Unable to disable snd_hda_intel power_save through modprobe
Starting from the last stable update (2020-10-01, linux58) I suddenly started to have popping issues with my ALC1220. I found that the fix is to disable power_save for the soundcard through /sys/module/snd_hda_intel/parameters/power_save, but I’m having trouble making it permanent through the use of a modprobe.d conf file.
Creating /etc/modprobe.d/snd-hda-intel.conf with the following contents:
# disable power saving to stop popping
options snd-hda-intel power_save=0
and rebuilding my initramfs through
sudo mkinitcpio -p linux58
does not disable power_save as expected after a reboot.
 > cat /sys/module/snd_hda_intel/parameters/power_save
1
During the initramfs rebuild I do see the modconf hook pick up the new conf file.
It seems like this is the well-known solution, but I’m having issues getting it to work. Anyone have any ideas as to what could be going wrong here?
Here is also the output of alsa-info.sh --no-upload --output infos_power. It list my modprobe option, but shows that the power_save option is still on for my soundcard.
Summary
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.65
!!Script ran on: Tue Oct 13 08:38:54 UTC 2020
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer:      Gigabyte Technology Co., Ltd.
Product Name:      X570 I AORUS PRO WIFI
Product Version:   -CF
Firmware Version:  F20
Board Vendor:      Gigabyte Technology Co., Ltd.
Board Name:        X570 I AORUS PRO WIFI
!!ACPI Device Status Information
/sys/bus/acpi/devices/AMDI0030:00/status 	 15
/sys/bus/acpi/devices/LNXTHERM:00/status 	 11
/sys/bus/acpi/devices/LNXTHERM:01/status 	 11
/sys/bus/acpi/devices/PNP0103:00/status 	 15
/sys/bus/acpi/devices/PNP0A08:00/status 	 15
/sys/bus/acpi/devices/PNP0C01:00/status 	 15
/sys/bus/acpi/devices/PNP0C02:01/status 	 15
/sys/bus/acpi/devices/PNP0C02:03/status 	 15
/sys/bus/acpi/devices/PNP0C0C:00/status 	 11
/sys/bus/acpi/devices/PNP0C0F:00/status 	 11
/sys/bus/acpi/devices/PNP0C0F:01/status 	 11
/sys/bus/acpi/devices/PNP0C0F:02/status 	 11
/sys/bus/acpi/devices/PNP0C0F:03/status 	 11
/sys/bus/acpi/devices/PNP0C0F:04/status 	 11
/sys/bus/acpi/devices/PNP0C0F:05/status 	 11
/sys/bus/acpi/devices/PNP0C0F:06/status 	 11
/sys/bus/acpi/devices/PNP0C0F:07/status 	 11
/sys/bus/acpi/devices/PNP0C14:00/status 	 11
!!Kernel Information
Kernel release:    5.8.11-1-MANJARO
Operating System:  GNU/Linux
Architecture:      x86_64
Processor:         unknown
SMP Enabled:       Yes
!!ALSA Version
Driver version:     k5.8.11-1-MANJARO
Library version:    1.2.3.2
Utilities version:  1.2.3
!!Loaded ALSA modules
snd_hda_intel
snd_hda_intel
snd_usb_audio
!!Sound Servers on this system
Pulseaudio:
      Installed - Yes (/usr/bin/pulseaudio)
      Running - Yes
Jack:
      Installed - Yes (/usr/bin/jackd)
      Running - No
!!Soundcards recognised by ALSA
 0 [NVidia         ]: HDA-Intel - HDA NVidia
                      HDA NVidia at 0xfc080000 irq 140
 1 [Generic        ]: HDA-Intel - HD-Audio Generic
                      HD-Audio Generic at 0xfcb00000 irq 142
 2 [PCW1           ]: USB-Audio - AUKEY PC-W1
                      Sonix Technology Co., Ltd. AUKEY PC-W1 at usb-0000:07:00.3-3, high speed
!!PCI Soundcards installed in the system
0a:00.1 Audio device [0403]: NVIDIA Corporation TU104 HD Audio Controller [10de:10f8] (rev a1)
	Subsystem: eVga.com. Corp. Device [3842:3172]
0c:00.4 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller [1022:1487]
	Subsystem: Gigabyte Technology Co., Ltd Device [1458:a0c3]
!!Modprobe options (Sound related)
snd_hda_intel: power_save=0
!!Loaded sound module options
!!Module: snd_hda_intel
	align_buffer_size : -1
	bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	dmic_detect : Y
	enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
	enable_msi : -1
	id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	pm_blacklist : Y
	position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	power_save : 1
	power_save_controller : Y
	probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	single_cmd : -1
	snoop : -1
	dmic_detect : Y
	enable_msi : -1
	pm_blacklist : Y
	power_save : 1
	single_cmd : -1
	snoop : -1
!!Module: snd_usb_audio
	autoclock : Y
	delayed_register : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	device_setup : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
	ignore_ctl_error : N
	pid : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
	quirk_alias : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
	skip_validation : N
	use_vmalloc : Y
	vid : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
!!HDA-Intel Codec information
--startcollapse--
Codec: Nvidia GPU 92 HDMI/DP
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x10de0092
Subsystem Id: 0x38423172
Revision Id: 0x100100
No Modem Function Group found
Default PCM:
    rates [0x0]:
    bits [0x0]:
    formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
  Power states:  D0 D1 D2 D3 CLKSTOP EPSS
  Power: setting=D0, actual=D0
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x04 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
  Pincap 0x09000094: OUT Detect HBR HDMI DP
  Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
    Conn = Digital, Color = Unknown
    DefAssociation = 0xf, Sequence = 0x0
  Pin-ctls: 0x00:
  Unsolicited: tag=01, enabled=1
  Devices: 4
     Dev 00: PD = 0, ELDV = 0, IA = 0
     Dev 01: PD = 0, ELDV = 0, IA = 0
     Dev 02: PD = 0, ELDV = 0, IA = 0
    *Dev 03: PD = 0, ELDV = 0, IA = 0
  Connection: 4
     0x08* 0x09 0x0a 0x0b
Node 0x05 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
  Pin-ctls: 0x00:
  Unsolicited: tag=05, enabled=1
  Devices: 4
    *Dev 00: PD = 1, ELDV = 1, IA = 0
  Connection: 4
Node 0x06 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
  Pin-ctls: 0x00:
  Unsolicited: tag=09, enabled=1
  Devices: 4
  Connection: 4
Node 0x07 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
  Pin-ctls: 0x00:
  Unsolicited: tag=0d, enabled=1
  Devices: 4
  Connection: 4
Node 0x08 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
  Converter: stream=0, channel=0
  Digital: Enabled
  Digital category: 0x0
  IEC Coding Type: 0x0
  PCM:
    rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
    bits [0xe]: 16 20 24
    formats [0x5]: PCM AC3
  Unsolicited: tag=00, enabled=0
Node 0x09 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
  Digital:
  PCM:
Node 0x0a [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
  Digital:
  PCM:
Node 0x0b [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
  Digital:
  PCM:
Codec: Realtek ALC1220
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec1220
Subsystem Id: 0x1458a0c3
Revision Id: 0x100101
Default PCM:
    rates [0x5f0]: 32000 44100 48000 88200 96000 192000
    formats [0x1]: PCM
  Power states:  D0 D1 D2 D3 D3cold CLKSTOP EPSS
GPIO: io=8, o=0, i=0, unsolicited=1, wake=0
  IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[3]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[4]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[5]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[6]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
  IO[7]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Front Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=Out, idx=0, ofs=0
  Device: name="ALC1220 Analog", type="Audio", device=0
  Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
  Amp-Out vals:  [0x33 0x33]
  Converter: stream=5, channel=0
  PCM:
    rates [0x7e0]: 44100 48000 88200 96000 176400 192000
    bits [0x1e]: 16 20 24 32
    formats [0x1]: PCM
  Power states:  D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Surround Playback Volume", index=0, device=0
  Amp-Out vals:  [0x00 0x00]
  PCM:
    formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Center Playback Volume", index=0, device=0
    ControlAmp: chs=1, dir=Out, idx=0, ofs=0
  Control: name="LFE Playback Volume", index=0, device=0
    ControlAmp: chs=2, dir=Out, idx=0, ofs=0
  PCM:
    formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Control: name="Headphone Playback Volume", index=0, device=0
  PCM:
    formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
  Digital:
  PCM:
    formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Control: name="Capture Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=0, ofs=0
  Control: name="Capture Switch", index=0, device=0
  Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
  Amp-In vals:  [0x3f 0x3f]
  Converter: stream=1, channel=0
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
  Control: name="Capture Volume", index=1, device=0
  Control: name="Capture Switch", index=1, device=0
  Device: name="ALC1220 Alt Analog", type="Audio", device=2
  Amp-In vals:  [0x80 0x80]
  SDI-Select: 0
  PCM:
    formats [0x1]: PCM
  Connection: 1
     0x22
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Control: name="Front Mic Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=1, ofs=0
  Control: name="Front Mic Playback Switch", index=0, device=0
  Control: name="Rear Mic Playback Volume", index=0, device=0
  Control: name="Rear Mic Playback Switch", index=0, device=0
  Control: name="Line Playback Volume", index=0, device=0
    ControlAmp: chs=3, dir=In, idx=2, ofs=0
  Control: name="Line Playback Switch", index=0, device=0
  Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
  Amp-In vals:  [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 8
     0x18 0x19 0x1a 0x1b 0x1d 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Amp-In vals:  [0x00 0x00] [0x80 0x80]
  Connection: 2
     0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x05 0x0b
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
  Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
  Pincap 0x00000020: IN
  Pin Default 0x403fc000: [N/A] CD at Ext N/A
    Conn = Other, Color = UNKNOWN
    DefAssociation = 0x0, Sequence = 0x0
  Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Control: name="Front Playback Switch", index=0, device=0
  Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
  Pincap 0x0001001c: OUT HP EAPD Detect
  EAPD 0x2: EAPD
  Pin Default 0x01014010: [Jack] Line Out at Ext Rear
    Conn = 1/8, Color = Green
    DefAssociation = 0x1, Sequence = 0x0
  Pin-ctls: 0x00:
  Connection: 1
     0x0c
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
  Amp-Out vals:  [0x80 0x80]
  Pincap 0x00000034: IN OUT Detect
  Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
    Conn = 1/8, Color = Black
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
  Connection: 1
     0x0d
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
  Connection: 1
     0x0e
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
    Misc = NO_PRESENCE
  Pin-ctls: 0x20: IN
  Connection: 1
     0x0f
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Center Playback Switch", index=0, device=0
  Control: name="LFE Playback Switch", index=0, device=0
  Control: name="Rear Mic Boost Volume", index=0, device=0
  Pincap 0x00003734: IN OUT Detect
    Vref caps: HIZ 50 GRD 80 100
  Pin Default 0x01a19030: [Jack] Mic at Ext Rear
    Conn = 1/8, Color = Pink
    DefAssociation = 0x3, Sequence = 0x0
  Pin-ctls: 0x24: IN VREF_80
  Unsolicited: tag=03, enabled=1
  Connection: 5
     0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Front Mic Boost Volume", index=0, device=0
  Amp-In vals:  [0x01 0x01]
  Pincap 0x0000373c: IN OUT HP Detect
  Pin Default 0x02a19040: [Jack] Mic at Ext Front
    DefAssociation = 0x4, Sequence = 0x0
  Unsolicited: tag=02, enabled=1
  Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Surround Playback Switch", index=0, device=0
  Control: name="Line Boost Volume", index=0, device=0
  Pin Default 0x0181303f: [Jack] Line In at Ext Rear
    Conn = 1/8, Color = Blue
    DefAssociation = 0x3, Sequence = 0xf
  Pin-ctls: 0x20: IN VREF_HIZ
  Unsolicited: tag=04, enabled=1
  Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
  Control: name="Headphone Playback Switch", index=0, device=0
  Pincap 0x0001373c: IN OUT HP EAPD Detect
  EAPD 0x2: EAPD
  Pin Default 0x02214020: [Jack] HP Out at Ext Front
    DefAssociation = 0x2, Sequence = 0x0
  Pin-ctls: 0xc0: OUT HP VREF_HIZ
  Connection: 5
     0x0c 0x0d 0x0e 0x0f* 0x26
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
  Pin Default 0x4047c669: [N/A] SPDIF Out at Ext N/A
    Conn = Analog, Color = UNKNOWN
    DefAssociation = 0x6, Sequence = 0x9
  Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
  Pincap 0x00000010: OUT
    Misc = NO_PRESENCE
  Pin-ctls: 0x40: OUT
  Connection: 1
     0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
  Processing caps: benign=0, ncoeff=127
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Amp-In vals:  [0x80 0x80] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
  Connection: 10
     0x18 0x19 0x1a 0x1b 0x1d 0x15 0x16 0x17 0x12 0x0b
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 10
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Audio Output] wcaps 0x41d: Stereo Amp-Out
  Amp-Out vals:  [0x57 0x57]
  PCM:
    formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
  Connection: 2
     0x25 0x0b
--endcollapse--
!!USB Mixer information
--startcollapse--
USB Mixer: usb_id=0x0c456366, ctrlif=2, ctlerr=0
Card: Sonix Technology Co., Ltd. AUKEY PC-W1 at usb-0000:07:00.3-3, high speed
  Unit: 2
    Control: name="Mic Capture Volume", index=0
    Info: id=2, control=2, cmask=0x1, channels=1, type="S16"
    Volume: min=-24320, max=0, dBmin=-9500, dBmax=0
  Unit: 2
    Control: name="Mic Capture Switch", index=0
    Info: id=2, control=1, cmask=0x0, channels=1, type="INV_BOOLEAN"
    Volume: min=0, max=1, dBmin=0, dBmax=0
--endcollapse--
!!ALSA Device nodes
crw-rw----+ 1 root audio 116, 10 Oct 13 03:17 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 15 Oct 13 03:17 /dev/snd/controlC1
crw-rw----+ 1 root audio 116, 17 Oct 13 03:17 /dev/snd/controlC2
crw-rw----+ 1 root audio 116,  9 Oct 13 03:17 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 14 Oct 13 03:17 /dev/snd/hwC1D0
crw-rw----+ 1 root audio 116,  6 Oct 13 03:17 /dev/snd/pcmC0D10p
crw-rw----+ 1 root audio 116,  7 Oct 13 03:17 /dev/snd/pcmC0D11p
crw-rw----+ 1 root audio 116,  8 Oct 13 03:17 /dev/snd/pcmC0D12p
crw-rw----+ 1 root audio 116,  2 Oct 13 03:17 /dev/snd/pcmC0D3p
crw-rw----+ 1 root audio 116,  3 Oct 13 03:17 /dev/snd/pcmC0D7p
crw-rw----+ 1 root audio 116,  4 Oct 13 03:17 /dev/snd/pcmC0D8p
crw-rw----+ 1 root audio 116,  5 Oct 13 03:17 /dev/snd/pcmC0D9p
crw-rw----+ 1 root audio 116, 12 Oct 13 03:18 /dev/snd/pcmC1D0c
crw-rw----+ 1 root audio 116, 11 Oct 13 03:18 /dev/snd/pcmC1D0p
crw-rw----+ 1 root audio 116, 13 Oct 13 03:17 /dev/snd/pcmC1D2c
crw-rw----+ 1 root audio 116, 16 Oct 13 03:17 /dev/snd/pcmC2D0c
crw-rw----+ 1 root audio 116,  1 Oct 13 03:17 /dev/snd/seq
crw-rw----+ 1 root audio 116, 33 Oct 13 03:17 /dev/snd/timer
/dev/snd/by-id:
total 0
drwxr-xr-x 2 root root  60 Oct 13 03:17 .
drwxr-xr-x 4 root root 440 Oct 13 03:17 ..
lrwxrwxrwx 1 root root  12 Oct 13 03:17 usb-Sonix_Technology_Co.__Ltd._AUKEY_PC-W1_AUKEY_PC-W1-02 -> ../controlC2
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 100 Oct 13 03:17 .
lrwxrwxrwx 1 root root  12 Oct 13 03:17 pci-0000:07:00.3-usb-0:3:1.2 -> ../controlC2
lrwxrwxrwx 1 root root  12 Oct 13 03:17 pci-0000:0a:00.1 -> ../controlC0
lrwxrwxrwx 1 root root  12 Oct 13 03:17 pci-0000:0c:00.4 -> ../controlC1
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
  Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
  Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 12: HDMI 6 [HDMI 6]
  Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 0: ALC1220 Analog [ALC1220 Analog]
  Subdevices: 0/1
ARECORD
**** List of CAPTURE Hardware Devices ****
  Subdevices: 1/1
card 1: Generic [HD-Audio Generic], device 2: ALC1220 Alt Analog [ALC1220 Alt Analog]
  Subdevices: 1/1
card 2: PCW1 [AUKEY PC-W1], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card NVidia
Card hw:0 'NVidia'/'HDA NVidia at 0xfc080000 irq 140'
  Mixer name	: 'Nvidia GPU 92 HDMI/DP'
  Components	: 'HDA:10de0092,38423172,00100100'
  Controls      : 49
  Simple ctrls  : 7
Simple mixer control 'IEC958',0
  Capabilities: pswitch pswitch-joined
  Playback channels: Mono
  Mono: Playback [on]
Simple mixer control 'IEC958',1
  Mono: Playback [on]
Simple mixer control 'IEC958',2
  Mono: Playback [on]
Simple mixer control 'IEC958',3
  Mono: Playback [on]
Simple mixer control 'IEC958',4
  Mono: Playback [on]
Simple mixer control 'IEC958',5
  Mono: Playback [on]
Simple mixer control 'IEC958',6
  Mono: Playback [on]
!!-------Mixer controls for card Generic
Card hw:1 'Generic'/'HD-Audio Generic at 0xfcb00000 irq 142'
  Mixer name	: 'Realtek ALC1220'
  Components	: 'HDA:10ec1220,1458a0c3,00100101'
  Controls      : 39
  Simple ctrls  : 20
Simple mixer control 'Master',0
  Capabilities: pvolume pvolume-joined pswitch pswitch-joined
  Limits: Playback 0 - 87
  Mono: Playback 51 [59%] [-27.00dB] [on]
Simple mixer control 'Headphone',0
  Capabilities: pvolume pswitch
  Mono:
  Front Left: Playback 87 [100%] [0.00dB] [on]
  Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
  Limits: Playback 0 - 255
  Mono:
  Front Left: Playback 253 [99%] [-0.40dB]
  Front Right: Playback 253 [99%] [-0.40dB]
Simple mixer control 'Front',0
  Mono:
Simple mixer control 'Front Mic',0
  Limits: Playback 0 - 31
  Mono:
  Front Left: Playback 0 [0%] [-34.50dB] [off]
  Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
  Capabilities: volume
  Limits: 0 - 3
  Front Left: 1 [33%] [10.00dB]
  Front Right: 1 [33%] [10.00dB]
Simple mixer control 'Surround',0
  Mono:
  Front Left: Playback 0 [0%] [-65.25dB] [off]
  Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'Center',0
  Mono: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'LFE',0
Simple mixer control 'Line',0
  Mono:
Simple mixer control 'Line Boost',0
  Limits: 0 - 3
  Front Left: 0 [0%] [0.00dB]
  Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Capture',0
  Capabilities: cvolume cswitch
  Limits: Capture 0 - 63
  Front Left: Capture 63 [100%] [30.00dB] [on]
  Front Right: Capture 63 [100%] [30.00dB] [on]
Simple mixer control 'Capture',1
  Front Left: Capture 0 [0%] [-17.25dB] [off]
  Front Right: Capture 0 [0%] [-17.25dB] [off]
Simple mixer control 'Auto-Mute Mode',0
  Capabilities: enum
  Items: 'Disabled' 'Enabled'
  Item0: 'Enabled'
Simple mixer control 'Channel Mode',0
  Capabilities: enum
  Items: '2ch' '4ch' '6ch'
  Item0: '2ch'
Simple mixer control 'Input Source',0
  Capabilities: cenum
  Items: 'Front Mic' 'Rear Mic' 'Line'
  Item0: 'Front Mic'
Simple mixer control 'Input Source',1
  Capabilities: cenum
  Item0: 'Front Mic'
Simple mixer control 'Loopback Mixing',0
  Capabilities: enum
  Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
  Mono:
Simple mixer control 'Rear Mic Boost',0
  Limits: 0 - 3
!!-------Mixer controls for card PCW1
Card hw:2 'PCW1'/'Sonix Technology Co., Ltd. AUKEY PC-W1 at usb-0000:07:00.3-3, high speed'
  Mixer name	: 'USB Mixer'
  Components	: 'USB0c45:6366'
  Controls      : 4
  Simple ctrls  : 1
Simple mixer control 'Mic',0
  Capabilities: cvolume cvolume-joined cswitch cswitch-joined
  Capture channels: Mono
  Limits: Capture 0 - 256
  Mono: Capture 256 [100%] [0.00dB] [on]
!!Alsactl output
--startcollapse--
state.NVidia {
	control.1 {
		iface CARD
		name 'HDMI/DP,pcm=3 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.2 {
		iface MIXER
		name 'IEC958 Playback Con Mask'
		value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.3 {
		iface MIXER
		name 'IEC958 Playback Pro Mask'
		value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access read
			type IEC958
			count 1
	control.4 {
		iface MIXER
		name 'IEC958 Playback Default'
		value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			access 'read write'
			type IEC958
			count 1
	control.5 {
		iface MIXER
		name 'IEC958 Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.6 {
		iface PCM
		device 3
		name ELD
		value ''
		comment {
			access 'read volatile'
			type BYTES
			count 0
	control.7 {
		iface CARD
		name 'HDMI/DP,pcm=7 Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.8 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.9 {
		iface MIXER
		index 1
		comment {
			access read
			type IEC958
			count 1
	control.10 {
		iface MIXER
		index 1
		comment {
			access 'read write'
			type IEC958
			count 1
	control.11 {
		iface MIXER
		index 1
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.12 {
		iface PCM
		device 7
		name ELD
		value '100008006d14000100080000000000001e6d095b4c4720556c7472612048440a200907070000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			type BYTES
			count 95
	control.13 {
		iface CARD
		name 'HDMI/DP,pcm=8 Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.14 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.15 {
		iface MIXER
		index 2
		comment {
			access read
			type IEC958
			count 1
	control.16 {
		iface MIXER
		index 2
		comment {
			access 'read write'
			type IEC958
			count 1
	control.17 {
		iface MIXER
		index 2
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.18 {
		iface PCM
		device 8
		name ELD
		value '100008006d14000100200000000000001e6d095b4c4720556c7472612048440a200907070000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
		comment {
			type BYTES
			count 95
	control.19 {
		iface CARD
		name 'HDMI/DP,pcm=9 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.20 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.21 {
		iface MIXER
		index 3
		comment {
			access read
			type IEC958
			count 1
	control.22 {
		iface MIXER
		index 3
		comment {
			access 'read write'
			type IEC958
			count 1
	control.23 {
		iface MIXER
		index 3
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.24 {
		iface PCM
		device 9
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.25 {
		iface CARD
		name 'HDMI/DP,pcm=10 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.26 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.27 {
		iface MIXER
		index 4
		comment {
			access read
			type IEC958
			count 1
	control.28 {
		iface MIXER
		index 4
		comment {
			access 'read write'
			type IEC958
			count 1
	control.29 {
		iface MIXER
		index 4
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.30 {
		iface PCM
		device 10
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.31 {
		iface CARD
		name 'HDMI/DP,pcm=11 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.32 {
		iface MIXER
		index 5
		comment {
			access read
			type IEC958
			count 1
	control.33 {
		iface MIXER
		index 5
		comment {
			access read
			type IEC958
			count 1
	control.34 {
		iface MIXER
		index 5
		comment {
			access 'read write'
			type IEC958
			count 1
	control.35 {
		iface MIXER
		index 5
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.36 {
		iface PCM
		device 11
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.37 {
		iface CARD
		name 'HDMI/DP,pcm=12 Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.38 {
		iface MIXER
		index 6
		comment {
			access read
			type IEC958
			count 1
	control.39 {
		iface MIXER
		index 6
		comment {
			access read
			type IEC958
			count 1
	control.40 {
		iface MIXER
		index 6
		comment {
			access 'read write'
			type IEC958
			count 1
	control.41 {
		iface MIXER
		index 6
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.42 {
		iface PCM
		device 12
		name ELD
		value ''
		comment {
			type BYTES
			count 0
	control.43 {
		iface PCM
		device 3
		name 'Playback Channel Map'
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.44 {
		iface PCM
		device 7
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.45 {
		iface PCM
		device 8
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.46 {
		iface PCM
		device 9
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.47 {
		iface PCM
		device 10
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.48 {
		iface PCM
		device 11
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
	control.49 {
		iface PCM
		device 12
		value.0 0
		value.1 0
		value.2 0
		value.3 0
		value.4 0
		value.5 0
		value.6 0
		value.7 0
		comment {
			access 'read write'
			type INTEGER
			count 8
			range '0 - 36'
state.Generic {
	control.1 {
		iface MIXER
		name 'Channel Mode'
		value '2ch'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 '2ch'
			item.1 '4ch'
			item.2 '6ch'
	control.2 {
		iface MIXER
		name 'Front Playback Volume'
		value.0 87
		value.1 87
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 87'
			dbmin -6525
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.3 {
		iface MIXER
		name 'Front Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.4 {
		iface MIXER
		name 'Surround Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 87'
			dbmin -6525
			dbmax 0
			dbvalue.0 -6525
			dbvalue.1 -6525
	control.5 {
		iface MIXER
		name 'Surround Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.6 {
		iface MIXER
		name 'Center Playback Volume'
		value 0
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 87'
			dbmin -6525
			dbmax 0
			dbvalue.0 -6525
	control.7 {
		iface MIXER
		name 'LFE Playback Volume'
		value 0
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 87'
			dbmin -6525
			dbmax 0
			dbvalue.0 -6525
	control.8 {
		iface MIXER
		name 'Center Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.9 {
		iface MIXER
		name 'LFE Playback Switch'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.10 {
		iface MIXER
		name 'Headphone Playback Volume'
		value.0 87
		value.1 87
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 87'
			dbmin -6525
			dbmax 0
			dbvalue.0 0
			dbvalue.1 0
	control.11 {
		iface MIXER
		name 'Headphone Playback Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.12 {
		iface MIXER
		name 'Loopback Mixing'
		value Disabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.13 {
		iface MIXER
		name 'Front Mic Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.14 {
		iface MIXER
		name 'Front Mic Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.15 {
		iface MIXER
		name 'Rear Mic Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.16 {
		iface MIXER
		name 'Rear Mic Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.17 {
		iface MIXER
		name 'Line Playback Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 31'
			dbmin -3450
			dbmax 1200
			dbvalue.0 -3450
			dbvalue.1 -3450
	control.18 {
		iface MIXER
		name 'Line Playback Switch'
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.19 {
		iface MIXER
		name 'Auto-Mute Mode'
		value Enabled
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 Disabled
			item.1 Enabled
	control.20 {
		iface MIXER
		name 'Input Source'
		value 'Front Mic'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 'Front Mic'
			item.1 'Rear Mic'
			item.2 Line
	control.21 {
		iface MIXER
		name 'Input Source'
		index 1
		value 'Front Mic'
		comment {
			access 'read write'
			type ENUMERATED
			count 1
			item.0 'Front Mic'
			item.1 'Rear Mic'
			item.2 Line
	control.22 {
		iface MIXER
		name 'Capture Volume'
		value.0 63
		value.1 63
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 63'
			dbmin -1725
			dbmax 3000
			dbvalue.0 3000
			dbvalue.1 3000
	control.23 {
		iface MIXER
		name 'Capture Switch'
		value.0 true
		value.1 true
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.24 {
		iface MIXER
		index 1
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 63'
			dbmin -1725
			dbmax 3000
			dbvalue.0 -1725
			dbvalue.1 -1725
	control.25 {
		iface MIXER
		index 1
		value.0 false
		value.1 false
		comment {
			access 'read write'
			type BOOLEAN
			count 2
	control.26 {
		iface MIXER
		name 'Front Mic Boost Volume'
		value.0 1
		value.1 1
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 1000
			dbvalue.1 1000
	control.27 {
		iface MIXER
		name 'Rear Mic Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.28 {
		iface MIXER
		name 'Line Boost Volume'
		value.0 0
		value.1 0
		comment {
			access 'read write'
			type INTEGER
			count 2
			range '0 - 3'
			dbmin 0
			dbmax 3000
			dbvalue.0 0
			dbvalue.1 0
	control.29 {
		iface MIXER
		name 'Master Playback Volume'
		value 51
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 87'
			dbmin -6525
			dbmax 0
			dbvalue.0 -2700
	control.30 {
		iface MIXER
		name 'Master Playback Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.31 {
		iface CARD
		name 'Front Mic Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.32 {
		iface CARD
		name 'Rear Mic Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.33 {
		iface CARD
		name 'Line Jack'
		value false
		comment {
			access read
			type BOOLEAN
			count 1
	control.34 {
		iface CARD
		name 'Line Out Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.35 {
		iface CARD
		name 'Front Headphone Jack'
		value true
		comment {
			access read
			type BOOLEAN
			count 1
	control.36 {
		iface PCM
		value.0 3
		value.1 4
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.37 {
		iface PCM
		name 'Capture Channel Map'
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.38 {
		iface PCM
		device 2
		value.0 0
		value.1 0
		comment {
			access read
			type INTEGER
			count 2
			range '0 - 36'
	control.39 {
		iface MIXER
		name 'PCM Playback Volume'
		value.0 253
		value.1 253
		comment {
			access 'read write user'
			type INTEGER
			count 2
			range '0 - 255'
			tlv '0000000100000008ffffec1400000014'
			dbmin -5100
			dbmax 0
			dbvalue.0 -40
			dbvalue.1 -40
state.PCW1 {
	control.1 {
		iface PCM
		value 0
		comment {
			access read
			type INTEGER
			count 1
			range '0 - 36'
	control.2 {
		iface MIXER
		name 'Mic Capture Switch'
		value true
		comment {
			access 'read write'
			type BOOLEAN
			count 1
	control.3 {
		iface MIXER
		name 'Mic Capture Volume'
		value 256
		comment {
			access 'read write'
			type INTEGER
			count 1
			range '0 - 256'
			dbmin -9500
			dbmax 0
			dbvalue.0 0
	control.4 {
		iface CARD
		name 'Keep Interface'
		value false
		comment {
			access 'read write'
			type BOOLEAN
			count 1
--endcollapse--
!!All Loaded Modules
acpi_cpufreq
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
ccp
cdc_acm
cec
cfg80211
cmac
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
dca
drm
drm_kms_helper
ebtable_filter
ebtables
ecc
ecdh_generic
edac_mce_amd
evdev
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_logitech_dj
hid_logitech_hidpp
i2c_algo_bit
i2c_nvidia_gpu
i2c_piix4
igb
input_leds
ip6_tables
ip6t_REJECT
ip6table_filter
ip6table_mangle
ip6table_nat
ip6table_raw
ip_tables
ipt_REJECT
iptable_filter
iptable_mangle
iptable_nat
iptable_raw
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
k10temp
kvm
kvm_amd
ledtrig_audio
libarc4
libcrc32c
loop
mac80211
mac_hid
mbcache
mc
mousedev
nf_conntrack
nf_defrag_ipv4
nf_defrag_ipv6
nf_nat
nf_reject_ipv4
nf_reject_ipv6
nls_cp437
nls_iso8859_1
nvidia
nvidia_drm
nvidia_modeset
pcspkr
pinctrl_amd
rapl
rc_core
rfcomm
rfkill
rng_core
sg
snd
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_intel
snd_hrtimer
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_rawmidi
snd_seq
snd_seq_device
snd_seq_dummy
snd_timer
snd_usb_audio
snd_usbmidi_lib
soundcore
sp5100_tco
squashfs
syscopyarea
sysfillrect
sysimgblt
typec
typec_ucsi
ucsi_ccg
uinput
usbhid
uvcvideo
vfat
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
wmi
wmi_bmof
x_tables
xhci_hcd
xhci_pci
xhci_pci_renesas
xt_cgroup
xt_mark
xt_multiport
xt_owner
xt_tcpudp
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x04 0x185600f0
0x05 0x185600f0
0x06 0x185600f0
0x07 0x185600f0
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x12 0x403fc000
0x14 0x01014010
0x15 0x411111f0
0x16 0x411111f0
0x17 0x411111f0
0x18 0x01a19030
0x19 0x02a19040
0x1a 0x0181303f
0x1b 0x02214020
0x1d 0x4047c669
0x1e 0x411111f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
Hi :wave:
If you want to disable it, then blacklist it also:
options snd-hda-intel power_save=0 pm_blacklist=true
More information at modinfo snd-hda-intel
I have just attempted this with another image rebuild and after reboot I got:
'true' invalid for parameter 'pm_blacklist'
in dmseg from snd-hda-intel and a failure to load the module. After changing it to
options snd-hda-intel power_save=0 pm_blacklist=Y
and rebooting the module loads successfully, but power save was not disabled.
try using underlines instead of dashes for snd_hda_intel
options snd_hda_intel power_save=0
Thanks for the suggestion, but underscores did not help.
kernel documentation shows the option you have been using is to set power-saving timeout
Advanced Linux Sound Architecture - Driver Configuration guide — The Linux Kernel documentation
power_save
Automatic power-saving timeout (in second, 0 = disable)
Reset HD-audio controller in power-saving mode (default = on)
try changing the modprobe option to power_save_controller=N
I forget my sources now but AFAIK power_save_controller is a subset of power_save. The goal is still to stop the power_save timeout as I have verified the solution to work manually, I am just unable to get it to stick through modprobe.
After spending much too much time on this issue I finally figured it out: seems like some recent TLP or kernel audio driver changes caused the issue. After using auditd to see what was editing the file I found out that tlp was wiping out any changes I did through modprobe or systemd services during boot. To solve the issue all I had to do was edit /etc/tlp.conf to such that the audio section looks like this (I didn’t dig into which line was specifically the culprit, but I seems like TLP may think that my desktop is on battery power?):
# Enable audio power saving for Intel HDA, AC97 devices (timeout in secs).
# A value of 0 disables, >=1 enables power saving (recommended: 1).
# Default: 0 (AC), 1 (BAT)
SOUND_POWER_SAVE_ON_AC=0
SOUND_POWER_SAVE_ON_BAT=0
# Disable controller too (HDA only): Y/N.
# Note: effective only when SOUND_POWER_SAVE_ON_AC/BAT is activated.
# Default: Y
SOUND_POWER_SAVE_CONTROLLER=N
And reboot. This alone solves my issue without any modprobe modifications.
Edit: Having a look at tlp-stat output TLP indeed thinks my desktop computer is running off of battery. Strange. Possible TLP regression?
Edit2:
This did the trick to fix TLP’s incorrect power supply mode detection:
# Operation mode when no power supply can be detected: AC, BAT.
# Concerns some desktop and embedded hardware only.
# Default: <none>
TLP_DEFAULT_MODE=AC
# Operation mode select: 0=depend on power source, 1=always use TLP_DEFAULT_MODE
# Note: use in conjunction with TLP_DEFAULT_MODE=BAT for BAT settings on AC.
# Default: 0
TLP_PERSISTENT_DEFAULT=1
With this the explicit audio power setting changes shouldn’t be needed.
