Unable to perform system update due to lib32-db dependency
When I try to perform a system update, I am getting the following error
[tom@test ~]$ sudo pacman -Syu
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
:: Replace at-spi2-atk with extra/at-spi2-core? [Y/n] Y
:: Replace atk with extra/at-spi2-core? [Y/n] Y
:: Replace lib32-at-spi2-atk with multilib/lib32-at-spi2-core? [Y/n] Y
:: Replace lib32-atk with multilib/lib32-at-spi2-core? [Y/n] Y
:: Replace steam-manjaro with multilib/steam? [Y/n] Y
resolving dependencies...
:: installing db (6.2.32-1) breaks dependency 'db=5.3.28' required by lib32-db
When I try to remove it, I get the following:
[tom@test ~]$ sudo pacman -R lib32-db
checking dependencies...
:: removing lib32-db breaks dependency 'lib32-db' required by lib32-jack
I am not sure how I can get around this.
remove them both:
sudo pacman -R lib32-db lib32-jack
rerun update again
Thanks.
I wasn’t sure what lib32-jack was being used for, so I didn’t know if it would cause an issue if I got rid of it.
the lib32 jack was dropped to aur, and it was dropped quite long ago… so are you regularly updating your system?
No, this was on a laptop that was not used for a little over a year.
I hadthe same problem.
I ran the command:
I got another error message, saying:
:: removing lib32-jack breaks dependency ‘libjack.so=0-32’ required by lib32-fluidsynth
:: removing lib32-jack breaks dependency ‘libjack.so=0-32’ required by lib32-portaudio
Should i just continue removing all programs required, similarly as done with lib32-jack?
well this is what happens when you dont update regularly…
yes remove them
Thank You Brahma!
I constructed the more lengthy command, ran it, & it seems to have removed all four of those problematic lib32 related files.
I am running the up-date now, & it seems to be functioning properly.
I have been dis-connected with the support crew here, & i was getting seriously desperate for a fix, even considering switching to a dabian-based distribution, & doing a complete re-instal with that.
I now realize, my problim likely started with my using an old version of Manjaro on a flash-drive, to do my most recent install on my new laptop; & that is likely where these older & seemingly obsolete files came from; Yes?
I am really thankful for your help here, Brahma.
I would like to send you Ten/10 (Legal-Fiction) US-Dollars, if we can figure a way to do that.
I frequently use Paypal.
Can i send you ten buckeroos thru Paypal?
yes, the old iso was the reason…
thank you for the offer, i appreciate it, but its not needed…
