Hello everyone,
I have a new laptop, a lenovo legion 5, on which I just installed manjaro.
Everything is working so far (when I did the first update the nonfree graphic driver was uninstalled and I had a black screen but I was able to correct it).
However the touchpad is not working, I saw this issue when looking at the laptop before buying it but my hope was that with manjaro it could work.
Do you think I may be able to get it to work ?
>>> xinput -list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ ITE Tech. Inc. ITE Device(8910) Consumer Control id=13 [slave pointer (2)]
⎜ ↳ MSFT0001:00 04F3:3140 Mouse id=16 [slave pointer (2)]
⎜ ↳ MSFT0001:00 04F3:3140 Touchpad id=17 [slave pointer (2)]
⎜ ↳ Logitech MX Anywhere 2 id=10 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Video Bus id=8 [slave keyboard (3)]
↳ Power Button id=9 [slave keyboard (3)]
↳ Integrated Camera: Integrated C id=11 [slave keyboard (3)]
↳ ITE Tech. Inc. ITE Device(8910) Keyboard id=12 [slave keyboard (3)]
↳ ITE Tech. Inc. ITE Device(8910) Wireless Radio Control id=14 [slave keyboard (3)]
↳ Ideapad extra buttons id=15 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=18 [slave keyboard (3)]
↳ ITE Tech. Inc. ITE Device(8910) Consumer Control id=20 [slave keyboard (3)]
>>> ls /sys/bus/i2c/drivers/
88PM860x adp5520 da903x dummy intel_soc_pmic_i2c max77620 max8997 rc5t583 stmpe-i2c tps65090 tps68470 twl6040 WM8400
aat2870 as3711 da9052 htcpld-chip lochnagar max77843 max8998 sec_pmic sx150x-pinctrl tps6586x tps80031 wm831x
ab3100 'CHT Whiskey Cove PMIC' da9055-pmic i2c_hid lp8788 max8925 palmas smsc tc3589x tps65910 twl wm8350
System: Kernel: 5.7.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.7-x86_64 root=UUID=97b6c881-3a83-4bc3-bd2f-bfc3a28f7ee8 rw quiet apparmor=1
Desktop: GNOME 3.36.5 tk: GTK 3.24.22 wm: gnome-shell dm: GDM 3.36.3 Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05 serial: <filter> Chassis: type: 10
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter> UEFI: LENOVO v: EUCN16WW date: 03/13/2020
Battery: ID-1: BAT0 charge: 50.8 Wh condition: 81.8/80.0 Wh (102%) volts: 15.6/15.4 model: Celxpert L19C4PC1 type: Li-poly
serial: <filter> status: Discharging cycles: 9
Device-1: hidpp_battery_1 model: Logitech Wireless Mobile Mouse MX Anywhere 2 serial: <filter>
charge: 10% (should be ignored) rechargeable: yes status: Discharging
CPU: Topology: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen family: 17 (23)
model-id: 60 (96) stepping: 1 microcode: 8600103 L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 92661
Speed: 1397 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz): 1: 1397 2: 1397 3: 1397 4: 1396 5: 1397
6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397 12: 1397 13: 1397 14: 1397 15: 1397 16: 1397
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA vendor: Lenovo driver: nvidia v: 450.57 alternate: nouveau,nvidia_drm bus ID: 01:00.0
chip ID: 10de:1f99
Device-2: Advanced Micro Devices [AMD/ATI] Renoir vendor: Lenovo driver: amdgpu v: kernel bus ID: 05:00.0
chip ID: 1002:1636
Device-3: Syntek Integrated Camera type: USB driver: uvcvideo bus ID: 1-3:3 chip ID: 174f:244c serial: <filter>
Display: x11 server: X.org 1.20.8 compositor: gnome-shell driver: amdgpu,ati,nvidia unloaded: modesetting,nouveau
alternate: fbdev,nv,vesa resolution: <xdpyinfo missing>
OpenGL: renderer: AMD RENOIR (DRM 3.37.0 5.7.15-1-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.5 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo driver: N/A
alternate: snd_pci_acp3x bus ID: 05:00.5 chip ID: 1022:15e2
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 05:00.6 chip ID: 1022:15e3
Sound Server: ALSA v: k5.7.15-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169 v: kernel port: 2000
bus ID: 03:00.0 chip ID: 10ec:8168
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000 bus ID: 04:00.0 chip ID: 8086:2723
IF: wlp4s0 state: up mac: <filter>
Drives: Local Storage: total: 476.94 GiB used: 12.10 GiB (2.5%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFM512GDHTNI-87A0B size: 476.94 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 11010C00 scheme: GPT
Partition: ID-1: / raw size: 195.31 GiB size: 191.25 GiB (97.92%) used: 12.06 GiB (6.3%) fs: ext4 dev: /dev/nvme0n1p5
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 35.8 C mobo: N/A gpu: amdgpu temp: 35 C
Info: Processes: 385 Uptime: 51m Memory: 7.21 GiB used: 3.06 GiB (42.4%) Init: systemd v: 245 Compilers: gcc: 10.1.0
clang: 10.0.1 Packages: pacman: 1235 lib: 337 flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.05
