tbri
13 August 2021 10:13
1
I have a brand new Samsung Galaxy laptop and it’s not working out so well. Manjaro seems to be a better distro than others I have tried, but none of them are having any luck enabling my Intel Wifi card:
[ 4.512608] Intel(R) Wireless WiFi driver for Linux
[ 4.512671] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[ 4.514149] iwlwifi: No config found for PCI dev a0f0/6074, rev=0x354, rfid=0x10a100
[ 4.514761] iwlwifi: probe of 0000:00:14.3 failed with error -22
Is there a more recent kernel than 5.1.3 or is there some other way to enable this card?
tbri
16 August 2021 18:07
3
Ok, as requested. System info
Kernel: 5.13.8-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=b5a61696-e1da-43ad-b262-bc22d0b420cd rw quiet apparmor=1
Console: tty pts/2 DM: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: SAMSUNG product: 750XDA v: P06CFD serial: <filter>
Chassis: type: 10 serial: N/A
Mobo: SAMSUNG model: NP750XDA-KD4SE v: SAMSUNG_SW_REVISION_12345+0.0.0000
serial: <filter> UEFI: American Megatrends LLC. v: P06CFD.028.210428.HQ
date: 04/28/2021
ID-1: BAT1 charge: 35.8 Wh (63.9%) condition: 56.0/54.4 Wh (103.0%)
volts: 15.5 min: 15.4 model: SAMSUNG Electronics SR Real Battery
type: Li-ion serial: <filter> status: Discharging cycles: 4
RAM: total: 15.36 GiB used: 3.25 GiB (21.1%)
Array-1: capacity: 16 GiB slots: 8 EC: None max-module-size: 2 GiB
note: est.
Device-1: Controller0-ChannelA size: 2 GiB speed: 4267 MT/s type: LPDDR4
detail: synchronous bus-width: 16 bits total: 16 bits manufacturer: Samsung
part-no: UBE3D4AA-MGCR serial: N/A
Device-2: Controller0-ChannelB size: 2 GiB speed: 4267 MT/s type: LPDDR4
Device-3: Controller0-ChannelC size: 2 GiB speed: 4267 MT/s type: LPDDR4
Device-4: Controller0-ChannelD size: 2 GiB speed: 4267 MT/s type: LPDDR4
Device-5: Controller1-ChannelA size: 2 GiB speed: 4267 MT/s type: LPDDR4
Device-6: Controller1-ChannelB size: 2 GiB speed: 4267 MT/s type: LPDDR4
Device-7: Controller1-ChannelC size: 2 GiB speed: 4267 MT/s type: LPDDR4
Device-8: Controller1-ChannelD size: 2 GiB speed: 4267 MT/s type: LPDDR4
Info: Quad Core model: 11th Gen Intel Core i7-1165G7 socket: U3E1 bits: 64
type: MT MCP arch: Tiger Lake family: 6 model-id: 8C (140) stepping: 1
microcode: 86 cache: L1: 320 KiB L2: 12 MiB L3: 12 MiB bogomips: 44864
Speed: 3086 MHz min/max: 400/4700 MHz base/boost: 2700/4700 volts: 0.8 V
ext-clock: 100 MHz Core speeds (MHz): 1: 3086 2: 2130 3: 2491 4: 2434
5: 2292 6: 1533 7: 2339 8: 1088
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2 cdp_l2 clflush
clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority flush_l1d fma
fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp hwp_notify
hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid invpcid_single
lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr
nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge
pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdt_a rdtscp rep_good
sdbg sep sha_ni smap smep split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel Iris Xe Graphics vendor: Samsung Co driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: SunplusIT 720p HD Camera type: USB driver: uvcvideo bus-ID: 3-7:3
chip-ID: 2b7e:b500 class-ID: 0e02 serial: <filter>
Display: server: X.org 1.20.11 compositor: kwin_x11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa tty: 111x26
Message: Advanced graphics data unavailable in console for root.
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Samsung Co
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.13.8-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: N/A modules: iwlwifi port: 3000
bus-ID: 00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
Device-2: Ralink RT5370 Wireless Adapter type: USB driver: rt2800usb
bus-ID: 3-2:2 chip-ID: 148f:5370 class-ID: 0000 serial: <filter>
IF: wlp0s20f0u2 state: up mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 9.19 GiB (1.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: SSSTC CL1-8D512 size: 476.94 GiB
block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
rotation: SSD serial: <filter> rev: E992004 temp: 30 Celsius C scheme: GPT
SMART: yes health: PASSED on: 18d 19h cycles: 76
read-units: 658,344 [337 GB] written-units: 923,395 [472 GB]
ID-1: / raw-size: 74.5 GiB size: 72.78 GiB (97.69%) used: 9.14 GiB (12.6%)
fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p7 maj-min: 259:7 label: N/A
uuid: b5a61696-e1da-43ad-b262-bc22d0b420cd
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 51.3 MiB (20.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1 label: SYSTEM uuid: 309F-1509
ID-1: swap-1 type: partition size: 18.19 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p9 maj-min: 259:9 label: N/A
uuid: b9fe75a6-3798-4995-b4ff-d4106a01d3aa
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 80 GiB fs: ntfs label: N/A
uuid: D0C4A0B0C4A09A6C
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 850 MiB fs: ntfs
label: Windows RE tools uuid: E4267D52267D26A8
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 14.65 GiB fs: ntfs
label: SAMSUNG_REC2 uuid: C6E63C2CE63C1EDD
ID-5: /dev/nvme0n1p6 maj-min: 259:6 size: 1024 MiB fs: fat (32 bit)
label: SAMSUNG_REC uuid: C2A5-5342
ID-6: /dev/nvme0n1p8 maj-min: 259:8 size: 282 GiB fs: xfs label: N/A
uuid: 577bf07f-31a0-4a7e-b2fc-14ea4302b520
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 3-2:2 info: Ralink RT5370 Wireless Adapter type: Network
driver: rt2800usb interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 450mA
Device-2: 3-7:3 info: SunplusIT 720p HD Camera type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 2b7e:b500
Device-3: 3-10:4 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 43.0 C mobo: N/A
Processes: 248 Uptime: 27m wakeups: 1778 Init: systemd v: 248
tool: systemctl Compilers: gcc: N/A Packages: pacman: 1188 lib: 322
flatpak: 0 Shell: Bash (su) v: 5.1.8 running-in: tty pts/2 inxi: 3.3.04
I see that you have USB network adapter. Does internet connection work properly using it? I suppose you want to make internal card to work properly instead of using external one.
Could you post output of this command below?
rfkill list
Check this topic: Intel Wi-Fi 6 AX201
Someone has described what to do with your wifi card.
