echo "file drivers/input/mouse/* +p" | sudo tee /s
ys/kernel/debug/dynamic_debug/control
[chavo@chavo-presario ~]$ echo serio2 | sudo tee /sys/bus/serio/drivers/psmo
use/unbind
serio2
use/bind
serio2
[chavo@chavo-presario ~]$ echo serio1 | sudo tee /sys/bus/serio/drivers/psmo
use/bind
serio1
tee: /sys/bus/serio/drivers/psmouse/bind: No such device
[chavo@chavo-presario ~]$ echo serio3 | sudo tee /sys/bus/serio/drivers/psmo
use/bind
serio3
[chavo@chavo-presario ~]$ echo serio4 | sudo tee /sys/bus/serio/drivers/psmo
use/bind
serio4
When you run sudo dmesg -w
, a wall of text will appear immediately, that is not needed now, please ignore the wall of text, and post only what appears after you ran the first command.
ok sorry, should i run it again?
Yes, please.
[ 2520.108778] psmouse serio2: vmmouse: VMMouse not running on supported hyp
ervisor.
[ 2520.227845] psmouse serio2: cypress_ps2: send extension cmd 0x00, [0 0 0
0]
[ 2520.459792] psmouse serio2: cypress_ps2: Command 0x00 response data (0x):
00 00 14
[ 2520.487489] psmouse serio2: alps: E6 report: 3c 03 00
[ 2520.550164] psmouse serio2: elantech: Elantech version query result 0x25,
0x4f, 0x00.
[ 2520.692536] psmouse serio2: elantech: assuming hardware version 3 (with f
irmware version 0x254f00)
[ 2520.893177] psmouse serio2: elantech: elantech_send_cmd query 0x02 failed
[ 2520.893187] psmouse serio2: elantech: failed to query capabilities.
[ 2521.383589] psmouse serio2: sentelic: READ REG: 0x00 is 0x00 (rc = -1)
[ 2521.586688] input: PS/2 Logitech Wheel Mouse as /devices/platform/i8042/s
erio2/input/input30
[ 2521.655022] atkbd serio0: Unknown key released (translated set 2, code 0x
7c on isa0060/serio0).
[ 2521.655024] atkbd serio0: Use 'setkeycodes 7c <keycode>' to make it knowno
i run āsudo dmesg -wā then i run the other whole bunchā¦ and i posted what appear in the first kosole after i run in the second one the other āwhole bunchā ā¦ did i make it right?
It looks better now. Do you happen to have Windows still installed? If so, please go to the device manager and dump all details about the touchpad. Post the output of lspci
as well.
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/
6th Gen Core Processor Host Bridge/DRAM Registers (rev 08)
00:02.0 VGA compatible controller: Intel Corporation Skylake GT2 [
HD Graphics 520] (rev 07)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 /
E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0
xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Po
int-LP Thermal subsystem (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-
LP CSME HECI #1 (rev 21)
00:17.0 SATA controller: Intel Corporation Sunrise Point-LP SATA C
ontroller [AHCI mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express
Root Port #4 (rev f1)
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express
Root Port #5 (rev f1)
00:1e.0 Signal processing controller: Intel Corporation Sunrise Po
int-LP Serial IO UART Controller #0 (rev 21)
00:1e.4 SD Host controller: Intel Corporation Device 9d2b (rev 21)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point-LP LPC Control
ler (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC
(rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio
(rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL81
11/8168/8411 PCI Express Gigabit Ethernet Controller (rev 07)
02:00.0 Network controller: Intel Corporation Wireless 3160 (rev 8
3)
yes i still have W10 on the other partition.
in the Touchpad Settings theres a red sign " No Touch Pad Found"-----this is in Manjaro Settiings.
In W10 touchpad settings it says ::
Version ELAN TouchPad 15.10.5.2_x64_WHQL
ELAN Smart-Pad Port PS/2
Please start sudo dmesg -w
, and as before, post only what appears after you ran the first command.
echo "file drivers/input/mouse/* +p" | sudo tee /sys/kernel/debug/dynamic_debug/control
echo "file drivers/input/serio/* +p" | sudo tee /sys/kernel/debug/dynamic_debug/control
echo serio2 | sudo tee /sys/bus/serio/drivers/psmouse/unbind
echo serio2 | sudo tee /sys/bus/serio/drivers/psmouse/bind
[10049.757892] psmouse serio2: f2 [] - 0/00000000 [00 00]
[10049.761543] psmouse serio2: f6 [] - 0/00000000 []
[10049.761548] psmouse serio2: vmmouse: VMMouse not running on supported hyperviso
r.
[10049.768531] psmouse serio2: f3 [0a] - 0/00000000 []
[10049.775109] psmouse serio2: e8 [00] - 0/00000000 []
[10049.781900] psmouse serio2: f3 [14] - 0/00000000 []
[10049.788704] psmouse serio2: f3 [3c] - 0/00000000 []
[10049.795385] psmouse serio2: f3 [28] - 0/00000000 []
[10049.802235] psmouse serio2: f3 [14] - 0/00000000 []
[10049.809020] psmouse serio2: f3 [14] - 0/00000000 []
[10049.816255] psmouse serio2: f3 [3c] - 0/00000000 []
[10049.823566] psmouse serio2: f3 [28] - 0/00000000 []
[10049.830339] psmouse serio2: f3 [14] - 0/00000000 []
[10049.837180] psmouse serio2: f3 [14] - 0/00000000 []
[10049.842173] psmouse serio2: f2 [] - 0/00000000 [00 00]
[10049.849664] psmouse serio2: e8 [00] - 0/00000000 []
[10049.855958] psmouse serio2: e8 [00] - 0/00000000 []
[10049.863035] psmouse serio2: e8 [00] - 0/00000000 []
[10049.869743] psmouse serio2: e8 [00] - 0/00000000 []
[10049.877948] psmouse serio2: e9 [] - 0/00000000 [00 00 14]
[10049.877961] psmouse serio2: cypress_ps2: send extension cmd 0x00, [0 0 0 0]
[10049.881366] psmouse serio2: e8 - 0
[10049.884546] psmouse serio2: 00 - 0
[10049.888151] psmouse serio2: e8 - 0
[10049.891305] psmouse serio2: 00 - 0
[10049.894700] psmouse serio2: e8 - 0
[10049.897708] psmouse serio2: 00 - 0
[10049.900840] psmouse serio2: e8 - 0
[10049.904024] psmouse serio2: 00 - 0
[10049.907582] psmouse serio2: e9 - 0
[10050.110360] psmouse serio2: cypress_ps2: Command 0x00 response data (0x): 00 00
14
[10050.113721] psmouse serio2: f6 [] - 0/00000000 []
[10050.121070] psmouse serio2: e8 [00] - 0/00000000 []
[10050.124455] psmouse serio2: e6 [] - 0/00000000 []
[10050.128444] psmouse serio2: e6 [] - 0/00000000 []
[10050.131714] psmouse serio2: e6 [] - 0/00000000 []
[10050.140028] psmouse serio2: e9 [] - 0/00000000 [3c 03 00]
[10050.140039] psmouse serio2: alps: E6 report: 3c 03 00
[10050.143578] psmouse serio2: f6 [] - 0/00000000 []
[10050.147088] psmouse serio2: f5 [] - 0/00000000 []
[10050.150380] psmouse serio2: e6 [] - 0/00000000 []
[10050.153883] psmouse serio2: e6 [] - 0/00000000 []
[10050.157017] psmouse serio2: e6 [] - 0/00000000 []
[10050.164640] psmouse serio2: e9 [] - 0/00000000 [3c 03 00]
[10050.167797] psmouse serio2: e6 [] - 0/00000000 []
[10050.174598] psmouse serio2: e8 [00] - 0/00000000 []
[10050.181365] psmouse serio2: e8 [00] - 0/00000000 []
[10050.188424] psmouse serio2: e8 [00] - 0/00000000 []
[10050.195368] psmouse serio2: e8 [01] - 0/00000000 []
[10050.195377] psmouse serio2: 01 - 0
[10050.203576] psmouse serio2: e9 [] - 0/00000000 [25 4f 00]
[10050.203590] psmouse serio2: elantech: Elantech version query result 0x25, 0x4f,
0x00.
[10050.307098] psmouse serio2: ff [] - 0/00000000 [aa 00]
[10050.310400] psmouse serio2: e6 [] - 0/00000000 []
[10050.316999] psmouse serio2: e8 [00] - 0/00000000 []
[10050.323730] psmouse serio2: e8 [00] - 0/00000000 []
[10050.330453] psmouse serio2: e8 [00] - 0/00000000 []
[10050.337017] psmouse serio2: e8 [01] - 0/00000000 []
[10050.337026] psmouse serio2: 01 - 0
[10050.345140] psmouse serio2: e9 [] - 0/00000000 [25 4f 00]
[10050.345153] psmouse serio2: elantech: assuming hardware version 3 (with firmwar
e version 0x254f00)
[10050.547050] psmouse serio2: f8 - -5 (1), attempt 0
[10050.547063] psmouse serio2: f8 [] - 1/00000000 []
[10050.547072] psmouse serio2: elantech: elantech_send_cmd query 0x02 failed.
[10050.547078] psmouse serio2: elantech: failed to query capabilities.
[10050.650470] psmouse serio2: ff [] - 0/00000000 [aa 00]
[10050.657044] psmouse serio2: e8 [03] - 0/00000000 []
[10050.660308] psmouse serio2: e6 [] - 0/00000000 []
[10050.663760] psmouse serio2: e6 [] - 0/00000000 []
[10050.667053] psmouse serio2: e6 [] - 0/00000000 []
[10050.675129] psmouse serio2: e9 [] - 0/00000000 [3c 03 00]
[10050.682091] psmouse serio2: e8 [00] - 0/00000000 []
[10050.685700] psmouse serio2: e6 [] - 0/00000000 []
[10050.689405] psmouse serio2: e6 [] - 0/00000000 []
[10050.693057] psmouse serio2: e6 [] - 0/00000000 []
[10050.701037] psmouse serio2: e9 [] - 0/00000000 [3c 03 00]
[10050.704172] psmouse serio2: e6 [] - 0/00000000 []
[10050.710483] psmouse serio2: e8 [00] - 0/00000000 []
[10050.717050] psmouse serio2: e8 [03] - 0/00000000 []
[10050.723787] psmouse serio2: e8 [02] - 0/00000000 []
[10050.730637] psmouse serio2: e8 [01] - 0/00000000 []
[10050.730645] psmouse serio2: 39 - 0
[10050.738822] psmouse serio2: eb [] - 0/00000000 [08 00 00]
[10050.742312] psmouse serio2: e6 [] - 0/00000000 []
[10050.754371] psmouse serio2: e8 [03] - 0/00000000 []
[10050.761083] psmouse serio2: e8 [01] - 0/00000000 []
[10050.767809] psmouse serio2: e8 [02] - 0/00000000 []
[10050.774368] psmouse serio2: e8 [03] - 0/00000000 []
[10050.774375] psmouse serio2: db - 0
[10050.782468] psmouse serio2: eb [] - 0/00000000 [08 00 00]
[10050.789742] psmouse serio2: e1 - -71 (fc), attempt 1
[10050.789754] psmouse serio2: e1 [] - fc/00000000 [00 00]
[10050.990477] psmouse serio2: 0a - -5 (1), attempt 0
[10050.990490] psmouse serio2: 0a [01 41] - 1/00000000 [01 41 00]
[10050.994051] psmouse serio2: f5 [] - 0/00000000 []
[10050.997801] psmouse serio2: f3 - 0
[10051.001299] psmouse serio2: 66 - -11 (fe), attempt 1
[10051.001308] psmouse serio2: 66 - fe
[10051.037090] psmouse serio2: 88 - -5 (1), attempt 0
[10051.037099] psmouse serio2: 88 - 1
[10051.040804] psmouse serio2: f3 - -71 (fc), attempt 0
[10051.040812] psmouse serio2: f3 - fc
[10051.043813] psmouse serio2: f4 [] - 0/00000000 []
[10051.043830] psmouse serio2: sentelic: READ REG: 0x00 is 0x00 (rc = -1)
[10051.047515] psmouse serio2: f6 [] - 0/00000000 []
[10051.150815] psmouse serio2: ff [] - 0/00000000 [aa 00]
[10051.157797] psmouse serio2: f3 [c8] - 0/00000000 []
[10051.164556] psmouse serio2: f3 [64] - 0/00000000 []
[10051.171183] psmouse serio2: f3 [50] - 0/00000000 []
[10051.176356] psmouse serio2: f2 [] - 0/00000000 [00 00]
[10051.183673] psmouse serio2: f3 [c8] - 0/00000000 []
[10051.190416] psmouse serio2: f3 [c8] - 0/00000000 []
[10051.197246] psmouse serio2: f3 [50] - 0/00000000 []
[10051.202094] psmouse serio2: f2 [] - 0/00000000 [00 00]
[10051.208884] psmouse serio2: f3 [c8] - 0/00000000 []
[10051.215920] psmouse serio2: f3 [64] - 0/00000000 []
[10051.222709] psmouse serio2: f3 [50] - 0/00000000 []
[10051.227851] psmouse serio2: f2 [] - 0/00000000 [00 00]
[10051.234519] psmouse serio2: f3 [64] - 0/00000000 []
[10051.241090] psmouse serio2: e8 [03] - 0/00000000 []
[10051.244670] psmouse serio2: e6 [] - 0/00000000 []
[10051.244913] input: PS/2 Logitech Wheel Mouse as /devices/platform/i8042/serio2/
input/input67
[10051.249307] psmouse serio2: f4 [] - 0/00000000 []
[10051.250749] audit: type=1106 audit(1605580727.428:153): pid=26804 uid=0 auid=10
00 ses=2 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,p
am_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/3 re
s=success'
[10051.251045] audit: type=1104 audit(1605580727.428:154): pid=26804 uid=0 auid=10
00 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam
_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/
pts/3 res=success'
i guess this is what you were askingā¦ if not tell me and i ll do it try to copy paste the right part.
Thatās it, yes. Could you please run sudo modprobe -r i8042 ; sudo modprobe i8042 debug=1
and do the same steps again?
cant do it, after i run modprobe -r i8042
the system crash. it freeze and i had to shut down my laptop oldstyle button
Interesting, in that case run echo 1 | sudo tee /sys/module/i8042/parameters/debug
, then start sudo dmesg -w
, and then run those 4 commands, and post the dmesg output.
again after running modprobe -r i8042
it freezes
I may not have been clear, you shouldnāt have run that command.
Run these commands:
, then in a different terminal, run
and then post what dmesg printed when the command has been run.
[ 3314.118441] audit: type=1101 audit(1605639559.579:306): pid=809
5 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting
grantors=pam_permit,pam_time acct="chavo" exe="/usr/bin/sudo" hos
tname=? addr=? terminal=/dev/pts/1 res=success'
[ 3314.119176] audit: type=1110 audit(1605639559.583:307): pid=809
5 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grant
ors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="
/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/1 res=success'
[ 3314.126211] audit: type=1105 audit(1605639559.589:308): pid=809
5 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open
grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/
[ 3314.130444] audit: type=1106 audit(1605639559.593:309): pid=809
5 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close
[ 3314.130722] audit: type=1104 audit(1605639559.593:310): pid=809
[ 3314.196483] i8042: [993884] ** <- i8042 (interrupt, 0, 1, timeo
ut)
I believe some text is missing, could you try again?
[ 3300.926189] audit: type=1101 audit(1605639546.390:297): pid=806
6 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting
[ 3300.926780] audit: type=1110 audit(1605639546.390:298): pid=806
6 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grant
[ 3300.933130] audit: type=1105 audit(1605639546.396:299): pid=806
6 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open
[ 3300.938182] audit: type=1106 audit(1605639546.400:300): pid=806
6 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_close
[ 3300.938405] audit: type=1104 audit(1605639546.400:301): pid=806
[ 3305.119791] i8042: [991161] 08 <- i8042 (interrupt, 3, 12)
[ 3305.120134] i8042: [991161] 00 <- i8042 (interrupt, 3, 12)
[ 3305.122710] i8042: [991162] 01 <- i8042 (interrupt, 3, 12)
[ 3305.132063] i8042: [991164] 08 <- i8042 (interrupt, 3, 12)
[ 3305.132437] i8042: [991165] 02 <- i8042 (interrupt, 3, 12)
[ 3305.135052] i8042: [991165] 03 <- i8042 (interrupt, 3, 12)
[ 3305.142903] i8042: [991168] 08 <- i8042 (interrupt, 3, 12)
[ 3305.148369] i8042: [991169] 07 <- i8042 (interrupt, 3, 12)
[ 3305.149766] i8042: [991170] 09 <- i8042 (interrupt, 3, 12)
[ 3305.155211] i8042: [991171] 08 <- i8042 (interrupt, 3, 12)
[ 3305.156694] i8042: [991172] 0f <- i8042 (interrupt, 3, 12)
[ 3305.158189] i8042: [991172] 11 <- i8042 (interrupt, 3, 12)
[ 3305.167523] i8042: [991175] 08 <- i8042 (interrupt, 3, 12)
[ 3305.169022] i8042: [991175] 15 <- i8042 (interrupt, 3, 12)
[ 3305.170517] i8042: [991176] 14 <- i8042 (interrupt, 3, 12)
[ 3305.179874] i8042: [991179] 08 <- i8042 (interrupt, 3, 12)
[ 3305.181384] i8042: [991179] 1b <- i8042 (interrupt, 3, 12)
[ 3305.182866] i8042: [991180] 13 <- i8042 (interrupt, 3, 12)
[ 3305.191737] i8042: [991182] 08 <- i8042 (interrupt, 3, 12)
[ 3305.193246] i8042: [991183] 1c <- i8042 (interrupt, 3, 12)
[ 3305.194725] i8042: [991183] 0c <- i8042 (interrupt, 3, 12)
[ 3305.205219] i8042: [991186] 08 <- i8042 (interrupt, 3, 12)
[ 3305.205511] i8042: [991186] 1c <- i8042 (interrupt, 3, 12)
[ 3305.208137] i8042: [991187] 07 <- i8042 (interrupt, 3, 12)
[ 3305.217507] i8042: [991190] 08 <- i8042 (interrupt, 3, 12)
[ 3305.217866] i8042: [991190] 1d <- i8042 (interrupt, 3, 12)
[ 3305.219449] i8042: [991191] 04 <- i8042 (interrupt, 3, 12)
[ 3305.228286] i8042: [991193] 08 <- i8042 (interrupt, 3, 12)
[ 3305.229776] i8042: [991194] 1a <- i8042 (interrupt, 3, 12)
[ 3305.232372] i8042: [991194] 00 <- i8042 (interrupt, 3, 12)
[ 3305.240116] i8042: [991197] 08 <- i8042 (interrupt, 3, 12)
[ 3305.242469] i8042: [991198] 16 <- i8042 (interrupt, 3, 12)
[ 3305.244219] i8042: [991198] 00 <- i8042 (interrupt, 3, 12)
[ 3305.252480] i8042: [991201] 28 <- i8042 (interrupt, 3, 12)
[ 3305.254064] i8042: [991201] 16 <- i8042 (interrupt, 3, 12)
[ 3305.255521] i8042: [991201] fe <- i8042 (interrupt, 3, 12)
[ 3305.265788] i8042: [991205] 28 <- i8042 (interrupt, 3, 12)
[ 3305.267422] i8042: [991205] 0e <- i8042 (interrupt, 3, 12)
[ 3305.268926] i8042: [991205] fd <- i8042 (interrupt, 3, 12)
[ 3305.277237] i8042: [991208] 28 <- i8042 (interrupt, 3, 12)
[ 3305.278760] i8042: [991208] 0f <- i8042 (interrupt, 3, 12)
[ 3305.280262] i8042: [991209] fb <- i8042 (interrupt, 3, 12)
[ 3305.289577] i8042: [991212] 28 <- i8042 (interrupt, 3, 12)
[ 3305.291169] i8042: [991212] 0a <- i8042 (interrupt, 3, 12)
[ 3305.292498] i8042: [991213] fd <- i8042 (interrupt, 3, 12)
[ 3305.302100] i8042: [991215] 28 <- i8042 (interrupt, 3, 12)
[ 3305.303772] i8042: [991216] 05 <- i8042 (interrupt, 3, 12)
[ 3305.305084] i8042: [991216] fe <- i8042 (interrupt, 3, 12)
[ 3305.314443] i8042: [991219] 28 <- i8042 (interrupt, 3, 12)
[ 3305.315937] i8042: [991220] 05 <- i8042 (interrupt, 3, 12)
[ 3305.317431] i8042: [991220] fe <- i8042 (interrupt, 3, 12)
[ 3305.326792] i8042: [991223] 28 <- i8042 (interrupt, 3, 12)
[ 3305.328296] i8042: [991223] 03 <- i8042 (interrupt, 3, 12)
[ 3305.329620] i8042: [991224] ff <- i8042 (interrupt, 3, 12)
[ 3305.339101] i8042: [991227] 08 <- i8042 (interrupt, 3, 12)
[ 3305.340632] i8042: [991227] 01 <- i8042 (interrupt, 3, 12)
[ 3305.342125] i8042: [991227] 00 <- i8042 (interrupt, 3, 12)
[ 3305.362278] i8042: [991233] 28 <- i8042 (interrupt, 3, 12)
[ 3305.363719] i8042: [991234] 01 <- i8042 (interrupt, 3, 12)
[ 3305.365274] i8042: [991234] ff <- i8042 (interrupt, 3, 12)
[ 3305.399128] i8042: [991245] 28 <- i8042 (interrupt, 3, 12)
[ 3305.401548] i8042: [991245] 00 <- i8042 (interrupt, 3, 12)
[ 3305.401980] i8042: [991245] ff <- i8042 (interrupt, 3, 12)
[ 3305.412898] i8042: [991249] 28 <- i8042 (interrupt, 3, 12)
[ 3305.413606] i8042: [991249] 00 <- i8042 (interrupt, 3, 12)
[ 3305.415772] i8042: [991250] ff <- i8042 (interrupt, 3, 12)
[ 3305.425245] i8042: [991252] 28 <- i8042 (interrupt, 3, 12)
[ 3305.426146] i8042: [991253] 00 <- i8042 (interrupt, 3, 12)
[ 3305.428713] i8042: [991253] fe <- i8042 (interrupt, 3, 12)
[ 3305.438569] i8042: [991256] 28 <- i8042 (interrupt, 3, 12)
[ 3305.439016] i8042: [991256] 00 <- i8042 (interrupt, 3, 12)
[ 3305.441549] i8042: [991257] fe <- i8042 (interrupt, 3, 12)
[ 3305.451381] i8042: [991260] 28 <- i8042 (interrupt, 3, 12)
[ 3305.451833] i8042: [991260] 00 <- i8042 (interrupt, 3, 12)
[ 3305.454471] i8042: [991261] ff <- i8042 (interrupt, 3, 12)
[ 3305.463720] i8042: [991264] 28 <- i8042 (interrupt, 3, 12)
[ 3305.465717] i8042: [991264] 00 <- i8042 (interrupt, 3, 12)
[ 3305.466137] i8042: [991265] ff <- i8042 (interrupt, 3, 12)
[ 3305.476548] i8042: [991268] 28 <- i8042 (interrupt, 3, 12)
[ 3305.478565] i8042: [991268] 00 <- i8042 (interrupt, 3, 12)
[ 3305.479118] i8042: [991269] ff <- i8042 (interrupt, 3, 12)
[ 3305.513756] i8042: [991279] 28 <- i8042 (interrupt, 3, 12)
[ 3305.514469] i8042: [991279] 00 <- i8042 (interrupt, 3, 12)
[ 3305.515829] i8042: [991280] ff <- i8042 (interrupt, 3, 12)
[ 3305.549953] i8042: [991290] 28 <- i8042 (interrupt, 3, 12)
[ 3305.551451] i8042: [991290] 00 <- i8042 (interrupt, 3, 12)
[ 3305.552875] i8042: [991291] ff <- i8042 (interrupt, 3, 12)
[ 3305.849440] i8042: [991380] 09 <- i8042 (interrupt, 3, 12)
[ 3305.849851] i8042: [991380] 00 <- i8042 (interrupt, 3, 12)
[ 3305.852413] i8042: [991381] 00 <- i8042 (interrupt, 3, 12)
[ 3306.071861] i8042: [991446] 08 <- i8042 (interrupt, 3, 12)
[ 3306.073350] i8042: [991447] 00 <- i8042 (interrupt, 3, 12)
[ 3306.074837] i8042: [991447] 00 <- i8042 (interrupt, 3, 12)
[ 3307.086941] i8042: [991751] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3307.172989] i8042: [991777] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3308.555011] i8042: [992191] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3308.696568] i8042: [992234] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3308.723357] i8042: [992242] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3308.835794] i8042: [992276] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3308.864144] i8042: [992284] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3309.046007] i8042: [992339] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3309.213566] i8042: [992389] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3309.339997] i8042: [992427] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3309.483126] i8042: [992470] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3309.619033] i8042: [992510] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3309.672728] i8042: [992527] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3309.799808] i8042: [992565] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3310.062160] i8042: [992643] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3310.179175] i8042: [992679] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3310.341662] i8042: [992727] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3310.418749] i8042: [992750] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3310.490383] i8042: [992772] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3310.597452] i8042: [992804] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3311.015552] i8042: [992929] ** <- i8042 (interrupt, 0, 1, timeo
ut)
[ 3311.036191] audit: type=1100 audit(1605639556.499:302): pid=807
9 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentica
tion grantors=pam_faillock,pam_permit,pam_faillock acct="chavo" ex
e="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=succes
s'
[ 3311.039497] audit: type=1101 audit(1605639556.503:303): pid=807
9 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting
tname=? addr=? terminal=/dev/pts/2 res=success'
[ 3311.040071] audit: type=1110 audit(1605639556.503:304): pid=807
9 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grant
ors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin
/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 3311.045494] audit: type=1105 audit(1605639556.506:305): pid=807
9 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open
[ 3311.116495] i8042: [992960] ** <- i8042 (interrupt, 0, 1, timeo
ut).
maybe like this??
Hmmm, Iām not sure, could you please repeat it again, but instead of sudo dmesg -w
, run journalctl -f --no-pager -k
and post its entire output?
-- Logs begin at Mon 2020-11-09 08:50:40 -03. --
nov 23 11:12:22 chavo-presario kernel: wlp2s0: Limiting TX power to 24 (24 -
0) dBm as advertised by f4:c1:14:a0:c8:68
nov 23 11:12:22 chavo-presario kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0
: link becomes ready
nov 23 11:12:22 chavo-presario kernel: audit: type=1130 audit(1606140742.575
:87): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=
NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" host
name=? addr=? terminal=? res=success'
nov 23 11:12:23 chavo-presario kernel: audit: type=1131 audit(1606140743.618
:88): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=
user@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? ter
nov 23 11:12:23 chavo-presario kernel: audit: type=1131 audit(1606140743.641
:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=
user-runtime-dir@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=
nov 23 11:12:27 chavo-presario kernel: audit: type=1131 audit(1606140747.131
:90): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=
pamac-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=?
nov 23 11:12:30 chavo-presario kernel: audit: type=1131 audit(1606140750.645
:91): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=
systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? a
nov 23 11:12:30 chavo-presario kernel: audit: type=1334 audit(1606140750.695
:92): prog-id=10 op=UNLOAD
:93): prog-id=9 op=UNLOAD
nov 23 11:12:32 chavo-presario kernel: audit: type=1131 audit(1606140752.990
:94): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=
i can give you access thru teamviewer if you wantā¦ cos i think i might be doing it wrong as im newer than a newbie at linux haha
