basically this is somewhat off course from my original thread of where i had an issue with Load Kernel Modules. i got suggested that i should fix this issue by going into tty1 and removing nvidia drivers, but when i try to do that it asks me for my password. i type my password in completely correctly (i have been using this password for years and ive used this multiple times when logging into Manjaro) except it says “incorrect password”. its not a keyboard problem since my characters are all latin and i typed it in on the command line and i wrote it exactly how it is meant to be. i dont know whats causing this.
Are you talking about login in or using something like sudo?
wait im sorry im dumb i didnt login
