I have absolutely no idea if this will work, but try resetting your mirror to the defaults:
sudo pacman-mirrors --country all
And then refreshing the mirror lists:
sudo pacman -Sy
And then try the update again:
sudo pacman -Syu
If you still get errors, please provide the complete outputs to the above commands, according to the below tip.
Tip
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
As I’m a moderator on the forum, I have taken the liberty of doing this for you, this time.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Note that the above text is partially pre-prepared as a general introduction for new forum Users. Please take the time to to understand how it is done and encourage quality responses.
