see it, can you put the URL?
Error: You can't reinstall your current kernel. Please use 'pacman -Syu' instead to update.
sudo mhwd-kernel -i linux66 -rmc                                                          1 ✘
Error: Invalid argument.
Please choose one of the available kernels:
   * linux419
   * linux510
   * linux515
   * linux54
   * linux61
   * linux610
   * linux66
   * linux68
   * linux69
   * linux61-rt
   * linux66-rt
   * linux67-rt
If you want to work on this one / remove this one, you need to boot another one of the kernels you have installed.
You can’t remove or reinstall the one that is in use.
As this is recurring topic - please see → [How To] Handle Nvidia conflicts on sync
I’m confused, the provided link seems to refer to unsupported kernels. Neither of my kernels are unsupported as far as I can tell.
"linux61-nvidia"
"linux66-nvidia"
That is correct - to use this command - the unsupported kernel must be the active kernel.
Otherwise use e.g.
sudo mhwd-kernel -r linux68
My apologies - it should be sudo mhwd-kernel -i linux66 rmc
None of the solutions work, it seems to be a problem with the update, more users have the same problem:
Since 550.90.07 is in all branches - in don’t see why this should an issue
spacing added for readability
 $ mbn info nvidia-utils -q
Branch         : archlinux
Version        : 550.90.07-1
Repository     : extra
Build Date     : Sun 09 Jun 2024 01:16:28
Packager       : Sven-Hendrik Haase <svenstaro@archlinux.org>
Branch         : unstable
Version        : 550.90.07-2
Repository     : extra
Build Date     : Thu 06 Jun 2024 01:51:45
Packager       : Mark Wagie <mark@manjaro.org>
Branch         : testing
Repository     : extra
Branch         : stable
Repository     : extra
So am I
“Maybe” simply the files are not or have not been synchronized on the servers.
That would point to a mirror issue - try switching mirror
sudo pacman-mirrors --continent
The Austrian mirror I use has the correct packages.
10:08:18 ○ [fh@tiger] ~
 $ pamac info nvidia-utils
Description           : NVIDIA drivers utilities
URL                   : http://www.nvidia.com/
Licenses              : custom
Repository            : extra
Installed Size        : 622,7 MB
Groups                : --
Depends On            : libglvnd egl-wayland
Optional Dependencies : nvidia-settings: configuration tool
                        xorg-server: Xorg support [Installed]
                        xorg-server-devel: nvidia-xconfig
                        opencl-nvidia=550.90.07: OpenCL support
Provides              : vulkan-driver opengl-driver nvidia-libgl nvidia-utils=550.90.07
Replaces              : nvidia-libgl
Conflicts With        : nvidia-libgl
Build Date            : tor 06 jun 2024 01:51:45 CEST
Validated By          : MD5 Sum  SHA-256 Sum  Signature
10:08:32 ○ [fh@tiger] ~
 $ pamac info linux66-nvidia
Description           : NVIDIA drivers for linux
Licenses              : custom
Repository            : extra
Installed Size        : 53,6 MB
Groups                : linux66-extramodules
Depends On            : linux66 nvidia-utils=550.90.07
Optional Dependencies : --
Provides              : nvidia=550.90.07 NVIDIA-MODULE
Replaces              : --
Conflicts With        : --
Build Date            : tor 06 jun 2024 02:18:50 CEST
I just saw it - I cannot imagine how this came to be - I can only
:facepalm:
At least I got to write the how-to - factually it is a recurring issue - usually with EOL kernels.
linux68 is EOL which is why I replied as I did - my apologies …
Better a poor response than none at all, intent to help is appreciated, thank you.
No need to apologize, your contributions here more than enough outweighs the odd slip-up.
With that I do not agree - but thank you for your understanding - much appreciated
  • I know I was too quick here
  • I know how many times I have seen variations over this
  • I you knew how many times I have repeated myself
  • That is why I provided the search comment
  • I even went on to create a proper search link
  • I went on to create a how-to I could refer back to instead of repeating myself
Update went through without protests but the happiness was short-lived. Now I’m unable to boot into Plasma, stuck at Reached graphical interface. Switching to the free driver “solved” the problem but it’s just a temporary solution. Seems like others have a similar problem.
