Iβm unable to boot into SDDM after the latest update. My mhwd -li
looks like this:
Please help me out.
looks like this:
You installed them all ?
no need for video-linux
sudo mhwd -r pci video-linux
Reboot after that.
I uninstalled it. Still nothing. Canβt log in.
Check this, maybe it will help you also: My switch to the 5.10 kernel with update 2020-12-30
Didnβt work. The only problematic thing that I found while following that is the output of mhwd-gpu
is xorg configuration file: ''
. Is it something related to permissions of files in /etc/X11/mhwd.d/
Did you install your video driver using the Hardware Configuration of Manjaro Settings?
That is what mhwd
isβ¦
Yeah. I installed it using mhwd -a pci nonfree 0300
Hmm dot it again ?
Can we reinstall with mhwd ?
What do you mean? Should I reinstall the nonfree drivers?
linux510 doesnβt support nvidia-prime. You may want to use linux54 or linux59.
What should I do if I want to keep using linux510
? Does any proprietary driver work?
It doesnβt really matter if I canβt use prime setup, since I donβt remember ever actually switching to the Intel GPU. I just want to use the nvidia GPU with proprietary drivers.
Not as of now. Maybe Nvidia comes around with a newer driver in 2021 β¦
Thats not what PRIME does⦠regular PRIME by default would be running on the intel, then activate nvidia with prime-run
But either way when it comes to nvidia and their proprietary driver β¦ you are at their whim for whether its βsupportedβ or βworkingβ or βdeprecatedβ etc β¦
Some users mention that video-nvidia
works with linux-510
though.
I tried what @philm said in the main update thread, but Iβm still unable to start SDDM. Iβm not sure itβs related to 5.10 kernel, as 5.4 isnβt working either.
Iβm getting
ls /etc/modprobe.d/
blacklist.conf mhwd-gpu.conf nvidia-drm.conf r8169_blacklist.conf ralink-bt.conf
Is this okay, or is something missing?
This is the output of journalctl -xe -n 100
after running systemctl start sddm
-- Journal begins at Fri 2020-05-29 11:10:21 IST, ends at Fri 2021-01-01 12:28:35 IST. --
Jan 01 12:23:58 sintan-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 01 12:23:58 sintan-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 01 12:23:58 sintan-pc kernel: audit: type=1130 audit(1609484038.020:145): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 01 12:23:58 sintan-pc kernel: audit: type=1131 audit(1609484038.020:146): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 01 12:24:42 sintan-pc syncthing[873]: [GTIW6] INFO: Joined relay relay://172.105.55.151:22067
Jan 01 12:28:22 sintan-pc polkitd[459]: Registered Authentication Agent for unix-process:11241:117558 (system bus name :1.53 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_IN)
Jan 01 12:28:25 sintan-pc audit[11247]: USER_AUTH pid=11247 uid=1000 auid=1000 ses=1 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="sintan" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=sintan-pc addr=? terminal=pts/0 res=success'
Jan 01 12:28:25 sintan-pc dbus-daemon[456]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.55' (uid=0 pid=11247 comm="/usr/lib/polkit-1/polkit-agent-helper-1 sintan ")
Jan 01 12:28:25 sintan-pc dbus-daemon[456]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jan 01 12:28:25 sintan-pc kernel: audit: type=1100 audit(1609484305.546:147): pid=11247 uid=1000 auid=1000 ses=1 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="sintan" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=sintan-pc addr=? terminal=pts/0 res=success'
Jan 01 12:28:25 sintan-pc polkit-agent-helper-1[11247]: pam_systemd_home(polkit-1:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 01 12:28:25 sintan-pc audit[11247]: USER_ACCT pid=11247 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="sintan" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
Jan 01 12:28:25 sintan-pc kernel: audit: type=1101 audit(1609484305.550:148): pid=11247 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="sintan" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
Jan 01 12:28:25 sintan-pc polkitd[459]: Operator of unix-process:11241:117558 successfully authenticated as unix-user:sintan to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.54 [systemctl start sddm] (owned by unix-user:sintan)
Jan 01 12:28:25 sintan-pc systemd[1]: Started Simple Desktop Display Manager.
ββ Subject: A start job for unit sddm.service has finished successfully
ββ Defined-By: systemd
ββ Support: https://forum.manjaro.org/c/support
ββ
ββ A start job for unit sddm.service has finished successfully.
ββ
ββ The job identifier is 2544.
Jan 01 12:28:25 sintan-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 01 12:28:25 sintan-pc kernel: audit: type=1130 audit(1609484305.570:149): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 01 12:28:25 sintan-pc polkitd[459]: Unregistered Authentication Agent for unix-process:11241:117558 (system bus name :1.53, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_IN) (disconnected from bus)
Jan 01 12:28:25 sintan-pc sddm[11274]: Initializing...
Jan 01 12:28:25 sintan-pc sddm[11274]: Starting...
Jan 01 12:28:25 sintan-pc sddm[11274]: Logind interface found
Jan 01 12:28:25 sintan-pc sddm[11274]: Adding new display on vt 1 ...
Jan 01 12:28:25 sintan-pc sddm[11274]: Loading theme configuration from ""
Jan 01 12:28:25 sintan-pc sddm[11274]: Display server starting...
Jan 01 12:28:25 sintan-pc sddm[11274]: Adding cookie to "/var/run/sddm/{38b825c6-ee86-4eb7-b7ad-4b6cdbd9c940}"
Jan 01 12:28:25 sintan-pc sddm[11274]: Running: /usr/bin/X -dpi 115 -auth /var/run/sddm/{38b825c6-ee86-4eb7-b7ad-4b6cdbd9c940} -background none -noreset -displayfd 17 -seat seat0 vt1
Jan 01 12:28:25 sintan-pc kernel: nvidia 0000:01:00.0: Enabling HDA controller
Jan 01 12:28:25 sintan-pc sddm[11274]: Failed to read display number from pipe
Jan 01 12:28:25 sintan-pc audit[11274]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 pid=11274 comm="sddm" exe="/usr/bin/sddm" sig=6 res=1
Jan 01 12:28:26 sintan-pc kernel: audit: type=1701 audit(1609484305.986:150): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=11274 comm="sddm" exe="/usr/bin/sddm" sig=6 res=1
Jan 01 12:28:25 sintan-pc sddm[11274]: Display server failed to start. Exiting
Jan 01 12:28:26 sintan-pc audit: BPF prog-id=22 op=LOAD
Jan 01 12:28:26 sintan-pc kernel: audit: type=1334 audit(1609484306.006:151): prog-id=22 op=LOAD
Jan 01 12:28:26 sintan-pc kernel: audit: type=1334 audit(1609484306.006:152): prog-id=23 op=LOAD
Jan 01 12:28:26 sintan-pc audit: BPF prog-id=23 op=LOAD
Jan 01 12:28:26 sintan-pc systemd[1]: Started Process Core Dump (PID 11296/UID 0).
ββ Subject: A start job for unit systemd-coredump@5-11296-0.service has finished successfully
ββ
ββ A start job for unit systemd-coredump@5-11296-0.service has finished successfully.
ββ
ββ The job identifier is 2653.
Jan 01 12:28:26 sintan-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@5-11296-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 01 12:28:26 sintan-pc kernel: audit: type=1130 audit(1609484306.010:153): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@5-11296-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 01 12:28:26 sintan-pc systemd-coredump[11300]: Process 11274 (sddm) of user 0 dumped core.
Stack trace of thread 11274:
#0 0x00007fe8ed9a8615 raise (libc.so.6 + 0x3d615)
#1 0x00007fe8ed991862 abort (libc.so.6 + 0x26862)
#2 0x00007fe8eddbd9ac _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0x909ac)
#3 0x0000558ba97b0108 n/a (sddm + 0x2a108)
#4 0x0000558ba97f4271 _ZN4SDDM4SeatC2ERK7QStringP7QObject (sddm + 0x6e271)
#5 0x0000558ba97f5ec1 _ZN4SDDM11SeatManager10createSeatERK7QString (sddm + 0x6fec1)
#6 0x0000558ba97f6d03 n/a (sddm + 0x70d03)
#7 0x00007fe8ee019dd6 n/a (libQt5Core.so.5 + 0x2ecdd6)
#8 0x0000558ba97f4ec0 _ZN4SDDM10LogindSeat19canGraphicalChangedEb (sddm + 0x6eec0)
#9 0x00007fe8ee019dd6 n/a (libQt5Core.so.5 + 0x2ecdd6)
#10 0x00007fe8ee97d9e0 _ZN23QDBusPendingCallWatcher8finishedEPS_ (libQt5DBus.so.5 + 0x649e0)
#11 0x00007fe8ee00f582 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2e2582)
#12 0x00007fe8edfe2a50 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x2b5a50)
#13 0x00007fe8edfe5573 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt5Core.so.5 + 0x2b8573)
#14 0x00007fe8ee03c0a4 n/a (libQt5Core.so.5 + 0x30f0a4)
#15 0x00007fe8ecb10a84 g_main_context_dispatch (libglib-2.0.so.0 + 0x52a84)
#16 0x00007fe8ecb649b1 n/a (libglib-2.0.so.0 + 0xa69b1)
#17 0x00007fe8ecb0f2b1 g_main_context_iteration (libglib-2.0.so.0 + 0x512b1)
#18 0x00007fe8ee03b6e1 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x30e6e1)
#19 0x00007fe8edfe13fc _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2b43fc)
#20 0x00007fe8edfe9894 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2bc894)
#21 0x0000558ba97b2f31 main (sddm + 0x2cf31)
#22 0x00007fe8ed993152 __libc_start_main (libc.so.6 + 0x28152)
#23 0x0000558ba97b323e _start (sddm + 0x2d23e)
Stack trace of thread 11288:
#0 0x00007fe8eda6046f __poll (libc.so.6 + 0xf546f)
#1 0x00007fe8ecb6493f n/a (libglib-2.0.so.0 + 0xa693f)
#2 0x00007fe8ecb0f2b1 g_main_context_iteration (libglib-2.0.so.0 + 0x512b1)
#3 0x00007fe8ee03b6e1 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x30e6e1)
#4 0x00007fe8edfe13fc _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2b43fc)
#5 0x00007fe8eddf9d22 _ZN7QThread4execEv (libQt5Core.so.5 + 0xccd22)
#6 0x00007fe8ee930098 n/a (libQt5DBus.so.5 + 0x17098)
#7 0x00007fe8eddfaf0f n/a (libQt5Core.so.5 + 0xcdf0f)
#8 0x00007fe8ed9523e9 start_thread (libpthread.so.0 + 0x93e9)
#9 0x00007fe8eda6b293 __clone (libc.so.6 + 0x100293)
ββ Subject: Process 11274 (sddm) dumped core
ββ Documentation: man:core(5)
ββ
ββ Process 11274 (sddm) crashed and dumped core.
ββ
ββ This usually indicates a programming error in the crashing program and
ββ should be reported to its vendor as a bug.
Jan 01 12:28:26 sintan-pc systemd[1]: sddm.service: Main process exited, code=dumped, status=6/ABRT
ββ Subject: Unit process exited
ββ
ββ An ExecStart= process belonging to unit sddm.service has exited.
ββ
ββ The process' exit code is 'dumped' and its exit status is 6.
Jan 01 12:28:26 sintan-pc kernel: audit: type=1131 audit(1609484306.200:154): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Jan 01 12:28:26 sintan-pc kernel: audit: type=1131 audit(1609484306.203:155): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@5-11296-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 01 12:28:26 sintan-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Jan 01 12:28:26 sintan-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@5-11296-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 01 12:28:26 sintan-pc systemd[1]: sddm.service: Failed with result 'core-dump'.
ββ Subject: Unit failed
ββ
ββ The unit sddm.service has entered the 'failed' state with result 'core-dump'.
Jan 01 12:28:26 sintan-pc systemd[1]: systemd-coredump@5-11296-0.service: Succeeded.
ββ Subject: Unit succeeded
ββ
ββ The unit systemd-coredump@5-11296-0.service has successfully entered the 'dead' state.
Jan 01 12:28:26 sintan-pc audit: BPF prog-id=23 op=UNLOAD
Jan 01 12:28:26 sintan-pc audit: BPF prog-id=22 op=UNLOAD
Jan 01 12:28:26 sintan-pc kernel: audit: type=1334 audit(1609484306.363:156): prog-id=23 op=UNLOAD
Jan 01 12:28:26 sintan-pc systemd[1]: sddm.service: Scheduled restart job, restart counter is at 1.
ββ Subject: Automatic restarting of a unit has been scheduled
ββ
ββ Automatic restarting of the unit sddm.service has been scheduled, as the result for
ββ the configured Restart= setting for the unit.
Jan 01 12:28:26 sintan-pc systemd[1]: Stopped Simple Desktop Display Manager.
ββ Subject: A stop job for unit sddm.service has finished
ββ
ββ A stop job for unit sddm.service has finished.
ββ
ββ The job identifier is 2662 and the job result is done.
Jan 01 12:28:26 sintan-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 01 12:28:26 sintan-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 01 12:28:26 sintan-pc systemd[1]: Started Simple Desktop Display Manager.
ββ
ββ
ββ The job identifier is 2662.
Jan 01 12:28:26 sintan-pc sddm[11314]: Initializing...
Jan 01 12:28:26 sintan-pc sddm[11314]: Starting...
Jan 01 12:28:26 sintan-pc sddm[11314]: Logind interface found
Jan 01 12:28:26 sintan-pc sddm[11314]: Adding new display on vt 1 ...
Jan 01 12:28:26 sintan-pc sddm[11314]: Loading theme configuration from ""
Jan 01 12:28:26 sintan-pc sddm[11314]: Display server starting...
Jan 01 12:28:26 sintan-pc sddm[11314]: Adding cookie to "/var/run/sddm/{6878ee7d-ec78-4fa0-8086-9ab8cf3c967e}"
Jan 01 12:28:26 sintan-pc sddm[11314]: Running: /usr/bin/X -dpi 115 -auth /var/run/sddm/{6878ee7d-ec78-4fa0-8086-9ab8cf3c967e} -background none -noreset -displayfd 17 -seat seat0 vt1
Jan 01 12:28:26 sintan-pc kernel: nvidia 0000:01:00.0: Enabling HDA controller
Jan 01 12:28:26 sintan-pc sddm[11314]: Failed to read display number from pipe
Jan 01 12:28:26 sintan-pc audit[11314]: ANOM_ABEND auid=4294967295 uid=0 gid=0 ses=4294967295 pid=11314 comm="sddm" exe="/usr/bin/sddm" sig=6 res=1
Jan 01 12:28:26 sintan-pc sddm[11314]: Display server failed to start. Exiting
Jan 01 12:28:27 sintan-pc audit: BPF prog-id=24 op=LOAD
Jan 01 12:28:27 sintan-pc audit: BPF prog-id=25 op=LOAD
Jan 01 12:28:27 sintan-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@6-11319-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 01 12:28:27 sintan-pc systemd[1]: Started Process Core Dump (PID 11319/UID 0).
ββ Subject: A start job for unit systemd-coredump@6-11319-0.service has finished successfully
ββ
ββ A start job for unit systemd-coredump@6-11319-0.service has finished successfully.
ββ
ββ The job identifier is 2771.
Jan 01 12:28:27 sintan-pc systemd-coredump[11322]: Process 11314 (sddm) of user 0 dumped core.
Stack trace of thread 11314:
#0 0x00007fb6c7e52615 raise (libc.so.6 + 0x3d615)
#1 0x00007fb6c7e3b862 abort (libc.so.6 + 0x26862)
#2 0x00007fb6c82679ac _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0x909ac)
#3 0x000055fb886bc108 n/a (sddm + 0x2a108)
#4 0x000055fb88700271 _ZN4SDDM4SeatC2ERK7QStringP7QObject (sddm + 0x6e271)
#5 0x000055fb88701ec1 _ZN4SDDM11SeatManager10createSeatERK7QString (sddm + 0x6fec1)
#6 0x000055fb88702d03 n/a (sddm + 0x70d03)
#7 0x00007fb6c84c3dd6 n/a (libQt5Core.so.5 + 0x2ecdd6)
#8 0x000055fb88700ec0 _ZN4SDDM10LogindSeat19canGraphicalChangedEb (sddm + 0x6eec0)
#9 0x00007fb6c84c3dd6 n/a (libQt5Core.so.5 + 0x2ecdd6)
#10 0x00007fb6c8e279e0 _ZN23QDBusPendingCallWatcher8finishedEPS_ (libQt5DBus.so.5 + 0x649e0)
#11 0x00007fb6c84b9582 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2e2582)
#12 0x00007fb6c848ca50 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x2b5a50)
#13 0x00007fb6c848f573 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt5Core.so.5 + 0x2b8573)
#14 0x00007fb6c84e60a4 n/a (libQt5Core.so.5 + 0x30f0a4)
#15 0x00007fb6c6fbaa84 g_main_context_dispatch (libglib-2.0.so.0 + 0x52a84)
#16 0x00007fb6c700e9b1 n/a (libglib-2.0.so.0 + 0xa69b1)
#17 0x00007fb6c6fb92b1 g_main_context_iteration (libglib-2.0.so.0 + 0x512b1)
#18 0x00007fb6c84e56e1 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x30e6e1)
#19 0x00007fb6c848b3fc _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2b43fc)
#20 0x00007fb6c8493894 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2bc894)
#21 0x000055fb886bef31 main (sddm + 0x2cf31)
#22 0x00007fb6c7e3d152 __libc_start_main (libc.so.6 + 0x28152)
#23 0x000055fb886bf23e _start (sddm + 0x2d23e)
Stack trace of thread 11315:
#0 0x00007fb6c7f0a46f __poll (libc.so.6 + 0xf546f)
#1 0x00007fb6c700e93f n/a (libglib-2.0.so.0 + 0xa693f)
#2 0x00007fb6c6fb92b1 g_main_context_iteration (libglib-2.0.so.0 + 0x512b1)
#3 0x00007fb6c84e56e1 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x30e6e1)
#4 0x00007fb6c848b3fc _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2b43fc)
#5 0x00007fb6c82a3d22 _ZN7QThread4execEv (libQt5Core.so.5 + 0xccd22)
#6 0x00007fb6c8dda098 n/a (libQt5DBus.so.5 + 0x17098)
#7 0x00007fb6c82a4f0f n/a (libQt5Core.so.5 + 0xcdf0f)
#8 0x00007fb6c7dfc3e9 start_thread (libpthread.so.0 + 0x93e9)
#9 0x00007fb6c7f15293 __clone (libc.so.6 + 0x100293)
ββ Subject: Process 11314 (sddm) dumped core
ββ
ββ Process 11314 (sddm) crashed and dumped core.
ββ
Jan 01 12:28:27 sintan-pc systemd[1]: sddm.service: Main process exited, code=dumped, status=6/ABRT
ββ
ββ
Jan 01 12:28:27 sintan-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Jan 01 12:28:27 sintan-pc systemd[1]: sddm.service: Failed with result 'core-dump'.
ββ
Jan 01 12:28:27 sintan-pc systemd[1]: systemd-coredump@6-11319-0.service: Succeeded.
ββ
ββ The unit systemd-coredump@6-11319-0.service has successfully entered the 'dead' state.
Jan 01 12:28:27 sintan-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@6-11319-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 01 12:28:27 sintan-pc audit: BPF prog-id=25 op=UNLOAD
Jan 01 12:28:27 sintan-pc audit: BPF prog-id=24 op=UNLOAD
Jan 01 12:28:27 sintan-pc systemd[1]: sddm.service: Scheduled restart job, restart counter is at 2.
ββ
Jan 01 12:28:27 sintan-pc systemd[1]: Stopped Simple Desktop Display Manager.
ββ
ββ
ββ The job identifier is 2780 and the job result is done.
Jan 01 12:28:27 sintan-pc audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 01 12:28:27 sintan-pc audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jan 01 12:28:27 sintan-pc systemd[1]: sddm.service: Start request repeated too quickly.
ββ
Jan 01 12:28:27 sintan-pc systemd[1]: Failed to start Simple Desktop Display Manager.
ββ Subject: A start job for unit sddm.service has failed
ββ
ββ A start job for unit sddm.service has finished with a failure.
ββ
ββ The job identifier is 2780 and the job result is failed.
Jan 01 12:28:32 sintan-pc polkitd[459]: Registered Authentication Agent for unix-process:11381:118608 (system bus name :1.61 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_IN)
Jan 01 12:28:35 sintan-pc audit[11387]: USER_AUTH pid=11387 uid=1000 auid=1000 ses=1 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="sintan" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=sintan-pc addr=? terminal=pts/0 res=success'
Jan 01 12:28:35 sintan-pc kernel: kauditd_printk_skb: 14 callbacks suppressed
Jan 01 12:28:35 sintan-pc kernel: audit: type=1100 audit(1609484315.518:171): pid=11387 uid=1000 auid=1000 ses=1 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="sintan" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=sintan-pc addr=? terminal=pts/0 res=success'
Jan 01 12:28:35 sintan-pc dbus-daemon[456]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.63' (uid=0 pid=11387 comm="/usr/lib/polkit-1/polkit-agent-helper-1 sintan ")
Jan 01 12:28:35 sintan-pc dbus-daemon[456]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Jan 01 12:28:35 sintan-pc polkit-agent-helper-1[11387]: pam_systemd_home(polkit-1:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Jan 01 12:28:35 sintan-pc kernel: audit: type=1101 audit(1609484315.521:172): pid=11387 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="sintan" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
Jan 01 12:28:35 sintan-pc audit[11387]: USER_ACCT pid=11387 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="sintan" exe="/usr/lib/polkit-1/polkit-agent-helper-1" hostname=? addr=? terminal=? res=success'
Jan 01 12:28:35 sintan-pc polkitd[459]: Operator of unix-process:11381:118608 successfully authenticated as unix-user:sintan to gain TEMPORARY authorization for action org.freedesktop.systemd1.manage-units for system-bus-name::1.62 [systemctl start sddm] (owned by unix-user:sintan)
Jan 01 12:28:35 sintan-pc systemd[1]: sddm.service: Start request repeated too quickly.
Jan 01 12:28:35 sintan-pc systemd[1]: sddm.service: Failed with result 'core-dump'.
ββ
Jan 01 12:28:35 sintan-pc systemd[1]: Failed to start Simple Desktop Display Manager.
ββ
ββ
ββ The job identifier is 2889 and the job result is failed.
Jan 01 12:28:35 sintan-pc polkitd[459]: Unregistered Authentication Agent for unix-process:11381:118608 (system bus name :1.61, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_IN) (disconnected from bus)
Maybe it helps.
I doubt that will be helpful as it does not provide info on the driverβ¦
You might check the output of sudo dmesg --human with errors related to your GPU.
Besides it would also help to have detailed info about your system, see:
I would personally advice on using the manjaro-log-helper
utility
Okay, here are the related outputs.
sudo dmesg --human
[Jan 1 16:56] microcode: microcode updated early to revision 0xe0, date = 2020-06-17
[ +0.000000] Linux version 5.10.2-2-MANJARO (builduser@LEGION) (gcc (GCC) 10.2.0, GNU ld (GNU Binutils) 2.35.1) #1 SMP PREEMPT Tue Dec 22 08:14:42 UTC 2020
[ +0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=fe64fafd-1c2a-4b55-846f-c264196ff166 rw nomce "acpi_osi=Windows 2018" quiet resume=UUID=4517ac81-4ac6-42a0-8e7a-a5870b5f98df
[ +0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ +0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ +0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ +0.000000] x86/fpu: Supporting XSAVE feature 0x008: 'MPX bounds registers'
[ +0.000000] x86/fpu: Supporting XSAVE feature 0x010: 'MPX CSR'
[ +0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ +0.000000] x86/fpu: xstate_offset[3]: 832, xstate_sizes[3]: 64
[ +0.000000] x86/fpu: xstate_offset[4]: 896, xstate_sizes[4]: 64
[ +0.000000] x86/fpu: Enabled xstate features 0x1f, context size is 960 bytes, using 'compacted' format.
[ +0.000000] BIOS-provided physical RAM map:
[ +0.000000] BIOS-e820: [mem 0x0000000000000000-0x0000000000057fff] usable
[ +0.000000] BIOS-e820: [mem 0x0000000000058000-0x0000000000058fff] reserved
[ +0.000000] BIOS-e820: [mem 0x0000000000059000-0x000000000009dfff] usable
[ +0.000000] BIOS-e820: [mem 0x000000000009e000-0x00000000000fffff] reserved
[ +0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000006420cfff] usable
[ +0.000000] BIOS-e820: [mem 0x000000006420d000-0x000000006420dfff] ACPI NVS
[ +0.000000] BIOS-e820: [mem 0x000000006420e000-0x000000006420efff] reserved
[ +0.000000] BIOS-e820: [mem 0x000000006420f000-0x000000007bd4dfff] usable
[ +0.000000] BIOS-e820: [mem 0x000000007bd4e000-0x000000007c09dfff] type 20
[ +0.000000] BIOS-e820: [mem 0x000000007c09e000-0x000000007c88dfff] reserved
[ +0.000000] BIOS-e820: [mem 0x000000007c88e000-0x000000007cf7dfff] ACPI NVS
[ +0.000000] BIOS-e820: [mem 0x000000007cf7e000-0x000000007cffdfff] ACPI data
[ +0.000000] BIOS-e820: [mem 0x000000007cffe000-0x000000007cffefff] usable
[ +0.000000] BIOS-e820: [mem 0x000000007cfff000-0x000000007fffffff] reserved
[ +0.000000] BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
[ +0.000000] BIOS-e820: [mem 0x00000000fd000000-0x00000000fe7fffff] reserved
[ +0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ +0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ +0.000000] BIOS-e820: [mem 0x00000000fed10000-0x00000000fed19fff] reserved
[ +0.000000] BIOS-e820: [mem 0x00000000fed84000-0x00000000fed84fff] reserved
[ +0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ +0.000000] BIOS-e820: [mem 0x00000000ffa00000-0x00000000ffffffff] reserved
[ +0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000027effffff] usable
[ +0.000000] NX (Execute Disable) protection: active
[ +0.000000] efi: EFI v2.50 by INSYDE Corp.
[ +0.000000] efi: ACPI 2.0=0x7cffd014 SMBIOS=0x7c0d8000 SMBIOS 3.0=0x7c0d6000 ESRT=0x7c0d3c58 MEMATTR=0x6c9a1018
[ +0.000000] SMBIOS 3.0.0 present.
[ +0.000000] DMI: HP HP Pavilion Laptop 14-bf1xx/83CE, BIOS F.31 10/30/2017
[ +0.000000] tsc: Detected 2000.000 MHz processor
[ +0.000000] tsc: Detected 1999.968 MHz TSC
[ +0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ +0.000004] e820: remove [mem 0x000a0000-0x000fffff] usable
[ +0.000011] last_pfn = 0x27f000 max_arch_pfn = 0x400000000
[ +0.000006] MTRR default type: write-back
[ +0.000001] MTRR fixed ranges enabled:
[ +0.000002] 00000-9FFFF write-back
[ +0.000001] A0000-BFFFF uncachable
[ +0.000002] C0000-FFFFF write-protect
[ +0.000001] MTRR variable ranges enabled:
[ +0.000002] 0 base 0080000000 mask 7F80000000 uncachable
[ +0.000002] 1 base 007E000000 mask 7FFE000000 uncachable
[ +0.000001] 2 base 007D800000 mask 7FFF800000 uncachable
[ +0.000001] 3 disabled
[ +0.000001] 4 disabled
[ +0.000001] 5 disabled
[ +0.000001] 6 disabled
[ +0.000001] 7 disabled
[ +0.000001] 8 disabled
[ +0.000001] 9 disabled
[ +0.000733] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ +0.000546] last_pfn = 0x7cfff max_arch_pfn = 0x400000000
[ +0.017470] esrt: Reserving ESRT space from 0x000000007c0d3c58 to 0x000000007c0d3c90.
[ +0.000011] check: Scanning 1 areas for low memory corruption
[ +0.000006] Using GB pages for direct mapping
[ +0.000630] Secure boot could not be determined
[ +0.000002] RAMDISK: [mem 0x36b4b000-0x3759cfff]
[ +0.000008] ACPI: Early table checksum verification disabled
[ +0.000004] ACPI: RSDP 0x000000007CFFD014 000024 (v02 HPQOEM)
[ +0.000006] ACPI: XSDT 0x000000007CFB4188 000144 (v01 HPQOEM SLIC-MPC 00000000 HP 01000013)
[ +0.000008] ACPI: FACP 0x000000007CFDD000 00010C (v05 HPQOEM SLIC-MPC 00000000 HP 00040000)
[ +0.000007] ACPI: DSDT 0x000000007CFB8000 021283 (v02 HPQOEM SLIC-MPC 00000000 ACPI 00040000)
[ +0.000005] ACPI: FACS 0x000000007CF59000 000040
[ +0.000005] ACPI: UEFI 0x000000007CFFC000 000236 (v01 HPQOEM INSYDE 00000001 HP 00040000)
[ +0.000004] ACPI: UEFI 0x000000007CFFB000 000042 (v01 HPQOEM INSYDE 00000002 HP 00040000)
[ +0.000005] ACPI: SSDT 0x000000007CFF3000 007764 (v01 HPQOEM INSYDE 00001000 ACPI 00040000)
[ +0.000005] ACPI: MSDM 0x000000007CFF2000 000055 (v03 HPQOEM SLIC-MPC 00000001 HP 00040000)
[ +0.000004] ACPI: SSDT 0x000000007CFF1000 0004C3 (v02 HPQOEM INSYDE 00001000 ACPI 00040000)
[ +0.000005] ACPI: SSDT 0x000000007CFF0000 000046 (v02 HPQOEM INSYDE 00003000 ACPI 00040000)
[ +0.000005] ACPI: TPM2 0x000000007CFEF000 000034 (v03 HPQOEM INSYDE 00000000 HP 00040000)
[ +0.000004] ACPI: SSDT 0x000000007CFEB000 003247 (v02 HPQOEM INSYDE 00003000 ACPI 00040000)
[ +0.000005] ACPI: SSDT 0x000000007CFE2000 008832 (v02 HPQOEM INSYDE 00001000 ACPI 00040000)
[ +0.000004] ACPI: ASF! 0x000000007CFE1000 0000A5 (v32 HPQOEM INSYDE 00000001 HP 00040000)
[ +0.000005] ACPI: ASPT 0x000000007CFE0000 000034 (v07 HPQOEM INSYDE 00000001 HP 00040000)
[ +0.000005] ACPI: BOOT 0x000000007CFDF000 000028 (v01 HPQOEM INSYDE 00000001 HP 00040000)
[ +0.000005] ACPI: DBGP 0x000000007CFDE000 000034 (v01 HPQOEM SLIC-MPC 00000001 HP 00040000)
[ +0.000004] ACPI: HPET 0x000000007CFDC000 000038 (v01 HPQOEM INSYDE 00000001 HP 00040000)
[ +0.000005] ACPI: APIC 0x000000007CFDB000 0000BC (v03 HPQOEM SLIC-MPC 00000001 HP 00040000)
[ +0.000004] ACPI: MCFG 0x000000007CFDA000 00003C (v01 HPQOEM INSYDE 00000001 HP 00040000)
[ +0.000005] ACPI: SSDT 0x000000007CFB7000 000517 (v02 HPQOEM INSYDE 00000000 ACPI 00040000)
[ +0.000004] ACPI: SSDT 0x000000007CFB6000 000E24 (v02 HPQOEM INSYDE 00001000 ACPI 00040000)
[ +0.000005] ACPI: SSDT 0x000000007CFB5000 0001BC (v02 HPQOEM INSYDE 00001000 ACPI 00040000)
[ +0.000004] ACPI: SSDT 0x000000007CFB3000 00018E (v02 HPQOEM INSYDE 00001000 ACPI 00040000)
[ +0.000005] ACPI: LPIT 0x000000007CFB2000 000094 (v01 HPQOEM INSYDE 00000000 HP 00040000)
[ +0.000005] ACPI: WSMT 0x000000007CFB1000 000028 (v01 HPQOEM INSYDE 00000000 HP 00040000)
[ +0.000004] ACPI: SSDT 0x000000007CFB0000 00029F (v02 HPQOEM INSYDE 00000000 ACPI 00040000)
[ +0.000005] ACPI: SSDT 0x000000007CFAF000 000346 (v01 HPQOEM INSYDE 00000000 ACPI 00040000)
[ +0.000004] ACPI: SSDT 0x000000007CFAB000 003002 (v02 HPQOEM INSYDE 00001000 ACPI 00040000)
[ +0.000005] ACPI: SSDT 0x000000007CFAA000 00051E (v02 HPQOEM INSYDE 00001000 ACPI 00040000)
[ +0.000004] ACPI: DBGP 0x000000007CFA9000 000034 (v01 HPQOEM SLIC-MPC 00000002 HP 00040000)
[ +0.000005] ACPI: DBG2 0x000000007CFA8000 000054 (v00 HPQOEM INSYDE 00000002 HP 00040000)
[ +0.000005] ACPI: SSDT 0x000000007CFA6000 0010B0 (v02 HPQOEM INSYDE 00001000 ACPI 00040000)
[ +0.000004] ACPI: SSDT 0x000000007CFA5000 000EDE (v02 HPQOEM INSYDE 00003000 ACPI 00040000)
[ +0.000005] ACPI: SSDT 0x000000007CFA1000 0038C9 (v01 HPQOEM INSYDE 00001000 ACPI 00040000)
[ +0.000005] ACPI: DMAR 0x000000007CFA0000 0000A8 (v01 HPQOEM INSYDE 00000001 HP 00040000)
[ +0.000004] ACPI: NHLT 0x000000007CF9F000 00002D (v00 HPQOEM INSYDE 00000002 HP 00040000)
[ +0.000005] ACPI: FPDT 0x000000007CF9E000 000044 (v01 HPQOEM SLIC-MPC 00000002 HP 00040000)
[ +0.000004] ACPI: BGRT 0x000000007CF9D000 000038 (v01 HPQOEM INSYDE 00000001 HP 00040000)
[ +0.000011] ACPI: Local APIC address 0xfee00000
[ +0.000098] No NUMA configuration found
[ +0.000002] Faking a node at [mem 0x0000000000000000-0x000000027effffff]
[ +0.000005] NODE_DATA(0) allocated [mem 0x27effc000-0x27effffff]
[ +0.030777] Zone ranges:
[ +0.000001] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ +0.000003] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ +0.000002] Normal [mem 0x0000000100000000-0x000000027effffff]
[ +0.000002] Device empty
[ +0.000001] Movable zone start for each node
[ +0.000002] Early memory node ranges
[ +0.000001] node 0: [mem 0x0000000000001000-0x0000000000057fff]
[ +0.000001] node 0: [mem 0x0000000000059000-0x000000000009dfff]
[ +0.000002] node 0: [mem 0x0000000000100000-0x000000006420cfff]
[ +0.000001] node 0: [mem 0x000000006420f000-0x000000007bd4dfff]
[ +0.000001] node 0: [mem 0x000000007cffe000-0x000000007cffefff]
[ +0.000001] node 0: [mem 0x0000000100000000-0x000000027effffff]
[ +0.000317] Zeroed struct page in unavailable ranges: 21271 pages
[ +0.000002] Initmem setup node 0 [mem 0x0000000000001000-0x000000027effffff]
[ +0.000008] On node 0 totalpages: 2075881
[ +0.000002] DMA zone: 64 pages used for memmap
[ +0.000001] DMA zone: 22 pages reserved
[ +0.000002] DMA zone: 3996 pages, LIFO batch:0
[ +0.000041] DMA32 zone: 7862 pages used for memmap
[ +0.000002] DMA32 zone: 503117 pages, LIFO batch:63
[ +0.006679] Normal zone: 24512 pages used for memmap
[ +0.000002] Normal zone: 1568768 pages, LIFO batch:63
[ +0.023641] Reserving Intel graphics memory at [mem 0x7e000000-0x7fffffff]
[ +0.000153] ACPI: PM-Timer IO Port: 0x1808
[ +0.000002] ACPI: Local APIC address 0xfee00000
[ +0.000009] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ +0.000002] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ +0.000001] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ +0.000001] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[ +0.000001] ACPI: LAPIC_NMI (acpi_id[0x05] high edge lint[0x1])
[ +0.000001] ACPI: LAPIC_NMI (acpi_id[0x06] high edge lint[0x1])
[ +0.000002] ACPI: LAPIC_NMI (acpi_id[0x07] high edge lint[0x1])
[ +0.000001] ACPI: LAPIC_NMI (acpi_id[0x08] high edge lint[0x1])
[ +0.000028] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ +0.000003] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ +0.000002] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ +0.000002] ACPI: IRQ0 used by override.
[ +0.000002] ACPI: IRQ9 used by override.
[ +0.000003] Using ACPI (MADT) for SMP configuration information
[ +0.000002] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ +0.000009] e820: update [mem 0x6c41c000-0x6c42ffff] usable ==> reserved
[ +0.000014] TSC deadline timer available
[ +0.000001] smpboot: Allowing 8 CPUs, 0 hotplug CPUs
[ +0.000028] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ +0.000003] PM: hibernation: Registered nosave memory: [mem 0x00058000-0x00058fff]
[ +0.000002] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x000fffff]
[ +0.000003] PM: hibernation: Registered nosave memory: [mem 0x6420d000-0x6420dfff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0x6420e000-0x6420efff]
[ +0.000002] PM: hibernation: Registered nosave memory: [mem 0x6c41c000-0x6c42ffff]
[ +0.000002] PM: hibernation: Registered nosave memory: [mem 0x7bd4e000-0x7c09dfff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0x7c09e000-0x7c88dfff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0x7c88e000-0x7cf7dfff]
[ +0.000003] PM: hibernation: Registered nosave memory: [mem 0x7cf7e000-0x7cffdfff]
[ +0.000002] PM: hibernation: Registered nosave memory: [mem 0x7cfff000-0x7fffffff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0x80000000-0xdfffffff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfcffffff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfd000000-0xfe7fffff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfe800000-0xfebfffff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfecfffff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed0ffff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfed1a000-0xfed83fff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfed84000-0xfed84fff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfed85000-0xfedfffff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xff9fffff]
[ +0.000001] PM: hibernation: Registered nosave memory: [mem 0xffa00000-0xffffffff]
[ +0.000003] [mem 0x80000000-0xdfffffff] available for PCI devices
[ +0.000001] Booting paravirtualized kernel on bare hardware
[ +0.000004] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ +0.007795] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:8 nr_node_ids:1
[ +0.000314] percpu: Embedded 56 pages/cpu s192512 r8192 d28672 u262144
[ +0.000015] pcpu-alloc: s192512 r8192 d28672 u262144 alloc=1*2097152
[ +0.000004] pcpu-alloc: [0] 0 1 2 3 4 5 6 7
[ +0.000031] Built 1 zonelists, mobility grouping on. Total pages: 2043421
[ +0.000001] Policy zone: Normal
[ +0.000002] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=fe64fafd-1c2a-4b55-846f-c264196ff166 rw nomce "acpi_osi=Windows 2018" quiet resume=UUID=4517ac81-4ac6-42a0-8e7a-a5870b5f98df
[ +0.000920] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ +0.000416] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ +0.000111] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[ +0.042978] Memory: 8012152K/8303524K available (14344K kernel code, 2065K rwdata, 4832K rodata, 1720K init, 4232K bss, 291112K reserved, 0K cma-reserved)
[ +0.000010] random: get_random_u64 called from __kmem_cache_create+0x26/0x520 with crng_init=0
[ +0.000179] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ +0.000019] Kernel/User page tables isolation: enabled
[ +0.000025] ftrace: allocating 42041 entries in 165 pages
[ +0.021327] ftrace: allocated 165 pages with 4 groups
[ +0.000143] rcu: Preemptible hierarchical RCU implementation.
[ +0.000001] rcu: RCU dyntick-idle grace-period acceleration is enabled.
[ +0.000002] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=8.
[ +0.000001] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ +0.000002] Trampoline variant of Tasks RCU enabled.
[ +0.000000] Rude variant of Tasks RCU enabled.
[ +0.000001] Tracing variant of Tasks RCU enabled.
[ +0.000002] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ +0.000001] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ +0.005677] NR_IRQS: 20736, nr_irqs: 2048, preallocated irqs: 16
[ +0.000632] Console: colour dummy device 80x25
[ +0.000021] printk: console [tty0] enabled
[ +0.000025] ACPI: Core revision 20200925
[ +0.000526] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[ +0.000069] APIC: Switch to symmetric I/O mode setup
[ +0.000003] DMAR: Host address width 39
[ +0.000002] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[ +0.000007] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[ +0.000002] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[ +0.000005] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[ +0.000001] DMAR: RMRR base: 0x0000007c799000 end: 0x0000007c7b8fff
[ +0.000002] DMAR: RMRR base: 0x0000007d800000 end: 0x0000007fffffff
[ +0.000003] DMAR-IR: IOAPIC id 2 under DRHD base 0xfed91000 IOMMU 1
[ +0.000001] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[ +0.000001] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ +0.001647] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ +0.000002] x2apic enabled
[ +0.000013] Switched APIC routing to cluster x2apic.
[ +0.004021] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ +0.014183] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x39a8208cdd2, max_idle_ns: 881590748921 ns
[ +0.000005] Calibrating delay loop (skipped), value calculated using timer frequency.. 4001.60 BogoMIPS (lpj=6666560)
[ +0.000004] pid_max: default: 32768 minimum: 301
[ +0.003378] LSM: Security Framework initializing
[ +0.000009] Yama: becoming mindful.
[ +0.000043] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ +0.000016] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ +0.000333] x86/cpu: VMX (outside TXT) disabled by BIOS
[ +0.000047] process: using mwait in idle threads
[ +0.000004] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[ +0.000001] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[ +0.000004] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ +0.000002] Spectre V2 : Mitigation: Full generic retpoline
[ +0.000001] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ +0.000001] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ +0.000002] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ +0.000001] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[ +0.000002] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[ +0.000008] SRBDS: Mitigation: Microcode
[ +0.000001] MDS: Mitigation: Clear CPU buffers
[ +0.000340] Freeing SMP alternatives memory: 36K
[ +0.002587] smpboot: CPU0: Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz (family: 0x6, model: 0x8e, stepping: 0xa)
[ +0.000135] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[ +0.000018] ... version: 4
[ +0.000000] ... bit width: 48
[ +0.000001] ... generic registers: 4
[ +0.000002] ... value mask: 0000ffffffffffff
[ +0.000000] ... max period: 00007fffffffffff
[ +0.000001] ... fixed-purpose events: 3
[ +0.000001] ... event mask: 000000070000000f
[ +0.000165] rcu: Hierarchical SRCU implementation.
[ +0.001240] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ +0.000109] smp: Bringing up secondary CPUs ...
[ +0.000140] x86: Booting SMP configuration:
[ +0.000002] .... node #0, CPUs: #1 #2 #3 #4
[ +0.012185] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ +0.000000] #5 #6 #7
[ +0.002941] smp: Brought up 1 node, 8 CPUs
[ +0.000000] smpboot: Max logical packages: 1
[ +0.000000] smpboot: Total of 8 processors activated (32012.80 BogoMIPS)
[ +0.003309] devtmpfs: initialized
[ +0.000000] x86/mm: Memory block size: 128MB
[ +0.000454] PM: Registering ACPI NVS region [mem 0x6420d000-0x6420dfff] (4096 bytes)
[ +0.000000] PM: Registering ACPI NVS region [mem 0x7c88e000-0x7cf7dfff] (7274496 bytes)
[ +0.000000] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ +0.000000] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ +0.000000] pinctrl core: initialized pinctrl subsystem
[ +0.000000] PM: RTC time: 11:26:42, date: 2021-01-01
[ +0.000000] NET: Registered protocol family 16
[ +0.000000] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ +0.000000] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ +0.000075] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ +0.000015] audit: initializing netlink subsys (disabled)
[ +0.000015] audit: type=2000 audit(1609500401.046:1): state=initialized audit_enabled=0 res=1
[ +0.000000] thermal_sys: Registered thermal governor 'fair_share'
[ +0.000000] thermal_sys: Registered thermal governor 'bang_bang'
[ +0.000000] thermal_sys: Registered thermal governor 'step_wise'
[ +0.000000] thermal_sys: Registered thermal governor 'user_space'
[ +0.000000] thermal_sys: Registered thermal governor 'power_allocator'
[ +0.000000] cpuidle: using governor ladder
[ +0.000000] cpuidle: using governor menu
[ +0.000000] Simple Boot Flag at 0x44 set to 0x1
[ +0.000000] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ +0.000000] ACPI: bus type PCI registered
[ +0.000000] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ +0.000000] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ +0.000000] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ +0.000000] PCI: Using configuration type 1 for base access
[ +0.002626] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ +0.001270] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ +0.000000] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ +0.000000] ACPI: Added _OSI(Module Device)
[ +0.000000] ACPI: Added _OSI(Processor Device)
[ +0.000000] ACPI: Added _OSI(3.0 _SCP Extensions)
[ +0.000000] ACPI: Added _OSI(Processor Aggregator Device)
[ +0.000000] ACPI: Added _OSI(Linux-Dell-Video)
[ +0.000000] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ +0.000000] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ +0.075408] ACPI: 17 ACPI AML tables successfully acquired and loaded
[ +0.004978] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ +0.007348] ACPI: Dynamic OEM Table Load:
[ +0.000018] ACPI: SSDT 0xFFFF962EC0CAE000 0005CD (v02 PmRef Cpu0Ist 00003000 INTL 20160527)
[ +0.002735] ACPI: \_PR_.CPU0: _OSC native thermal LVT Acked
[ +0.002653] ACPI: Dynamic OEM Table Load:
[ +0.000015] ACPI: SSDT 0xFFFF962EC1356400 0003FF (v02 PmRef Cpu0Cst 00003001 INTL 20160527)
[ +0.003244] ACPI: Dynamic OEM Table Load:
[ +0.000014] ACPI: SSDT 0xFFFF962EC0CAC000 00065C (v02 PmRef ApIst 00003000 INTL 20160527)
[ +0.003281] ACPI: Dynamic OEM Table Load:
[ +0.000012] ACPI: SSDT 0xFFFF962EC1301E00 00018A (v02 PmRef ApCst 00003000 INTL 20160527)
[ +0.008001] ACPI: EC: EC started
[ +0.000001] ACPI: EC: interrupt blocked
[ +0.000648] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ +0.000002] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
[ +0.000001] ACPI: Interpreter enabled
[ +0.000078] ACPI: (supports S0 S3 S4 S5)
[ +0.000002] ACPI: Using IOAPIC for interrupt routing
[ +0.000064] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ +0.001953] ACPI: Enabled 7 GPEs in block 00 to 7F
[ +0.011878] ACPI: Power Resource [PC01] (on)
[ +0.004168] ACPI: Power Resource [WRST] (on)
[ +0.030188] ACPI: Power Resource [FN00] (off)
[ +0.000161] ACPI: Power Resource [FN01] (off)
[ +0.000158] ACPI: Power Resource [FN02] (off)
[ +0.000153] ACPI: Power Resource [FN03] (off)
[ +0.000152] ACPI: Power Resource [FN04] (off)
[ +0.001975] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[ +0.000008] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ +0.000347] acpi PNP0A08:00: _OSC: platform does not support [PCIeHotplug SHPCHotplug PME]
[ +0.000328] acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability LTR DPC]
[ +0.000002] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[ +0.003488] PCI host bridge to bus 0000:00
[ +0.000007] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ +0.000002] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ +0.000002] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
[ +0.000002] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
[ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
[ +0.000002] pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
[ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[ +0.000002] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[ +0.000002] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[ +0.000002] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[ +0.000001] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[ +0.000002] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff window]
[ +0.000001] pci_bus 0000:00: root bus resource [mem 0x80000000-0xdfffffff window]
[ +0.000002] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[ +0.000001] pci_bus 0000:00: root bus resource [bus 00-fe]
[ +0.000019] pci 0000:00:00.0: [8086:5914] type 00 class 0x060000
[ +0.001778] pci 0000:00:02.0: [8086:5917] type 00 class 0x030000
[ +0.000015] pci 0000:00:02.0: reg 0x10: [mem 0xa2000000-0xa2ffffff 64bit]
[ +0.000009] pci 0000:00:02.0: reg 0x18: [mem 0xb0000000-0xbfffffff 64bit pref]
[ +0.000006] pci 0000:00:02.0: reg 0x20: [io 0x5000-0x503f]
[ +0.000026] pci 0000:00:02.0: BAR 2: assigned to efifb
[ +0.001463] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[ +0.000016] pci 0000:00:04.0: reg 0x10: [mem 0xa4220000-0xa4227fff 64bit]
[ +0.001549] pci 0000:00:08.0: [8086:1911] type 00 class 0x088000
[ +0.000017] pci 0000:00:08.0: reg 0x10: [mem 0xa4232000-0xa4232fff 64bit]
[ +0.001457] pci 0000:00:14.0: [8086:9d2f] type 00 class 0x0c0330
[ +0.000023] pci 0000:00:14.0: reg 0x10: [mem 0xa4210000-0xa421ffff 64bit]
[ +0.000087] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ +0.001697] pci 0000:00:14.2: [8086:9d31] type 00 class 0x118000
[ +0.000023] pci 0000:00:14.2: reg 0x10: [mem 0xa4233000-0xa4233fff 64bit]
[ +0.001478] pci 0000:00:16.0: [8086:9d3a] type 00 class 0x078000
[ +0.000026] pci 0000:00:16.0: reg 0x10: [mem 0xa4234000-0xa4234fff 64bit]
[ +0.000091] pci 0000:00:16.0: PME# supported from D3hot
[ +0.001590] pci 0000:00:17.0: [8086:9d03] type 00 class 0x010601
[ +0.000018] pci 0000:00:17.0: reg 0x10: [mem 0xa4230000-0xa4231fff]
[ +0.000010] pci 0000:00:17.0: reg 0x14: [mem 0xa4237000-0xa42370ff]
[ +0.000010] pci 0000:00:17.0: reg 0x18: [io 0x5080-0x5087]
[ +0.000009] pci 0000:00:17.0: reg 0x1c: [io 0x5088-0x508b]
[ +0.000010] pci 0000:00:17.0: reg 0x20: [io 0x5060-0x507f]
[ +0.000010] pci 0000:00:17.0: reg 0x24: [mem 0xa4235000-0xa42357ff]
[ +0.000056] pci 0000:00:17.0: PME# supported from D3hot
[ +0.001527] pci 0000:00:1c.0: [8086:9d10] type 01 class 0x060400
[ +0.000103] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ +0.001691] pci 0000:00:1c.4: [8086:9d14] type 01 class 0x060400
[ +0.000103] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ +0.001595] pci 0000:00:1c.5: [8086:9d15] type 01 class 0x060400
[ +0.000102] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ +0.001683] pci 0000:00:1f.0: [8086:9d4e] type 00 class 0x060100
[ +0.001608] pci 0000:00:1f.2: [8086:9d21] type 00 class 0x058000
[ +0.000019] pci 0000:00:1f.2: reg 0x10: [mem 0xa422c000-0xa422ffff]
[ +0.001551] pci 0000:00:1f.3: [8086:9d71] type 00 class 0x040380
[ +0.000029] pci 0000:00:1f.3: reg 0x10: [mem 0xa4228000-0xa422bfff 64bit]
[ +0.000039] pci 0000:00:1f.3: reg 0x20: [mem 0xa4200000-0xa420ffff 64bit]
[ +0.000064] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ +0.001767] pci 0000:00:1f.4: [8086:9d23] type 00 class 0x0c0500
[ +0.000058] pci 0000:00:1f.4: reg 0x10: [mem 0xa4236000-0xa42360ff 64bit]
[ +0.000070] pci 0000:00:1f.4: reg 0x20: [io 0x5040-0x505f]
[ +0.001630] pci 0000:01:00.0: [10de:134d] type 00 class 0x030200
[ +0.000019] pci 0000:01:00.0: reg 0x10: [mem 0xa3000000-0xa3ffffff]
[ +0.000016] pci 0000:01:00.0: reg 0x14: [mem 0x90000000-0x9fffffff 64bit pref]
[ +0.000015] pci 0000:01:00.0: reg 0x1c: [mem 0xa0000000-0xa1ffffff 64bit pref]
[ +0.000011] pci 0000:01:00.0: reg 0x24: [io 0x4000-0x407f]
[ +0.000010] pci 0000:01:00.0: reg 0x30: [mem 0xfff80000-0xffffffff pref]
[ +0.000028] pci 0000:01:00.0: Enabling HDA controller
[ +0.000286] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ +0.000004] pci 0000:00:1c.0: bridge window [io 0x4000-0x4fff]
[ +0.000003] pci 0000:00:1c.0: bridge window [mem 0xa3000000-0xa3ffffff]
[ +0.000006] pci 0000:00:1c.0: bridge window [mem 0x90000000-0xa1ffffff 64bit pref]
[ +0.000085] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ +0.000023] pci 0000:02:00.0: reg 0x10: [io 0x3000-0x30ff]
[ +0.000032] pci 0000:02:00.0: reg 0x18: [mem 0xa4104000-0xa4104fff 64bit]
[ +0.000020] pci 0000:02:00.0: reg 0x20: [mem 0xa4100000-0xa4103fff 64bit]
[ +0.000131] pci 0000:02:00.0: supports D1 D2
[ +0.000002] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ +0.000188] pci 0000:00:1c.4: PCI bridge to [bus 02]
[ +0.000003] pci 0000:00:1c.4: bridge window [io 0x3000-0x3fff]
[ +0.000004] pci 0000:00:1c.4: bridge window [mem 0xa4100000-0xa41fffff]
[ +0.000332] pci 0000:03:00.0: [8086:095a] type 00 class 0x028000
[ +0.000089] pci 0000:03:00.0: reg 0x10: [mem 0xa4000000-0xa4001fff 64bit]
[ +0.000477] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ +0.000950] pci 0000:00:1c.5: PCI bridge to [bus 03]
[ +0.000006] pci 0000:00:1c.5: bridge window [mem 0xa4000000-0xa40fffff]
[ +0.008979] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ +0.000099] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[ +0.000095] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[ +0.000094] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[ +0.000094] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[ +0.000094] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 *11 12 14 15)
[ +0.000095] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[ +0.000093] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[ +0.001602] ACPI: EC: interrupt unblocked
[ +0.000001] ACPI: EC: event unblocked
[ +0.000011] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[ +0.000002] ACPI: EC: GPE=0x50
[ +0.000002] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC initialization complete
[ +0.000002] ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to handle transactions and events
[ +0.000088] iommu: Default domain type: Translated
[ +0.000015] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ +0.000000] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ +0.000000] pci 0000:00:02.0: vgaarb: bridge control possible
[ +0.000000] vgaarb: loaded
[ +0.000000] SCSI subsystem initialized
[ +0.000000] libata version 3.00 loaded.
[ +0.000000] ACPI: bus type USB registered
[ +0.000000] usbcore: registered new interface driver usbfs
[ +0.000000] usbcore: registered new interface driver hub
[ +0.000000] usbcore: registered new device driver usb
[ +0.000000] pps_core: LinuxPPS API ver. 1 registered
[ +0.000000] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ +0.000000] PTP clock support registered
[ +0.000000] EDAC MC: Ver: 3.0.0
[ +0.000000] Registered efivars operations
[ +0.000000] NetLabel: Initializing
[ +0.000000] NetLabel: domain hash size = 128
[ +0.000000] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ +0.000000] NetLabel: unlabeled traffic allowed by default
[ +0.000000] PCI: Using ACPI for IRQ routing
[ +0.028886] PCI: pci_cache_line_size set to 64 bytes
[ +0.000236] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[ +0.000002] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[ +0.000001] e820: reserve RAM buffer [mem 0x6420d000-0x67ffffff]
[ +0.000001] e820: reserve RAM buffer [mem 0x6c41c000-0x6fffffff]
[ +0.000002] e820: reserve RAM buffer [mem 0x7bd4e000-0x7bffffff]
[ +0.000001] e820: reserve RAM buffer [mem 0x7cfff000-0x7fffffff]
[ +0.000001] e820: reserve RAM buffer [mem 0x27f000000-0x27fffffff]
[ +0.001067] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ +0.000008] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ +0.002296] clocksource: Switched to clocksource tsc-early
[ +0.014829] VFS: Disk quotas dquot_6.6.0
[ +0.000035] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ +0.000088] pnp: PnP ACPI init
[ +0.000289] system 00:00: [mem 0xfd000000-0xfdabffff] has been reserved
[ +0.000002] system 00:00: [mem 0xfdad0000-0xfdadffff] has been reserved
[ +0.000002] system 00:00: [mem 0xfdb00000-0xfdffffff] has been reserved
[ +0.000002] system 00:00: [mem 0xfe000000-0xfe01ffff] has been reserved
[ +0.000001] system 00:00: [mem 0xfe036000-0xfe03bfff] has been reserved
[ +0.000002] system 00:00: [mem 0xfe03d000-0xfe3fffff] has been reserved
[ +0.000002] system 00:00: [mem 0xfe410000-0xfe7fffff] has been reserved
[ +0.000007] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[ +0.000552] system 00:01: [io 0x2000-0x20fe] has been reserved
[ +0.000005] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ +0.000288] system 00:02: [io 0x0680-0x069f] has been reserved
[ +0.000003] system 00:02: [io 0xfd60-0xfd63] has been reserved
[ +0.000001] system 00:02: [io 0xffff] has been reserved
[ +0.000002] system 00:02: [io 0xffff] has been reserved
[ +0.000001] system 00:02: [io 0x1800-0x18fe] has been reserved
[ +0.000002] system 00:02: [io 0x164e-0x164f] has been reserved
[ +0.000005] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ +0.000164] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ +0.000058] system 00:04: [io 0x1854-0x1857] has been reserved
[ +0.000004] system 00:04: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ +0.000053] pnp 00:05: Plug and Play ACPI device, IDs PNP0303 (active)
[ +0.000035] pnp 00:06: Plug and Play ACPI device, IDs SYN3266 PNP0f13 (active)
[ +0.009217] system 00:07: [mem 0xfe029000-0xfe029fff] has been reserved
[ +0.000002] system 00:07: [mem 0xfe028000-0xfe028fff] has been reserved
[ +0.000002] system 00:07: [mem 0xfdaf0000-0xfdafffff] has been reserved
[ +0.000002] system 00:07: [mem 0xfdae0000-0xfdaeffff] has been reserved
[ +0.000002] system 00:07: [mem 0xfdac0000-0xfdacffff] has been reserved
[ +0.000005] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ +0.001004] system 00:08: [mem 0xfed10000-0xfed17fff] has been reserved
[ +0.000002] system 00:08: [mem 0xfed18000-0xfed18fff] has been reserved
[ +0.000002] system 00:08: [mem 0xfed19000-0xfed19fff] has been reserved
[ +0.000002] system 00:08: [mem 0xe0000000-0xefffffff] has been reserved
[ +0.000002] system 00:08: [mem 0xfed20000-0xfed3ffff] has been reserved
[ +0.000002] system 00:08: [mem 0xfed90000-0xfed93fff] could not be reserved
[ +0.000002] system 00:08: [mem 0xfed45000-0xfed8ffff] could not be reserved
[ +0.000002] system 00:08: [mem 0xff000000-0xff000fff] has been reserved
[ +0.000003] system 00:08: [mem 0xff010000-0xffffffff] could not be reserved
[ +0.000002] system 00:08: [mem 0xfee00000-0xfeefffff] could not be reserved
[ +0.000002] system 00:08: [mem 0x80000000-0x8001ffff] has been reserved
[ +0.000005] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ +0.001201] pnp: PnP ACPI: found 9 devices
[ +0.006017] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ +0.000086] NET: Registered protocol family 2
[ +0.000219] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ +0.000060] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ +0.000179] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ +0.000103] TCP: Hash tables configured (established 65536 bind 65536)
[ +0.000073] MPTCP token hash table entries: 8192 (order: 5, 196608 bytes, linear)
[ +0.000048] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ +0.000033] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ +0.000095] NET: Registered protocol family 1
[ +0.000006] NET: Registered protocol family 44
[ +0.000006] pci 0000:01:00.0: can't claim BAR 6 [mem 0xfff80000-0xffffffff pref]: no compatible bridge window
[ +0.000012] pci 0000:01:00.0: BAR 6: no space for [mem size 0x00080000 pref]
[ +0.000002] pci 0000:01:00.0: BAR 6: failed to assign [mem size 0x00080000 pref]
[ +0.000002] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ +0.000003] pci 0000:00:1c.0: bridge window [io 0x4000-0x4fff]
[ +0.000005] pci 0000:00:1c.0: bridge window [mem 0xa3000000-0xa3ffffff]
[ +0.000004] pci 0000:00:1c.0: bridge window [mem 0x90000000-0xa1ffffff 64bit pref]
[ +0.000006] pci 0000:00:1c.4: PCI bridge to [bus 02]
[ +0.000002] pci 0000:00:1c.4: bridge window [io 0x3000-0x3fff]
[ +0.000008] pci 0000:00:1c.5: PCI bridge to [bus 03]
[ +0.000004] pci 0000:00:1c.5: bridge window [mem 0xa4000000-0xa40fffff]
[ +0.000009] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ +0.000002] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ +0.000001] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ +0.000002] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[ +0.000001] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[ +0.000002] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[ +0.000001] pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
[ +0.000002] pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
[ +0.000001] pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
[ +0.000002] pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
[ +0.000001] pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
[ +0.000002] pci_bus 0000:00: resource 15 [mem 0x000e0000-0x000e3fff window]
[ +0.000001] pci_bus 0000:00: resource 16 [mem 0x000e4000-0x000e7fff window]
[ +0.000002] pci_bus 0000:00: resource 17 [mem 0x000e8000-0x000ebfff window]
[ +0.000001] pci_bus 0000:00: resource 18 [mem 0x000ec000-0x000effff window]
[ +0.000002] pci_bus 0000:00: resource 19 [mem 0x000f0000-0x000fffff window]
[ +0.000001] pci_bus 0000:00: resource 20 [mem 0x80000000-0xdfffffff window]
[ +0.000002] pci_bus 0000:00: resource 21 [mem 0xfd000000-0xfe7fffff window]
[ +0.000002] pci_bus 0000:01: resource 0 [io 0x4000-0x4fff]
[ +0.000002] pci_bus 0000:01: resource 1 [mem 0xa3000000-0xa3ffffff]
[ +0.000001] pci_bus 0000:01: resource 2 [mem 0x90000000-0xa1ffffff 64bit pref]
[ +0.000002] pci_bus 0000:02: resource 0 [io 0x3000-0x3fff]
[ +0.000001] pci_bus 0000:02: resource 1 [mem 0xa4100000-0xa41fffff]
[ +0.000002] pci_bus 0000:03: resource 1 [mem 0xa4000000-0xa40fffff]
[ +0.000289] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ +0.001889] PCI: CLS 64 bytes, default 64
[ +0.000053] Trying to unpack rootfs image as initramfs...
[ +0.157059] Freeing initrd memory: 10568K
[ +0.000050] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ +0.000018] software IO TLB: mapped [mem 0x000000007776b000-0x000000007b76b000] (64MB)
[ +0.000780] check: Scanning for low memory corruption every 60 seconds
[ +0.000418] Initialise system trusted keyrings
[ +0.000022] Key type blacklist registered
[ +0.000067] workingset: timestamp_bits=41 max_order=21 bucket_order=0
[ +0.001556] zbud: loaded
[ +0.013205] Key type asymmetric registered
[ +0.000001] Asymmetric key parser 'x509' registered
[ +0.000009] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ +0.000057] io scheduler mq-deadline registered
[ +0.000002] io scheduler kyber registered
[ +0.000032] io scheduler bfq registered
[ +0.000117] atomic64_test: passed for x86-64 platform with CX8 and with SSE
[ +0.000493] pcieport 0000:00:1c.0: AER: enabled with IRQ 122
[ +0.000385] pcieport 0000:00:1c.4: AER: enabled with IRQ 123
[ +0.000350] pcieport 0000:00:1c.5: AER: enabled with IRQ 124
[ +0.000106] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ +0.000044] efifb: probing for efifb
[ +0.000028] efifb: showing boot graphics
[ +0.001023] efifb: framebuffer at 0xb0000000, using 8128k, total 8128k
[ +0.000002] efifb: mode is 1920x1080x32, linelength=7680, pages=1
[ +0.000000] efifb: scrolling: redraw
[ +0.000002] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ +0.000043] fbcon: Deferring console take-over
[ +0.000001] fb0: EFI VGA frame buffer device
[ +0.000010] intel_idle: MWAIT substates: 0x11142120
[ +0.000001] intel_idle: v0.5.1 model 0x8E
[ +0.000616] intel_idle: Local APIC timer is reliable in all C-states
[ +0.000280] ACPI: AC Adapter [ACAD] (on-line)
[ +0.000114] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:19/PNP0C0D:00/input/input0
[ +0.000021] ACPI: Lid Switch [LID0]
[ +0.000072] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ +0.000159] ACPI: Power Button [PWRF]
[ +0.002374] thermal LNXTHERM:00: registered as thermal_zone0
[ +0.000002] ACPI: Thermal Zone [TZ00] (28 C)
[ +0.000270] thermal LNXTHERM:01: registered as thermal_zone1
[ +0.000001] ACPI: Thermal Zone [TZ01] (30 C)
[ +0.000106] thermal LNXTHERM:02: registered as thermal_zone2
[ +0.000001] ACPI: Thermal Zone [TZ02] (10 C)
[ +0.000322] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ +0.002372] Non-volatile memory driver v1.3
[ +0.000002] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[ +0.000001] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[ +0.001250] ahci 0000:00:17.0: version 3.0
[ +0.000256] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 3 ports 6 Gbps 0x5 impl SATA mode
[ +0.000003] ahci 0000:00:17.0: flags: 64bit ncq ilck pm led clo only pio slum part deso sadm sds apst
[ +0.000672] scsi host0: ahci
[ +0.000248] scsi host1: ahci
[ +0.000251] scsi host2: ahci
[ +0.000041] ata1: SATA max UDMA/133 abar m2048@0xa4235000 port 0xa4235100 irq 125
[ +0.000001] ata2: DUMMY
[ +0.000002] ata3: SATA max UDMA/133 abar m2048@0xa4235000 port 0xa4235200 irq 125
[ +0.000036] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ +0.000005] ehci-pci: EHCI PCI platform driver
[ +0.000011] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ +0.000002] ohci-pci: OHCI PCI platform driver
[ +0.000008] uhci_hcd: USB Universal Host Controller Interface driver
[ +0.000036] usbcore: registered new interface driver usbserial_generic
[ +0.000005] usbserial: USB Serial support registered for generic
[ +0.000030] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ +0.019105] serio: i8042 KBD port at 0x60,0x64 irq 1
[ +0.000042] serio: i8042 AUX port at 0x60,0x64 irq 12
[ +0.000269] rtc_cmos 00:03: RTC can wake from S4
[ +0.000572] rtc_cmos 00:03: registered as rtc0
[ +0.000144] rtc_cmos 00:03: setting system clock to 2021-01-01T11:26:42 UTC (1609500402)
[ +0.000017] rtc_cmos 00:03: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ +0.000041] intel_pstate: Intel P-state driver initializing
[ +0.000399] intel_pstate: HWP enabled
[ +0.000064] ledtrig-cpu: registered to indicate activity on CPUs
[ +0.009551] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[ +0.027328] battery: ACPI: Battery Slot [BAT1] (battery present)
[ +0.019394] pstore: Registered efi as persistent store backend
[ +0.000016] hid: raw HID events driver (C) Jiri Kosina
[ +0.000138] ashmem: initialized
[ +0.000065] intel_pmc_core INT33A1:00: initialized
[ +0.000116] drop_monitor: Initializing network drop monitor service
[ +0.000052] Initializing XFRM netlink socket
[ +0.000105] NET: Registered protocol family 10
[ +0.004094] Segment Routing with IPv6
[ +0.000001] RPL Segment Routing with IPv6
[ +0.000029] NET: Registered protocol family 17
[ +0.000086] mce: Unable to init MCE device (rc: -5)
[ +0.000092] microcode: sig=0x806ea, pf=0x80, revision=0xe0
[ +0.000213] microcode: Microcode Update Driver: v2.2.
[ +0.000018] IPI shorthand broadcast: enabled
[ +0.000007] sched_clock: Marking stable (753818998, 843300)->(1459893308, -705231010)
[ +0.000205] registered taskstats version 1
[ +0.000005] Loading compiled-in X.509 certificates
[ +0.002129] Loaded X.509 cert 'Build time autogenerated kernel key: b1cdd648fec5b824279d0b7b0f9bae72f872e75a'
[ +0.001309] zswap: loaded using pool zstd/z3fold
[ +0.000531] Key type ._fscrypt registered
[ +0.000001] Key type .fscrypt registered
[ +0.000000] Key type fscrypt-provisioning registered
[ +0.000211] pstore: Using crash dump compression: zstd
[ +0.000862] PM: Magic number: 5:582:427
[ +0.000240] RAS: Correctable Errors collector initialized.
[ +0.233430] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ +0.000032] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ +0.001172] ata3.00: ATA-9: SanDisk SD8SN8U-128G-1006, X4120006, max UDMA/133
[ +0.000006] ata3.00: 250069680 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ +0.002866] ata3.00: configured for UDMA/133
[ +0.010442] ata1.00: ATA-10: ST1000LM035-1RK172, RSM7, max UDMA/100
[ +0.000006] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[ +0.002131] ahci 0000:00:17.0: port does not support device sleep
[ +0.029191] ata1.00: configured for UDMA/100
[ +0.021142] scsi 0:0:0:0: Direct-Access ATA ST1000LM035-1RK1 RSM7 PQ: 0 ANSI: 5
[ +0.000381] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ +0.000004] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ +0.000016] sd 0:0:0:0: [sda] Write Protect is off
[ +0.000003] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ +0.000024] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ +0.000194] scsi 2:0:0:0: Direct-Access ATA SanDisk SD8SN8U- 0006 PQ: 0 ANSI: 5
[ +0.000383] sd 2:0:0:0: [sdb] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[ +0.000004] sd 2:0:0:0: [sdb] 4096-byte physical blocks
[ +0.000013] sd 2:0:0:0: [sdb] Write Protect is off
[ +0.000004] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ +0.000019] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ +0.006305] sdb: sdb1 sdb2 sdb3 sdb5
[ +0.000755] sd 2:0:0:0: [sdb] Attached SCSI disk
[ +0.390962] sda: sda3
[ +0.000711] sd 0:0:0:0: [sda] Attached SCSI disk
[ +0.021968] psmouse serio1: synaptics: queried max coordinates: x [..5656], y [..4768]
[ +0.031098] psmouse serio1: synaptics: queried min coordinates: x [1284..], y [1120..]
[ +0.000011] psmouse serio1: synaptics: Your touchpad (PNP: SYN3266 PNP0f13) says it can support a different bus. If i2c-hid and hid-rmi are not used, you might want to try setting psmouse.synaptics_intertouch to 1 and report this to linux-input@vger.kernel.org.
[ +0.013861] random: fast init done
[ +0.047408] psmouse serio1: synaptics: Touchpad model: 1, fw: 8.16, id: 0x1e2b1, caps: 0xf00223/0x840300/0x12e800/0x400000, board id: 3384, fw id: 2601547
[ +0.039083] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio1/input/input4
[ +0.005119] Freeing unused decrypted memory: 2036K
[ +0.000509] Freeing unused kernel image (initmem) memory: 1720K
[ +0.000084] Write protecting the kernel read-only data: 22528k
[ +0.000969] Freeing unused kernel image (text/rodata gap) memory: 2036K
[ +0.000513] Freeing unused kernel image (rodata/data gap) memory: 1312K
[ +0.032506] tsc: Refined TSC clocksource calibration: 1992.000 MHz
[ +0.000004] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x396d519840e, max_idle_ns: 881590569543 ns
[ +0.000045] clocksource: Switched to clocksource tsc
[ +0.007876] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ +0.000003] rodata_test: all tests were successful
[ +0.000002] x86/mm: Checking user space page tables
[ +0.038545] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ +0.000004] Run /init as init process
[ +0.000000] with arguments:
[ +0.000001] /init
[ +0.000000] with environment:
[ +0.000001] HOME=/
[ +0.000000] TERM=linux
[ +0.000001] BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64
[ +0.187451] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ +0.000010] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ +0.001130] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081109810
[ +0.000279] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ +0.000238] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ +0.000002] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ +0.000003] usb usb1: Product: xHCI Host Controller
[ +0.000001] usb usb1: Manufacturer: Linux 5.10.2-2-MANJARO xhci-hcd
[ +0.000002] usb usb1: SerialNumber: 0000:00:14.0
[ +0.000206] hub 1-0:1.0: USB hub found
[ +0.000024] hub 1-0:1.0: 12 ports detected
[ +0.002564] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ +0.000005] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ +0.000004] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ +0.000052] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ +0.000002] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ +0.000002] usb usb2: Product: xHCI Host Controller
[ +0.000001] usb usb2: Manufacturer: Linux 5.10.2-2-MANJARO xhci-hcd
[ +0.000002] usb usb2: SerialNumber: 0000:00:14.0
[ +0.000135] hub 2-0:1.0: USB hub found
[ +0.000016] hub 2-0:1.0: 6 ports detected
[ +0.000356] usb: port power management may be unreliable
[ +0.310844] PM: Image not found (code -22)
[ +0.016863] usb 1-2: new full-speed USB device number 2 using xhci_hcd
[ +0.060892] EXT4-fs (sdb5): mounted filesystem with ordered data mode. Opts: (null)
[ +0.081321] usb 1-2: New USB device found, idVendor=3938, idProduct=1031, bcdDevice= 1.08
[ +0.000006] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0.000003] usb 1-2: Product: 2.4G Wireless Mouse
[ +0.000003] usb 1-2: Manufacturer: MOSART Semi.
[ +0.124362] usb 1-4: new full-speed USB device number 3 using xhci_hcd
[ +0.010347] systemd[1]: systemd 247.2-1-manjaro running in system mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ +0.016651] systemd[1]: Detected architecture x86-64.
[ +0.034342] systemd[1]: Set hostname to <sintan-pc>.
[ +0.079581] usb 1-4: New USB device found, idVendor=8087, idProduct=0a2a, bcdDevice= 0.03
[ +0.000001] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ +0.122502] usb 1-5: new high-speed USB device number 4 using xhci_hcd
[ +0.148518] usb 1-5: New USB device found, idVendor=04f2, idProduct=b5d6, bcdDevice=32.22
[ +0.000003] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ +0.000002] usb 1-5: Product: HP Wide Vision HD Camera
[ +0.000002] usb 1-5: Manufacturer: Chicony
[ +0.090011] systemd[1]: /usr/lib/systemd/system/anydesk.service:9: PIDFile= references a path below legacy directory /var/run/, updating /var/run/anydesk.pid β /run/anydesk.pid; please update the unit file accordingly.
[ +0.001792] systemd[1]: Queued start job for default target Graphical Interface.
[ +0.009486] systemd[1]: Created slice system-getty.slice.
[ +0.000283] systemd[1]: Created slice system-modprobe.slice.
[ +0.000252] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ +0.000255] systemd[1]: Created slice User and Session Slice.
[ +0.000062] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ +0.000049] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ +0.000132] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ +0.000042] systemd[1]: Reached target Local Encrypted Volumes.
[ +0.000017] systemd[1]: Reached target Login Prompts.
[ +0.000028] systemd[1]: Reached target Remote File Systems.
[ +0.000012] systemd[1]: Reached target Slices.
[ +0.000081] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ +0.000313] systemd[1]: Listening on LVM2 metadata daemon socket.
[ +0.000233] systemd[1]: Listening on LVM2 poll daemon socket.
[ +0.000959] systemd[1]: Listening on Process Core Dump Socket.
[ +0.000121] systemd[1]: Listening on Journal Audit Socket.
[ +0.000077] systemd[1]: Listening on Journal Socket (/dev/log).
[ +0.000089] systemd[1]: Listening on Journal Socket.
[ +0.000302] systemd[1]: Listening on udev Control Socket.
[ +0.000067] systemd[1]: Listening on udev Kernel Socket.
[ +0.000635] systemd[1]: Mounting Huge Pages File System...
[ +0.000671] systemd[1]: Mounting POSIX Message Queue File System...
[ +0.000682] systemd[1]: Mounting Kernel Debug File System...
[ +0.000682] systemd[1]: Mounting Kernel Trace File System...
[ +0.001039] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ +0.000658] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[ +0.000627] systemd[1]: Starting Load Kernel Module configfs...
[ +0.000596] systemd[1]: Starting Load Kernel Module drm...
[ +0.000588] systemd[1]: Starting Load Kernel Module fuse...
[ +0.001449] systemd[1]: Starting Set Up Additional Binary Formats...
[ +0.000048] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ +0.001012] systemd[1]: Starting Load Kernel Modules...
[ +0.000559] systemd[1]: Starting Remount Root and Kernel File Systems...
[ +0.000049] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[ +0.000558] systemd[1]: Starting Coldplug All udev Devices...
[ +0.001544] systemd[1]: Mounted Huge Pages File System.
[ +0.000090] systemd[1]: Mounted POSIX Message Queue File System.
[ +0.000074] systemd[1]: Mounted Kernel Debug File System.
[ +0.000065] systemd[1]: Mounted Kernel Trace File System.
[ +0.000404] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ +0.000233] systemd[1]: modprobe@configfs.service: Succeeded.
[ +0.000314] systemd[1]: Finished Load Kernel Module configfs.
[ +0.000198] systemd[1]: modprobe@drm.service: Succeeded.
[ +0.000337] systemd[1]: Finished Load Kernel Module drm.
[ +0.000110] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 238 (systemd-binfmt)
[ +0.000685] systemd[1]: Mounting Arbitrary Executable File Formats File System...
[ +0.000094] EXT4-fs (sdb5): re-mounted. Opts: (null)
[ +0.000715] systemd[1]: Mounting Kernel Configuration File System...
[ +0.002134] systemd[1]: Finished Remount Root and Kernel File Systems.
[ +0.000087] systemd[1]: Mounted Arbitrary Executable File Formats File System.
[ +0.000066] systemd[1]: Mounted Kernel Configuration File System.
[ +0.000001] random: lvm: uninitialized urandom read (4 bytes read)
[ +0.000063] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[ +0.002255] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ +0.000207] fuse: init (API version 7.32)
[ +0.000412] systemd[1]: Starting Load/Save Random Seed...
[ +0.000057] systemd[1]: Condition check resulted in Create System Users being skipped.
[ +0.000525] systemd[1]: Starting Create Static Device Nodes in /dev...
[ +0.000260] systemd[1]: modprobe@fuse.service: Succeeded.
[ +0.000228] systemd[1]: Finished Load Kernel Module fuse.
[ +0.000814] systemd[1]: Mounting FUSE Control File System...
[ +0.000364] systemd[1]: Finished Set Up Additional Binary Formats.
[ +0.001480] systemd[1]: Mounted FUSE Control File System.
[ +0.022766] systemd[1]: Finished Create Static Device Nodes in /dev.
[ +0.000836] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[ +0.001075] systemd[1]: Starting Journal Service...
[ +0.001427] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[ +0.051273] systemd[1]: Finished Coldplug All udev Devices.
[ +0.000054] audit: type=1130 audit(1609500404.907:2): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.004567] systemd[1]: Started Journal Service.
[ +0.000047] audit: type=1130 audit(1609500404.910:3): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.071112] nvidia: loading out-of-tree module taints kernel.
[ +0.000009] nvidia: module license 'NVIDIA' taints kernel.
[ +0.000001] Disabling lock debugging due to kernel taint
[ +0.009887] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ +0.011806] audit: type=1130 audit(1609500405.004:4): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.001070] audit: type=1130 audit(1609500405.004:5): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.001314] nvidia-nvlink: Nvlink Core is being initialized, major device number 238
[ +0.000657] nvidia 0000:01:00.0: enabling device (0406 -> 0407)
[ +0.052651] input: HP Wireless hotkeys as /devices/virtual/input/input5
[ +0.019313] hp_accel: laptop model unknown, using default axes configuration
[ +0.000778] random: crng init done
[ +0.007700] audit: type=1130 audit(1609500405.087:6): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.009189] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[ +0.000006] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[ +0.000001] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[ +0.000002] wmi_bus wmi_bus-PNP0C14:00: WQ data block query control method not found
[ +0.000739] wmi_bus wmi_bus-PNP0C14:02: WQBJ data block query control method not found
[ +0.027007] kernel read not supported for file pci0000:00/0000:00:1c.0/0000:01:00.0/config (pid: 239 comm: systemd-modules)
[ +0.000030] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 455.45.01 Thu Nov 5 23:03:56 UTC 2020
[ +0.026624] acpi INT33D6:00: intel-vbtn: created platform device
[ +0.000430] intel-vbtn INT33D6:00: failed to read Intel Virtual Button driver
[ +0.045859] Linux agpgart interface v0.103
[ +0.012274] lis3lv02d: 8 bits 3DC sensor found
[ +0.009862] input: PC Speaker as /devices/platform/pcspkr/input/input6
[ +0.010006] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ +0.009845] Adding 8494076k swap on /dev/sdb3. Priority:-2 extents:1 across:8494076k SSFS
[ +0.022424] mousedev: PS/2 mouse device common for all mice
[ +0.000332] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ +0.013517] intel_rapl_common: Found RAPL domain package
[ +0.000002] intel_rapl_common: Found RAPL domain dram
[ +0.000089] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[ +0.001335] i2c i2c-0: 1/2 memory slots populated (from DMI)
[ +0.000339] i2c i2c-0: Successfully instantiated SPD at 0x50
[ +0.026062] r8168 Gigabit Ethernet driver 8.048.03-NAPI loaded
[ +0.018797] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 455.45.01 Thu Nov 5 22:55:44 UTC 2020
[ +0.008450] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ +0.002036] r8168 Copyright (C) 2020 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ +0.008344] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ +0.000477] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ +0.000002] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
[ +0.000168] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[ +0.000002] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ +0.000000] RAPL PMU: hw unit of domain package 2^-14 Joules
[ +0.000001] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ +0.000001] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ +0.000005] RAPL PMU: hw unit of domain psys 2^-14 Joules
[ +0.002312] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ +0.008197] input: ST LIS3LV02DL Accelerometer as /devices/platform/lis3lv02d/input/input7
[ +0.056881] mc: Linux media interface: v0.10
[ +0.001253] audit: type=1130 audit(1609500405.410:7): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.004611] input: MOSART Semi. 2.4G Wireless Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:3938:1031.0001/input/input8
[ +0.000089] input: MOSART Semi. 2.4G Wireless Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0/0003:3938:1031.0001/input/input9
[ +0.000103] hid-generic 0003:3938:1031.0001: input,hiddev96,hidraw0: USB HID v1.10 Mouse [MOSART Semi. 2.4G Wireless Mouse] on usb-0000:00:14.0-2/input0
[ +0.000030] usbcore: registered new interface driver usbhid
[ +0.000001] usbhid: USB HID core driver
[ +0.001958] cryptd: max_cpu_qlen set to 1000
[ +0.029786] AVX2 version of gcm_enc/dec engaged.
[ +0.000002] AES CTR mode by8 optimization enabled
[ +0.004819] intel_rapl_common: Found RAPL domain package
[ +0.000002] intel_rapl_common: Found RAPL domain core
[ +0.000000] intel_rapl_common: Found RAPL domain uncore
[ +0.000001] intel_rapl_common: Found RAPL domain dram
[ +0.000001] intel_rapl_common: Found RAPL domain psys
[ +0.029168] audit: type=1130 audit(1609500405.480:8): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.000784] r8168 0000:02:00.0 eno1: renamed from eth0
[ +0.019538] loop: module loaded
[ +0.007839] Intel(R) Wireless WiFi driver for Linux
[ +0.000720] iTCO_vendor_support: vendor-support=0
[ +0.024032] ee1004 0-0050: 512 byte EE1004-compliant SPD EEPROM, read-only
[ +0.005666] iwlwifi 0000:03:00.0: loaded firmware version 29.198743027.0 7265D-29.ucode op_mode iwlmvm
[ +0.011850] audit: type=1130 audit(1609500405.550:9): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-afef074d\x2d3775\x2d4873\x2da5a0\x2dba8d22bf05c0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.001635] videodev: Linux video capture interface: v2.00
[ +0.005563] EXT4-fs (sdb2): mounted filesystem with ordered data mode. Opts: (null)
[ +0.004655] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[ +0.000062] iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[ +0.000208] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ +0.009841] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ +0.004122] Bluetooth: Core ver 2.22
[ +0.000015] NET: Registered protocol family 31
[ +0.000002] Bluetooth: HCI device and connection manager initialized
[ +0.000002] Bluetooth: HCI socket layer initialized
[ +0.000003] Bluetooth: L2CAP socket layer initialized
[ +0.000003] Bluetooth: SCO socket layer initialized
[ +0.006210] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ +0.017624] audit: type=1130 audit(1609500405.600:10): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-27454cca\x2d524b\x2d4918\x2dafa5\x2d9ae9dbb2d1ee comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.051642] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[ +0.035198] Bluetooth: RTBT_Tb: vendor=0x1814, device=0x3298
[ +0.000018] Bluetooth: RTBT_Tb: vendor=0x0, device=0x0
[ +0.000005] Bluetooth: DynamicAlloc pci_device_id table at 0x0000000043bb09c0 with size 64
[ +0.000003] Bluetooth: RTBT_Tb: vendor=0x1814, device=0x3298
[ +0.000003] Bluetooth: Convert: vendor=0x1814, device=0x3298
[ +0.000003] Bluetooth: RTBT_Tb: vendor=0x0, device=0x0
[ +0.000003] Bluetooth: pci_device_id: vendor=0x1814, device=0x3298
[ +0.001895] checking generic (b0000000 7f0000) vs hw (a2000000 1000000)
[ +0.000007] checking generic (b0000000 7f0000) vs hw (b0000000 10000000)
[ +0.000004] fb0: switching to inteldrmfb from EFI VGA
[ +0.000764] usbcore: registered new interface driver btusb
[ +0.002365] i915 0000:00:02.0: vgaarb: deactivate vga console
[ +0.010641] Bluetooth: hci0: read Intel version: 370810225019140f00
[ +0.000887] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.8.10-fw-22.50.19.14.f.bseq
[ +0.044816] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ +0.001567] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[ +0.002478] i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[ +0.045454] uvcvideo: Found UVC 1.00 device HP Wide Vision HD Camera (04f2:b5d6)
[ +0.022177] input: HP Wide Vision HD Camera: HP Wi as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input11
[ +0.000166] usbcore: registered new interface driver uvcvideo
[ +0.000002] USB Video Class driver (1.1.1)
[ +0.078807] iwlwifi 0000:03:00.0: Detected Intel(R) Dual Band Wireless AC 7265, REV=0x210
[ +0.015255] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ +0.000048] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ +0.000008] pcieport 0000:00:1c.5: device [8086:9d15] error status/mask=00000001/00002000
[ +0.000005] pcieport 0000:00:1c.5: [ 0] RxErr (First)
[ +0.010570] iwlwifi 0000:03:00.0: base HW address: a0:af:bd:4f:d8:5f
[ +0.026140] snd_hda_intel 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if info 0x040380
[ +0.036247] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ +0.007469] iwlwifi 0000:03:00.0 wlo1: renamed from wlan0
[ +0.044225] thermal thermal_zone7: failed to read out thermal zone (-61)
[ +0.036674] Bluetooth: hci0: Intel BT fw patch 0x41 completed & activated
[ +0.141601] 8021q: 802.1Q VLAN Support v1.8
[ +0.021742] input: HP WMI hotkeys as /devices/virtual/input/input10
[ +0.005857] eno1: 0xffffbbb1403bf000, ac:e2:d3:81:12:6f, IRQ 128
[ +0.383570] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ +0.000004] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ +0.000001] pcieport 0000:00:1c.5: device [8086:9d15] error status/mask=00000001/00002000
[ +0.000001] pcieport 0000:00:1c.5: [ 0] RxErr (First)
[ +0.027157] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ +0.000002] Bluetooth: BNEP filters: protocol multicast
[ +0.000004] Bluetooth: BNEP socket layer initialized
[ +0.006961] NET: Registered protocol family 38
[ +0.000434] process '/usr/bin/anydesk.bin' started with executable stack
[ +0.043482] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ +0.000005] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ +0.000002] pcieport 0000:00:1c.5: [ 0] RxErr (First)
[ +0.147644] [drm] Initialized i915 1.6.0 20200917 for 0000:00:02.0 on minor 1
[ +0.002407] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ +0.000903] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input12
[ +0.000144] [Firmware Bug]: ACPI(PXSX) defines _DOD but not _DOS
[ +0.000010] ACPI: Video Device [PXSX] (multi-head: yes rom: yes post: no)
[ +0.000045] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:35/LNXVIDEO:01/input/input13
[ +0.000247] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ +0.005039] fbcon: i915drmfb (fb0) is primary device
[ +0.000002] fbcon: Deferring console take-over
[ +0.000004] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[ +0.021711] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ +0.000007] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ +0.040880] hp_wmi: query 0x4c returned error 0x3
[ +0.009146] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC295: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ +0.000004] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ +0.000001] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ +0.000001] snd_hda_codec_realtek hdaudioC0D0: mono: mono_out=0x0
[ +0.000002] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ +0.000001] snd_hda_codec_realtek hdaudioC0D0: Mic=0x19
[ +0.000002] snd_hda_codec_realtek hdaudioC0D0: Internal Mic=0x12
[ +0.060461] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[ +0.000060] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[ +0.000050] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[ +0.000050] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input17
[ +0.000047] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input18
[ +0.000083] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input19
[ +0.000057] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input20
[ +0.105013] kauditd_printk_skb: 32 callbacks suppressed
[ +0.000002] audit: type=1130 audit(1609500407.100:43): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cpupower-gui comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.000013] audit: type=1131 audit(1609500407.100:44): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cpupower-gui comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.017182] nvidia 0000:01:00.0: Enabling HDA controller
[ +0.023169] audit: type=1701 audit(1609500407.140:45): auid=4294967295 uid=0 gid=0 ses=4294967295 pid=507 comm="sddm" exe="/usr/bin/sddm" sig=6 res=1
[ +0.055997] audit: type=1334 audit(1609500407.197:46): prog-id=11 op=LOAD
[ +0.000003] audit: type=1334 audit(1609500407.197:47): prog-id=12 op=LOAD
[ +0.000603] audit: type=1130 audit(1609500407.197:48): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-599-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.094810] audit: type=1131 audit(1609500407.294:49): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ +0.000670] audit: type=1131 audit(1609500407.294:50): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-coredump@0-599-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.145056] audit: type=1334 audit(1609500407.440:51): prog-id=12 op=UNLOAD
[ +0.000009] audit: type=1334 audit(1609500407.440:52): prog-id=11 op=UNLOAD
[ +0.459945] nvidia 0000:01:00.0: Enabling HDA controller
[ +0.351674] fbcon: Taking over console
[ +0.002151] Console: switching to colour frame buffer device 240x67
[ +2.478900] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ +0.000125] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ +0.000004] pcieport 0000:00:1c.5: device [8086:9d15] error status/mask=00000001/00002000
[ +0.000004] pcieport 0000:00:1c.5: [ 0] RxErr (First)
[ +3.897851] kauditd_printk_skb: 16 callbacks suppressed
[ +0.000002] audit: type=1100 audit(1609500414.630:69): pid=818 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="sintan" exe="/usr/bin/login" hostname=sintan-pc addr=? terminal=tty2 res=success'
[ +0.009879] audit: type=1101 audit(1609500414.640:70): pid=818 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sintan" exe="/usr/bin/login" hostname=sintan-pc addr=? terminal=tty2 res=success'
[ +0.004051] audit: type=1103 audit(1609500414.644:71): pid=818 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="sintan" exe="/usr/bin/login" hostname=sintan-pc addr=? terminal=tty2 res=success'
[ +0.000128] audit: type=1006 audit(1609500414.644:72): pid=818 uid=0 old-auid=4294967295 auid=1000 tty=tty2 old-ses=4294967295 ses=1 res=1
[ +0.017575] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ +0.000018] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ +0.000003] pcieport 0000:00:1c.5: [ 0] RxErr (First)
[ +0.010714] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ +0.000015] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ +0.000003] pcieport 0000:00:1c.5: device [8086:9d15] error status/mask=00000001/00002000
[ +0.007444] audit: type=1130 audit(1609500414.680:73): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.012761] audit: type=1101 audit(1609500414.694:74): pid=832 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="sintan" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.000108] audit: type=1103 audit(1609500414.694:75): pid=832 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:setcred grantors=? acct="sintan" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[ +0.000129] audit: type=1006 audit(1609500414.694:76): pid=832 uid=0 old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[ +0.002551] audit: type=1105 audit(1609500414.694:77): pid=832 uid=0 auid=1000 ses=2 msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="sintan" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.012138] audit: type=1334 audit(1609500414.707:78): prog-id=15 op=LOAD
[ +2.599283] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ +0.000017] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[Jan 1 16:57] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ +0.000006] pcieport 0000:00:1c.5: device [8086:9d15] error status/mask=00000001/00002000
[ +0.000006] pcieport 0000:00:1c.5: [ 0] RxErr (First)
[ +11.998984] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ +0.000022] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ +0.000005] pcieport 0000:00:1c.5: device [8086:9d15] error status/mask=00000001/00002000
[ +3.998867] kauditd_printk_skb: 5 callbacks suppressed
[ +0.000004] audit: type=1131 audit(1609500436.804:84): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ +0.143992] audit: type=1334 audit(1609500436.950:85): prog-id=10 op=UNLOAD
[ +0.000008] audit: type=1334 audit(1609500436.950:86): prog-id=9 op=UNLOAD
[ +5.861532] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ +0.000147] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ +14.003691] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ +10.601115] audit: type=1325 audit(1609500467.367:87): table=filter family=2 entries=0 op=xt_register pid=1417 comm="modprobe"
[ +0.066681] audit: type=1325 audit(1609500467.454:88): table=filter family=2 entries=4 op=xt_replace pid=1422 comm="iptables"
[ +0.040011] audit: type=1325 audit(1609500467.494:89): table=filter family=2 entries=5 op=xt_replace pid=1423 comm="iptables"
[ +0.053314] audit: type=1325 audit(1609500467.534:90): table=filter family=2 entries=6 op=xt_replace pid=1424 comm="iptables"
[ +0.053402] audit: type=1325 audit(1609500467.587:91): table=filter family=2 entries=7 op=xt_replace pid=1425 comm="iptables"
[Jan 1 16:58] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ +0.000007] pcieport 0000:00:1c.5: device [8086:9d15] error status/mask=00000001/00002000
[Jan 1 16:59] pcieport 0000:00:1c.5: AER: Corrected error received: 0000:00:1c.5
[ +0.000153] pcieport 0000:00:1c.5: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ +17.399317] audit: type=1100 audit(1609500566.210:92): pid=2285 uid=1000 auid=1000 ses=1 msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="sintan" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.001637] audit: type=1101 audit(1609500566.210:93): pid=2285 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="sintan" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.000380] audit: type=1110 audit(1609500566.214:94): pid=2285 uid=1000 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.003232] audit: type=1105 audit(1609500566.217:95): pid=2285 uid=1000 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +19.069495] audit: type=1106 audit(1609500585.284:96): pid=2285 uid=1000 auid=1000 ses=1 msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.000274] audit: type=1104 audit(1609500585.284:97): pid=2285 uid=1000 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +8.412059] audit: type=1101 audit(1609500593.697:98): pid=2550 uid=1000 auid=1000 ses=1 msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="sintan" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.000498] audit: type=1110 audit(1609500593.697:99): pid=2550 uid=1000 auid=1000 ses=1 msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
[ +0.004716] audit: type=1105 audit(1609500593.704:100): pid=2550 uid=1000 auid=1000 ses=1 msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
inxi -Fazy
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=fe64fafd-1c2a-4b55-846f-c264196ff166 rw nomce "acpi_osi=Windows
2018" quiet resume=UUID=4517ac81-4ac6-42a0-8e7a-a5870b5f98df
Console: tty 2 DM: GDM 3.38.2, SDDM Distro: Manjaro Linux
Type: Laptop System: HP product: HP Pavilion Laptop 14-bf1xx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 83CE v: 59.38 serial: <filter> UEFI: Insyde v: F.31
date: 10/30/2017
ID-1: BAT1 charge: 2.3 Wh condition: 31.1/42.1 Wh (74%) volts: 10.8/11.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
status: Unknown
Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: E0 L2 cache: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 32012
Speed: 986 MHz min/max: 400/1800 MHz Core speeds (MHz): 1: 986 2: 950 3: 960
4: 952 5: 945 6: 948 7: 923 8: 949
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:5917
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: Hewlett-Packard
driver: nvidia v: 455.45.01 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:134d
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus ID: 1-5:4 chip ID: 04f2:b5d6
Display: server: X.org 1.20.10 driver: nvidia tty: 240x66
Message: Advanced graphics data unavailable in console. Try -G --display
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
chip ID: 8086:9d71
Sound Server: ALSA v: k5.10.2-2-MANJARO
vendor: Hewlett-Packard driver: r8168 v: 8.048.03-NAPI modules: r8169
port: 3000 bus ID: 02:00.0 chip ID: 10ec:8168
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: 3000
bus ID: 03:00.0 chip ID: 8086:095a
IF: wlo1 state: down mac: <filter>
Local Storage: total: 1.03 TiB used: 544.67 GiB (51.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: RSM7
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SD8SN8U-128G-1006
size: 119.24 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 0006
ID-1: / raw size: 50 GiB size: 48.72 GiB (97.43%) used: 39.53 GiB (81.1%)
fs: ext4 dev: /dev/sdb5 maj-min: 8:21
ID-2: /boot/efi raw size: 277 MiB size: 276.4 MiB (99.80%)
used: 280 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw size: 60.87 GiB size: 59.67 GiB (98.02%)
used: 31.73 GiB (53.2%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
Kernel: swappiness: 5 (default 60) cache pressure: 50 (default 100)
ID-1: swap-1 type: partition size: 8.1 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb3 maj-min: 8:19
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 212 Uptime: 3m wakeups: 1 Memory: 7.69 GiB used: 607.7 MiB (7.7%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: 1965 pacman: 1964
lib: 453 flatpak: 1 Shell: fish v: 3.1.2 running in: tty 2 inxi: 3.2.01
The solution was very dumb. I just had to rm /etc/X11/xorg.conf
