Hi, this is my first time using Manjaro. I installed the i3 community edition yesterday. Afterwards I installed kitty and alacritty but i get these errors anytime i try to run them.
[126 14:55:02.023327] [glfw error 65543]: GLX: Failed to create context: GLXBadFBConfig
[126 14:55:02.023443] Failed to create GLFW temp window! This usually happens because of old/broken OpenGL drivers. kitty requires working OpenGL 3.3 drivers.
Created log file at "/tmp/Alacritty-1392.log"
[2021-05-06 14:55:04.529075007] [ERROR] [alacritty] Alacritty encountered an unrecoverable error:
There was an error initializing the shaders: Failed compiling shader: 0:1(10): error: GLSL 3.30 is not supported. Supported versions are: 1.10, 1.20, and 1.00 ES
Is there anything I can do to get them to work or am I out of luck?
Both terminal emulators are using OpenGL. I guess you don’t have the proper drivers installed.
How do I download the correct ones? I’ve tried this so far but no luck it seems.
sudo mhwd -a pci free 0300
> Skipping already installed config 'video-linux' for device: 0000:00:02.0 (0300:8086:2a42) Display controller Intel Corporation Mobile 4 Series Chipset Integrated Graphics Controller
Ah, I’m sorry. Heres my inxi output:
Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=73c76e54-0738-4d65-9c92-5264b85c8eb9 rw quiet apparmor=1
Console: tty pts/2 DM: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Hewlett-Packard product: HP Pavilion dv6 Notebook PC
v: Rev 1 serial: <filter> Chassis: Quanta type: 10 serial: <filter>
Mobo: Quanta model: 3627 v: 18.42 serial: <filter> BIOS: Hewlett-Packard
v: F.31 date: 08/21/2009
ID-1: BAT0 charge: 0% condition: N/A/47.5 Wh volts: N/A min: 10.8
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Unknown
RAM: total: 3.75 GiB used: 596.6 MiB (15.5%)
Info: Dual Core model: Intel Core2 Duo T6600 bits: 64 type: MCP arch: Penryn
family: 6 model-id: 17 (23) stepping: A (10) microcode: A0B cache: L2: 2 MiB
bogomips: 8777
Speed: 1250 MHz min/max: 1200/2200 MHz Core speeds (MHz): 1: 1250 2: 1239
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid
cx16 cx8 de ds_cpl dtes64 dtherm dts est fpu fxsr ht lahf_lm lm mca mce mmx
monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge pni pse pse36 pti
rep_good sep sse sse2 sse4_1 ssse3 syscall tm tm2 tsc vme xsave xtpr
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: Intel Mobile 4 Series Integrated Graphics vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:2a42 class-ID: 0300
Device-2: Quanta HP Webcam type: USB driver: uvcvideo bus-ID: 2-4:2
chip-ID: 0408:03f1 class-ID: 0e02
Display: server: X.org 1.20.11 compositor: picom v: git-dac85 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa tty: 120x28
Message: Advanced graphics data unavailable in console. Try -G --display
Device-1: Intel 82801I HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:293e
class-ID: 0403
Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Device-1: Intel Centrino Wireless-N 1000 [Condor Peak] driver: iwlwifi
v: kernel port: 7000 bus-ID: 02:00.0 chip-ID: 8086:0084 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: 5000 bus-ID: 03:00.0 chip-ID: 10ec:8136
class-ID: 0200
Local Storage: total: 298.09 GiB used: 7.74 GiB (2.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS723232L9A360
size: 298.09 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
rotation: 7200 rpm serial: <filter> rev: C60D scheme: MBR
Optical-1: /dev/sr0 vendor: hp model: DVDRAM GT20L rev: DC05
dev-links: cdrom
ID-1: / raw-size: 298.09 GiB size: 292.35 GiB (98.07%) used: 7.74 GiB (2.6%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 73c76e54-0738-4d65-9c92-5264b85c8eb9
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 2.0
Device-1: 2-4:2 info: Quanta HP Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0408:03f1
class-ID: 0e02
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip-ID: 1d6b:0001 class-ID: 0900
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-7: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-8: 8-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
System Temperatures: cpu: 51.0 C mobo: N/A
Processes: 140 Uptime: 5h 29m wakeups: 2 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1059 lib: 291
Shell: Zsh v: 5.8 running-in: tty pts/2 inxi: 3.3.04
What are my options for getting it to work?
Could you also provide inxi -G --display ?
Here’s the output of that.
Graphics: Device-1: Intel Mobile 4 Series Integrated Graphics driver: i915 v: kernel
Display: x11 server: X.Org 1.20.11 driver: loaded: intel unloaded: modesetting resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Mobile Intel GM45 Express (CTG) v: 2.1 Mesa 21.0.3
I’m curious about that driver: loaded: intel unloaded.
It seems your GPU is too old to support the GL version >= 3.3 that alacritty/kitty needs.
That’s unfortunate, but ok thank you for your help.
I might be mistaken, maybe there is someone else who can help investigate this further.
