Touchscreen Calibration displays garbage
I bought a Raspberry-pi 400 a while ago to use to learn linux. I also bought this touch screen to go with it GeeekPi-1024x600-Capacitive-Monitor-Raspberry/dp/B075QCXLPF on amazon which works great as a display. However the calibration on the touch is off. It also requires a resolution of 1024x600 or it displays lines all over. I tried to use ts_calibrate to calibrate the display but this just makes the screen show nothing or random lines of random colors sliding all over the place. I tried to contact the maintainer of the tslib but the email on the github page for support blocks emails. Is there another tool that I should be using instead? or is there a way to force ts to use the resolution needed by my display?
Thank you very much.
Whats the proper way to calibrate a touch display? Ive seen a handfull of guides that dont work, ive tried installing xinput_calibrate and running ts_calibrate. The latter of wich just makes my screen go crazy, and the support email in the github blocks emails. Im on an arm raspi400. Thank yall
Please review Forum Rules - Manjaro regarding Cross-Posting.
Here is a tutorial on How to provide good information and share it here. Also provide:
xinput --list
This are the best sources of investigation Touchscreen - ArchWiki and
Calibrating Touchscreen - ArchWiki
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ ILITEK ILITEK-TP Mouse id=7 [slave pointer (2)]
⎜ ↳ ILITEK ILITEK-TP id=6 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Raspberry Pi Internal Keyboard id=8 [slave keyboard (3)]
↳ Raspberry Pi Internal Keyboard id=9 [slave keyboard (3)]
ive gone through those, they arent helpful
