Uknown network interface
Hello,
I am using manjaro kde and am having an issue with a network interface
vxlan.calico: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1410
It activates it self every time i open the computer and it reactivates it self every time i try to delete/disable it. When i try ifconfig down it permanently disables but reactivates on the next boot.
Is there a way to figure out where its created and why so i can remove it?
:+1: Welcome to Manjaro! :+1:
  1. Please read this:
    How to provide good information
    and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies… :grin:
  2. An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
    Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
  3. Are you running any of the following: Kubernetes, OpenShift, Docker EE, OpenStack and does the issue go away if you stop these?
:+1:
P.S. If you enter a bit more details in your profile, we can also see which Desktop Environment you’re using, which CPU/GPU or Kernel, … you have without typing it every time
Thank you for your response!
The output of the inxi --admin --verbosity=7 --filter --no-host --width command is this :
a52dec 0.7.4-11
aalib 1.4rc5-14
accounts-qml-module 0.7-4
accountsservice 0.6.55-3
acl 2.3.1-1
acpi 1.7-3
acpid 2.0.32-2
adobe-source-code-pro-fonts 2.038ro+1.058it+1.018var-1
adwaita-icon-theme 40.0-1
aircrack-ng 1.6-4
aisleriot 3.22.14-1
alsa-card-profiles 1:0.3.26-1
alsa-firmware 1.2.4-2
alsa-lib 1.2.5-2
alsa-oss 1.1.8-3
alsa-plugins 1:1.2.5-2
alsa-topology-conf 1.2.5-1
alsa-ucm-conf 1.2.5-1
alsa-utils 1.2.5-3
android-tools 31.0.0-2
android-udev 20210425-1
ansible 4.0.0-1
ansible-core 2.11.1-1
aom 3.0.0-2
apparmor 3.0.1-3
appimagelauncher 2.2.0-5
appstream 0.14.3-1
appstream-glib 0.7.18-2
appstream-qt 0.14.3-1
archlinux-appstream-data 20210423-1
archlinux-keyring 20210110-1
argon2 20190702-3
ark 21.04.1-1
at-spi2-atk 2.38.0-1
at-spi2-core 2.40.2-1
atk 2.36.0-1
attica 5.81.0-1
attr 2.5.1-1
audiofile 0.3.6-6
audit 3.0.1-1
avahi 0.8+20+gd1e71b3-1
b43-fwcutter 019-3
babl 0.1.86-1
baloo 5.81.0-1
baloo-widgets 21.04.1-1
bash 5.1.004-1
bashrc-manjaro 5.1.004-1
bc 1.07.1-4
binutils 2.36.1-3
blas 3.9.1-1
bluedevil 1:5.21.4-1
bluez 5.58-1
bluez-libs 5.58-1
bluez-qt 5.81.0-1
boost-libs 1.75.0-5
botan 2.18.0-1
breath2-icon-themes 1.0.13-1
breath2-wallpaper 1.0.13-1
breeze 5.21.4-1
breeze-icons 5.81.0-1
brotli 1.0.9-4
btrfs-progs 5.11.1-1
bubblewrap 0.4.1-1
bzip2 1.0.8-4
ca-certificates 20210529-1
ca-certificates-mozilla 3.66-1
ca-certificates-utils 20210529-1
cairo 1.17.4-5
cantarell-fonts 1:0.301-1
cantata 2.4.2-1
cdparanoia 10.2-8
cdrdao 1.2.4-2
cdrtools 3.02a09-4
ceph-libs 15.2.12-1
cfitsio 1:3.49-1
chromaprint 1.5.0-3
cifs-utils 6.13-2
ckbcomp 1.194-1
clucene 2.3.3.4-11
colord 1.4.5-4
colord-sane 1.4.5-4
confuse 3.3-3
convertlit 1.8-10
coreutils 8.32-1
cpupower 5.12-1
crda 4.14-4
cronie 1.5.7-2
cryptsetup 2.3.6-1
cups 1:2.3.3op2-3
cups-filters 1.28.8-1
cups-pdf 3.0.1-6
cups-pk-helper 0.2.6-4
curl 7.77.0-1
dav1d 0.9.0-1
db 5.3.28-5
dbus 1.12.20-1
dbus-glib 0.112-1
dbus-python 1.2.16-4
dconf 0.40.0-1
ddcutil 1.1.0-1
desktop-file-utils 0.26-1
device-mapper 2.03.11-5
dhclient 4.4.2.P1-1
dhcpcd 9.4.0-1
diffutils 3.7-3
ding-libs 0.6.1-3
discord 0.0.14-1
discount 2.2.7-1
djvulibre 3.5.28-3
dmidecode 3.3-1
dmraid 1.0.0.rc16.3-13
dnsmasq 2.85-1
dnssec-anchors 20190629-3
docbook-xml 4.5-9
docbook-xsl 1.79.2-7
dolphin 21.04.1-1
dolphin-plugins 21.04.1-1
dosfstools 4.2-1
double-conversion 3.1.5-2
dvd+rw-tools 7.1-9
e2fsprogs 1.46.2-1
ebook-tools 0.2.2-7
ecryptfs-utils 111-4
editorconfig-core-c 0.12.4-1
efibootmgr 17-2
efivar 37-4
elfutils 0.185-1
emovix 0.9.0-8
enchant 2.2.15-2
ethtool 1:5.10-1
exfat-utils 1.3.0-2
exiv2 0.27.3-1
expat 2.4.1-1
f2fs-tools 1.14.0-1
faac 1.30-2
faad2 2.10.0-1
ffmpeg 2:4.4-2
ffmpegthumbs 21.04.1-1
fftw 3.3.9-1
file 5.40-2
filelight 21.04.1-1
filesystem 2021.01.19-1
findutils 4.8.0-1
firefox 89.0.2-0.1
flac 1.3.3-2
flashrom 1.2-2
flatpak 1.11.1-2
fluidsynth 2.1.8-1
fmt 7.1.3-1
fontconfig 2:2.13.93-4
foomatic-db 3:20210528-1
foomatic-db-engine 4:20200206-1
foomatic-db-gutenprint-ppds 5.3.4-1
frameworkintegration 5.81.0-1
freeglut 3.2.1-2
freetype2 2.10.4-1
fribidi 1.0.10-1
fuse-common 3.10.3-1
fuse2 2.9.9-4
fuse3 3.10.3-1
fwupd 1.5.9-1
game-devices-udev 0.13-1
gawk 5.1.0-1
gc 8.0.4-4
gcab 1.4-1
gcc 11.1.0-1
gcc-libs 11.1.0-1
gcr 3.40.0-1
gd 2.3.2-2
gdbm 1.19-2
gdk-pixbuf2 2.42.6-1
gegl 0.4.30-3
geoclue 2.5.7-3
geocode-glib 3.26.2-1
gettext 0.21-1
ghostscript 9.54.0-2
giflib 5.2.1-2
gimp 2.10.24-4
git 2.32.0-1
glew 2.2.0-2
glib-networking 1:2.68.1-1
glib2 2.68.2-1
glibc 2.33-5
glslang 11.4.0-1
glu 9.0.1-2
gmp 6.2.1-1
gnome-icon-theme 3.12.0-6
gnome-icon-theme-symbolic 3.12.0-6
gnome-sudoku 40.1-1
gnome-themes-extra 3.28-2
gnupg 2.2.27-1
gnustep-base 1.27.0-3
gnutls 3.7.2-1
gobject-introspection-runtime 1.68.0-1
gpgme 1.15.1-1
gpm 1.20.7.r38.ge82d1a6-3
gptfdisk 1.0.7-1
grantlee 5.2.0-3
graphene 1.10.6-1
graphite 1:1.3.14-1
graphviz 2.47.2-1
grep 3.6-1
groff 1.22.4-5
grub 2.06-1
grub-theme-manjaro 20.2-12
gsettings-desktop-schemas 40.0-3
gsfonts 20200910-2
gsm 1.0.19-1
gssdp 1.2.3-1
gssproxy 0.8.4-1
gst-libav 1.18.4-1
gst-plugins-bad 1.18.4-7
gst-plugins-bad-libs 1.18.4-7
gst-plugins-base 1.18.4-1
gst-plugins-base-libs 1.18.4-1
gst-plugins-good 1.18.4-2
gst-plugins-ugly 1.18.4-2
gstreamer 1.18.4-1
gtk-theme-breath 5.9.0-1
gtk-update-icon-cache 1:4.2.0-5
gtk2 2.24.33-2
gtk3 1:3.24.29-2
gts 0.7.6.121130-2
guile 2.2.7-1
gupnp 1.2.7-1
gupnp-igd 1.2.0-1
gutenprint 5.3.4-1
gvfs 1.48.1-1
gvfs-afc 1.48.1-1
gvfs-gphoto2 1.48.1-1
gvfs-mtp 1.48.1-1
gvfs-nfs 1.48.1-1
gvfs-smb 1.48.1-1
gwenview 21.04.1-1
gzip 1.10-3
harfbuzz 2.8.0-3
harfbuzz-icu 2.8.0-3
hdparm 9.60-1
hicolor-icon-theme 0.17-2
hidapi 0.10.1-1
hplip 1:3.21.4-1
htop 3.0.5-1
http-parser 2.9.4-1
hunspell 1.7.0-3
hwids 20201207-1
hwinfo 21.74-1
hwloc 2.4.1-1
hyphen 2.8.8-3
iana-etc 20210202-1
icu 69.1-1
ijs 0.35-3
illyria-wallpaper 1.4-1
imagemagick 7.0.11.10-1
imath 3.0.4-1
imlib2 1.7.1-1
inetutils 2.0-1
iniparser 4.1-3
intel-ucode 20210216-1
intltool 0.51.0-6
inxi 3.3.04.1-1
iproute2 5.12.0-1
iptables 1:1.8.7-1
iputils 20210202-1
iso-codes 4.6.0-1
iw 5.9-1
jack 0.125.0-9
jansson 2.13.1-1
jasper 2.0.28-1
jbig2dec 0.19-1
jemalloc 1:5.2.1-3
jfsutils 1.1.15-7
js78 78.10.0-1
json-c 0.15-1
json-glib 1.6.2-1
k3b 1:21.04.1-1
kaccounts-integration 21.04.1-1
kaccounts-providers 21.04.1-1
kactivities 5.81.0-1
kactivities-stats 5.81.0-1
kactivitymanagerd 5.21.4-1
kamera 21.04.1-1
karchive 5.81.0-1
kate 21.04.1-1
kauth 5.81.0-1
kazam 1.4.5-9
kbd 2.4.0-2
kbookmarks 5.81.0-1
kcalc 21.04.1-1
kcmutils 5.81.0-1
kcodecs 5.81.0-1
kcolorpicker 0.1.6-1
kcompletion 5.81.0-1
kconfig 5.81.0-1
kconfigwidgets 5.81.0-1
kcontacts 1:5.81.0-1
kcoreaddons 5.81.0-1
kcrash 5.81.0-1
kdbusaddons 5.81.0-1
kde-cli-tools 5.21.4-1
kde-gtk-config 5.21.4-1
kdeclarative 5.81.0-1
kdeconnect 21.04.1-2
kdecoration 5.21.4-1
kded 5.81.0-1
kdegraphics-thumbnailers 21.04.1-1
kdelibs4support 5.81.0-1
kdenetwork-filesharing 21.04.1-1
kdeplasma-addons 5.21.4-1
kdesu 5.81.0-1
kdnssd 5.81.0-1
kdoctools 5.81.0-1
kdsoap 1.10.0-1
kdsoap-ws-discovery-client git20200927-1
keditbookmarks 21.04.1-1
kemoticons 5.81.0-1
kernel-alive 0.5-1
keyutils 1.6.3-1
kfilemetadata 5.81.0-1
kfind 21.04.1-1
kgamma5 5.21.4-1
kget 21.04.1-1
kglobalaccel 5.81.0-1
kguiaddons 5.81.0-1
khelpcenter 21.04.1-1
kholidays 1:5.81.0-1
khotkeys 5.21.4-1
khtml 5.81.0-1
ki18n 5.81.0-1
kiconthemes 5.81.0-1
kidletime 5.81.0-1
kimageannotator 0.5.1-1
kimageformats 5.81.0-2
kinfocenter 5.21.4-1
kinit 5.81.0-1
kio 5.81.0-1
kio-extras 21.04.1-2
kirigami2 5.81.0-1
kitemmodels 5.81.0-1
kitemviews 5.81.0-1
kjobwidgets 5.81.0-1
kjs 5.81.0-1
kmenuedit 5.21.4-1
kmod 29-1
knewstuff 5.81.0-1
knotifications 5.81.0-1
knotifyconfig 5.81.0-1
konsole 21.04.1-1
konversation 21.04.1-1
kpackage 5.81.0-1
kparts 5.81.0-1
kpeople 5.81.0-1
kpeoplevcard 0.1+r38.32d50a9-1
kpmcore 21.04.1-1
kpty 5.81.0-1
kquickcharts 5.81.0-1
krb5 1.19.1-1
krunner 5.81.0-1
kscreen 5.21.4-1
kscreenlocker 5.21.4-1
kservice 5.81.0-1
ksshaskpass 5.21.4-1
ksysguard 5.21.4-1
ksystemlog 21.04.1-1
ktexteditor 5.81.0-1
ktextwidgets 5.81.0-1
kunitconversion 5.81.0-1
kuserfeedback 1.0.0-1
kwallet 5.81.0-1
kwallet-pam 5.21.4-1
kwalletmanager 21.04.1-1
kwayland 5.81.0-1
kwayland-integration 5.21.4-1
kwayland-server 5.21.4-1
kwidgetsaddons 5.81.0-1
kwin 5.21.4-1
kwindowsystem 5.81.0-1
kwrited 5.21.4-1
kxmlgui 5.81.0-1
l-smash 2.14.5-2
lame 3.100-3
lapack 3.9.1-1
lcms2 2.12-1
ldb 1:2.3.0-1
ldns 1.7.1-2
lensfun 0.3.95-4
less 1:581.2-1
lib32-alsa-lib 1.2.5-2
lib32-alsa-plugins 1.2.5-1
lib32-at-spi2-atk 2.38.0-1
lib32-at-spi2-core 2.40.0-1
lib32-atk 2.36.0-2
lib32-brotli 1.0.9-1
lib32-bzip2 1.0.8-2
lib32-cairo 1.17.4-5
lib32-colord 1.4.5-3
lib32-curl 7.77.0-1
lib32-db 5.3.28-4
lib32-dbus 1.12.20-1
lib32-e2fsprogs 1.46.2-2
lib32-expat 2.4.1-1
lib32-flac 1.3.3-1
lib32-fontconfig 2:2.13.93-4
lib32-freetype2 2.10.4-1
lib32-fribidi 1.0.10-1
lib32-gcc-libs 11.1.0-1
lib32-gdk-pixbuf2 2.42.6-1
lib32-glew 2.2.0-1
lib32-glib-networking 2.68.0-1
lib32-glib2 2.68.2-1
lib32-glibc 2.33-5
lib32-glu 9.0.1-1
lib32-gmp 6.2.1-1
lib32-gnutls 3.7.2-1
lib32-gtk3 3.24.27-2
lib32-harfbuzz 2.8.0-3
lib32-icu 69.1-1
lib32-jack 0.125.0-3
lib32-json-glib 1.6.2-1
lib32-keyutils 1.6.3-1
lib32-krb5 1.19.1-1
lib32-lcms2 2.12-1
lib32-libasyncns 0.8+3+g68cd5af-2
lib32-libcanberra 0.30+2+gc0620e4-4
lib32-libcap 2.50-1
lib32-libcups 2.3.3-1
lib32-libdatrie 0.2.13-1
lib32-libdrm 2.4.106-1
lib32-libelf 0.185-1
lib32-libepoxy 1.5.8-1
lib32-libffi 3.3-2
lib32-libgcrypt 1.9.3-1
lib32-libglvnd 1.3.3-1
lib32-libgpg-error 1.42-1
lib32-libice 1.0.10-1
lib32-libidn2 2.3.1-1
lib32-libjpeg-turbo 2.1.0-1
lib32-libldap 2.4.58-1
lib32-libltdl 2.4.6+42+gb88cebd5-1
lib32-libnsl 1.3.0-2
lib32-libogg 1.3.5-1
lib32-libpciaccess 0.16-1
lib32-libpng 1.6.37-3
lib32-libproxy 0.4.17-1
lib32-libpsl 0.21.1-1
lib32-libpulse 14.2-2
lib32-librsvg 2:2.50.7-1
lib32-libsm 1.2.3-1
lib32-libsndfile 1.0.31-1
lib32-libsoup 2.72.0-1
lib32-libssh2 1.9.0-1
lib32-libtasn1 4.16.0-2
lib32-libthai 0.1.28-1
lib32-libtiff 4.3.0-1
lib32-libtirpc 1.3.2-1
lib32-libunistring 0.9.10-1
lib32-libunwind 1.5.0-1
lib32-libusb 1.0.24-1
lib32-libva 2.11.0-1
lib32-libva-intel-driver 2.4.1-1
lib32-libva-mesa-driver 21.1.2-1
lib32-libva-vdpau-driver 0.7.4-6
lib32-libvdpau 1.4-1
lib32-libvorbis 1.3.7-1
lib32-libx11 1.7.2-1
lib32-libxau 1.0.9-1
lib32-libxcb 1.14-1
lib32-libxcomposite 0.4.5-1
lib32-libxcrypt 4.4.19-1
lib32-libxcursor 1.2.0-1
lib32-libxdamage 1.1.5-1
lib32-libxdmcp 1.1.3-1
lib32-libxext 1.3.4-1
lib32-libxfixes 5.0.3-2
lib32-libxft 2.3.3-1
lib32-libxi 1.7.10-2
lib32-libxinerama 1.1.4-1
lib32-libxkbcommon 1.2.1-1
lib32-libxml2 2.9.10-4
lib32-libxmu 1.1.3-1
lib32-libxrandr 1.5.2-1
lib32-libxrender 0.9.10-2
lib32-libxshmfence 1.3-2
lib32-libxss 1.2.3-1
lib32-libxt 1.2.1-1
lib32-libxtst 1.2.3-2
lib32-libxxf86vm 1.1.4-2
lib32-llvm-libs 12.0.0-1
lib32-lm_sensors 1:3.6.0.r41.g31d1f125-1
lib32-mesa 21.1.2-1
lib32-mesa-demos 8.4.0-2
lib32-mesa-vdpau 21.1.2-1
lib32-ncurses 6.2-1
lib32-nettle 3.7.2-1
lib32-nspr 4.31-1
lib32-nss 3.66-1
lib32-openssl 1:1.1.1.k-1
lib32-opus 1.3.1-1
lib32-p11-kit 0.23.22-1
lib32-pam 1.5.1-1
lib32-pango 1:1.48.5-1
lib32-pcre 8.44-1
lib32-pixman 0.40.0-1
lib32-readline 8.1.0-2
lib32-rest 0.8.1-3
lib32-sqlite 3.35.5-1
lib32-systemd 247.6-1
lib32-tdb 1.4.3-1
lib32-util-linux 2.37-1
lib32-vulkan-icd-loader 1.2.176-1
lib32-vulkan-intel 21.1.2-1
lib32-vulkan-radeon 21.1.2-1
lib32-wayland 1.19.0-1
lib32-xz 5.2.5-2
lib32-zlib 1.2.11-3
lib32-zstd 1.5.0-2
libabw 0.1.3-2
libaccounts-glib 1.25-4
libaccounts-qt 1.16-3
libaio 0.3.112-2
libao 1.2.2-5
libappimage 1.0.3-3
libarchive 3.5.1-1
libass 0.15.0-2
libassuan 2.5.5-1
libasyncns 0.8+3+g68cd5af-3
libatasmart 0.19-5
libatomic_ops 7.6.10-2
libavc1394 0.5.4-4
libavif 0.9.0-2
libavtp 0.1.0-2
libblockdev 2.25-2
libbluray 1.3.0-1
libbs2b 3.1.0-7
libbsd 0.10.0-2
libburn 1.5.4-1
libbytesize 2.5-1
libcaca 0.99.beta19-5
libcap 2.50-1
libcap-ng 0.8.2-1
libcddb 1.3.2-6
libcdio 2.1.0-2
libcdio-paranoia 10.2+2.0.1-2
libcdr 0.1.7-2
libcloudproviders 0.3.1-2
libcmis 0.5.2-7
libcolord 1.4.5-4
libcroco 0.6.13-2
libcups 1:2.3.3op2-3
libdaemon 0.14-5
libdatrie 0.2.13-1
libdbusmenu-qt5 0.9.3+16.04.20160218-5
libdc1394 2.2.6-2
libdca 0.0.7-1
libde265 1.0.8-1
libdmtx 0.7.5-2
libdrm 2.4.106-1
libdv 1.0.0-9
libdvbpsi 1:1.3.3-2
libdvdcss 1.4.3-1
libdvdnav 6.1.1-1
libdvdread 6.1.2-1
libe-book 0.1.3-9
libebml 1.4.2-1
libebur128 1.2.6-1
libedit 20210522_3.1-1
libelf 0.185-1
libepoxy 1.5.8-1
libepubgen 0.1.1-2
libetonyek 0.1.10-1
libevdev 1.11.0-1
libevent 2.1.12-1
libexif 0.6.22-1
libexttextcat 3.4.5-2
libfakekey 0.3-2
libfdk-aac 2.0.2-1
libffi 3.3-4
libfontenc 1.1.4-3
libfreehand 0.1.2-3
libftdi 1.5-2
libgcrypt 1.9.3-1
libgee 0.20.4-1
libgexiv2 0.12.2-1
libgit2 1:1.1.0-1
libglvnd 1.3.3-1
libgme 0.6.3-1
libgpg-error 1.42-1
libgphoto2 2.5.27-1
libgudev 236-1
libgusb 0.3.7-1
libheif 1.11.0-3
libibus 1.5.24-1
libical 3.0.10-1
libice 1.0.10-3
libid3tag 0.15.1b-11
libidn 1.37-1
libidn2 2.3.1-1
libiec61883 1.2.0-6
libieee1284 0.2.11-11
libimagequant 2.14.1-1
libimobiledevice 1.3.0-3
libinih 53-1
libinput 1.18.0-1
libinstpatch 1.1.6-1
libixion 0.16.1-5
libjcat 0.1.6-1
libkate 0.4.1-7
libkcddb 21.04.1-1
libkdcraw 21.04.1-1
libkexiv2 21.04.1-1
libkeybinder3 0.3.2-3
libkipi 21.04.1-1
libksane 21.04.1-1
libksba 1.4.0-2
libkscreen 5.21.4-1
libksysguard 5.21.4-1
libktorrent 21.04.1-1
liblangtag 0.6.3-2
libldac 2.0.2.3-1
libldap 2.4.58-3
liblouis 3.18.0-1
liblqr 0.4.2-3
liblrdf 0.6.1-4
libmad 0.15.1b-9
libmanette 0.2.6-1
libmatroska 1.6.3-1
libmbim 1.24.8-1
libmfx 21.1.3-2
libmicrodns 0.2.0-1
libmicrohttpd 0.9.73-1
libmikmod 3.3.11.1-4
libmm-glib 1.16.6-1
libmms 0.6.4-3
libmng 2.0.3-3
libmnl 1.0.4-3
libmodplug 0.8.9.0-3
libmpc 1.2.1-1
libmpcdec 1:0.1+r475-3
libmpdclient 2.19-3
libmpeg2 0.5.1-7
libmspub 0.1.4-10
libmtp 1.1.18-1
libmusicbrainz5 5.1.0-4
libmwaw 0.3.19-1
libmypaint 1.6.1-1
libndp 1.8-1
libnetfilter_conntrack 1.0.8-1
libnewt 0.52.21-5
libnfnetlink 1.0.1-4
libnfs 4.0.0-4
libnftnl 1.2.0-1
libnghttp2 1.43.0-1
libnice 0.1.18-2
libnl 3.5.0-3
libnm 1.30.4-1
libnotify 0.7.9-1
libnsl 1.3.0-2
libnumbertext 1.0.7-1
libodfgen 0.1.8-1
libofa 0.9.3-9
libogg 1.3.5-1
libomxil-bellagio 0.9.3-3
libopenaptx 0.2.0-1
liborcus 0.16.1-6
libp11-kit 0.23.22-1
libpagemaker 0.0.4-2
libpaper 1.1.28-1
libpcap 1.10.0-1
libpciaccess 0.16-2
libpgm 5.3.128-1
libpipeline 1.5.3-1
libplacebo 3.120.2-1
libplist 2.2.0-3
libpng 1.6.37-3
libproxy 0.4.17-2
libpsl 0.21.1-1
libpulse 14.2-3
libqaccessibilityclient 0.4.1-2
libqalculate 3.19.0-1
libqmi 1.28.6-1
libqrtr-glib 1.0.0-1
libqxp 0.0.2-6
libraqm 0.7.1-1
libraw 0.20.2-1
libraw1394 2.1.2-3
libreoffice-still 7.0.5-3
librevenge 0.0.4-3
librsvg 2:2.50.7-1
libsamplerate 0.2.1-1
libsasl 2.1.27-3
libseccomp 2.5.1-2
libsecret 0.20.4-1
libshout 1:2.4.5-1
libsidplay 1.36.59-10
libsidplayfp 2.1.1-1
libsm 1.2.3-2
libsmbios 2.4.3-3
libsndfile 1.0.31-1
libsodium 1.0.18-2
libsoup 2.72.0+10+gfe1e295d-1
libsoxr 0.1.3-2
libspectre 0.2.9-2
libspiro 1:20200505-2
libsrtp 1:2.3.0-1
libssh 0.9.5-1
libssh2 1.9.0-3
libstaroffice 0.0.7-1
libstemmer 0+713-2
libtar 1.2.20-5
libtasn1 4.17.0-1
libteam 1.31-3
libthai 0.1.28-2
libtheora 1.1.1-5
libtiff 4.3.0-1
libtirpc 1.3.2-1
libtommath 1.2.0-3
libtool 2.4.6+42+gb88cebd5-14
libtorrent-rasterbar 1:1.2.11-1
libunistring 0.9.10-3
libunwind 1.5.0-1
libupnp 1.14.6-1
liburing 2.0-1
libusb 1.0.24-2
libusb-compat 0.1.7-1
libusbmuxd 2.0.2-1
libutempter 1.2.1-1
libuv 1.41.0-1
libva 2.11.0-1
libva-vdpau-driver 0.7.4-5
libvdpau 1.4-1
libvisio 0.1.7-5
libvisual 0.4.0-8
libvorbis 1.3.7-2
libvpx 1.10.0-1
libwacom 1.10-1
libwebp 1.2.0-1
libwmf 0.2.12-2
libwnck3 3.36.0-1
libwpd 0.10.3-3
libwpe 1.10.0-1
libwpg 0.3.3-2
libwps 0.4.12-1
libx11 1.7.2-1
libx86emu 3.1-1
libxau 1.0.9-3
libxaw 1.0.14-1
libxcb 1.14-1
libxcomposite 0.4.5-3
libxcrypt 4.4.19-1
libxcursor 1.2.0-2
libxdamage 1.1.5-3
libxdmcp 1.1.3-3
libxext 1.3.4-3
libxfixes 6.0.0-1
libxfont2 2.0.4-3
libxft 2.3.3-2
libxi 1.7.10-3
libxinerama 1.1.4-3
libxkbcommon 1.3.0-1
libxkbcommon-x11 1.3.0-1
libxkbfile 1.1.0-2
libxml2 2.9.10-9
libxmlb 0.3.0-1
libxmu 1.1.3-2
libxpm 3.5.13-2
libxrandr 1.5.2-3
libxrender 0.9.10-4
libxres 1.2.1-1
libxshmfence 1.3-2
libxslt 1.1.34-5
libxss 1.2.3-3
libxt 1.2.1-1
libxtst 1.2.3-4
libxv 1.0.11-4
libxvmc 1.0.12-3
libxxf86vm 1.1.4-4
libyaml 0.2.5-1
libyuv r2212+dfaf7534-2
libzip 1.7.3-2
libzmf 0.0.2-10
licenses 20200427-1
lilv 0.24.12-1
linux-api-headers 5.12.3-1
linux-firmware 20210426.r1905.fa0efef-1
linux510 5.10.34-1
linux510-virtualbox-host-modules 6.1.22-2
lirc 1:0.10.1-8
llvm-libs 12.0.0-1
lmdb 0.9.29-1
logrotate 3.18.0-1
lpsolve 5.5.2.11-1
lsb-release 1.4-13
lsof 4.94.0-1
lua52 5.2.4-5
lua53 5.3.6-1
luajit 2.0.5-3
lvm2 2.03.11-5
lz4 1:1.9.3-2
lzo 2.10-3
mailcap 2.1.49-1
man-db 2.9.4-1
man-pages 5.11-1
manjaro-alsa 20210109-1
manjaro-application-utility 1.3.3-4.1
manjaro-base-skel 20171029-3
manjaro-browser-settings 20201114-1
manjaro-documentation-en 20181009-1
manjaro-firmware 20160419-1
manjaro-hello 0.6.6-5
manjaro-hotfixes 2018.08-6
manjaro-icons 20191015-1
manjaro-kde-settings 20200804-1
manjaro-keyring 20201216-1
manjaro-printer 20200215-2
manjaro-pulse 20210109-1
manjaro-release 21.0.4-1
manjaro-settings-manager 0.5.6-14
manjaro-settings-manager-kcm 0.5.6-14
manjaro-settings-manager-knotifier 0.5.6-14
manjaro-system 20210612-1
manjaro-wallpapers-18.0 1.4-3
manjaro-zsh-config 0.20-3
mariadb 10.5.9-1
mariadb-clients 10.5.9-1
mariadb-libs 10.5.9-1
md4c 0.4.7-1
mdadm 4.1-2
media-player-info 24-2
memtest86+ 5.01-4
mesa 21.1.2-1
mesa-demos 8.4.0-4
mesa-vdpau 21.1.2-1
metis 5.1.0.p10-2
mhwd 0.6.5-2
mhwd-amdgpu 19.1.0-1
mhwd-ati 19.1.0-1
mhwd-db 0.6.5-9
mhwd-nvidia 460.73.01-1
mhwd-nvidia-390xx 390.143-1
milou 5.21.4-1
minizip 1:1.2.11-4
mjpegtools 2.2.0beta-1
mkinitcpio 30-2
mkinitcpio-busybox 1.32.1-3
mkinitcpio-openswap 0.1.0-3
mobile-broadband-provider-info 20201225-1
modemmanager 1.16.6-1
modemmanager-qt 5.81.0-1
mpd 0.22.8-1
mpfr 4.1.0-1
mpg123 1.26.5-1
mtdev 1.1.6-1
mtpfs 1.1-4
mypaint-brushes1 1.3.1-1
nano 5.7-1
ncurses 6.2-1
ndctl 71.1-1
neon 0.31.2-1
nerd-fonts-noto-sans-mono 2.0.0-1
net-snmp 5.9.1-1
net-tools 2.10-1
netpbm 10.73.33-1
nettle 3.7.3-1
networkmanager 1.30.4-1
networkmanager-openconnect 1.2.7dev+49+gc512d5a-1
networkmanager-openvpn 1.8.14-1
networkmanager-pptp 1.2.9dev+10+gb41b0d0-3
networkmanager-qt 5.81.0-1
networkmanager-vpnc 1.2.7dev+20+gdca3aea-2
nfs-utils 2.5.3-1
nfsidmap 2.5.3-1
nmap 7.91-1
node-gyp 7.1.2-1
nodejs 16.0.0-1
noto-fonts 20201226-2
noto-fonts-cjk 20201206-2
noto-fonts-compat 20151217-1
noto-fonts-emoji 20200916-1
npm 7.11.2-1
npth 1.6-3
nspr 4.31-1
nss 3.66-1
nss-mdns 0.14.1-3
ntfs-3g 2017.3.23-5
ntp 4.2.8.p15-1
numlockx 1.2-5
oath-toolkit 2.6.6-2
oh-my-zsh r5951.86f805280-1
okular 21.04.1-1
openal 1.21.1-1
openconnect 1:8.10-1
opencore-amr 0.1.5-5
openexr 3.0.4-1
openjpeg2 2.4.0-1
openmpi 4.1.1-1
openresolv 3.12.0-1
openssh 8.6p1-1
openssl 1.1.1.k-1
openvpn 2.5.2-1
opus 1.3.1-2
orc 0.4.32-1
os-prober 1.78-0.1
ostree 2021.2-1
oxygen 5.21.4-1
oxygen-icons 1:5.81.0-1
p11-kit 0.23.22-1
p7zip 1:17.04-1
pacman 5.2.2-6
pacman-mirrors 4.21.3-2
pam 1.5.1-1
pamac-cli 10.0.6-2
pamac-common 10.0.6-2
pamac-flatpak-plugin 10.0.6-2
pamac-gtk 10.0.6-2
pamac-snap-plugin 10.0.6-2
pamac-tray-icon-plasma 0.1.2-4
pambase 20210605-2
pango 1:1.48.5-1
parted 3.4-2
partitionmanager 21.04.1-1
pciutils 3.7.0-1
pcre 8.44-1
pcre2 10.37-1
pcsclite 1.9.1-1
perl 5.34.0-1
perl-alien-build 2.40-3
perl-alien-libxml2 0.17-2
perl-capture-tiny 0.48-5
perl-clone 0.45-3
perl-dbi 1.643-3
perl-encode-locale 1.05-8
perl-error 0.17029-3
perl-ffi-checklib 0.28-2
perl-file-basedir 0.08-6
perl-file-chdir 0.1011-4
perl-file-desktopentry 0.22-8
perl-file-listing 6.14-2
perl-file-mimeinfo 0.30-2
perl-file-which 1.24-2
perl-html-parser 3.76-2
perl-html-tagset 3.20-11
perl-http-cookies 6.10-2
perl-http-daemon 6.06-3
perl-http-date 6.05-4
perl-http-message 6.32-2
perl-http-negotiate 6.01-9
perl-io-html 1.004-2
perl-ipc-system-simple 1.30-3
perl-libwww 6.53-1
perl-lwp-mediatypes 6.02-9
perl-mailtools 2.21-5
perl-net-http 6.21-2
perl-parse-yapp 1.21-4
perl-path-tiny 0.118-2
perl-timedate 2.33-3
perl-try-tiny 0.30-6
perl-uri 5.09-2
perl-www-robotrules 6.02-9
perl-xml-libxml 2.0207-2
perl-xml-namespacesupport 1.12-4
perl-xml-parser 2.46-3
perl-xml-sax 1.02-1
perl-xml-sax-base 1.09-4
perl-xml-writer 0.625-7
phonon-qt5 4.11.1-2
phonon-qt5-gstreamer 4.10.0-2
pinentry 1.1.1-1
pipewire 1:0.3.26-1
pixman 0.40.0-1
pkcs11-helper 1.27.0-1
pkgfile 21-2
plasma-desktop 5.21.4-1
plasma-framework 5.81.0-1
plasma-integration 5.21.4-1
plasma-nm 5.21.4-1
plasma-pa 5.21.4-1
plasma-simplemenu 1.0.12-1
plasma-workspace 5.21.4-1
plasma-workspace-wallpapers 5.21.4-1
plasma5-themes-breath2 1.0.13-1
polkit 0.119-1
polkit-kde-agent 5.21.4-1
polkit-qt5 0.113.0-2
poppler 21.04.0-2
poppler-data 0.4.10-1
poppler-glib 21.04.0-2
poppler-qt5 21.04.0-2
popt 1.18-1
portaudio 1:19.7.0-1
powerdevil 5.21.4-1
powertop 2.14-1
ppp 2.4.8-1
pptpclient 1.10.0-2
print-manager 21.04.1-1
prison 5.81.0-1
procps-ng 3.3.17-1
protobuf 3.15.8-1
psmisc 23.4-1
pulseaudio 14.2-3
pulseaudio-alsa 1:1.2.5-2
pulseaudio-bluetooth 14.2-3
pulseaudio-ctl 1.67-1
pulseaudio-equalizer 14.2-3
pulseaudio-jack 14.2-3
pulseaudio-lirc 14.2-3
pulseaudio-qt 1.3-1
pulseaudio-rtp 14.2-3
pulseaudio-zeroconf 14.2-3
purpose 5.81.0-1
python 3.9.4-1
python-appdirs 1.4.4-3
python-bcrypt 3.2.0-3
python-cachecontrol 0.12.6-3
python-cairo 1.20.0-3
python-cffi 1.14.5-1
python-chardet 4.0.0-1
python-colorama 0.4.4-3
python-contextlib2 0.6.0.post1-3
python-cryptography 3.4.7-1
python-distlib 0.3.2-1
python-distro 1.5.0-3
python-distutils-extra 2.39-8
python-dnspython 1:1.16.0-3
python-docopt 0.6.2-9
python-gobject 3.40.1-1
python-html5lib 1.1-6
python-idna 3.2-1
python-jinja 3.0.1-1
python-keyutils 0.6-6
python-markdown 3.3.4-1
python-markupsafe 2.0.1-1
python-msgpack 1.0.2-2
python-npyscreen 4.10.5-5
python-ordered-set 4.0.2-3
python-packaging 20.9-1
python-paramiko 2.7.2-3
python-pep517 0.10.0-1
python-pillow 8.2.0-2
python-pip 20.3.1-1
python-ply 3.11-7
python-progress 1.5-5
python-pycparser 2.20-3
python-pycups 2.0.1-3
python-pycurl 7.43.0.6-4
python-pynacl 1.4.0-3
python-pyopenssl 20.0.1-1
python-pyparsing 2.4.7-3
python-pyqt5 5.15.4-1
python-pyqt5-sip 12.9.0-1
python-pysmbc 1.0.23-2
python-pyxdg 0.27-1
python-reportlab 3.5.66-1
python-requests 2.25.1-1
python-resolvelib 0.5.4-1
python-retrying 1.3.3-9
python-setuptools 1:56.0.0-1
python-six 1.15.0-3
python-toml 0.10.2-3
python-urllib3 1.26.5-1
python-webencodings 0.5.1-6
python-yaml 5.4.1.1-2
qbittorrent 4.3.3-1
qca-qt5 2.3.3-1
qgpgme 1.15.1-1
qpdf 10.3.1-1
qqc2-desktop-style 5.81.0-1
qqwing 1.3.4-5
qrencode 4.1.1-1
qt5-base 5.15.2+kde+r196-1
qt5-declarative 5.15.2+kde+r28-1
qt5-graphicaleffects 5.15.2-1
qt5-imageformats 5.15.2-1
qt5-location 5.15.2-3
qt5-multimedia 5.15.2-1
qt5-quickcontrols 5.15.2-1
qt5-quickcontrols2 5.15.2-1
qt5-script 5.15.2-1
qt5-sensors 5.15.2-1
qt5-speech 5.15.2-1
qt5-svg 5.15.2+kde+r7-1
qt5-tools 5.15.2+kde+r17-2
qt5-virtualkeyboard 5.15.2-1
qt5-wayland 5.15.2+kde+r23-1
qt5-webchannel 5.15.2-1
qt5-webengine 5.15.3-4
qt5-webkit 5.212.0alpha4-10
qt5-x11extras 5.15.2-1
raptor 2.0.15-16
rasqal 1:0.9.33-4
rav1e 0.4.1-1
re2 1:20210601-1
readline 8.1.0-2
redland 1:1.0.17-8
reiserfsprogs 3.6.27-3
rest 0.8.1-3
rpcbind 1.2.5-3
rsync 3.2.3-3
rtkit 0.13-1
rtmpdump 1:2.4.r96.fa8646d-6
ruby 3.0.1-1
ruby-irb 1.3.5-1
ruby-reline 0.2.5-1
rubygems 3.2.18-1
run-parts 4.11.2-1
s-nail 14.9.22-1
samba 4.14.4-1
sane 1.0.32-3
sbc 1.5-2
screenfetch 3.9.1-1
sddm 0.19.0-6
sddm-breath2-theme 1.0.13-1
sddm-kcm 5.21.4-1
sdl 1.2.15-14
sdl2 2.0.14-1
sed 4.8-1
semver 7.3.5-2
serd 0.30.10-1
shaderc 2020.5-1
shadow 4.8.1-4
shared-mime-info 2.0+57+gc1d1c70-1
signon-kwallet-extension 21.04.1-1
signon-plugin-oauth2 0.25-1
signon-ui 0.17+20171022-2
signond 8.60-3
skanlite 2.2.0-1
slang 2.3.2-2
smartmontools 7.2-1
smbclient 4.14.4-1
snapd 2.51-1
snapd-glib 1.54-1
snappy 1.1.8-2
socat 1.7.4.1-1
sof-firmware 1.7-2
solid 5.81.0-1
sonnet 5.81.0-1
sord 0.16.8-1
sound-theme-freedesktop 0.8-4
soundtouch 2.2-1
spandsp 0.0.6-3
spectacle 21.04.1-1
spectre-meltdown-checker 0.44-1
speex 1.2.0-3
speexdsp 1.2.0-2
spirv-tools 2020.7-1
splix 2.0.0-15
sqlite 3.35.5-1
squashfs-tools 4.4_git.1-1
squashfuse 0.1.104-2
sratom 0.6.8-1
srt 1.4.3-1
sshfs 3.7.1-1
startup-notification 0.12-7
steam-manjaro 1.0.0.70-1
stoken 0.92-4
sudo 1.9.7-1
suitesparse 5.10.1-1
svt-av1 0.8.6-2
svt-hevc 1.5.1-1
syntax-highlighting 5.81.0-1
sysfsutils 2.1.1-1
system-config-printer 1.5.15-1
systemd 247.6-1.0
systemd-fsck-silent 239-1
systemd-kcm 1.2.1-5
systemd-libs 247.6-1.0
systemd-sysvcompat 247.6-1.0
systemsettings 5.21.4-1
taglib 1.12-1
talloc 2.3.2-1
tar 1.34-1
tbb 2020.3-1
tcl 8.6.11-1
tdb 1.4.3-4
terminus-font 4.49.1-2
tevent 1:0.10.2-3
texinfo 6.7-3
thin-provisioning-tools 0.9.0-1
threadweaver 5.81.0-1
thunderbird 78.10.1-0.2
tlp 1.3.1-2
tpm2-tss 3.1.0-1
transcode 1.1.7-38
tslib 1.22-1
ttf-dejavu 2.37+18+g9b5d1b2f-3
ttf-droid 20121017-10
ttf-hack 3.003-3
ttf-inconsolata 1:3.000-3
ttf-indic-otf 0.2-11
ttf-liberation 2.1.3-1
twolame 0.4.0-2
tzdata 2021a-1
udiskie 2.3.3-1
udisks2 2.9.2-1
unarchiver 1.10.7-3
unzip 6.0-14
upower 0.99.11-3
usb_modeswitch 2.6.1-1
usbmuxd 1.1.1-1
usbutils 013-1
util-linux 2.37-3
util-linux-libs 2.37-3
v4l-utils 1.20.0-1
v86d 0.1.10-5.1
vcdimager 2.0.1-4
vi 1:070224-4
vid.stab 1.1-3
vim 8.2.2815-1
vim-runtime 8.2.2815-1
virtualbox 6.1.22-1
virtualbox-sdk 6.1.22-1
vlc 3.0.12-6
vmaf 1.5.3-1
volume_key 0.3.12-5
vpnc 1:0.5.3.r468.r81-2
vte-common 0.64.2-2
vte3 0.64.2-2
w3m 0.5.3.git20200507-2
wallpapers-2018 1.2-1
wallpapers-juhraya 1.1-2
wavpack 5.4.0-1
wayland 1.19.0-1
wayland-protocols 1.20-1
web-installer-url-handler 1.0.2-1
webkit2gtk 2.32.0-2
webrtc-audio-processing 0.3.1-3
wget 1.21.1-1
which 2.21-5
wildmidi 0.4.4-1
wireless-regdb 2020.11.20-1
wireless_tools 30.pre9-3
woff2 1.0.2-3
wpa_supplicant 2:2.9-8
wpebackend-fdo 1.8.3-1
x264 3:0.161.r3039.544c61f-1
x265 3.5-1
xapian-core 1:1.4.18-1
xcb-proto 1.14.1-3
xcb-util 0.4.0-3
xcb-util-cursor 0.1.3-3
xcb-util-image 0.4.0-3
xcb-util-keysyms 0.4.0-3
xcb-util-renderutil 0.3.9-3
xcb-util-wm 0.4.1-3
xdg-dbus-proxy 0.1.2-3
xdg-desktop-portal 1.8.0-1
xdg-desktop-portal-kde 5.21.4-1
xdg-user-dirs 0.17-3
xdg-utils 1.1.3+19+g9816ebb-1
xf86-input-elographics 1.4.2-2
xf86-input-evdev 2.10.6-2
xf86-input-libinput 1.0.1-1
xf86-input-void 1.4.1-5
xf86-video-amdgpu 19.1.0-2
xf86-video-ati 1:19.1.0-2
xf86-video-intel 1:2.99.917+916+g31486f40-1
xf86-video-nouveau 1.0.17-1
xfsprogs 5.11.0-2
xkeyboard-config 2.32-1
xmlsec 1.2.32-1
xorg-fonts-encodings 1.0.5-2
xorg-mkfontscale 1.2.1-2
xorg-server 1.20.11-1
xorg-server-common 1.20.11-1
xorg-setxkbmap 1.3.2-2
xorg-twm 1.0.11-1
xorg-xauth 1.1-2
xorg-xdpyinfo 1.3.2-4
xorg-xinit 1.4.1-3
xorg-xkbcomp 1.4.5-1
xorg-xkill 1.0.5-2
xorg-xmessage 1.0.5-2
xorg-xmodmap 1.0.10-2
xorg-xprop 1.2.5-1
xorg-xrandr 1.5.1-2
xorg-xrdb 1.2.0-2
xorg-xset 1.2.4-2
xorg-xsetroot 1.1.2-2
xorgproto 2021.3-1
xvidcore 1.3.7-2
xxhash 0.8.0-1
xz 5.2.5-1
yajl 2.1.0-4
yakuake 21.04.1-1
zbar 0.23.1-7
zenity 3.32.0+55+gd7bedff-1
zensu 0.3-1
zeromq 4.3.4-1
zimg 3.0.1-2
zita-alsa-pcmi 0.3.2-3
zita-resampler 1.8.0-1
zlib 1:1.2.11-4
zsh 5.8-1
zsh-autosuggestions 0.7.0-1
zsh-completions 0.32.0-1
zsh-history-substring-search 1.0.2-1
zsh-syntax-highlighting 0.7.1-1
zsh-theme-powerlevel10k 1.14.6-1
zstd 1.5.0-1
zvbi 0.2.35-4
zxing-cpp 1.2.0-1
zziplib 0.13.72-1
  Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=e119510a-ad41-40b3-b71a-0fd906757fae ro quiet apparmor=1
  Desktop: KDE Plasma 5.21.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: ASUSTeK product: VivoBook 15_ASUS Laptop X540UB v: 1.0
  serial: <filter>
  Mobo: ASUSTeK model: X540UB v: 1.0 serial: <filter>
  UEFI: American Megatrends v: X540UB.303 date: 04/15/2019
  ID-1: BAT0 charge: 30.3 Wh (96.8%) condition: 31.3/33.2 Wh (94.3%)
  volts: 10.8 min: 10.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
  status: Not charging cycles: 453
  RAM: total: 7.65 GiB used: 3.05 GiB (39.8%)
  Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
  arch: Amber/Kaby Lake note: check family: 6 model-id: 8E (142) stepping: 9
  microcode: DE cache: L2: 3 MiB bogomips: 21599
  Speed: 2081 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 2081 2: 2097
  3: 2255 4: 2282
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
  Device-2: NVIDIA GM108M [GeForce MX110] vendor: ASUSTeK driver: nouveau
  v: kernel bus-ID: 01:00.0 chip-ID: 10de:174e class-ID: 0302
  Device-3: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
  bus-ID: 1-6:3 chip-ID: 13d3:5a01 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
  loaded: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
  display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2726x768 s-dpi: 96 s-size: 720x203mm (28.3x8.0")
  s-diag: 748mm (29.5")
  Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
  diag: 389mm (15.3")
  Monitor-2: HDMI2 res: 1360x768 hz: 60 dpi: 22 size: 1600x900mm (63.0x35.4")
  diag: 1836mm (72.3")
  OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.2
  direct render: Yes
  Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
  chip-ID: 8086:9d71 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.26 running: no
  Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: e000
  bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
  IF-ID-1: cali9025b104978 state: up speed: 10000 Mbps duplex: full
  mac: <filter>
  IF-ID-2: vxlan.calico state: unknown speed: N/A duplex: N/A mac: <filter>
  IP v6: <filter> scope: link
  bus-ID: 1-8:4 chip-ID: 8087:0a2b class-ID: e001
  Permissions: Unable to run lvs. Root privileges required.
  Local Storage: total: 1.14 TiB used: 39.4 GiB (3.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD9SB8W256G1002
  size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
  rotation: SSD serial: <filter> rev: 3002 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Western Digital
  model: WD My Passport 25E1 size: 931.48 GiB block-size: physical: 512 B
  logical: 512 B serial: <filter> rev: 1021 scheme: GPT
  ID-1: / raw-size: 46.62 GiB size: 45.64 GiB (97.89%) used: 39.36 GiB (86.3%)
  fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
  uuid: e119510a-ad41-40b3-b71a-0fd906757fae
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
  used: 32.6 MiB (12.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: SYSTEM
  uuid: 3430-08CA
  ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
  label: N/A uuid: N/A
  ID-2: /dev/sda3 maj-min: 8:3 size: 190.81 GiB fs: <superuser required>
  label: OS uuid: 1C0831CD0831A6A4
  ID-3: /dev/sda4 maj-min: 8:4 size: 800 MiB fs: <superuser required>
  label: RECOVERY uuid: 5C5AE0605AE03882
  ID-4: /dev/sdb1 maj-min: 8:17 size: 931.48 GiB fs: <superuser required>
  label: My Passport uuid: D25223025222EB45
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  Device-1: 1-2:2
  info: Microsoft 2.4GHz Transceiver v8.0 used by mouse Wireless Desktop 900
  type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
  speed: 12 Mb/s power: 100mA chip-ID: 045e:07b2 class-ID: 0300
  Device-2: 1-6:3 info: IMC Networks USB2.0 VGA UVC WebCam type: Video
  Device-3: 1-8:4 info: Intel Bluetooth wireless interface type: Bluetooth
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  Device-1: 2-1:2 info: Western Digital My Passport (WD20NMVW)
  type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s
  power: 896mA chip-ID: 1058:25e1 class-ID: 0806 serial: <filter>
  System Temperatures: cpu: 50.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 1800
  Processes: 263 Uptime: 2m wakeups: 1 Init: systemd v: 247 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: 1331 pacman: 1312 lib: 397 flatpak: 7
  snap: 12 Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.04
and i was infact using docker and kubernedes but i think i deleted them completely (including the home folder) and still having the same issue.
I also updated my profile to include specific information about my hardware
Nah, there is stuff left behind, so just execute:
sudo ip link delete cali9025b104978
sudo ip link delete vxlan.calico
and then the network portion will be deleted as well.
For the future,
pamac remove --no-save szPackageName
will remove zsPackageName and its config files from your system.
:crossed_fingers:
P.S. This is unrelated to your problem, but you only have 7.65 GiB RAM and 3.05 GiB (39.8%) is used so please read this…
This indeed worked! thank you very much and thank for the tip i will definitely check that out!
I’m just marking this thread as solved for you. For future threads, make sure you do this by clicking on the “hamburger” button at the bottom of the relevant post. The solution option is hidden there.
