Transparency stuck on KDE desktop
Ive got trouble with the task bar and app launcher:
I can not get ridd of the transparency - Looked at loads of topics, searched the web up and down and all workarounds seem to be not working. it only started happening after the upgrade.
Install a different “Plasma style” theme. The one you’re using appears to not be compatible anymore. And actually, you should have reverted all theming to the stock KDE Breeze theme before the upgrade.
awesome, thanks - yes that’s fixed it.
