Rodolfo Giometti <giometti@linux.it>
[ 0.260364] PTP clock support registered
[ 0.260364] EDAC MC: Ver: 3.0.0
[ 0.260364] Registered efivars operations
[ 0.260364] NetLabel: Initializing
[ 0.260364] NetLabel: domain hash size = 128
[ 0.260364] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.260364] NetLabel: unlabeled traffic allowed by default
[ 0.260364] PCI: Using ACPI for IRQ routing
[ 0.288719] PCI: pci_cache_line_size set to 64 bytes
[ 0.288812] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff
[ 0.288813] e820: reserve RAM buffer [mem 0x00088000-0x0008ffff
[ 0.288814] e820: reserve RAM buffer [mem 0x707be000-0x73ffffff
[ 0.288815] e820: reserve RAM buffer [mem 0x70879000-0x73ffffff
[ 0.288816] e820: reserve RAM buffer [mem 0x771a5000-0x77ffffff
[ 0.288817] e820: reserve RAM buffer [mem 0x8738e000-0x87ffffff
[ 0.288818] e820: reserve RAM buffer [mem 0x87fff000-0x87ffffff
[ 0.288823] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0
, 0
[ 0.288823] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[ 0.290192] clocksource: Switched to clocksource tsc-early
[ 0.302906] VFS: Disk quotas dquot_6.6.0
[ 0.302920] VFS: Dquot-cache hash table entries: 512 (order 0,
4096 bytes)
[ 0.303033] AppArmor: AppArmor Filesystem Enabled
[ 0.303063] pnp: PnP ACPI init
[ 0.303292] system 00:00: [mem 0xfd000000-0xfdabffff] has been
reserved
[ 0.303293] system 00:00: [mem 0xfdad0000-0xfdadffff] has been
reserved
[ 0.303295] system 00:00: [mem 0xfdb00000-0xfdffffff] could not
be reserved
[ 0.303296] system 00:00: [mem 0xfe000000-0xfe01ffff] has been
reserved
[ 0.303298] system 00:00: [mem 0xfe036000-0xfe03bfff] has been
reserved
[ 0.303299] system 00:00: [mem 0xfe03d000-0xfe3fffff] has been
reserved
[ 0.303300] system 00:00: [mem 0xfe410000-0xfe7fffff] has been
reserved
[ 0.303306] system 00:00: Plug and Play ACPI device, IDs PNP0c0
2 (active)
[ 0.303719] system 00:01: [io 0x2000-0x20fe] has been reserved
[ 0.303724] system 00:01: Plug and Play ACPI device, IDs PNP0c0
2 (active)
[ 0.304993] system 00:02: [io 0x0680-0x069f] has been reserved
[ 0.304995] system 00:02: [io 0xffff] has been reserved
[ 0.304996] system 00:02: [io 0xffff] has been reserved
[ 0.304998] system 00:02: [io 0xffff] has been reserved
[ 0.304999] system 00:02: [io 0x1800-0x18fe] has been reserved
[ 0.305000] system 00:02: [io 0x164e-0x164f] has been reserved
[ 0.305004] system 00:02: Plug and Play ACPI device, IDs PNP0c0
2 (active)
[ 0.305125] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (
active)
[ 0.305171] system 00:04: [io 0x1854-0x1857] has been reserved
[ 0.305174] system 00:04: Plug and Play ACPI device, IDs INT3f0
d PNP0c02 (active)
[ 0.305274] pnp 00:05: Plug and Play ACPI device, IDs PNP0303 (
active)
[ 0.305294] pnp 00:06: Plug and Play ACPI device, IDs ETD0440 P
NP0f13 (active)
[ 0.307000] system 00:07: [mem 0xfe029000-0xfe029fff] has been
reserved
[ 0.307002] system 00:07: [mem 0xfe028000-0xfe028fff] has been
reserved
[ 0.307003] system 00:07: [mem 0xfdaf0000-0xfdafffff] has been
reserved
[ 0.307005] system 00:07: [mem 0xfdae0000-0xfdaeffff] has been
reserved
[ 0.307006] system 00:07: [mem 0xfdac0000-0xfdacffff] has been
reserved
[ 0.307010] system 00:07: Plug and Play ACPI device, IDs PNP0c0
2 (active)
[ 0.307759] system 00:08: [mem 0xfed10000-0xfed17fff] has been
reserved
[ 0.307761] system 00:08: [mem 0xfed18000-0xfed18fff] has been
reserved
[ 0.307762] system 00:08: [mem 0xfed19000-0xfed19fff] has been
reserved
[ 0.307763] system 00:08: [mem 0xe0000000-0xefffffff] has been
reserved
[ 0.307766] system 00:08: [mem 0xfed20000-0xfed3ffff] has been
reserved
[ 0.307767] system 00:08: [mem 0xfed90000-0xfed93fff] could not
be reserved
[ 0.307769] system 00:08: [mem 0xfed45000-0xfed8ffff] could not
be reserved
[ 0.307770] system 00:08: [mem 0xff000000-0xffffffff] could not
be reserved
[ 0.307772] system 00:08: [mem 0xfee00000-0xfeefffff] could not
be reserved
[ 0.307773] system 00:08: [mem 0x8b000000-0x8b01ffff] has been
reserved
[ 0.307777] system 00:08: Plug and Play ACPI device, IDs PNP0c0
2 (active)
[ 0.308559] pnp: PnP ACPI: found 9 devices
[ 0.314353] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0x
ffffff, max_idle_ns: 2085701024 ns
[ 0.314411] NET: Registered protocol family 2
[ 0.314561] tcp_listen_portaddr_hash hash table entries: 2048 (
order: 3, 32768 bytes, linear)
[ 0.314585] TCP established hash table entries: 32768 (order: 6
, 262144 bytes, linear)
[ 0.314652] TCP bind hash table entries: 32768 (order: 7, 52428
8 bytes, linear)
[ 0.314699] TCP: Hash tables configured (established 32768 bind
32768)
[ 0.314745] MPTCP token hash table entries: 4096 (order: 4, 983
04 bytes, linear)
[ 0.314771] UDP hash table entries: 2048 (order: 4, 65536 bytes
, linear)
[ 0.314784] UDP-Lite hash table entries: 2048 (order: 4, 65536
bytes, linear)
[ 0.314847] NET: Registered protocol family 1
[ 0.314852] NET: Registered protocol family 44
[ 0.314863] pci 0000:00:1c.0: PCI bridge to [bus 01]
[ 0.314866] pci 0000:00:1c.0: bridge window [io 0x3000-0x3ff
f]
[ 0.314872] pci 0000:00:1c.0: bridge window [mem 0xa1000000-0
xa10fffff 64bit pref]
[ 0.314877] pci 0000:00:1c.4: PCI bridge to [bus 02]
[ 0.314881] pci 0000:00:1c.4: bridge window [mem 0xa1100000-0
xa11fffff]
[ 0.314889] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 wind
ow]
[ 0.314890] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff wind
ow]
[ 0.314891] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bf
fff window]
[ 0.314892] pci_bus 0000:00: resource 7 [mem 0x8b000000-0xdffff
fff window]
[ 0.314894] pci_bus 0000:00: resource 8 [mem 0xfd000000-0xfe7ff
fff window]
[ 0.314895] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ 0.314896] pci_bus 0000:01: resource 2 [mem 0xa1000000-0xa10ff
fff 64bit pref]
[ 0.314897] pci_bus 0000:02: resource 1 [mem 0xa1100000-0xa11ff
fff]
[ 0.315121] pci 0000:00:02.0: Video device with shadowed ROM at
[mem 0x000c0000-0x000dffff]
[ 0.316737] PCI: CLS 64 bytes, default 64
[ 0.316787] Trying to unpack rootfs image as initramfs...
[ 0.490744] Freeing initrd memory: 12644K
[ 0.490779] DMAR: ACPI device "device:6d" under DMAR at fed9100
0 as 00:1e.0
[ 0.490795] PCI-DMA: Using software bounce buffering for IO (SW
IOTLB)
[ 0.490797] software IO TLB: mapped [mem 0x7a2b8000-0x7e2b8000]
(64MB)
[ 0.490947] check: Scanning for low memory corruption every 60
seconds
[ 0.491285] Initialise system trusted keyrings
[ 0.491293] Key type blacklist registered
[ 0.491339] workingset: timestamp_bits=41 max_order=20 bucket_o
rder=0
[ 0.492571] zbud: loaded
[ 0.502744] Key type asymmetric registered
[ 0.502745] Asymmetric key parser 'x509' registered
[ 0.502754] Block layer SCSI generic (bsg) driver version 0.4 l
oaded (major 244)
[ 0.502795] io scheduler mq-deadline registered
[ 0.502796] io scheduler kyber registered
[ 0.502819] io scheduler bfq registered
[ 0.503262] pcieport 0000:00:1c.0: PME: Signaling with IRQ 122
[ 0.503319] pcieport 0000:00:1c.0: AER: enabled with IRQ 122
[ 0.503591] pcieport 0000:00:1c.4: PME: Signaling with IRQ 123
[ 0.503684] shpchp: Standard Hot Plug PCI Controller Driver ver
sion: 0.4
[ 0.503769] efifb: probing for efifb
[ 0.503786] efifb: showing boot graphics
[ 0.504333] efifb: framebuffer at 0x90000000, using 4160k, tota
l 4160k
[ 0.504334] efifb: mode is 1366x768x32, linelength=5504, pages=
1
[ 0.504334] efifb: scrolling: redraw
[ 0.504336] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.504376] fbcon: Deferring console take-over
[ 0.504377] fb0: EFI VGA frame buffer device
[ 0.504385] intel_idle: MWAIT substates: 0x11142120
[ 0.504386] intel_idle: v0.5.1 model 0x4E
[ 0.504629] intel_idle: Local APIC timer is reliable in all C-s
tates
[ 0.504698] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:
00/PNP0A08:00/device:18/PNP0C09:00/PNP0C0D:00/input/input0
[ 0.504719] ACPI: Lid Switch [LID0]
[ 0.504788] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBU
S:00/PNP0C0E:00/input/input1
[ 0.504806] ACPI: Sleep Button [SLPB]
[ 0.504839] input: Power Button as /devices/LNXSYSTM:00/LNXPWRB
N:00/input/input2
[ 0.506892] ACPI: Power Button [PWRF]
[ 0.508535] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.508537] ACPI: Thermal Zone [TZ00] (28 C)
[ 0.508753] thermal LNXTHERM:01: registered as thermal_zone1
[ 0.508754] ACPI: Thermal Zone [TZ01] (30 C)
[ 0.509149] Serial: 8250/16550 driver, 4 ports, IRQ sharing ena
bled
[ 0.509960] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel
@suse.de>
[ 0.509961] AMD-Vi: AMD IOMMUv2 functionality not available on
this system
[ 0.510459] ahci 0000:00:17.0: version 3.0
[ 0.510682] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 3 ports
6 Gbps 0x7 impl SATA mode
[ 0.510685] ahci 0000:00:17.0: flags: 64bit ncq pm led clo only
pio slum part deso sadm sds apst
[ 0.511113] scsi host0: ahci
[ 0.511236] scsi host1: ahci
[ 0.511331] scsi host2: ahci
[ 0.511370] ata1: SATA max UDMA/133 abar m2048@0xa122f000 port
0xa122f100 irq 124
[ 0.511372] ata2: SATA max UDMA/133 abar m2048@0xa122f000 port
0xa122f180 irq 124
[ 0.511373] ata3: SATA max UDMA/133 abar m2048@0xa122f000 port
0xa122f200 irq 124
[ 0.511437] usbcore: registered new interface driver usbserial_
generic
[ 0.511441] usbserial: USB Serial support registered for generi
c
[ 0.511463] rtc_cmos 00:03: RTC can wake from S4
[ 0.511977] rtc_cmos 00:03: registered as rtc0
[ 0.512077] rtc_cmos 00:03: setting system clock to 2020-11-14T
15:21:38 UTC (1605367298)
[ 0.512093] rtc_cmos 00:03: alarms up to one month, y3k, 242 by
tes nvram, hpet irqs
[ 0.512157] intel_pstate: Intel P-state driver initializing
[ 0.512338] intel_pstate: HWP enabled
[ 0.512378] ledtrig-cpu: registered to indicate activity on CPU
s
[ 0.512449] ashmem: initialized
[ 0.512557] intel_pmc_core intel_pmc_core.0: initialized
[ 0.512608] drop_monitor: Initializing network drop monitor ser
vice
[ 0.512766] NET: Registered protocol family 10
[ 0.518136] Segment Routing with IPv6
[ 0.518137] RPL Segment Routing with IPv6
[ 0.518164] NET: Registered protocol family 17
[ 0.518434] microcode: sig=0x406e3, pf=0x80, revision=0xd6
[ 0.518482] microcode: Microcode Update Driver: v2.2.
[ 0.518486] IPI shorthand broadcast: enabled
[ 0.518493] sched_clock: Marking stable (517941107, 537385)->(5
21703927, -3225435)
[ 0.518566] registered taskstats version 1
[ 0.518574] Loading compiled-in X.509 certificates
[ 0.521731] Loaded X.509 cert 'Build time autogenerated kernel
key: de009724167e325b20ce6996965fc1a8885d7ce9'
[ 0.522459] zswap: loaded using pool zstd/z3fold
[ 0.522654] Key type ._fscrypt registered
[ 0.522655] Key type .fscrypt registered
[ 0.522656] Key type fscrypt-provisioning registered
[ 0.522698] AppArmor: AppArmor sha1 policy hashing enabled
[ 0.523888] PM: Magic number: 12:496:386
[ 0.523902] thermal cooling_device1: hash matches
[ 0.524080] RAS: Correctable Errors collector initialized.
[ 0.826925] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 3
00)
[ 0.826949] ata1: SATA link down (SStatus 4 SControl 300)
[ 0.826974] ata2: SATA link down (SStatus 4 SControl 300)
[ 0.827181] ata3.00: ATA-10: KINGSTON SA400S37240G, SBFKJ3A3, m
ax UDMA/133
[ 0.827184] ata3.00: 468862128 sectors, multi 1: LBA48 NCQ (dep
th 32), AA
[ 0.827450] ata3.00: configured for UDMA/133
[ 0.840577] scsi 2:0:0:0: Direct-Access ATA KINGSTON S
A400S3 J3A3 PQ: 0 ANSI: 5
[ 0.840911] sd 2:0:0:0: [sda] 468862128 512-byte logical blocks
: (240 GB/224 GiB)
[ 0.840925] sd 2:0:0:0: [sda] Write Protect is off
[ 0.840928] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.840949] sd 2:0:0:0: [sda] Write cache: enabled, read cache:
enabled, doesn't support DPO or FUA
[ 0.843918] sda: sda1 sda2 sda3 sda4 sda5 sda6
[ 0.844575] sd 2:0:0:0: [sda] Attached SCSI disk
[ 0.847166] Freeing unused decrypted memory: 2040K
[ 0.847774] Freeing unused kernel image (initmem) memory: 1664K
[ 0.866935] Write protecting the kernel read-only data: 22528k
[ 0.867961] Freeing unused kernel image (text/rodata gap) memor
y: 2044K
[ 0.868472] Freeing unused kernel image (rodata/data gap) memor
y: 1408K
[ 0.951341] x86/mm: Checked W+X mappings: passed, no W+X pages
found.
[ 0.951343] x86/mm: Checking user space page tables
[ 1.016060] x86/mm: Checked W+X mappings: passed, no W+X pages
found.
[ 1.016065] Run /init as init process
[ 1.016066] with arguments:
[ 1.016067] /init
[ 1.016068] with environment:
[ 1.016068] HOME=/
[ 1.016069] TERM=linux
[ 1.016069] BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
[ 1.209540] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:P
S2M] at 0x60,0x64 irq 1,12
[ 1.212913] i8042: Detected active multiplexing controller, rev
1.1
[ 1.214675] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.214718] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 1.214755] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 1.214791] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 1.214826] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 1.231040] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.231048] xhci_hcd 0000:00:14.0: new USB bus registered, assi
gned bus number 1
[ 1.232143] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci ve
rsion 0x100 quirks 0x0000000081109810
[ 1.232275] xhci_hcd 0000:00:14.0: cache line size of 64 is not
supported
[ 1.232524] usb usb1: New USB device found, idVendor=1d6b, idPr
oduct=0002, bcdDevice= 5.09
[ 1.232527] usb usb1: New USB device strings: Mfr=3, Product=2,
SerialNumber=1
[ 1.232529] usb usb1: Product: xHCI Host Controller
[ 1.232530] usb usb1: Manufacturer: Linux 5.9.3-1-MANJARO xhci-
hcd
[ 1.232532] usb usb1: SerialNumber: 0000:00:14.0
[ 1.232679] hub 1-0:1.0: USB hub found
[ 1.232697] hub 1-0:1.0: 12 ports detected
[ 1.234974] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 1.234985] xhci_hcd 0000:00:14.0: new USB bus registered, assi
gned bus number 2
[ 1.234989] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperS
peed
[ 1.235039] usb usb2: New USB device found, idVendor=1d6b, idPr
oduct=0003, bcdDevice= 5.09
[ 1.235042] usb usb2: New USB device strings: Mfr=3, Product=2,
SerialNumber=1
[ 1.235043] usb usb2: Product: xHCI Host Controller
[ 1.235045] usb usb2: Manufacturer: Linux 5.9.3-1-MANJARO xhci-
hcd
[ 1.235046] usb usb2: SerialNumber: 0000:00:14.0
[ 1.235173] hub 2-0:1.0: USB hub found
[ 1.235187] hub 2-0:1.0: 6 ports detected
[ 1.236246] usb: port power management may be unreliable
[ 1.242477] sdhci: Secure Digital Host Controller Interface dri
ver
[ 1.242478] sdhci: Copyright(c) Pierre Ossman
[ 1.247283] sdhci-pci 0000:00:1e.4: SDHCI controller found [808
6:9d2b] (rev 21)
[ 1.252155] mmc0: SDHCI controller on PCI [0000:00:1e.4] using
ADMA 64-bit
[ 1.288138] random: fast init done
[ 1.324034] EXT4-fs (sda5): mounted filesystem with ordered dat
a mode. Opts: (null)
[ 1.396110] input: AT Translated Set 2 keyboard as /devices/pla
tform/i8042/serio0/input/input3
[ 1.428944] atkbd serio0: Unknown key released (translated set
2, code 0x7c on isa0060/serio0).
[ 1.428948] atkbd serio0: Use 'setkeycodes 7c <keycode>' to mak
e it known.
[ 1.479868] systemd[1]: systemd 246.6-1-manjaro running in syst
em mode. (+PAM +AUDIT -SELINUX -IMA -APPARMOR +SMACK -SYSVINIT +UT
MP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BL
KID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 1.493689] systemd[1]: Detected architecture x86-64.
[ 1.496927] tsc: Refined TSC clocksource calibration: 2304.007
MHz
[ 1.496933] clocksource: tsc: mask: 0xffffffffffffffff max_cycl
es: 0x2135fe3feda, max_idle_ns: 440795221734 ns
[ 1.496952] clocksource: Switched to clocksource tsc
[ 1.510752] systemd[1]: Set hostname to <chavo-presario>.
[ 1.563515] usb 1-6: new full-speed USB device number 2 using x
hci_hcd
[ 1.632262] atkbd serio0: Unknown key released (translated set
[ 1.632264] atkbd serio0: Use 'setkeycodes 7c <keycode>' to mak
e it known.
[ 1.704541] usb 1-6: New USB device found, idVendor=8087, idPro
duct=07dc, bcdDevice= 0.01
[ 1.704544] usb 1-6: New USB device strings: Mfr=0, Product=0,
SerialNumber=0
[ 1.725497] systemd[1]: Queued start job for default target Gra
phical Interface.
[ 1.726672] systemd[1]: Created slice system-getty.slice.
[ 1.726969] systemd[1]: Created slice system-modprobe.slice.
[ 1.727179] systemd[1]: Created slice system-systemd\x2dfsck.sl
ice.
[ 1.727413] systemd[1]: Created slice User and Session Slice.
[ 1.727483] systemd[1]: Started Dispatch Password Requests to C
onsole Directory Watch.
[ 1.727533] systemd[1]: Started Forward Password Requests to Wa
ll Directory Watch.
[ 1.727739] systemd[1]: Set up automount Arbitrary Executable F
ile Formats File System Automount Point.
[ 1.727778] systemd[1]: Reached target Local Encrypted Volumes.
[ 1.727790] systemd[1]: Reached target Login Prompts.
[ 1.727816] systemd[1]: Reached target Remote File Systems.
[ 1.727825] systemd[1]: Reached target Slices.
[ 1.727906] systemd[1]: Listening on Device-mapper event daemon
FIFOs.
[ 1.728160] systemd[1]: Listening on LVM2 metadata daemon socke
t.
[ 1.728239] systemd[1]: Listening on LVM2 poll daemon socket.
[ 1.729854] systemd[1]: Listening on Process Core Dump Socket.
[ 1.730017] systemd[1]: Listening on Journal Audit Socket.
[ 1.730119] systemd[1]: Listening on Journal Socket (/dev/log).
[ 1.730252] systemd[1]: Listening on Journal Socket.
[ 1.730374] systemd[1]: Listening on udev Control Socket.
[ 1.730460] systemd[1]: Listening on udev Kernel Socket.
[ 1.731388] systemd[1]: Mounting Huge Pages File System...
[ 1.732436] systemd[1]: Mounting POSIX Message Queue File Syste
m...
[ 1.733787] systemd[1]: Mounting Kernel Debug File System...
[ 1.735109] systemd[1]: Mounting Kernel Trace File System...
[ 1.736592] systemd[1]: Starting Load AppArmor profiles...
[ 1.738167] systemd[1]: Starting Create list of static device n
odes for the current kernel...
[ 1.739515] systemd[1]: Starting Monitoring of LVM2 mirrors, sn
apshots etc. using dmeventd or progress polling...
[ 1.740958] systemd[1]: Starting Load Kernel Module drm...
[ 1.742820] systemd[1]: Starting Set Up Additional Binary Forma
ts...
[ 1.742908] systemd[1]: Condition check resulted in File System
Check on Root Device being skipped.
[ 1.745300] systemd[1]: Starting Journal Service...
[ 1.748305] systemd[1]: Starting Load Kernel Modules...
[ 1.749432] systemd[1]: Starting Remount Root and Kernel File S
ystems...
[ 1.749529] systemd[1]: Condition check resulted in Repartition
Root Disk being skipped.
[ 1.751005] systemd[1]: Starting Coldplug All udev Devices...
[ 1.753291] systemd[1]: Mounted Huge Pages File System.
[ 1.753480] systemd[1]: Mounted POSIX Message Queue File System
[ 1.753680] systemd[1]: Mounted Kernel Debug File System.
[ 1.753848] systemd[1]: Mounted Kernel Trace File System.
[ 1.754581] systemd[1]: Finished Create list of static device n
[ 1.754870] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got
automount request for /proc/sys/fs/binfmt_misc, triggered by 220 (
systemd-binfmt)
[ 1.756440] systemd[1]: Mounting Arbitrary Executable File Form
ats File System...
[ 1.760507] systemd[1]: Mounted Arbitrary Executable File Forma
ts File System.
[ 1.764114] Linux agpgart interface v0.103
[ 1.769058] systemd[1]: Finished Set Up Additional Binary Forma
ts.
[ 1.769376] EXT4-fs (sda5): re-mounted. Opts: (null)
[ 1.770272] random: lvm: uninitialized urandom read (4 bytes re
ad)
[ 1.774507] systemd[1]: Finished Remount Root and Kernel File S
ystems.
[ 1.774745] systemd[1]: Condition check resulted in First Boot
Wizard being skipped.
[ 1.777590] systemd[1]: Condition check resulted in Rebuild Har
dware Database being skipped.
[ 1.778858] systemd[1]: Starting Load/Save Random Seed...
[ 1.778980] systemd[1]: Condition check resulted in Create Syst
em Users being skipped.
[ 1.780333] systemd[1]: Starting Create Static Device Nodes in
/dev...
[ 1.791262] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 1.821206] systemd[1]: Finished Load Kernel Modules.
[ 1.821596] systemd[1]: Condition check resulted in FUSE Contro
l File System being skipped.
[ 1.826860] usb 1-7: new high-speed USB device number 3 using x
hci_hcd
[ 1.827781] systemd[1]: Mounting Kernel Configuration File Syst
em...
[ 1.829671] systemd[1]: Starting Apply Kernel Variables...
[ 1.830842] systemd[1]: Finished Create Static Device Nodes in
/dev.
[ 1.835535] atkbd serio0: Unknown key released (translated set
[ 1.835538] atkbd serio0: Use 'setkeycodes 7c <keycode>' to mak
e it known.
[ 1.837327] systemd[1]: Starting Rule-based Manager for Device
Events and Files...
[ 1.837882] systemd[1]: modprobe@drm.service: Succeeded.
[ 1.838495] systemd[1]: Finished Load Kernel Module drm.
[ 1.838819] systemd[1]: Mounted Kernel Configuration File Syste
m.
[ 1.847969] systemd[1]: Finished Apply Kernel Variables.
[ 1.896964] systemd[1]: Finished Coldplug All udev Devices.
[ 2.012970] usb 1-7: New USB device found, idVendor=058f, idPro
duct=3822, bcdDevice=11.00
[ 2.012973] usb 1-7: New USB device strings: Mfr=0, Product=2,
SerialNumber=0
[ 2.012975] usb 1-7: Product: HD Webcam
[ 2.038924] atkbd serio0: Unknown key released (translated set
[ 2.038926] atkbd serio0: Use 'setkeycodes 7c <keycode>' to mak
e it known.
[ 2.142333] audit: type=1400 audit(1605367300.124:2): apparmor=
"STATUS" operation="profile_load" profile="unconfined" name="lsb_r
elease" pid=235 comm="apparmor_parser"
[ 2.205151] audit: type=1400 audit(1605367300.188:3): apparmor=
"STATUS" operation="profile_load" profile="unconfined" name="nvidi
a_modprobe" pid=234 comm="apparmor_parser"
[ 2.218596] audit: type=1400 audit(1605367300.201:4): apparmor=
a_modprobe//kmod" pid=234 comm="apparmor_parser"
[ 2.359467] systemd[1]: Started Journal Service.
[ 2.359573] audit: type=1130 audit(1605367300.341:5): pid=1 uid
=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=syste
md-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname
=? addr=? terminal=? res=success'
[ 2.425591] audit: type=1400 audit(1605367300.408:6): apparmor=
"STATUS" operation="profile_load" profile="unconfined" name="dovec
ot-script-login" pid=236 comm="apparmor_parser"
[ 2.487861] audit: type=1130 audit(1605367300.471:7): pid=1 uid
md-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hos
tname=? addr=? terminal=? res=success'
[ 2.519392] audit: type=1130 audit(1605367300.501:8): pid=1 uid
md-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=?
[ 2.519397] audit: type=1400 audit(1605367300.501:9): apparmor=
"STATUS" operation="profile_load" profile="unconfined" name="php-f
pm" pid=242 comm="apparmor_parser"
[ 2.519400] audit: type=1130 audit(1605367300.501:10): pid=1 ui
d=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2
-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=?
[ 2.712417] ACPI: AC Adapter [ADP1] (on-line)
[ 2.806411] battery: ACPI: Battery Slot [BAT1] (battery present
[ 2.823904] tpm_crb MSFT0101:00: [Firmware Bug]: Bad ACPI memor
y layout
[ 2.917592] random: mktemp: uninitialized urandom read (6 bytes
read)
[ 2.929165] intel-lpss 0000:00:1e.0: enabling device (0000 -> 0
002)
[ 2.929645] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ 2.932886] libphy: Fixed MDIO Bus: probed
[ 2.938575] random: mktemp: uninitialized urandom read (6 bytes
read)
[ 2.955475] random: tlp-readconfs: uninitialized urandom read (
4 bytes read)
[ 3.037298] Adding 4096576k swap on /dev/sda6. Priority:-2 ext
ents:1 across:4096576k SSFS
[ 3.048541] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[ 3.050024] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[ 3.050067] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[ 3.059672] i2c i2c-0: 2/4 memory slots populated (from DMI)
[ 3.205968] input: PC Speaker as /devices/platform/pcspkr/input
/input8
[ 3.212765] cfg80211: Loading compiled-in X.509 certificates fo
r regulatory database
[ 3.223944] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47ae
f9cea7'
[ 3.303558] r8169 0000:01:00.0: can't disable ASPM; OS doesn't
have ASPM control
[ 3.316195] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counter
s, 655360 ms ovfl timer
[ 3.316197] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 3.316198] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 3.316199] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 3.316200] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[ 3.316201] RAPL PMU: hw unit of domain psys 2^-14 Joules
[ 3.326299] libphy: r8169: probed
[ 3.326599] r8169 0000:01:00.0 eth0: RTL8168evl/8111evl, 00:e0:
4c:69:b0:c7, XID 2c9, IRQ 127
[ 3.326602] r8169 0000:01:00.0 eth0: jumbo features [frames: 91
94 bytes, tx checksumming: ko]
[ 3.400538] loop: module loaded
[ 3.401846] cryptd: max_cpu_qlen set to 1000
[ 3.428911] ppdev: user-space parallel port driver
[ 3.466565] AVX2 version of gcm_enc/dec engaged.
[ 3.466567] AES CTR mode by8 optimization enabled
[ 3.468688] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 3.473506] random: crng init done
[ 3.473509] random: 1 urandom warning(s) missed due to ratelimi
ting
[ 3.477800] Intel(R) Wireless WiFi driver for Linux
[ 3.485172] iwlwifi 0000:02:00.0: loaded firmware version 17.32
16344376.0 3160-17.ucode op_mode iwlmvm
[ 3.520090] dw-apb-uart.0: ttyS0 at MMIO 0xa122d000 (irq = 20,
base_baud = 115200) is a 16550A
[ 3.569172] r8169 0000:01:00.0 enp1s0: renamed from eth0
[ 3.809540] psmouse serio2: elantech: assuming hardware version
3 (with firmware version 0x254f00)
[ 3.820431] iwlwifi 0000:02:00.0: Detected Intel(R) Dual Band W
ireless AC 3160, REV=0x164
[ 3.821033] checking generic (90000000 410000) vs hw (a0000000
1000000)
[ 3.821035] checking generic (90000000 410000) vs hw (90000000
10000000)
[ 3.821037] fb0: switching to inteldrmfb from EFI VGA
[ 3.821129] i915 0000:00:02.0: vgaarb: deactivate vga console
[ 3.831541] i915 0000:00:02.0: vgaarb: changed VGA decodes: old
decodes=io+mem,decodes=io+mem:owns=io+mem
[ 3.832907] i915 0000:00:02.0: [drm] Finished loading DMC firmw
are i915/skl_dmc_ver1_27.bin (v1.27)
[ 3.840028] iwlwifi 0000:02:00.0: base HW address: 78:0c:b8:f7:
3a:23
[ 3.853063] [drm] Initialized i915 1.6.0 20200715 for 0000:00:0
2.0 on minor 0
[ 3.857145] ACPI: Video Device [GFX0] (multi-head: yes rom: no
post: no)
[ 3.857843] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:0
0/PNP0A08:00/LNXVIDEO:00/input/input11
[ 3.858144] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops
i915_audio_component_bind_ops [i915])
[ 3.959424] ieee80211 phy0: Selected rate control algorithm 'iw
l-mvm-rs'
[ 3.981474] iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
[ 4.010176] psmouse serio2: elantech: elantech_send_cmd query 0
x02 failed.
[ 4.010179] psmouse serio2: elantech: failed to query capabilit
ies.
[ 4.059398] snd_hda_codec_realtek hdaudioC0D0: autoconfig for A
LC269VC: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[ 4.059401] snd_hda_codec_realtek hdaudioC0D0: speaker_outs=
0 (0x0/0x0/0x0/0x0/0x0)
[ 4.059404] snd_hda_codec_realtek hdaudioC0D0: hp_outs=1 (0x
15/0x0/0x0/0x0/0x0)
[ 4.059405] snd_hda_codec_realtek hdaudioC0D0: mono: mono_ou
t=0x0
[ 4.059406] snd_hda_codec_realtek hdaudioC0D0: inputs:
[ 4.059408] snd_hda_codec_realtek hdaudioC0D0: Mic=0x18
[ 4.059409] snd_hda_codec_realtek hdaudioC0D0: Internal Mi
c=0x12
[ 4.069001] fbcon: i915drmfb (fb0) is primary device
[ 4.069003] fbcon: Deferring console take-over
[ 4.069007] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffe
r device
[ 4.084372] intel_rapl_common: Found RAPL domain package
[ 4.084375] intel_rapl_common: Found RAPL domain core
[ 4.084376] intel_rapl_common: Found RAPL domain uncore
[ 4.084377] intel_rapl_common: Found RAPL domain dram
[ 4.127381] input: HDA Digital PCBeep as /devices/pci0000:00/00
00:00:1f.3/sound/card0/input12
[ 4.127468] input: HDA Intel PCH Mic as /devices/pci0000:00/000
0:00:1f.3/sound/card0/input13
[ 4.127545] input: HDA Intel PCH Headphone as /devices/pci0000:
00/0000:00:1f.3/sound/card0/input14
[ 4.127625] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0
000:00/0000:00:1f.3/sound/card0/input15
[ 4.127701] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0
000:00/0000:00:1f.3/sound/card0/input16
[ 4.127776] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0
000:00/0000:00:1f.3/sound/card0/input17
[ 4.127851] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0
000:00/0000:00:1f.3/sound/card0/input18
[ 4.127930] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci
0000:00/0000:00:1f.3/sound/card0/input19
[ 4.698595] input: PS/2 Logitech Wheel Mouse as /devices/platfo
rm/i8042/serio2/input/input10
[ 4.707351] mousedev: PS/2 mouse device common for all mice
[ 4.707520] atkbd serio0: Unknown key released (translated set
[ 4.707523] atkbd serio0: Use 'setkeycodes 7c <keycode>' to mak
e it known.
[ 4.823201] mc: Linux media interface: v0.10
[ 4.900305] videodev: Linux video capture interface: v2.00
[ 4.909735] atkbd serio0: Unknown key released (translated set
[ 4.909738] atkbd serio0: Use 'setkeycodes 7c <keycode>' to mak
e it known.
[ 4.982649] Bluetooth: Core ver 2.22
[ 4.982669] NET: Registered protocol family 31
[ 4.982670] Bluetooth: HCI device and connection manager initia
lized
[ 4.982674] Bluetooth: HCI socket layer initialized
[ 4.982676] Bluetooth: L2CAP socket layer initialized
[ 4.982680] Bluetooth: SCO socket layer initialized
[ 5.069133] uvcvideo: Found UVC 1.00 device HD Webcam (058f:382
2)
[ 5.089450] input: HD Webcam: HD Webcam as /devices/pci0000:00/
0000:00:14.0/usb1/1-7/1-7:1.0/input/input22
[ 5.089543] usbcore: registered new interface driver uvcvideo
[ 5.089544] USB Video Class driver (1.1.1)
[ 5.124342] usbcore: registered new interface driver btusb
[ 5.141135] Bluetooth: hci0: read Intel version: 3707100100012d
0d27
[ 5.141138] Bluetooth: hci0: Intel device is already patched. p
atch num: 27
[ 5.166519] kauditd_printk_skb: 33 callbacks suppressed
[ 5.166520] audit: type=1130 audit(1605367303.148:43): pid=1 ui
d=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blue
tooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? add
[ 5.178511] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.178513] Bluetooth: BNEP filters: protocol multicast
[ 5.178517] Bluetooth: BNEP socket layer initialized
[ 5.193934] audit: type=1130 audit(1605367303.178:44): pid=1 ui
d=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=syst
emd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostna
[ 5.200094] NET: Registered protocol family 38
[ 5.254149] audit: type=1130 audit(1605367303.238:45): pid=1 ui
d=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=Netw
orkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd
" hostname=? addr=? terminal=? res=success'
[ 5.255126] RTL8211E Gigabit Ethernet r8169-100:00: attached PH
Y driver [RTL8211E Gigabit Ethernet] (mii_bus:phy_addr=r8169-100:0
0, irq=IGNORE)
[ 5.322038] audit: type=1130 audit(1605367303.304:46): pid=1 ui
emd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=
[ 5.324084] audit: type=1130 audit(1605367303.308:47): pid=1 ui
d=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm
comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? t
[ 5.495173] r8169 0000:01:00.0 enp1s0: Link is Down
[ 5.620094] audit: type=1130 audit(1605367303.601:48): pid=1 ui
d=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=tlp
comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? te
[ 5.842850] audit: type=1130 audit(1605367303.824:49): pid=1 ui
d=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_
supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=
[ 5.961864] audit: type=1100 audit(1605367303.944:50): pid=906
uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:
authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/
sddm-helper" hostname=? addr=? terminal=? res=success'
[ 5.961962] audit: type=1101 audit(1605367303.944:51): pid=906
accounting grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm
[ 5.963066] audit: type=1103 audit(1605367303.944:52): pid=906
setcred grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-he
[ 8.302820] r8169 0000:01:00.0 enp1s0: Link is Up - 1Gbps/Full
- flow control rx/tx
[ 8.302840] IPv6: ADDRCONF(NETDEV_CHANGE): enp1s0: link becomes
ready
[ 12.443521] kauditd_printk_skb: 14 callbacks suppressed
[ 12.443551] audit: type=1130 audit(1605367310.424:67): pid=1 ui
orkManager-wait-online comm="systemd" exe="/usr/lib/systemd/system
d" hostname=? addr=? terminal=? res=success'
[ 12.494012] audit: type=1130 audit(1605367310.478:68): pid=1 ui
d=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=org.
cups.cupsd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=
[ 14.682821] audit: type=1100 audit(1605367312.664:69): pid=1013
:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_fa
illock acct="chavo" exe="/usr/lib/sddm/sddm-helper" hostname=? add
[ 14.684451] audit: type=1101 audit(1605367312.668:70): pid=1013
:accounting grantors=pam_access,pam_permit,pam_time acct="chavo" e
xe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=su
ccess'
[ 14.685041] audit: type=1103 audit(1605367312.668:71): pid=1013
:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock
acct="chavo" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? ter
[ 14.685227] audit: type=1006 audit(1605367312.668:72): pid=1013
uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) o
ld-ses=4294967295 ses=2 res=1
[ 14.711439] audit: type=1130 audit(1605367312.694:73): pid=1 ui
d=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user
-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" ho
[ 14.719788] audit: type=1101 audit(1605367312.701:74): pid=1015
xe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=suc
cess'
[ 14.719838] audit: type=1103 audit(1605367312.701:75): pid=1015
:setcred grantors=? acct="chavo" exe="/usr/lib/systemd/systemd" ho
stname=? addr=? terminal=? res=failed'
[ 14.719910] audit: type=1006 audit(1605367312.701:76): pid=1015
ld-ses=4294967295 ses=3 res=1
[ 15.023542] fuse: init (API version 7.31)
[ 17.702038] Bluetooth: RFCOMM TTY layer initialized
[ 17.702045] Bluetooth: RFCOMM socket layer initialized
[ 17.702051] Bluetooth: RFCOMM ver 1.11
[ 21.040564] wlp2s0: authenticate with a4:2b:b0:e7:51:dd
[ 21.050063] wlp2s0: send auth to a4:2b:b0:e7:51:dd (try 1/3)
[ 21.055598] wlp2s0: authenticated
[ 21.060351] wlp2s0: associate with a4:2b:b0:e7:51:dd (try 1/3)
[ 21.064541] wlp2s0: RX AssocResp from a4:2b:b0:e7:51:dd (capab=
0x411 status=0 aid=3)
[ 21.082880] wlp2s0: associated
[ 22.093348] IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes
ready
[ 22.139287] kauditd_printk_skb: 9 callbacks suppressed
[ 22.139289] audit: type=1130 audit(1605367320.121:86): pid=1 ui
[ 24.919353] audit: type=1131 audit(1605367322.901:87): pid=1 ui
@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr
[ 24.962876] audit: type=1131 audit(1605367322.944:88): pid=1 ui
-runtime-dir@967 comm="systemd" exe="/usr/lib/systemd/systemd" hos
[ 32.018283] audit: type=1131 audit(1605367330.001:89): pid=1 ui
[ 35.254160] audit: type=1131 audit(1605367333.238:90): pid=1 ui
[ 35.313745] audit: type=1334 audit(1605367333.298:91): prog-id=
10 op=UNLOAD
[ 35.313754] audit: type=1334 audit(1605367333.298:92): prog-id=
9 op=UNLOAD
[ 49.644142] audit: type=1100 audit(1605367347.814:93): pid=1948
uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authenticat
ion grantors=pam_faillock,pam_permit,pam_faillock acct="chavo" exe
="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success
[ 49.646493] audit: type=1101 audit(1605367347.817:94): pid=1948
uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting
grantors=pam_permit,pam_time acct="chavo" exe="/usr/bin/sudo" host
name=? addr=? terminal=/dev/pts/1 res=success'
[ 49.647101] audit: type=1110 audit(1605367347.817:95): pid=1948
uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred granto
rs=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/
sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 49.652139] audit: type=1105 audit(1605367347.824:96): pid=1948
uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open g
rantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/s
[ 49.655814] audit: type=1106 audit(1605367347.827:97): pid=1948
uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close
grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/
[ 49.655943] audit: type=1104 audit(1605367347.827:98): pid=1948
[ 95.787534] audit: type=1100 audit(1605367393.996:99): pid=2160
="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success
[ 95.789674] audit: type=1101 audit(1605367393.999:100): pid=216
0 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting
tname=? addr=? terminal=/dev/pts/3 res=success'
[ 95.790223] audit: type=1110 audit(1605367393.999:101): pid=216
0 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grant
ors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin
/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[ 95.793954] audit: type=1105 audit(1605367394.003:102): pid=216
0 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open
[ 119.619435] audit: type=1101 audit(1605367417.828:103): pid=224
6 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting
[ 119.619776] audit: type=1110 audit(1605367417.828:104): pid=224
6 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grant
ors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="
/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 119.622830] audit: type=1105 audit(1605367417.831:105): pid=224
6 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open
[ 119.625436] audit: type=1106 audit(1605367417.835:106): pid=224
6 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close
[ 119.625563] audit: type=1104 audit(1605367417.835:107): pid=224
[ 119.637068] audit: type=1101 audit(1605367417.848:108): pid=224
9 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting
[ 119.638058] audit: type=1110 audit(1605367417.848:109): pid=224
9 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grant
[ 119.640612] audit: type=1105 audit(1605367417.851:110): pid=224
9 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open
[ 119.666263] audit: type=1106 audit(1605367417.875:111): pid=224
9 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close
[ 119.666269] audit: type=1104 audit(1605367417.875:112): pid=224
[ 119.691710] psmouse serio2: vmmouse: VMMouse not running on sup
ported hypervisor.
[ 119.831782] psmouse serio2: cypress_ps2: send extension cmd 0x0
0, [0 0 0 0]
[ 120.063443] psmouse serio2: cypress_ps2: Command 0x00 response
data (0x): 00 00 14
[ 120.092023] psmouse serio2: alps: E6 report: 3c 03 00
[ 120.157052] psmouse serio2: elantech: Elantech version query re
sult 0x25, 0x4f, 0x00.
[ 120.300509] psmouse serio2: elantech: assuming hardware version
[ 120.503448] psmouse serio2: elantech: elantech_send_cmd query 0
x02 failed.
[ 120.503458] psmouse serio2: elantech: failed to query capabilit
ies.
[ 120.997019] psmouse serio2: sentelic: READ REG: 0x00 is 0x00 (r
c = -1)
[ 121.200440] input: PS/2 Logitech Wheel Mouse as /devices/platfo
rm/i8042/serio2/input/input23
[ 121.271622] atkbd serio0: Unknown key released (translated set
[ 121.271624] atkbd serio0: Use 'setkeycodes 7c <keycode>' to mak
e it known.
[ 146.724919] kauditd_printk_skb: 15 callbacks suppressed
[ 146.724927] audit: type=1106 audit(1605367444.937:128): pid=216
0 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close
[ 146.725287] audit: type=1104 audit(1605367444.937:129): pid=216
[ 177.950780] audit: type=1101 audit(1605367476.160:130): pid=233
[ 177.951452] audit: type=1110 audit(1605367476.163:131): pid=233
/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 res=success'
[ 177.958670] audit: type=1105 audit(1605367476.170:132): pid=233
[ 194.413614] audit: type=1101 audit(1605367492.624:133): pid=235
[ 194.414091] audit: type=1110 audit(1605367492.624:134): pid=235
[ 194.418415] audit: type=1105 audit(1605367492.630:135): pid=235
[ 194.421299] audit: type=1106 audit(1605367492.634:136): pid=235
[ 194.421429] audit: type=1104 audit(1605367492.634:137): pid=235
[ 194.432904] audit: type=1101 audit(1605367492.644:138): pid=235
[ 194.433194] audit: type=1110 audit(1605367492.644:139): pid=235
[ 194.436820] audit: type=1105 audit(1605367492.647:140): pid=235
[ 194.464396] audit: type=1106 audit(1605367492.677:141): pid=235
[ 194.464529] audit: type=1104 audit(1605367492.677:142): pid=235
[ 194.491900] psmouse serio2: vmmouse: VMMouse not running on sup
ported hypervisor.
[ 194.607188] psmouse serio2: cypress_ps2: send extension cmd 0x0
0, [0 0 0 0]
[ 194.840977] psmouse serio2: cypress_ps2: Command 0x00 response
data (0x): 00 00 14
[ 194.869812] psmouse serio2: alps: E6 report: 3c 03 00
[ 194.934660] psmouse serio2: elantech: Elantech version query re
[ 195.075820] psmouse serio2: elantech: assuming hardware version
[ 195.277738] psmouse serio2: elantech: elantech_send_cmd query 0
x02 failed.
[ 195.277748] psmouse serio2: elantech: failed to query capabilit
ies.
[ 195.771429] psmouse serio2: sentelic: READ REG: 0x00 is 0x00 (r
c = -1)
[ 195.974702] input: PS/2 Logitech Wheel Mouse as /devices/platfo
rm/i8042/serio2/input/input26
[ 196.018283] atkbd serio0: Unknown key released (translated set
[ 196.018285] atkbd serio0: Use 'setkeycodes 7c <keycode>' to mak
e it known.
[ 205.636801] kauditd_printk_skb: 15 callbacks suppressed
[ 205.636803] audit: type=1101 audit(1605367503.847:158): pid=239
2 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting
[ 205.637124] audit: type=1110 audit(1605367503.847:159): pid=239
2 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grant
[ 205.639766] audit: type=1105 audit(1605367503.850:160): pid=239
2 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open
[ 205.647488] atkbd serio0: Unknown key released (translated set
[ 205.647491] atkbd serio0: Use 'setkeycodes 7c <keycode>' to mak
e it known.
[ 205.845624] audit: type=1106 audit(1605367504.057:161): pid=239
2 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close
[ 205.845957] audit: type=1104 audit(1605367504.057:162): pid=239
