The only error I can track down is the following, which is written to the CLI when attempting run kwalletmanager from the CLI
Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
and it’s not so much an error as a warning. But the Kwallet Manager window greys out and display a not responding message in the Window decoration bar, and eventually the same message, above, is displayed in the Window.
If I log in as a different user Kwallet Manager loads correctly.
I’ve removed ~/.cache, and even renamed ~/.config/kwalletd and removed config files for kwalletmanager5 and kwalletmanger, but yet it does appear the problem is related to my personal account.
Kernel: 6.12.34-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1 clocksource: tsc
avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-6.12-x86_64
root=UUID=5aa9dd24-270a-4fe0-b9b1-5745bdc4f888 rw quiet splash udev.log_priority=3
sysrq_always_enabled=1 resume=UUID=4dc86597-0ba0-495d-8e95-cb30a5f34cef
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.15.0 wm: kwin_wayland vt: 5
dm: SDDM Distro: Manjaro base: Arch Linux
Type: Laptop System: Notebook product: W54_W94_W955TU,-T,-C v: N/A serial: <superuser required>
Chassis: type: 10 serial: <superuser required>
Mobo: Notebook model: W54_W94_W955TU,-T,-C v: V1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: 5.6.5 date: 08/14/2014
ID-1: BAT0 charge: 28.1 Wh (100.0%) condition: 28.1/32.6 Wh (86.2%) volts: 16.4 min: 14.8
model: Notebook BAT type: Li-ion serial: <filter> status: full
System RAM: total: 8 GiB available: 7.64 GiB used: 5.66 GiB (74.2%)
Array-1: capacity: 64 GiB slots: 2 modules: 1 EC: None max-module-size: 32 GiB note: est.
Device-1: A1_DIMM0 type: DDR3 detail: N/A size: 8 GiB speed: 1333 MT/s volts: min: 23.32
max: 47.183 width (bits): data: 64 total: 64 manufacturer: A-DATA part-no: N/A serial: <filter>
Device-2: A1_DIMM1 type: no module installed
Info: model: Intel Pentium N3540 bits: 64 type: MCP arch: Silvermont level: v2 built: 2013-15
process: Intel 22nm family: 6 model-id: 0x37 (55) stepping: 8 microcode: 0x838
Topology: cpus: 1x dies: 1 clusters: 2 cores: 4 smt: <unsupported> cache: L1: 224 KiB
desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 500 min/max: 500/2666 scaling: driver: intel_cpufreq governor: schedutil
cores: 1: 500 2: 500 3: 500 4: 500 bogomips: 17343
Flags: 3dnowprefetch acpi aperfmperf apic arat arch_perfmon bts clflush cmov constant_tsc
cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept erms est flexpriority fpu fxsr ht ibpb ibrs
ida lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe
pclmulqdq pdcm pebs pge pni popcnt pse pse36 pti rdrand rdtscp rep_good sep smep ss sse sse2
sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq tsc_reliable vme vmx vnmi vpid xtopology xtpr
Type: spec_store_bypass status: Not affected
Type: spectre_v2 mitigation: Retpolines; IBPB: conditional; IBRS_FW; STIBP: disabled; RSB
filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display vendor: CLEVO/KAPOK
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports: active: eDP-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0f31 class-ID: 0300
Device-2: Bison BisonCam NB Pro driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-4.3:6 chip-ID: 5986:024b class-ID: 0e02
Display: wayland server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8 compositor: kwin_wayland
driver: X: loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x03f8 built: 2012 res: mode: 1366x768 hz: 60
scale: 85% (0.85) to: 1607x904 dpi: 101 gamma: 1.2 chroma: red: x: 0.580 y: 0.345 green: x: 0.337
y: 0.573 blue: x: 0.157 y: 0.118 white: x: 0.314 y: 0.329 size: 345x194mm (13.58x7.64")
diag: 396mm (15.6") ratio: 16:9 modes: 1366x768
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus device: 1 drv: swrast
gbm: drv: crocus surfaceless: drv: crocus wayland: drv: crocus x11: drv: crocus
API: OpenGL v: 4.5 compat-v: 4.2 vendor: intel mesa v: 25.1.4-arch1.1 glx-v: 1.4
direct-render: yes renderer: Mesa Intel HD Graphics (BYT) device-ID: 8086:0f31 memory: 1.46 GiB
unified: yes display-ID: :3.0
API: Vulkan v: 1.4.313 layers: N/A device: 0 type: integrated-gpu name: Intel HD Graphics (BYT)
driver: mesa intel v: 25.1.4-arch1.1 device-ID: 8086:0f31 surfaces: N/A
Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,kscreen-doctor
wl: wayland-info,wlr-randr x11: xdpyinfo,xprop
Device-1: Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:0f04 class-ID: 0403
API: ALSA v: k6.12.34-1-MANJARO status: kernel-api with: aoss type: oss-emulator
Server-1: JACK v: 1.9.22 status: off with: nsmd status: off tools: N/A
Server-2: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse status: active
2: wireplumber status: active 3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: CLEVO/KAPOK driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 01:00.2 chip-ID: 10ec:8136
class-ID: 0200
IF: enp1s0f2 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless 3160 driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 8086:08b3 class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 5.91 TiB used: 416.93 GiB (6.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB size: 931.51 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: SSD serial: <filter> fw-rev: 2B6Q
scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST500LT012-1DG142 size: 465.76 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: HDD rpm: 5400 serial: <filter> scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD20SDRW-11VUUS0 size: 1.82 TiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1034 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital model: WD20NMVW-11AV3S2 size: 1.82 TiB
tech: HDD rpm: 5200 serial: <filter> fw-rev: 1012 scheme: MBR
ID-5: /dev/sde maj-min: 8:64 vendor: Western Digital model: WD10SMRW-59Y43S0 size: 931.48 GiB
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW SU-208FB rev: TC00 dev-links: cdrom
Features: speed: 24 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram
state: running
ID-1: / raw-size: 63.48 GiB size: 62.18 GiB (97.96%) used: 39.62 GiB (63.7%) fs: ext4
dev: /dev/sda2 maj-min: 8:2 label: N/A uuid: 5aa9dd24-270a-4fe0-b9b1-5745bdc4f888
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 320 KiB (0.1%) fs: vfat
dev: /dev/sda1 maj-min: 8:1 label: N/A uuid: A7B5-6A4D
ID-3: /home raw-size: 847.72 GiB size: 833.34 GiB (98.30%) used: 376.81 GiB (45.2%) fs: ext4
dev: /dev/sda4 maj-min: 8:4 label: N/A uuid: 4634127b-b874-49cf-944d-be311c3556a9
ID-4: /run/media/tracy/Books raw-size: N/A size: 7.22 TiB used: 957.57 GiB (13.0%) fs: cifs
dev: /dev/books
ID-5: /run/media/tracy/Movies raw-size: N/A size: 7.22 TiB used: 5.38 TiB (74.5%) fs: cifs
dev: /dev/movies
ID-1: swap-1 type: partition size: 20.02 GiB used: 514 MiB (2.5%) priority: -2 dev: /dev/sda3
maj-min: 8:3 label: N/A uuid: 4dc86597-0ba0-495d-8e95-cb30a5f34cef
ID-1: /dev/sdb1 maj-min: 8:17 size: 465.76 GiB fs: ext4 label: ManjaroRepo
uuid: e17fa113-15a8-41f6-96ea-20ed16243d27
ID-2: /dev/sdc1 maj-min: 8:33 size: 1.82 TiB fs: ext4 label: N/A
uuid: d3e822ba-8666-4da3-a05b-8ab0417a2455
ID-3: /dev/sdd2 maj-min: 8:50 size: 1.82 TiB fs: ext4 label: Extras
uuid: e071aa09-1db8-4c37-b59b-7ae159972592
ID-4: /dev/sde1 maj-min: 8:65 size: 931.48 GiB fs: ext4 label: N/A
uuid: 3f558786-90f7-4ce7-968f-a1e92c012106
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
Device-1: 1-2:2 info: Intel Bluetooth wireless interface type: bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Hub-2: 1-4:3 info: Alcor Micro USB Hub ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 100mA chip-ID: 058f:6254 class-ID: 0900
Hub-3: 1-4.1:4 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 0bda:5411 class-ID: 0900
Hub-4: 1-4.1.1:7 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
Hub-5: 1-4.1.1.1:10 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
Hub-6: 1-4.1.1.1.1:12 info: Realtek RTS5411 Hub ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
Device-1: 1-4.1.1.1.3:13 info: Western Digital Elements 25A2 type: mass storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 1058:25a2 class-ID: 0806 serial: <filter>
Device-2: 1-4.1.2:8 info: Western Digital My Passport (WDBPKJ) type: mass storage
power: 500mA chip-ID: 1058:2626 class-ID: 0806 serial: <filter>
Device-3: 1-4.1.3:9 info: Iomega Prestige Portable Hard Drive type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 2mA chip-ID: 059b:0470 class-ID: 0806 serial: <filter>
Device-4: 1-4.1.4:11 info: Western Digital Elements Portable (WDBU6Y WDBUZG) type: mass storage
power: 500mA chip-ID: 1058:10b8 class-ID: 0806 serial: <filter>
Device-5: 1-4.2:5 info: [Maxxter] Optical gaming mouse type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
power: 100mA chip-ID: 18f8:0f99 class-ID: 0300
Device-6: 1-4.3:6 info: Bison BisonCam NB Pro type: video driver: uvcvideo interfaces: 2
rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 200mA chip-ID: 5986:024b
class-ID: 0e02
Hub-7: 2-0:1 info: super-speed hub ports: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 chip-ID: 1d6b:0003 class-ID: 0900
System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: 1711 pm: pacman pkgs: 1659 libs: 338 tools: octopi,pamac,yay pm: flatpak pkgs: 52
1: https: //mirror.xenyth.net/manjaro/stable/$repo/$arch
2: https: //mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
3: http: //mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
4: https: //mirror.hostiko.network/manjaro/stable/$repo/$arch
5: https: //quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
6: https: //manjaro.c3sl.ufpr.br/stable/$repo/$arch
7: https: //mirror.2degrees.nz/manjaro/stable/$repo/$arch
8: https: //bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 317
1: cpu: 400% command: ps pid: 7596 mem: 3.95 MiB (0.0%)
2: cpu: 55.2% command: python3 pid: 7578 mem: 231.8 MiB (2.9%)
3: cpu: 8.9% command: kwin_wayland pid: 2914 mem: 419.9 MiB (5.3%)
4: cpu: 8.3% command: kate pid: 7035 mem: 287.0 MiB (3.6%)
5: cpu: 7.9% command: firefox pid: 3319 mem: 546.4 MiB (6.9%)
Memory top: 5 of 317
1: mem: 560.9 MiB (7.1%) command: plasmashell pid: 3089 cpu: 5.2%
2: mem: 546.4 MiB (6.9%) command: firefox pid: 3319 cpu: 7.9%
3: mem: 477.1 MiB (6.1%) command: firefox pid: 6022 cpu: 1.6%
4: mem: 474.9 MiB (6.0%) command: firefox pid: 4011 cpu: 3.1%
5: mem: 419.9 MiB (5.3%) command: kwin_wayland pid: 2914 cpu: 8.9%
Processes: 317 Power: uptime: 1h 8m states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 3.04 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 257
Compilers: clang: 20.1.6 gcc: 15.1.1 Client: Unknown python3.13 client inxi: 3.3.38
