Hi everyone. I am a brand new Linux user. I have essentially no command line experience. I am trying to get my USB3 Targus DOCK191 to work - that is to say, work with my other two displays. I tried to install evdi in the terminal but no luck. I would appreciate any assistance, particularly step by step instructions. Please be patient with this noob ![]()
Create a snapshot of your computer system - your issue may be caused by the dock
pamac build hw-probe
Hope I did this right! It isn’t letting me post the hyperlink for some reason, so here is the probeid
probe=049863bd33
There is no dock in the listing - so either you did not attach while running the probe or it does not work with Linux.
Sorry, this one with the hub connected!
probe=f8e42da2f1
The device is connect and appears functional
Product=Targus USB-C DV4K Docking Station 100W Power– HW probe of Lenovo ThinkPad E14 Gen 5 2... #f8e42da2f1: usb-devices
Locate your system’s Settings Manager and setup your displays
We need the Global information for your system as described in [HowTo] Find system information
Kernel: 6.9.3-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
clocksource: hpet avail: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
root=UUID=c5fd7a13-657e-4fc6-847e-32d9336afc2f rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: LENOVO product: 21JSS0Y500 v: ThinkPad E14 Gen 5
Mobo: LENOVO model: 21JSS0Y500 v: ThinkPad serial: <superuser required>
part-nu: LENOVO_MT_21JS_BU_Think_FM_ThinkPad E14 Gen 5
uuid: <superuser required> UEFI: LENOVO v: R2CET29W (1.11 )
date: 07/25/2023
ID-1: BAT0 charge: 47.9 Wh (99.4%) condition: 48.2/47.0 Wh (102.5%)
volts: 13.0 min: 11.3 model: Sunwoda L22D3PG4 type: Li-poly serial: <filter>
status: full cycles: 11
Device-1: hidpp_battery_1 model: Logitech ERGO M575 Trackball
serial: <filter> charge: 100% rechargeable: yes status: discharging
System RAM: total: 24 GiB available: 22.36 GiB used: 3.06 GiB (13.7%)
(unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Crucial
part-no: CT16G4SFRA32A.M16FE serial: <filter>
(unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M471A1G44BB0-CWE serial: N/A
Info: model: AMD Ryzen 7 7730U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000D
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1165 high: 2606 min/max: 400/4546 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2403 2: 1674 3: 2192
4: 2606 5: 2136 6: 400 7: 400 8: 400 9: 2416 10: 400 11: 400 12: 400
13: 400 14: 400 15: 1625 16: 400 bogomips: 63906
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
xtopology
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
affected
Device-1: AMD Barcelo vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:15e7
class-ID: 0300 temp: 48.0 C
Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 174f:2469
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 507x317mm (19.96x12.48")
s-diag: 598mm (23.54") monitors: <missing: xrandr>
Monitor-1: eDP-1 model: AU Optronics 0xfa9b built: 2021 res: 1920x1200
dpi: 162 gamma: 1.2 chroma: red: x: 0.576 y: 0.345 green: x: 0.349 y: 0.569
blue: x: 0.157 y: 0.114 white: x: 0.314 y: 0.329
size: 301x188mm (11.85x7.4") diag: 355mm (14") ratio: 16:10
modes: 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
1280x800, 1280x720, 1024x768, 800x600, 640x480
device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.9-manjaro1.1
renoir LLVM 17.0.6 DRM 3.57 6.9.3-3-MANJARO) device-ID: 1002:15e7
memory: 1000 MiB unified: no
Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: DisplayLink Targus USB-C DV4K Docking Station 100W Power
driver: cdc_ncm,snd-usb-audio type: USB rev: 3.2 speed: 5 Gb/s lanes: 1
mode: 3.2 gen-1x1 bus-ID: 4-1.2:3 chip-ID: 17e9:6027 class-ID: 0a00
serial: <filter>
API: ALSA v: k6.9.3-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp1s0 state: down mac: <filter>
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF-ID-1: enp4s0f4u1u2i5 state: down mac: <filter>
Device-1: Foxconn / Hon Hai Bluetooth 5.2 Adapter [MediaTek MT7922]
driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 3-4:3 chip-ID: 0489:e0d8 class-ID: e001 serial: <filter>
Local Storage: total: 931.51 GiB used: 8.82 GiB (0.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate model: BarraCuda Q5
ZP1000CV30001 size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: SU5ST000
temp: 31.9 C scheme: GPT
ID-1: / raw-size: 465.37 GiB size: 456.99 GiB (98.20%) used: 8.8 GiB (1.9%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: c5fd7a13-657e-4fc6-847e-32d9336afc2f
used: 26.7 MiB (27.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 1084-6E94
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 465.37 GiB fs: ntfs label: N/A
uuid: C8C884EEC884DC56
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 674 MiB fs: ntfs label: N/A
uuid: 5684D47884D45C55
Device-1: 1-3:3 info: Syntek Integrated Camera type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 174f:2469 class-ID: 0e02
serial: <filter>
Hub-4: 3-1:4 info: Genesys Logic Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
Hub-5: 3-1.4:5 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 3-1.4.2:6 info: Logitech Logi Bolt Receiver
type: keyboard,mouse,HID driver: hid-generic,hid-multitouch,usbhid
interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 98mA chip-ID: 046d:c548 class-ID: 0300
Device-2: 3-1.4.3:7 info: Canon MF3010 type: printer driver: usblp
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 2mA chip-ID: 04a9:2759 class-ID: 0701 serial: <filter>
Device-3: 3-1.4.4:8 info: Logitech Unifying Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c52b class-ID: 0300
Device-4: 3-3:2 info: Shenzhen Goodix FingerPrint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:550a class-ID: ff00
Device-5: 3-4:3 info: Foxconn / Hon Hai Bluetooth 5.2 Adapter [MediaTek
MT7922] type: bluetooth driver: btusb interfaces: 3 rev: 2.1
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-7: 4-1:2 info: Genesys Logic USB3.2 Hub ports: 4 rev: 3.2
speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 05e3:0625
Device-1: 4-1.2:3 info: DisplayLink Targus USB-C DV4K Docking Station
100W Power type: audio,communication,CDC-data
driver: cdc_ncm,snd-usb-audio interfaces: 7 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 17e9:6027 class-ID: 0a00 serial: <filter>
Hub-8: 4-1.4:4 info: Genesys Logic GL3523 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
System Temperatures: cpu: 55.0 C mobo: 38.0 C gpu: amdgpu temp: 50.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Packages: pm: pacman pkgs: 1170 libs: 322 tools: pamac pm: flatpak pkgs: 0
1: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mirrors.manjaro.org/repo/stable/$repo/$arch
3: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 320
1: cpu: 4.0% command: firefox pid: 40940 mem: 235.1 MiB (1.0%)
2: cpu: 3.0% command: zsh pid: 41614 mem: 9.97 MiB (0.0%)
3: cpu: 1.7% command: konsole pid: 41586 mem: 143.8 MiB (0.6%)
4: cpu: 1.3% command: firefox pid: 41287 mem: 202.4 MiB (0.8%)
5: cpu: 1.2% command: systemsettings pid: 40083 mem: 237.9 MiB (1.0%)
Memory top: 5 of 320
1: mem: 565.9 MiB (2.4%) command: firefox pid: 39275 cpu: 0.1%
2: mem: 431.6 MiB (1.8%) command: plasmashell pid: 1033 cpu: 0.0%
3: mem: 266.0 MiB (1.1%) command: firefox pid: 39513 cpu: 0.0%
4: mem: 237.9 MiB (1.0%) command: systemsettings pid: 40083 cpu: 1.2%
5: mem: 235.1 MiB (1.0%) command: firefox pid: 40940 cpu: 4.0%
Processes: 320 Power: uptime: 21h 42m states: freeze,mem,disk
suspend: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 8.93 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: gcc: 14.1.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.26
running-in: konsole inxi: 3.3.35
no known issues
desktop used (Plasma) and mode (usb 3.2) seems to indicate you may want to install plasma-thunderbolt package - you may need to reconnect the device
sudo pacman -Syu plasma-thunderbolt
First of all, thank you for responding so fast! I’m sorry it took me awhile to post the information; I had a little trouble figuring out how to format the from the terminal so I didn’t get rejected for having a link ![]()
Anyway, I entered the command you indicated, then restarted and unfortunately no luck. The displays still are not recognized, or indicated in the System Settings - Displays & Monitor.
Not sure what to do next.
Also, I unplugged and plugged in the device again.
