I have had to create a new partition and do a fresh installation of manjaro because of other problems that i shan’t go into here but the first thing i am banging my head against is why are the setting for my touchpad different in one installation to the other and how do i sort the new installation out to be the same as the old one because the new touchpad is all messed up (edges are dead, can’t set natural scrolling, etc)
The second screenshot leads me to believe that you’re running KWin as a Wayland compositor, can you confirm that (inxi -G)? In the first case, you were probably running KWin on Xorg with libinput or synatipcs input driver.
I shall reboot in and try @FadeMind instructions. Although i don’t remember doing this before (that’s my problem though, i can never remember half of the thing iv done to get things working by the time i need to use them again)
