TP-Link T3U Plus USB WiFi failing frequently
I recently moved from Windows to Manajaro on a desktop system. I’m having problems with WiFi connectivity. It’s effectively unstable. Runs for a while and then stalls… occasionally silently and then at some point states limited connectivty. Eventually it fails altogether and there is no WiFi connection.
A reboot will “fix it” but that may be for a couple of days or only a few minutes. Turning the wifi off and then on again has also been effective at “bringing it back” although this has now failed entirely twice today which seems new. Again when it comes back from this it may be minutes or hours before it fails again.
I’m getting the following noise in dmesg around when the wifi fails
rtw_8822bu 1-11:1.0: write register 0xc4 failed with -71
rtw_8822bu 1-11:1.0: rtw_usb_reg_sec: reg 0x4e0, usb write 1 fail, status: -71
followed by :
rtw_8822bu 2-5:1.0: failed to get tx report from firmware
\[ 3353.263475\] rtw_8822bu 2-5:1.0: failed to get tx report from firmware
\[ 3354.250146\] rtw_8822bu 2-5:1.0: failed to get tx report from firmware
\[ 3355.266808\] rtw_8822bu 2-5:1.0: failed to get tx report from firmware
\[ 3356.253477\] rtw_8822bu 2-5:1.0: failed to get tx report from firmware
\[ 3357.240142\] rtw_8822bu 2-5:1.0: failed to get tx report from firmware
\[ 3358.226827\] rtw_8822bu 2-5:1.0: failed to get tx report from firmware
\[ 3358.691009\] wlp0s20f0u5: deauthenticated from e4:f4:c6:06:b8:33 (Reason: 16=GROUP_KEY_HANDSHAKE_TIMEOUT)
\[ 3358.983435\] rtw_8822bu 2-5:1.0: error beacon valid
\[ 3358.983504\] rtw_8822bu 2-5:1.0: failed to download rsvd page
\[ 3358.983822\] rtw_8822bu 2-5:1.0: failed to download firmware
\[ 3358.986787\] rtw_8822bu 2-5:1.0: leave idle state failed
\[ 3358.991263\] rtw_8822bu 2-5:1.0: failed to leave ips state
\[ 3358.991267\] rtw_8822bu 2-5:1.0: failed to leave idle state
\[ 3363.154085\] rtw_8822bu 2-5:1.0: error beacon valid
\[ 3363.154153\] rtw_8822bu 2-5:1.0: failed to download rsvd page
\[ 3363.154475\] rtw_8822bu 2-5:1.0: failed to download firmware
\[ 3363.157434\] rtw_8822bu 2-5:1.0: leave idle state failed
\[ 3363.161917\] rtw_8822bu 2-5:1.0: failed to leave ips state
\[ 3363.161920\] rtw_8822bu 2-5:1.0: failed to leave idle state
output of sudo inxi -zv8 follows
  Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=3dfc5a12-dede-4661-b082-08dfee2bf061 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: B150M-C v: Rev X.0x serial: <filter>
    part-nu: SKU uuid: eefff5e0-72ba-11e3-a27b-f832e46e0127 Firmware: UEFI
    vendor: American Megatrends v: 1801 date: 05/10/2016
  System RAM: total: 16 GiB available: 15.54 GiB used: 5.52 GiB (35.5%)
  Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
  Device-1: DIMM_A1 type: no module installed
  Device-2: DIMM_A2 type: DDR4 detail: synchronous size: 8 GiB
    speed: 2133 MT/s volts: curr: 1.2 width (bits): data: 64 total: 64
    manufacturer: Kingston part-no: 9905625-030.A00G serial: <filter>
  Device-3: DIMM_B1 type: no module installed
  Device-4: DIMM_B2 type: DDR4 detail: synchronous size: 8 GiB
  Slot: 0 type: PCIe status: in use length: long volts: 3.3 bus-ID: 01:01.0
  Slot: 1 type: PCIe status: available length: long volts: 3.3
    bus-ID: 02:1c.3
  Slot: 2 type: PCIe status: available length: short volts: 3.3
    bus-ID: 03:1c.4
  Slot: 4 type: PCI status: available length: short volts: 3.3
    bus-ID: 06:1c.6
  Info: model: Intel Core i7-6700 socket: LGA1151 bits: 64 type: MT MCP
    arch: Skylake-S gen: core 6 level: v3 note: check built: 2015
    process: Intel 14nm family: 6 model-id: 0x5E (94) stepping: 3
    microcode: 0xF0
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 3700 min/max: 800/4000 base/boost: 3400/4000 scaling:
    driver: intel_pstate governor: powersave volts: 1.1 V ext-clock: 100 MHz
    cores: 1: 3700 2: 3700 3: 3700 4: 3700 5: 3700 6: 3700 7: 3700 8: 3700
    bogomips: 54417
    dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
    smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Device-1: NVIDIA GM204 [GeForce GTX 970] vendor: Gigabyte driver: nouveau
    v: kernel non-free: 550-580.xx+ status: current (as of 2025-11;
    EOL~2026-12-xx) arch: Maxwell code: GMxxx process: TSMC 28nm
    built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, DVI-I-1
    bus-ID: 01:00.0 chip-ID: 10de:13c2 class-ID: 0300 temp: 41.0 C
  Device-2: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4
    chip-ID: 046d:085b class-ID: 0102 serial: <filter>
  Display: unspecified server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: nouveau gpu: nouveau display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
    s-diag: 777mm (30.58") monitors: <missing: xrandr>
  Monitor-1: HDMI-A-1 model: BenQ GW2765 serial: <filter> built: 2014
    res: 2560x1440 dpi: 109 gamma: 1.2 chroma: red: x: 0.663 y: 0.333 green:
    x: 0.298 y: 0.631 blue: x: 0.145 y: 0.051 white: x: 0.314 y: 0.329
    size: 597x336mm (23.5x13.23") diag: 686mm (27") ratio: 16:9
    modes: 2560x1440, 1920x1080, 1920x1080i, 1680x1050, 1600x900, 1280x1024,
    1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576,
    720x480, 640x480, 720x400
  API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
    device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
    drv: nouveau inactive: wayland
  API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 25.2.3-arch1.2 glx-v: 1.4
    direct-render: yes renderer: NV124 device-ID: 10de:13c2 memory: 3.88 GiB
    unified: no
  API: Vulkan v: 1.4.321 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 970 (NVK GM204) driver: mesa nvk v: 25.2.3-arch1.2
    device-ID: 10de:13c2 surfaces: N/A
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:a170 class-ID: 0403
  Device-2: NVIDIA GM204 High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fbb
    class-ID: 0403
  Device-3: Logitech Logitech Webcam C925e driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.8 status: n/a (root, process) with:
    vendor: ASUSTeK P8 series driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp4s0 state: down mac: <filter>
  Device-2: TP-Link 802.11ac NIC driver: rtw_8822bu type: USB rev: 3.0
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-5:4 chip-ID: 2357:0138
    class-ID: 0000 serial: <filter>
  IF: wlp0s20f0u5 state: up mac: <filter>
  Info: services: NetworkManager, smbd, systemd-timesyncd, wpa_supplicant
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2
    chip-ID: 0a12:0001 class-ID: e001
  Local Storage: total: 4.77 TiB used: 3.11 TiB (65.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SP550 family: based SSDs
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B sata: 3.1
    speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0C temp: 30 C
    scheme: GPT
  SMART: yes state: enabled health: PASSED on: 1y 208d 6h cycles: 528
    read: 69.39 TiB written: 95.28 TiB
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1SB10C
    family: Barracuda 7200.14 (AF) size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD rpm: 7200
    serial: <filter> fw-rev: CC43 temp: 32 C scheme: MBR
  SMART: yes state: enabled health: PASSED on: 8y 240d 8h cycles: 523
    read: 8.02 TiB written: 6.39 TiB Pre-Fail: attribute: Spin_Retry_Count
    value: 100 worst: 100 threshold: 97
  ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD40EZRZ-22GXCB0 family: Blue (CMR) size: 3.64 TiB block-size:
    physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: HDD
    rpm: 5400 serial: <filter> fw-rev: 0A80 temp: 39 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 4y 281d 16h cycles: 369
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSC0 rev: LI00
    dev-links: cdrom
  Features: speed: 12 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 223.28 GiB size: 223.28 GiB (100.00%)
    used: 60.68 GiB (27.2%) fs: btrfs block-size: 4096 B dev: /dev/sda2
    maj-min: 8:2 label: N/A uuid: 3dfc5a12-dede-4661-b082-08dfee2bf061
    used: 636 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
    label: N/A uuid: 303D-1D31
  ID-3: /home raw-size: 223.28 GiB size: 223.28 GiB (100.00%)
  ID-4: /run/media/mstewart/42 raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
    used: 2.38 TiB (65.5%) fs: ntfs block-size: 4096 B dev: /dev/sdc2
    maj-min: 8:34 label: 42 uuid: 3A7256227255E2E5
  ID-5: /run/media/mstewart/Shared raw-size: 931.51 GiB
    size: 931.51 GiB (100.00%) used: 684.46 GiB (73.5%) fs: ntfs
    block-size: 4096 B dev: /dev/sdb1 maj-min: 8:17 label: Shared
    uuid: C0461E52461E4A14
  ID-6: /var/cache raw-size: 223.28 GiB size: 223.28 GiB (100.00%)
  ID-7: /var/log raw-size: 223.28 GiB size: 223.28 GiB (100.00%)
  ID-1: /dev/sdc1 maj-min: 8:33 size: 16 MiB fs: N/A label: N/A uuid: N/A
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-1:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
    type: bluetooth driver: btusb interfaces: 2 rev: 2.0
  Device-2: 1-4:3 info: Logitech Mouse type: mouse
    chip-ID: 046d:c077 class-ID: 0301
  Device-3: 1-6:4 info: Logitech Logitech Webcam C925e type: video,audio
  Device-4: 1-12:6 info: Logitech Keyboard K120 type: keyboard,HID
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 90mA
    chip-ID: 046d:c31c class-ID: 0300
  Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
  Device-1: 2-5:4 info: TP-Link 802.11ac NIC type: Network
    driver: rtw_8822bu interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 power: 504mA chip-ID: 2357:0138 class-ID: 0000
    serial: <filter>
  System Temperatures: cpu: 77.0 C mobo: N/A gpu: nouveau temp: 42.0 C
  Fan Speeds (rpm): N/A gpu: nouveau fan: 1229
  Packages: 1588 pm: dpkg pkgs: 0 pm: pacman pkgs: 1569 libs: 390 tools: pamac
    pm: rpm pkgs: 0 pm: flatpak pkgs: 19
    1: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    3: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 320
  1: cpu: 23.8% command: firefox pid: 3525 mem: 458.5 MiB (2.8%)
  2: cpu: 7.6% command: chromium pid: 6268 mem: 362.3 MiB (2.2%)
  3: cpu: 7.5% command: [kworker/u32:8-flush-btrfs-1] pid: 7624
    mem: 0.00 MiB (0.0%)
  4: cpu: 7.4% command: chromium pid: 7879 mem: 451.6 MiB (2.8%)
  5: cpu: 5.8% command: [kworker/u32:4-btrfs-endio-write] pid: 7445
  Memory top: 5 of 320
  1: mem: 794.3 MiB (4.9%) command: plasmashell pid: 945 cpu: 0.5%
  2: mem: 458.5 MiB (2.8%) command: firefox pid: 3525 cpu: 23.8%
  3: mem: 451.6 MiB (2.8%) command: chromium pid: 7879 cpu: 7.4%
  4: mem: 387.1 MiB (2.4%) command: chromium pid: 1286 cpu: 2.4%
  5: mem: 362.3 MiB (2.2%) command: chromium pid: 6268 cpu: 7.6%
  Processes: 320 Power: uptime: 2h 10m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Sudo (sudo) v: 1.9.17p1
    default: Bash v: 5.3.3 running-in: konsole inxi: 3.3.40
Mod edit:- Tidied formatting in accordance with forum guidelines. No charge. Please edit the topic title to better describe your issue. The pre-formatted text guidelines refer to all code or command output, and not just that of inxi output.
Mod note:- Thank you for the edits and conforming to guidelines. Note that when using inxi, privilege elevation with sudo is not generally required. Cheers.
Your post has been moved to a dedicated topic.
Avoid adding your own issue to another member’s Support topic, especially one that has been abandoned for a long period. :eyes:
Please edit the first post in this thread.
Specifically state the nature of your problem, and give as much detail as possible to help others help you.
Take a look at the inxi output you provided. :eyes:
That doesn’t look right, does it? :wink:
Please provide your system information as described (below).
Also included are links designed to help you use the forum. Particularly useful will be the link concerning posting code and command output as pre-formatted text.
I’m sure someone will help as soon as they are able.
What follows is from a standard template.
As a new or infrequent forum user, please take some time to familiarise yourself with forum requirements, and the many ways to use the forum to your benefit.
Note: By virtue of using the Manjaro forum you acknowledge and agree to follow Rules and Guidelines outlined; so, you really should read them:
Required Reading
Highly Recommended
Work with us, not against us
It is important to provide as much actionable information as possible in your first post, rather than simply indicating there is a problem. Please also be prepared to provide output from commands if/when asked.
Simply waiting for others to ask you questions is counter-productive – typically, nobody has a :crystal_ball: at their disposal – and your clear, concise and accurate input is often relied upon in order to help you.
Please help others to make informed suggestions based on information you provide.
System Information
inxi -zv8 (short-form)
inxi man pages (manual)
If running `inxi` within a `chroot` environment
Your privacy is respected
Update Announcements
Technical Resources
https://bbs.archlinux.org/viewtopic.php?id=276847
As AUR may be involved - for building a customised driver package - please acknowledge the unsupported nature of custom packages.
Install the headers for your active kernel
Kernel example - yours may be different
 $ mhwd-kernel -li
Currently running: 6.18.0-1-MANJARO (linux618)
   * linux618
Note the line Currently running: 6.18.0-1-MANJARO (linux618)
Prepare by syncing the base-devel and linux618-headers
Yours may be different - adjust accordingly
sudo pacman -Syu base-devel linux618-headers
Build the driver
pamac build rtl88x2bu-dkms-git
You can try this:
Thank you for the pointers. I do apologize for the state of the original post… I’m relatively new here and appreciate your patience.
Installing the RinCat driver appears to have done the trick. I’ve written up how I got it sorted out (as I didn’t find just one simple instruction set with clear guidance that didn’t need modification for me)
thank you all again.
