I upgraded to Plasma 6 today and I was greeted with a weird look.
- Floating panel is active but it doesn’t float.
- Boxy look.
- Takes awhile to log out.
My issue seems similar to this but I have already tried the proposed solution.
Screenshots:
Kernel: 6.1.90-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=ceffef7e-e60f-4e13-8bcc-fab6e0860e39 rw quiet splash
udev.log_priority=3 resume=UUID=386684cd-e5fa-4a29-8800-015a86734107
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.1.0
Type: Laptop System: Acer product: Aspire A515-43 v: V1.08
serial: <superuser required>
Mobo: PK model: Grumpy_PK v: V1.08 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.08
date: 04/07/2020
ID-1: BAT1 charge: 26.6 Wh (99.3%) condition: 26.8/47.8 Wh (56.0%)
volts: 12.1 min: 11.2 model: LGC AP18C8K type: Li-ion serial: <filter>
status: discharging
Info: model: AMD Ryzen 3 3200U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
stepping: 1 microcode: 0x8108102
L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1390 high: 1400 min/max: 1400/2600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1400 2: 1393
3: 1400 4: 1368 bogomips: 20769
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spec_rstack_overflow mitigation: safe RET
Device-1: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
lanes: 16 ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 05:00.0
chip-ID: 1002:15d8 class-ID: 0300 temp: 57.0 C
Device-2: Chicony HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1:2 chip-ID: 04f2:b64f
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.6-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 3 Graphics
(radeonsi raven2 LLVM 17.0.6 DRM 3.49 6.1.90-1-MANJARO)
device-ID: 1002:15d8 memory: 1.95 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu name: AMD
Radeon Vega 3 Graphics (RADV RAVEN2) driver: mesa radv
v: 24.0.6-manjaro1.1 device-ID: 1002:15d8 surfaces: xcb,xlib,wayland
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 05:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.90-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.5 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:095a class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:4 chip-ID: 8087:0a2a
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 1.03 TiB used: 825.82 GiB (78.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-128G-1014 size: 119.24 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20110000 temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
tech: HDD rpm: 5400 serial: <filter> fw-rev: 5J scheme: GPT
ID-1: / raw-size: 36.1 GiB size: 35.24 GiB (97.61%) used: 23.11 GiB (65.6%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 82.64 GiB size: 80.79 GiB (97.76%)
used: 72.56 GiB (89.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 5.08 GiB used: 388 KiB (0.0%)
priority: -2 dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 58.2 C mobo: N/A gpu: amdgpu temp: 58.0 C
Fan Speeds (rpm): N/A
Packages: 1512 pm: pacman pkgs: 1498 libs: 428 tools: pamac,yay pm: flatpak
pkgs: 14
1: https://mirrors2.manjaro.org/stable/$repo/$arch
2: https://mirrors.manjaro.org/repo/stable/$repo/$arch
3: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
Memory: total: 20 GiB note: est. available: 17.5 GiB used: 4.05 GiB (23.1%)
Processes: 221 Power: uptime: 44m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.99 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
