Unable to launch Flameshot from keyboard shortcut
Hi everyone,
I’m having trouble using Flameshot with a keyboard shortcut on Manjaro Linux.
I configured the shortcut exactly as indicated in the official guide:
:point_right: https://flameshot.org/docs/guide/key-bindings/#on-ubuntu-and-other-gnome-based-distros
However, whenever I try to launch Flameshot via the shortcut, it doesn’t start. Instead, I get a notification saying:
impossible to capture the screen
If I launch Flameshot manually from the application’s menu or using the same command from terminal, it works fine. The issue only happens when using the key binding.
Has anyone else faced this on Manjaro? Any ideas on how to fix it?
Thanks in advance!
Would help if you’d post the result of inxi -zv8c0 for starters. :wink:
But anyways. I understand from your link, that you are using Gnome (and the tag)? Are you using Wayland on it? When I changed to Wayland, I had issues with Flameshot until I installed a patch for Flameshot on Wayland from the repo.
  Kernel: 6.15.11-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.15-x86_64
    root=UUID=efcf7327-b70a-4194-8cd4-6d749e10920e rw rootflags=subvol=@
    quiet splash apparmor=1 security=apparmor udev.log_priority=3
  Desktop: GNOME v: 48.4 tk: GTK v: 3.24.50 wm: gnome-shell
    base: Arch Linux
  Mobo: ASUSTeK model: ROG STRIX B550-F GAMING (WI-FI) v: Rev X.0x
    UEFI: American Megatrends v: 2803 date: 04/27/2022
  Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
    serial: <filter> charge: 50% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 32 GiB available: 31.25 GiB used: 8.39 GiB (26.8%)
  Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: 3733 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Patriot
    part-no: 3733 C17 Series serial: <filter>
  Device-2: DIMM_A2 type: DDR4 detail: synchronous unbuffered (unregistered)
    part-no: 3733 C17 Series serial: N/A
  Device-3: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Device-4: DIMM_B2 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201211
    desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 1759 min/max: 557/4867 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1759 2: 1759 3: 1759
    4: 1759 5: 1759 6: 1759 7: 1759 8: 1759 9: 1759 10: 1759 11: 1759 12: 1759
    13: 1759 14: 1759 15: 1759 16: 1759 bogomips: 108803
    xsaves xtopology
    affected
  Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ZOTAC driver: nvidia
    v: 575.64.05 alternate: nouveau,nova_core,nvidia_drm non-free: 550-580.xx+
    status: current (as of 2025-08; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none
    off: DP-1,DP-2 empty: DP-3,HDMI-A-1 bus-ID: 0b:00.0 chip-ID: 10de:2484
    class-ID: 0300
    compositor: gnome-shell driver: X: loaded: N/A failed: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: 0
  Monitor-1: DP-1 model: Dell U2412M serial: <filter> built: 2011
    res: 1920x1200 dpi: 94 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green:
    x: 0.298 y: 0.600 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10
    modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1280x960,
    1024x768, 800x600, 640x480
  Monitor-2: DP-2 model: Lenovo LEN G34w-10 serial: <filter> built: 2020
    res: 3440x1440 dpi: 110 gamma: 1.2 chroma: red: x: 0.678 y: 0.310 green:
    x: 0.200 y: 0.690 blue: x: 0.149 y: 0.051 white: x: 0.314 y: 0.329
    size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: 3440x1440,
    2560x1440, 2560x1080, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
    1600x900, 1280x1024, 1440x900, 1366x768, 1280x800, 1152x864, 1280x720,
    1024x768, 800x600, 720x576, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 90 2: parse_edid:
    unknown tag 112
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
    x11: drv: nvidia inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 575.64.05
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
    memory: 7.81 GiB display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
    x11: xprop,xrandr
  Device-1: NVIDIA GA104 High Definition Audio vendor: ZOTAC
    driver: snd_hda_intel v: kernel alternate: nova_core pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 10de:228b class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Creative Pebble V3 driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:5
    chip-ID: 041e:3272 class-ID: 0300 serial: <filter>
  API: ALSA v: k6.15.11-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp9s0 state: up mac: <filter>
  Device-2: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0a:00.0
    chip-ID: 8086:15f3 class-ID: 0200
  IF: enp10s0 state: down mac: <filter>
  Local Storage: total: 5.24 TiB used: 178.56 GiB (3.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Western Digital
    model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 620311WD temp: 50.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: KIOXIA model: EXCERIA G2 SSD
    lanes: 4 tech: SSD serial: <filter> fw-rev: ECFA17.1 temp: 46.9 C
    scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDH3500G
    tech: SSD serial: <filter> fw-rev: 70RL scheme: MBR
  ID-4: /dev/sdb maj-min: 8:16 vendor: OCZ model: VERTEX4 size: 238.47 GiB
    block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
    serial: <filter> fw-rev: 1.5 scheme: MBR
  ID-5: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DL003-9VT166
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5900 serial: <filter> fw-rev: CC32 scheme: MBR
  ID-1: / raw-size: 397.67 GiB size: 397.67 GiB (100.00%)
    used: 178.56 GiB (44.9%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:8
    label: N/A uuid: efcf7327-b70a-4194-8cd4-6d749e10920e
    used: 348 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p6 maj-min: 259:9 label: N/A
    uuid: 24EB-20C0
  ID-3: /home raw-size: 397.67 GiB size: 397.67 GiB (100.00%)
  ID-4: /var/cache raw-size: 397.67 GiB size: 397.67 GiB (100.00%)
  ID-5: /var/log raw-size: 397.67 GiB size: 397.67 GiB (100.00%)
  ID-1: /dev/nvme0n1p1 maj-min: 259:4 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p2 maj-min: 259:5 size: 100 MiB fs: vfat label: N/A
    uuid: ECCC-7828
  ID-3: /dev/nvme0n1p3 maj-min: 259:6 size: 1.43 TiB fs: ntfs label: N/A
    uuid: 9428DBD628DBB588
  ID-4: /dev/nvme0n1p4 maj-min: 259:7 size: 758 MiB fs: ntfs label: N/A
    uuid: DA342A0D3429ECE7
  ID-5: /dev/nvme1n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
  ID-6: /dev/nvme1n1p2 maj-min: 259:2 size: 931.5 GiB fs: ntfs
    label: NVMe 1TB uuid: 3E0E309D0E304FDF
  ID-7: /dev/sda1 maj-min: 8:1 size: 465.76 GiB fs: ntfs label: SDD 500GB
    uuid: 5CD028FCD028DDD0
  ID-8: /dev/sdb1 maj-min: 8:17 size: 238.47 GiB fs: ntfs label: SSD 240GB
    uuid: 3816F45B16F41C16
  ID-9: /dev/sdc1 maj-min: 8:33 size: 1.82 TiB fs: ntfs label: Arxius 2TB
    uuid: 60A6CCB155D250D7
  Device-1: 1-2:5 info: Creative Pebble V3 type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
  Device-2: 1-6:2 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:1939 class-ID: 0300
    serial: <filter>
  Hub-2: 1-7:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-7.1:4 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-3:2 info: ROCCAT Kave Headset type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 1e7d:38a4 class-ID: 0301
  Hub-5: 3-4:3 info: Microchip (formerly SMSC) USB 2.0 Hub ports: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
    chip-ID: 0424:2514 class-ID: 0900
  Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 41.5 C mobo: 40.0 C
  Fan Speeds (rpm): fan-1: 560 fan-2: 505 fan-3: 0 fan-4: 598 fan-5: 0
    fan-6: 0 fan-7: 487
  Packages: 1643 pm: pacman pkgs: 1621 libs: 508 tools: gnome-software,pamac
    pm: flatpak pkgs: 22
    1: https://manjaro.ynh.ovh/stable/$repo/$arch
    2: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    6: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    8: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 443
  1: cpu: 20.1% command: chromium pid: 28078 mem: 395.9 MiB (1.2%)
  2: cpu: 7.6% command: gnome-shell pid: 1722 mem: 789.3 MiB (2.4%)
  3: cpu: 5.7% command: chromium pid: 27461 mem: 338.5 MiB (1.0%)
  4: cpu: 4.1% command: chromium pid: 2866 mem: 562.0 MiB (1.7%)
  5: cpu: 3.7% command: spotify pid: 4693 mem: 428.3 MiB (1.3%)
  Memory top: 5 of 443
  1: mem: 789.3 MiB (2.4%) command: gnome-shell pid: 1722 cpu: 7.6%
  2: mem: 709.3 MiB (2.2%) command: Telegram pid: 13610 cpu: 0.1%
  3: mem: 577.9 MiB (1.8%) command: chromium pid: 2483 cpu: 2.4%
  4: mem: 562.0 MiB (1.7%) command: chromium pid: 2866 cpu: 4.1%
  5: mem: 556.9 MiB (1.7%) command: nautilus pid: 7636 cpu: 0.2%
  Processes: 443 Power: uptime: 3h 20m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.47 GiB services: gsd-power,
    tool: systemctl
  Compilers: gcc: 15.2.1 Shell: fish v: 4.0.2 running-in: gnome-terminal
    inxi: 3.3.39
Yes, I’m using Wayland…
Do you remember the patch you had installed?
Gnome has got it’s own integrated tool for making screenshots - already bound to this shortcut by default.
I do not know the (terminal) command for that.
Perhaps you first need to disable that built in function. :man_shrugging:
Or simply use another, unoccupied shortcut …
dconf-editor might be needed for this
Gnome is strange in many ways.
It’s nothing more than pressing the print-key (on an German keyboard Druck).
And that works way better than any special applet I’ve ever tried.
Unfortunately not, but I did find a few other resources that might help:
This is from Flameshot’s own site about troubleshooting Flameshot on Wayland.
And then there’s this one on these forums: Shortkeys not working after update Gnome Wayland
Hopefully these are of use.
Wayland Help | Flameshot
Gnome shortcut does not trigger Flameshot
Symptom: When using a shortcut (Print screen) to run Flameshot I get “Unable to capture screen”. When I run the command from the shortcut in a terminal, it works. Both used to work fine before, but stopped working after my daily updates. The normal Gnome screenshot program still works. [source]
We don’t have a definite answer of what in Gnome have changed, but Gnome users have provided the following solution:
Run the flameshot gui via a shell script
script --command "QT_QPA_PLATFORM=wayland flameshot gui" /dev/null
# or
bash -c -- "QT_QPA_PLATFORM=wayland flameshot gui"
# or
If this didn’t solve your issue or if you are not sure what you do about this, Best places to look for are #3365 and #3326.
Reset Gnome shortcut permission
In Gnome Wayland the users is asked if they want to give permission to the screenshot tool to capture the screen. It is possible to hit the wrong button and permanently block Flameshot from taking the screenshot. The workaround have been proposed by the community. Running the following command in terminal would reset the permission in Gnome Wayland:
dbus-send --session  --print-reply=literal --dest=org.freedesktop.impl.portal.PermissionStore /org/freedesktop/impl/portal/PermissionStore org.freedesktop.impl.portal.PermissionStore.D
eletePermission string:'screenshot' string:'screenshot' string:''
Gnome Help - Screenshots and screencasts
I know.
I tried with a default Manjaro Gnome installation.
Gnome has got it’s own built in screenshot tool for that already - using this very shortcut.
It’s not a special applet - it is a built in functionality.
(you can take screenshots with it - without installing flameshot or any extra program)
Assigning the same shortcut to flameshot as well might create a conflict.
Yes, it makes a screenshot but nothing more.
Flameshot has more gadgets I need. You can edit the snapshot on the fly, put square in the place you want to focus, numbers, text, blur content…
Thank for you help, but seems it doesn’t solve the problem.
Tomorrow I will try it again.
