Ukui pre1 is broken
controll center seems too be broken afther clean install
it pop up and the crash
how too fix this
rude really rude
Did you install all UKUI applications?
its from that ukiu pr1 iso that comes uot also with deepin pr1 iso
Whut? :face_with_raised_eyebrow:
that one but after install control center is broken
Ahh there is a specific UKUI iso? Myself I picked the Deepin iso and installed UKUI above it, as described here:
In Pamac, I installed all the UKUI related packages.
Maybe try the same, select and reinstall all UKUI packages, especially UKUI control center.
will try that thx
