Did a restore from Timeshift a few weeks back, not sure on details. When it came back UEFI gave me a Grub Rescue.
⦠as usual:
very, very terse description - expecting us to elicit relevant information from you
to even learn what your problem might be
in order to then render advise
use ⦠more ⦠words ![]()
Sorry, not sure how to find out more, just if I select UEFI, it just goes to Grub Rescue, no error. Just not sure what to type.
UEFI goes to Grub Rescue, but MBR boota fine?
if MBR boots fine
why would you want to boot via UEFI - and expect it to work as well?
why disregard what works?
and focus on something that isnāt ⦠?
itās a mystery to me ā¦
If the Legacy MBR Boot mode works, but your UEFI boot mode gives you a Grub rescue prompt, it just means your grub.cfg in your ESP is wrongā¦
(Maybe the config in /boot/grub also)
Try to boot via a LIVE-ISO in UEFI mode and re-install your Grub (efi version).
I have the error it said āgrub_debug_mallocā not found. Didnāt try the live boot yet.
MBR uses - well - MBR partition layout
EFI uses GPT partition layout
So while you cannot have MBR and GPT on the same disk,
you can have BIOS and EFI on the same GPT disk layout.
When GPT is the disk layout and you want to support both boot paradigms you need
- unformatted partition min size 1M - partitition type EF02 (bios boot) - bios boot loader
- fat32 formatted partition (calamares default to 300M) - partition type EF00 (efi boot) - efi boot loader
- root partition - any size - partition type 8304 (Linux x86-64 root /)
Just odd after a timeshift restore this happened, just wondering why? Linux is the only OS ib that drive.
How many drives do you have, you might be booting from another drive without you realizing itā¦![]()
Some system info about your drives/partitions would be handy, but as no technical info is provided at all, all we can do is guessā¦
I have 2 drives.
Widows- https://photos.google.com/search/_tra_/photo/AF1QipPWy2i5g9AvGk5cavOVflyvoz1-2pe91eLZ84bC
Linux- https://photos.google.com/search/_tra_/photo/AF1QipP-6oet3xJt6aj_bh8g3Njp9OipXUXdVNiaJ1nQ
sudo fdisk -l
Excuse me if this sounds rude, but I know youāre not a newcomer, yet all your posts start this cryptic, and everyone has to ask you for the same information every time. Please see:
Expecially thed part that says
Regardless of your problem, always do the following:
[ā¦]
Copy-paste the following:inxi --admin --verbosity=7 --filter --width
And:
Instead of pictures.
Sorry Iām an a55h0le, but someone has to say it.
Disk model: SHGS31-1000GS-2
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0x79ebd583
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 246647377 246645330 117.6G 7 HPFS/NTFS/exFAT
/dev/sda2 246648832 247711743 1062912 519M 27 Hidden NTFS WinRE
/dev/sda3 247713792 248815615 1101824 538M 27 Hidden NTFS WinRE
/dev/sda4 248815616 1953523711 1704708096 812.9G 5 Extended
/dev/sda5 248817664 1551216639 1302398976 621G 7 HPFS/NTFS/exFAT
/dev/sda6 1551218688 1953523711 402305024 191.8G 7 HPFS/NTFS/exFAT
Disk /dev/sdb: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors
Disk model: WDC WD10EZEX-08W
Disklabel type: gpt
Disk identifier: E5802447-08C9-7C47-B1FD-F7758A25D427
Device Start End Sectors Size Type
/dev/sdb1 4096 618495 614400 300M EFI System
/dev/sdb2 618496 1935065125 1934446630 922.4G Linux filesystem
/dev/sdb3 1935065126 1953520064 18454939 8.8G Linux swap
Partition 3 does not start on physical sector boundary.
Disk /dev/sdc: 1.89 GiB, 2031091712 bytes, 3966976 sectors
Disk model: DataTraveler 2.0
Disklabel type: dos
Disk identifier: 0xe040036d
/dev/sdc1 * 63 3966939 3966877 1.9G 7 HPFS/NTFS/exFAT
SDC is just a blank thumb drive.
You have one disk BIOS/MBR - your Windows disk
You have one disk EFI - your Linux disk
You need to use your firmware boot override to be able to select which one to boot.
Bootloader for MBR and GPT cannot coexist - this is likely the cause of your issues.
Ok, I will change to EFI when I upgrade to 11 to fix it.
Both links to your images give errorsā¦
Next time please post all info without cuting out partsā¦
Fe. your windows disk total size⦠is most likely >=2TB, yet the model shows as a 1TB drive when searched on internet.
(Correction i just noticed sda4 is an extended partitionā¦)
Anyhowā¦
You should be able to disable Legacy (BIOS-MBR) boot in your UEFI-BIOS, but we wonāt be able to assist because only you know your hardware infoā¦
