Hi i use last manjaro release (xfce 20.1.1) and i try to install ukui but i have some problems, i can not acces to ukui control center i have this error:
i use last ukui stable version (in the official repo)
Scan Plugin: "libabout.so"
Create youker Interface Failed When Get Computer info: QDBusError("org.freedesktop.DBus.Error.ServiceUnknown", "The name com.kylin.assistant.systemdaemon was not provided by any .service files")
Create active Interface Failed When Get Computer info: QDBusError("org.freedesktop.DBus.Error.ServiceUnknown", "The name org.freedesktop.activation was not provided by any .service files")
Load Plugin : "Messages" -> "About"
Scan Plugin: "libarea.so"
Segmentation fault (core dumped)
i reboot my virtal machine
i select ukui in the login screen and i start my session
ukui start correctly (i have start screen and desktop…)
but i have same problem with the control manager.
I tested UKUI inside a Manjaro Deepin VM. I installed all the UKUI packages (from Manjaro repos) from pamac, including UKUI control manager, and it launched fine after reboot.
Not in front of the computer right now but I went on Pamac (so in GUI), typed UKUI and selected for install all UKUI-something applications from Manjaro official repositories. So the latest version to date.
There were also UKUI packages from AUR, but I didn’t pick them. There were some dependencies from some apps installed alongside.
It’s a 2011 Dell, with i5-2520M, Nvidia NVS 4200M and 8Go RAM.
To be really sure of all UKUI packages you install, better use GUI Pamac as in my previous post screenshot.
I don’t know if your command sudo pacman -S ukui really installs ukui related packages without the name ukui in it, like peony
Nope, I don’t think so (I don’t currently have UKUI or Deepin VM right now). Maybe another instance launched of a pinned application from taskbar?
Or it’s really on the desktop that all is in double ?
