I have a hard drive which is automounted at /home/USERNAME/sda1 using fstab. I executed
sudo chmod -R 777 /home/USERNAME/sda1
then rebooted to see if that would get steam to see the drive but it is still not there.
What can I do now?
What can I do now?
Welcome here, @Ka5pian
Please post your fstab file
cat /etc/fstab
to see how you mounted the partition and what file system it has.
Also, please show us output of
sudo parted -l
sudo blkid
UUID=779C-BE0B /boot/efi vfat umask=0077 0 2
UUID=8379197a-5a6d-4e32-b79c-51bbc8e05f5d / ext4 defaults,noatime 0 1
UUID=feb26a93-365d-4035-ab60-cbee1fc41690 swap swap defaults,noatime 0 0
UUID=b7763217-46bd-4b42-bd4a-9a08c13a254f /home/ka5pian/sda1 ext4 defaults 0 2
UUID=19d1258d-6a67-4517-9fdf-8865459ad0d0 /home/ka5pian/nvme1n1 ext4 defaults 0 2
the bold is the drive i am trying to use
Model: ATA ST2000DM001-1CH1 (scsi)
Disk /dev/sda: 2000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 17.4kB 2000GB 2000GB ext4 LDM data partition
/dev/sda1: LABEL="Syuff" UUID="b7763217-46bd-4b42-bd4a-9a08c13a254f" BLOCK_SIZE="4096" TYPE="ext4" PARTLABEL="LDM data partition" PARTUUID="c286a643-fe79-11e9-9fce-4ccc6a60fe49"
Did you create the folder by
sudo mkdir /home/ka5pian/sda1
Have you tried getting ownership by
sudo chown -R ka5pian /home/ka5pian/sda1
I made the directory before editing fstab
tried
sudo chown ka5pian /home/ka5pian/sda1
then restarted steam and nothing changed
I can access the drive through nemo
What gives
ls -la /home/ka5pian
You can truncate it if you don’t want to show all.
drwx------ 3 ka5pian ka5pian 4096 Jan 30 20:39 nvme1n1
drwxrwxrwx 14 ka5pian ka5pian 4096 Jan 30 20:28 sda1
sda1 is dark blue text and has a teal highlight whereas the nvme drive is only dark blue.
(sidenote: Steam is the flathpak version)
Then the folder is OK and the issue on the side of steam I guess…
You can certainly check content of the folder by
ls -la /home/ka5pian/sda1
drwxrwxrwx 3 ka5pian ka5pian 4096 Dec 13 16:34 SteamLibrary
I now understand what the text colour means
I’m going to try and install the windows version of steam and using it through wine to see if that solves the issue.
(will reply the outcome)
The windows version worked but I’ll try the AUR version.
I think reinstalling steam fixed the issue. I used the AUR package
