Unable to log into Gnome desktop after system update
Hello everyone. Hope you’re having nice weekend.
I have encountered an issue where I can’t log into my machine after upgrading to either of 2024-05-13 or 2024-05-18 releases.
The system boots, I enter user password, loading icon appears and then disappears. Password field is not responding. System menu (the one with wifi, bluetooth, shutdown) is functional. If I go to console log in through Ctrl+Alt+F3 and then back to Ctrl+Alt+F1 - the login screen is back at user choice.
I tried disabling and removing all gnome extensions. Turned off mounting encrypted volumes on login. Still the same issue.
I’d appreciate any help!
Here’s the boot log. At ~ 15:14 (or some seconds earlier) is when I tried to log in through GUI. Then at 15:15:09 is when I logged in the console to restore the system.
Boot log on pastebin.
As it looks to be related to graphics (some errors and warning there), here’s also mhwd output.
$ mhwd -li         ✔
> Installed PCI configs:
           video-linux            2018.05.04                true            PCI
video-hybrid-amd-nvidia-prime            2023.03.23               false            PCI
Here is the inxi output with some data stripped out
Generated on 2024-05-25 15:19:1716661184
#################### inxi -Fxzc0 ########################
  Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
  Desktop: GNOME v: 45.4 Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 82L5 v: IdeaPad 5 Pro 16ACH6 serial: <superuser required>
  Info: 8-core model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3
  Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Lenovo driver: nvidia v: 550.67
    arch: Ampere bus-ID: 01:00.0
  Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series] vendor: Lenovo driver: amdgpu
    v: kernel arch: GCN-5 bus-ID: 05:00.0 temp: 46.0 C
  Display: x11 server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.6 driver: X:
    loaded: amdgpu,nvidia unloaded: modesetting,nouveau,radeon dri: radeonsi gpu: amdgpu
    resolution: 1680x1050~120Hz
  API: EGL v: 1.5 drivers: nvidia,radeonsi,swrast platforms: active: x11,surfaceless,device
    inactive: gbm,wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1 glx-v: 1.4
    direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir LLVM 16.0.6 DRM 3.54
    6.6.26-1-MANJARO)
  API: Vulkan v: 1.3.279 drivers: nvidia,radv surfaces: xcb,xlib devices: 2
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo driver: snd_hda_intel v: kernel
    bus-ID: 05:00.1
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A bus-ID: 05:00.5
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
    bus-ID: 05:00.6
  API: ALSA v: k6.6.26-1-MANJARO status: kernel-api
  Server-1: JACK v: 1.9.22 status: off
  Server-2: PipeWire v: 1.0.3 status: off
  Server-3: PulseAudio v: 17.0 status: active
You’re not up to date as GNOME 46 is available in all branches. Please see Pacman-mirrors - Manjaro
What command did you run? Why are you only sharing the graphics information? Inxi does not reveal any information that isn’t designed for sharing publicly. Please see [HowTo] Find system information
The current golden standard is
inxi -zv8
Thanks for taking time to reply!
I’ll try update with refreshing mirror list.
I just now realized that I gave the output of both mhwd and inxi before updating.
As for inxi output, it’s from Manjaro Log Helper, which uses inxi -Fxzc0. But I removed some stuff which shouldn’t be relevant.
Unfortunately, updating mirrors list didn’t help. Same issue persists.
The full inxi -zv8 output from the system after updating (in tty3):
  Kernel: 6.6.30-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: hpet
    avail: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
    root=UUID=8e50babd-d978-452a-84f5-c19ce197176b rw rootflags=subvol=@ random.trust_cpu=on
    quiet splash apparmor=1 security=apparmor udev.log_priority=3
  Console: tty 3 DM: GDM v: 46.0 Distro: Manjaro base: Arch Linux
    Chassis: type: 10 v: IdeaPad 5 Pro 16ACH6 serial: <superuser required>
  Mobo: LENOVO model: LNVNB161216 v: SDK0R32862 WIN serial: <superuser required>
    part-nu: LENOVO_MT_82L5_BU_idea_FM_IdeaPad 5 Pro 16ACH6 uuid: <superuser required> UEFI: LENOVO
    v: GSCN23WW date: 05/11/2021
  ID-1: BAT0 charge: 64.4 Wh (100.0%) condition: 64.4/75.0 Wh (85.9%) volts: 17.2 min: 15.4
    model: SMP L20M4PE1 type: Li-ion serial: <filter> status: full cycles: 5
  System RAM: total: 32 GiB available: 27.26 GiB used: 1.42 GiB (5.2%)
  Array-1: capacity: 32 GiB slots: 2 modules: 2 EC: None max-module-size: 16 GiB note: est.
  Device-1: Channel-A DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64
    total: 64 manufacturer: Samsung part-no: M471A2G44AM0-CWE serial: N/A
  Device-2: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 9 5900HX with Radeon Graphics bits: 64 type: MT MCP arch: Zen 3 gen: 4
    level: v3 note: check built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
    model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache: L1: 512 KiB
    desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 462 high: 1397 min/max: 400/4680 scaling: driver: amd-pstate-epp
    governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 1397 6: 400 7: 400 8: 400 9: 400
    10: 400 11: 400 12: 400 13: 400 14: 400 15: 400 16: 400 bogomips: 105441
  Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext cat_l3
    cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc
    cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists
    erms extapic extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate
    ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
    msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni
    popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap
    smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme
    vmmcall vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
  Type: spectre_v2 mitigation: Retpolines; IBPB: conditional; IBRS_FW; STIBP: always-on; RSB
    filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA GA107M [GeForce RTX 3050 Mobile] vendor: Lenovo driver: nvidia v: 550.78
    alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of 2024-04; EOL~2026-12-xx)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:25a2
    class-ID: 0302
    driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
    speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
    empty: DP-1,HDMI-A-1 bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 41.0 C
  Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
    lanes: 1 mode: 2.0 bus-ID: 3-4:4 chip-ID: 04f2:b6be class-ID: fe01 serial: <filter>
  Display: server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6 compositor: gnome-shell driver:
    X: loaded: amdgpu,nvidia unloaded: modesetting,nouveau,radeon alternate: fbdev,nv,vesa
    dri: radeonsi gpu: amdgpu tty: 160x50
  Monitor-1: eDP-1 model: BOE Display 0x0997 built: 2020 res: 2560x1600 dpi: 188 gamma: 1.2
    chroma: red: x: 0.647 y: 0.325 green: x: 0.290 y: 0.620 blue: x: 0.149 y: 0.059 white: x: 0.314
    y: 0.329 size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10 modes: 2560x1600,
    1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
    1024x768, 800x600, 640x480
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0 drv: nvidia device: 2
    drv: radeonsi device: 3 drv: swrast surfaceless: drv: nvidia inactive: gbm,wayland,x11,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 24.0.6-manjaro1.1
    note: console (EGL sourced) renderer: NVIDIA GeForce RTX 3050 Laptop GPU/PCIe/SSE2, AMD Radeon
    Graphics (radeonsi renoir LLVM 17.0.6 DRM 3.54 6.6.30-2-MANJARO), llvmpipe (LLVM 17.0.6 256
    bits)
  API: Vulkan v: 1.3.279 layers: 7 device: 0 type: discrete-gpu name: NVIDIA GeForce RTX 3050
    Laptop GPU driver: nvidia v: 550.78 device-ID: 10de:25a2 surfaces: N/A device: 1
    type: integrated-gpu name: AMD Radeon Graphics (RADV RENOIR) driver: mesa radv
    v: 24.0.6-manjaro1.1 device-ID: 1002:1638 surfaces: N/A
    pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1
    chip-ID: 1002:1637 class-ID: 0403
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
    snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh
    pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.6.30-2-MANJARO status: kernel-api with: aoss type: oss-emulator
  Server-2: PipeWire v: 1.0.5 status: off with: pipewire-media-session status: active
    tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: off with: 1: pulseaudio-alsa type: plugin
    2: pulseaudio-jack type: module tools: pacat,pactl
  Device-1: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter vendor: Lenovo
    driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0
    chip-ID: 10ec:8852 class-ID: 0280
  IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running rfk-block:
    hardware: no software: yes address: see --recommends
  Local Storage: total: 953.87 GiB used: 896.68 GiB (94.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB1T0HBLR-000L2 size: 953.87 GiB
    block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter>
    fw-rev: 3L1QEXF7 temp: 39.9 C scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 775.17 GiB (81.3%) fs: btrfs
    dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A uuid: 8e50babd-d978-452a-84f5-c19ce197176b
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 568 KiB (0.2%) fs: vfat
    dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL uuid: B231-18E3
  ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 775.17 GiB (81.3%) fs: btrfs
  ID-7: /swap raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 775.17 GiB (81.3%) fs: btrfs
  ID-8: /var/cache raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 775.17 GiB (81.3%)
    fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
  ID-9: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%) used: 775.17 GiB (81.3%)
  Kernel: swappiness: 60 (default) cache-pressure: 100 (default) zswap: yes compressor: zstd
    max-pool: 20%
  ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2 file: /swap/swapfile
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
  Device-1: 1-2:2 info: Logitech G102/G203 LIGHTSYNC Gaming Mouse type: mouse,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 300mA chip-ID: 046d:c092 class-ID: 0300 serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
    mode: 3.2 gen-2x1 chip-ID: 1d6b:0003 class-ID: 0900
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
  Device-1: 3-2:2 info: Microsoft Wired Keyboard 600 (model 1576) type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
    power: 100mA chip-ID: 045e:07f8 class-ID: 0300
  Device-2: 3-3:3 info: Realtek Bluetooth Radio type: bluetooth driver: btusb interfaces: 2
    rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 500mA chip-ID: 0bda:4852
  Device-3: 3-4:4 info: Chicony Integrated Camera type: video driver: uvcvideo interfaces: 5
    rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b6be
  Hub-4: 4-0:1 info: super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
  System Temperatures: cpu: 51.8 C mobo: N/A
  Fan Speeds (rpm): N/A
  GPU: device: nvidia screen: :0.0 temp: 38 C device: amdgpu temp: 43.0 C
  Packages: 1828 pm: pacman pkgs: 1808 libs: 494 tools: gnome-software,pamac pm: flatpak pkgs: 11
    pm: snap pkgs: 9
  Active pacman repo servers in: /etc/pacman.conf
    1: https://download.sublimetext.com/arch/stable/x86_64
    1: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    2: https://linorg.usp.br/manjaro/stable/$repo/$arch
    3: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    4: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    5: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 387
  1: cpu: 3.0% command: gnome-shell pid: 2604 mem: 261.8 MiB (0.9%)
  2: cpu: 1.9% command: Xorg pid: 2526 mem: 192.5 MiB (0.6%)
  3: cpu: 0.8% command: -zsh pid: 5199 mem: 10.4 MiB (0.0%)
  4: cpu: 0.7% command: init pid: 1 mem: 12.8 MiB (0.0%)
  5: cpu: 0.7% command: [irq/92-rtw89_pci] pid: 765 mem: 0.00 MiB (0.0%)
  Memory top: 5 of 387
  1: mem: 261.8 MiB (0.9%) command: gnome-shell pid: 2604 cpu: 3.0%
  2: mem: 192.5 MiB (0.6%) command: Xorg pid: 2526 cpu: 1.9%
  3: mem: 96.7 MiB (0.3%) command: mutter-x11-frames pid: 2690 cpu: 0.0%
  4: mem: 41.9 MiB (0.1%) command: snapd pid: 1051 cpu: 0.2%
  5: mem: 26.7 MiB (0.0%) command: gjs pid: 3007 cpu: 0.0%
  Processes: 387 Power: uptime: 2m states: freeze,mem,disk suspend: s2idle wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 10.9 GiB
    services: gsd-power, power-profiles-daemon, upowerd Init: systemd v: 255 default: graphical
    tool: systemctl
  Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh (login) v: 5.9 running-in: tty 3 inxi: 3.3.34
The cause was found: libgdm-plymouth (which I don’t remember installing). Replacing it with libgdm after the update fixed the problem. Interesting, if libgdm-plymouth is an outdated or somehow irrelevant, why wouldn’t update offer replacing it with libgdm? Anyway, this thread on Arch forums had the answer.
Thanks for everyone spending their time to help. I appreciate it!
Unless there was a ‘replace’ line or something then it wouldnt.
But something like “package not found” should have been printed.
(or something like “No updates for local package XYZ” … I dont quite remember)
With pacman anyways.
