I found this post about the warning, but i don’t understand what should i do with it.
sudo pacman -Syu
core is up to date
extra is up to date
community is up to date
multilib is up to date
warning: nano-syntax-highlighting: local (2020.10.10+10+g1aa64a8-2) is newer than extra (2020.10.10-2)
there is nothing to do
The bigger problem I face is with AUR and yay:
yay -Syu
core is up to date
extra is up to date
:: Searching AUR for updates...
-> No AUR package found for clang=17.0.6
:: Searching databases for updates...
-> nano-syntax-highlighting: local (2020.10.10+10+g1aa64a8-2) is newer than extra (2020.10.10-2)
-> Packages not in AUR: ipw2100-fw ipw2200-fw manjaro-firmware manjaro-hotfixes nerd-fonts-jetbrains-mono-160 systemd-fsck-silent
-> Orphan (unmaintained) AUR Packages: interception-caps2esc-4modifiers-git
-> Flagged Out Of Date AUR Packages: auto-cpufreq gconf i3ipc-glib-git pyside2 python-rofi-git python-shiboken2
-> spectre-meltdown-checker: local (0.46+23+g0f2edb1-1) is newer than AUR (0.46-1)
:: 29 dependencies will also be installed for this operation.
extra/cbindgen -> 0.27.0-1
(make dependency of midori)
extra/cmake -> 3.30.2-1
(make dependency of lld17, wasi-compiler-rt17, ...)
extra/dump_syms -> 2.3.3-1
extra/imake -> 1.0.10-2
extra/mercurial -> 6.8.1-1
extra/meson -> 1.5.1-1
(make dependency of xwayland-run)
extra/mold -> 2.33.0-1
extra/nasm -> 2.16.03-1
extra/ninja -> 1.12.1-1
(make dependency of llvm17-libs, clang17, ...)
extra/python-build -> 1.2.1-3
(make dependency of llvm17, llvm17-libs, ...)
extra/python-installer -> 0.7.0-8
(make dependency of python-undervolt)
extra/python-recommonmark -> 0.7.1-7
(make dependency of clang17)
extra/python-sphinx -> 8.0.2-1
(make dependency of lld17)
extra/qt5-quickcontrols2 -> 5.15.14+kde+r5-1
(make dependency of pyside2, python-shiboken2)
extra/rustup -> 1.27.1-1
extra/wasi-libc -> 1:0+392+b9ef79d7-1
(make dependency of midori, wasi-compiler-rt17)
extra/wasi-libc++ -> 18.1.8-4
extra/wasi-libc++abi -> 18.1.8-4
extra/xorg-server-xvfb -> 21.1.13-1
(make dependency of github-desktop)
extra/xorg-xwayland -> 24.1.2-1
extra/yarn -> 1.22.22-2
extra/yasm -> 1.3.0-7
aur/clang17 -> 17.0.6-2
aur/compiler-rt17 -> 17.0.6-1
aur/lld17 -> 17.0.6-1
aur/llvm17 -> 17.0.6-1
(make dependency of lld17, clang17, ...)
aur/llvm17-libs -> 17.0.6-1
aur/wasi-compiler-rt17 -> 17.0.6-1
aur/xwayland-run -> 0.0.3-2
:: 15 packages to upgrade/install.
15 aur/betterlockscreen 4.2.0-1 -> 4.4.0-1
14 aur/github-desktop 3.3.8-1 -> 3.4.3-1
13 aur/i3lock-color 2.13.c.5-1 -> 2.13.c.5-3
12 aur/jellyfin-media-player 1.9.1-2 -> 1.11.1-2
11 aur/linux-wifi-hotspot 4.7.1-1 -> 4.7.2-1
10 aur/midori 9.0-6 -> 11.3.4-1
9 aur/morgen-bin 3.3.1-1 -> 3.5.6-1
8 aur/powerstat 0.04.02-1 -> 0.04.03-1
7 aur/pyside2 5.15.12-1 -> 5.15.13-2
6 aur/python-shiboken2 5.15.12-1 -> 5.15.13-2
5 aur/python-spotipy 2.23.0-1 -> 2.24.0-1
4 aur/python-undervolt 0.4.0-1 -> 0.4.0-2
3 aur/simplenote-electron-bin 2.21.0-1 -> 2.22.1-1
2 aur/spotify 1:1.2.31.1205-2 -> 1:1.2.42.290-1
1 aur/visual-studio-code-bin 1.87.2-1 -> 1.93.0-1
==> Packages to exclude: (eg: "1 2 3", "1-3", "^4" or repo name)
-> Excluding packages may cause partial upgrades and break systems
-> could not find all required packages: clang =17.0.6
clang -v output:
clang -v
clang version 18.1.8
Target: x86_64-pc-linux-gnu
Thread model: posix
InstalledDir: /usr/bin
Found candidate GCC installation: /usr/bin/../lib/gcc/x86_64-pc-linux-gnu/14.2.1
Found candidate GCC installation: /usr/bin/../lib64/gcc/x86_64-pc-linux-gnu/14.2.1
Selected GCC installation: /usr/bin/../lib64/gcc/x86_64-pc-linux-gnu/14.2.1
Candidate multilib: .;@m64
Candidate multilib: 32;@m32
Selected multilib: .;@m64
I dont even know what are those python packages. I did not install them (or at least i do not remember since i dont use python) and i dont know if those are dependencies.
EDIT: The reason i found this out is because i wanted to update VScode cause of a poor performance and popup window.
