Hi guys/girls, I’m facing the same problem with this thread: Unable to boot - error: symbol `grub_alloc’ not found though mine was triggered by an attempt of mine to unsuccessfully boot from a live USB. The live USB wouldn’t boot so I was trying all the available boot options in UEFI, legacy, UEFI with CSM, UEFI, boot priorities to no avail. After a restart with the previous “working” options set back I was welcomed with the above. I didn’t try the solution proposed there as it was not marked as the one and before trying to attempt numerous things I had in mind I thought it would be way better to ask the profis ![]()
So before trying that with the live USB my UEFI had 2 entries to choose from, Manjaro and UEFI:OS , the system booted with Manjaro , but now it isn’t listed in the UEFI, I assume something of the above somehow deleted it?
Here are some info for you booted from a rescue USB with Manjaro, and from inside chroot -a:
[manjaro boot]# fdisk -l
Disk /dev/sda: 238.47 GiB, 256060514304 bytes, 500118192 sectors
Disk model: TOSHIBA THNSNJ25
Disklabel type: gpt
Disk identifier: 5AA4BE13-233B-5E47-A92E-D08D0848B3E5
Device         Start       End   Sectors  Size Type
/dev/sda1       2048   1050623   1048576  512M EFI System
/dev/sda2    1050624  49285119  48234496   23G Linux filesystem
/dev/sda3   49285120 493826047 444540928  212G Linux filesystem
/dev/sda4  493826048 500118158   6292111    3G Linux swap
[manjaro boot]# lsblk -l
NAME  MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sda     8:0    0 238.5G  0 disk
sda1    8:1    0   512M  0 part /boot/efi
sda2    8:2    0    23G  0 part /
sda3    8:3    0   212G  0 part /home
sda4    8:4    0     3G  0 part
[manjaro boot]# cat /etc/fstab
# <file system>             <mount point>  <type>  <options>  <dump>  <pass>
UUID=967B-DD95                            /boot/efi      vfat    umask=0077 0 2
UUID=0e80bbe4-aed2-4f8d-9585-ff0caae4b265 /              ext4    defaults,noatime 0 1
UUID=951024f3-a06a-4604-8b8a-b3532c491e4f /home          ext4    defaults,noatime 0 2
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
[manjaro boot]# efibootmgr -v
BootCurrent: 0004
Timeout: 1 seconds
BootOrder: 0003,0004,0005
Boot0003* UEFI OS       HD(1,GPT,7b147200-18a6-8f45-98e1-810b0660c330,0x800,0x100000)/File(\EFI\BOOT\BOOTX64.EFI)..BO
Boot0004* UEFI: Memorex Cool Drive B PMAP       PciRoot(0x0)/Pci(0x14,0x0)/USB(1,0)/CDROM(1,0x46ef5c,0x8000)..BO
Boot0005  UEFI: Memorex Cool Drive B PMAP, Partition 1  PciRoot(0x0)/Pci(0x14,0x0)/USB(1,0)/HD(1,MBR,0x0,0x46ef5c,0x2000)..BO
The contents of /boot/*:
[manjaro boot]# ls * -R
initramfs-5.10-x86_64-fallback.img  initramfs-5.11-x86_64-fallback.img  intel-ucode.img       linux511-x86_64.kver  vmlinuz-5.11-x86_64
initramfs-5.10-x86_64.img           initramfs-5.11-x86_64.img           linux510-x86_64.kver  vmlinuz-5.10-x86_64
efi:
EFI
efi/EFI:
Manjaro  boot
efi/EFI/Manjaro:
grubx64.efi
efi/EFI/boot:
bootx64.efi
grub:
fonts  grub.cfg  grubenv  themes  x86_64-efi
grub/fonts:
unicode.pf2
grub/themes:
starfield
grub/themes/starfield:
COPYING.CC-BY-SA-3.0  boot_menu_e.png   boot_menu_s.png   dejavu_10.pf2  dejavu_bold_14.pf2  starfield.png       terminal_box_ne.png  terminal_box_sw.png
README                boot_menu_n.png   boot_menu_se.png  dejavu_12.pf2  slider_c.png        terminal_box_c.png  terminal_box_nw.png  terminal_box_w.png
blob_w.png            boot_menu_ne.png  boot_menu_sw.png  dejavu_14.pf2  slider_n.png        terminal_box_e.png  terminal_box_s.png   theme.txt
boot_menu_c.png       boot_menu_nw.png  boot_menu_w.png   dejavu_16.pf2  slider_s.png        terminal_box_n.png  terminal_box_se.png
grub/x86_64-efi:
acpi.mod              cmp.mod         ext2.mod             geli.mod                  loadenv.mod      mpi.mod              pbkdf2.mod          signature_test.mod    usbserial_ftdi.mod
adler32.mod           cmp_test.mod    extcmd.mod           gettext.mod               loopback.mod     msdospart.mod        pbkdf2_test.mod     sleep.mod             usbserial_pl2303.mod
affs.mod              command.lst     f2fs.mod             gfxmenu.mod               ls.mod           mul_test.mod         pcidump.mod         sleep_test.mod        usbserial_usbdebug.mod
afs.mod               configfile.mod  fat.mod              gfxterm.mod               lsacpi.mod       multiboot.mod        pgp.mod             smbios.mod            usbtest.mod
afsplitter.mod        core.efi        file.mod             gfxterm_background.mod    lsefi.mod        multiboot2.mod       play.mod            spkmodem.mod          verifiers.mod
ahci.mod              cpio.mod        fixvideo.mod         gfxterm_menu.mod          lsefimmap.mod    nativedisk.mod       png.mod             squash4.mod           video.lst
all_video.mod         cpio_be.mod     font.mod             gptsync.mod               lsefisystab.mod  net.mod              priority_queue.mod  strtoull_test.mod     video.mod
aout.mod              cpuid.mod       fs.lst               grub.efi                  lsmmap.mod       newc.mod             probe.mod           syslinuxcfg.mod       video_bochs.mod
appleldr.mod          crc64.mod       fshelp.mod           gzio.mod                  lspci.mod        nilfs2.mod           procfs.mod          tar.mod               video_cirrus.mod
archelp.mod           crypto.lst      functional_test.mod  halt.mod                  lssal.mod        normal.mod           progress.mod        terminal.lst          video_colors.mod
at_keyboard.mod       crypto.mod      gcry_arcfour.mod     hashsum.mod               luks.mod         ntfs.mod             raid5rec.mod        terminal.mod          video_fb.mod
ata.mod               cryptodisk.mod  gcry_blowfish.mod    hdparm.mod                luks2.mod        ntfscomp.mod         raid6rec.mod        terminfo.mod          videoinfo.mod
backtrace.mod         cs5536.mod      gcry_camellia.mod    hello.mod                 lvm.mod          odc.mod              random.mod          test.mod              videotest.mod
bfs.mod               ctz_test.mod    gcry_cast5.mod       help.mod                  lzopio.mod       offsetio.mod         rdmsr.mod           test_blockarg.mod     videotest_checksum.mod
bitmap.mod            date.mod        gcry_crc.mod         hexdump.mod               macbless.mod     ohci.mod             read.mod            testload.mod          wrmsr.mod
bitmap_scale.mod      datehook.mod    gcry_des.mod         hfs.mod                   macho.mod        part_acorn.mod       reboot.mod          testspeed.mod         xfs.mod
blocklist.mod         datetime.mod    gcry_dsa.mod         hfsplus.mod               mdraid09.mod     part_amiga.mod       regexp.mod          tftp.mod              xnu.mod
boot.mod              disk.mod        gcry_idea.mod        hfspluscomp.mod           mdraid09_be.mod  part_apple.mod       reiserfs.mod        tga.mod               xnu_uuid.mod
boottime.mod          diskfilter.mod  gcry_md4.mod         http.mod                  mdraid1x.mod     part_bsd.mod         relocator.mod       time.mod              xnu_uuid_test.mod
bsd.mod               div.mod         gcry_md5.mod         iorw.mod                  memdisk.mod      part_dfly.mod        romfs.mod           tpm.mod               xzio.mod
bswap_test.mod        div_test.mod    gcry_rfc2268.mod     iso9660.mod               memrw.mod        part_dvh.mod         scsi.mod            tr.mod                zfs.mod
btrfs.mod             dm_nv.mod       gcry_rijndael.mod    jfs.mod                   minicmd.mod      part_gpt.mod         search.mod          trig.mod              zfscrypt.mod
bufio.mod             echo.mod        gcry_rmd160.mod      jpeg.mod                  minix.mod        part_msdos.mod       search_fs_file.mod  true.mod              zfsinfo.mod
cacheinfo.mod         efi_gop.mod     gcry_rsa.mod         json.mod                  minix2.mod       part_plan.mod        search_fs_uuid.mod  udf.mod               zstd.mod
cat.mod               efi_uga.mod     gcry_seed.mod        keylayouts.mod            minix2_be.mod    part_sun.mod         search_label.mod    ufs1.mod
cbfs.mod              efifwsetup.mod  gcry_serpent.mod     keystatus.mod             minix3.mod       part_sunpc.mod       serial.mod          ufs1_be.mod
cbls.mod              efinet.mod      gcry_sha1.mod        ldm.mod                   minix3_be.mod    partmap.lst          setjmp.mod          ufs2.mod
cbmemc.mod            ehci.mod        gcry_sha256.mod      legacy_password_test.mod  minix_be.mod     parttool.lst         setjmp_test.mod     uhci.mod
cbtable.mod           elf.mod         gcry_sha512.mod      legacycfg.mod             mmap.mod         parttool.mod         setpci.mod          usb.mod
cbtime.mod            eval.mod        gcry_tiger.mod       linux.mod                 moddep.lst       password.mod         sfs.mod             usb_keyboard.mod
chain.mod             exfat.mod       gcry_twofish.mod     linux16.mod               modinfo.sh       password_pbkdf2.mod  shift_test.mod      usbms.mod
cmdline_cat_test.mod  exfctest.mod    gcry_whirlpool.mod   loadbios.mod              morse.mod        pata.mod             shim_lock.mod       usbserial_common.mod
memtest86+:
memtest.bin
syslinux:
syslinux.cfg
How should I proceed? Thanks in advance.
