I’m using Manjaro KDE on a Lenovo Miix 520, which has a detachable keyboard/touchpad.
The keyboard and touchpad work nicely, but if I set the system to sleep, when it wakes back up, the keyboard works, but the touchpad doesn’t.
Sometimes I see a popup saying “Touchpad disabled” on the screen right after it wakes up.
Removing and re-ataching the keyboard/touchpad does not work. Only a reboot works.
I don’t know what’s going on. Can anyone help?
EDIT: Here is the inxi and journalctl output, as requested by @Fabby
Kernel: 5.10.60-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=bd89d1ea-aabb-43ab-90ea-074d1e637173 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Detachable System: LENOVO product: 81CG v: MIIX 520-12IKB
serial: <filter> Chassis: type: 32 v: MIIX 520-12IKB serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN serial: <filter>
UEFI: LENOVO v: 6NCN39WW date: 10/10/2019
ID-1: BAT0 charge: 29.6 Wh (100.0%) condition: 29.6/38.0 Wh (77.7%)
volts: 7.7 min: N/A model: LENOVO SR Real Battery type: Li-poly
serial: <filter> status: Full
RAM: total: 7.55 GiB used: 3.44 GiB (45.6%)
Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
microcode: EA cache: L2: 6 MiB bogomips: 28808
Speed: 900 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 900 2: 900 3: 900
4: 900 5: 900 6: 900 7: 901 8: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.0x12.5")
s-diag: 599mm (23.6")
Monitor-1: eDP-1 res: 1920x1200 hz: 60 dpi: 185 size: 263x164mm (10.4x6.5")
diag: 310mm (12.2")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.1
direct render: Yes
Device-1: Intel Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Imaging
Unit
vendor: Lenovo driver: ipu3-imgu alternate: ipu3_imgu bus-ID: 00:05.0
chip-ID: 8086:1919 class-ID: 0480
Device-2: Intel CSI-2 Host vendor: Lenovo driver: ipu3-cio2
alternate: ipu3_cio2 bus-ID: 00:14.3 chip-ID: 8086:9d32 class-ID: 0480
Device-3: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.10.60-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: 4040
bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
bus-ID: 1-4:2 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 238.47 GiB used: 21.2 GiB (8.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLW256HEHP-000L2
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 4L1QCXB7 temp: 32.9 C scheme: GPT
ID-1: / raw-size: 57.09 GiB size: 55.89 GiB (97.90%) used: 21.17 GiB (37.9%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: bd89d1ea-aabb-43ab-90ea-074d1e637173
used: 25.3 MiB (26.3%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 6426-D537
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 499 MiB fs: ntfs label: Recovery
uuid: 64AC2603AC25CFFA
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 180.24 GiB fs: ntfs label: N/A
uuid: F4FC287EFC283D6C
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 556 MiB fs: ntfs label: N/A
uuid: E25870C958709E4B
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-4:2 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-5:3 info: Lenovo HID Device type: Keyboard,Mouse
driver: hid-generic,hid-multitouch,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 17ef:60bb class-ID: 0301
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 36.5 C mobo: 0.0 C
Processes: 226 Uptime: 18m wakeups: 2 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1224 lib: 332 flatpak: 0
Shell: Bash v: 5.1.8 running-in: yakuake inxi: 3.3.06
ago 30 23:31:51 miix520 systemd-logind[369]: Power key pressed.
ago 30 23:31:55 miix520 NetworkManager[363]: <info> [1630362715.7398] manager: sleep: sleep requested (sleeping: no enabled: yes)
ago 30 23:31:55 miix520 NetworkManager[363]: <info> [1630362715.7401] device (p2p-dev-wlp1s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
ago 30 23:31:55 miix520 ModemManager[423]: <info> [sleep-monitor] system is about to suspend
ago 30 23:31:55 miix520 NetworkManager[363]: <info> [1630362715.7413] manager: NetworkManager state is now ASLEEP
ago 30 23:31:55 miix520 NetworkManager[363]: <info> [1630362715.7418] device (wlp1s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
ago 30 23:31:55 miix520 dbus-daemon[362]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=363 comm="/usr/bin/NetworkManager --no-daemon ")
ago 30 23:31:55 miix520 systemd[1]: Starting Network Manager Script Dispatcher Service...
ago 30 23:31:55 miix520 dbus-daemon[362]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
ago 30 23:31:55 miix520 systemd[1]: Started Network Manager Script Dispatcher Service.
ago 30 23:31:55 miix520 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
ago 30 23:31:55 miix520 kernel: audit: type=1130 audit(1630362715.763:106): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
ago 30 23:31:55 miix520 kernel: wlp1s0: deauthenticating from 0c:9d:92:4f:59:3c by local choice (Reason: 3=DEAUTH_LEAVING)
ago 30 23:31:55 miix520 wpa_supplicant[650]: wlp1s0: CTRL-EVENT-DISCONNECTED bssid=0c:9d:92:4f:59:3c reason=3 locally_generated=1
ago 30 23:31:55 miix520 NetworkManager[363]: <info> [1630362715.7906] device (wlp1s0): supplicant interface state: completed -> disconnected
ago 30 23:31:55 miix520 NetworkManager[363]: <info> [1630362715.7910] device (wlp1s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
ago 30 23:31:55 miix520 avahi-daemon[360]: Withdrawing address record for fe80::7408:eaab:1f:8492 on wlp1s0.
ago 30 23:31:55 miix520 avahi-daemon[360]: Leaving mDNS multicast group on interface wlp1s0.IPv6 with address fe80::7408:eaab:1f:8492.
ago 30 23:31:55 miix520 avahi-daemon[360]: Interface wlp1s0.IPv6 no longer relevant for mDNS.
ago 30 23:31:55 miix520 NetworkManager[363]: <info> [1630362715.8170] dhcp4 (wlp1s0): canceled DHCP transaction
ago 30 23:31:55 miix520 NetworkManager[363]: <info> [1630362715.8171] dhcp4 (wlp1s0): state changed bound -> terminated
ago 30 23:31:55 miix520 avahi-daemon[360]: Interface wlp1s0.IPv4 no longer relevant for mDNS.
ago 30 23:31:55 miix520 avahi-daemon[360]: Leaving mDNS multicast group on interface wlp1s0.IPv4 with address 192.168.1.21.
ago 30 23:31:55 miix520 avahi-daemon[360]: Withdrawing address record for 192.168.1.21 on wlp1s0.
ago 30 23:31:55 miix520 NetworkManager[363]: <info> [1630362715.8234] device (wlp1s0): set-hw-addr: set MAC address to 52:7D:CD:5C:8A:0C (scanning)
ago 30 23:31:55 miix520 avahi-daemon[360]: Joining mDNS multicast group on interface wlp1s0.IPv4 with address 192.168.1.21.
ago 30 23:31:55 miix520 avahi-daemon[360]: New relevant interface wlp1s0.IPv4 for mDNS.
ago 30 23:31:55 miix520 avahi-daemon[360]: Registering new address record for 192.168.1.21 on wlp1s0.IPv4.
ago 30 23:31:55 miix520 NetworkManager[363]: <info> [1630362715.8404] device (wlp1s0): supplicant interface state: disconnected -> interface_disabled
ago 30 23:31:55 miix520 NetworkManager[363]: <info> [1630362715.8405] device (wlp1s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
ago 30 23:31:55 miix520 NetworkManager[363]: <info> [1630362715.8442] device (wlp1s0): set-hw-addr: reset MAC address to E4:70:B8:77:35:03 (unmanage)
ago 30 23:31:55 miix520 wpa_supplicant[650]: nl80211: deinit ifname=p2p-dev-wlp1s0 disabled_11b_rates=0
ago 30 23:31:56 miix520 wpa_supplicant[650]: nl80211: deinit ifname=wlp1s0 disabled_11b_rates=0
ago 30 23:31:56 miix520 systemd[1]: Reached target Sleep.
ago 30 23:31:56 miix520 systemd[1]: Starting System Suspend...
ago 30 23:31:57 miix520 systemd-sleep[4006]: Suspending system...
ago 30 23:31:57 miix520 kernel: PM: suspend entry (deep)
ago 30 23:31:57 miix520 kernel: Filesystems sync: 0.011 seconds
ago 30 23:32:05 miix520 kernel: Freezing user space processes ... (elapsed 0.003 seconds) done.
ago 30 23:32:05 miix520 kernel: OOM killer disabled.
ago 30 23:32:05 miix520 kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
ago 30 23:32:05 miix520 kernel: printk: Suspending console(s) (use no_console_suspend to debug)
ago 30 23:32:05 miix520 kernel: ACPI: EC: interrupt blocked
ago 30 23:32:05 miix520 kernel: ACPI: Preparing to enter system sleep state S3
ago 30 23:32:05 miix520 kernel: ACPI: EC: event blocked
ago 30 23:32:05 miix520 kernel: ACPI: EC: EC stopped
ago 30 23:32:05 miix520 kernel: PM: Saving platform NVS memory
ago 30 23:32:05 miix520 kernel: Disabling non-boot CPUs ...
ago 30 23:32:05 miix520 kernel: smpboot: CPU 1 is now offline
ago 30 23:32:05 miix520 kernel: smpboot: CPU 2 is now offline
ago 30 23:32:05 miix520 kernel: smpboot: CPU 3 is now offline
ago 30 23:32:05 miix520 kernel: smpboot: CPU 4 is now offline
ago 30 23:32:05 miix520 kernel: smpboot: CPU 5 is now offline
ago 30 23:32:05 miix520 kernel: smpboot: CPU 6 is now offline
ago 30 23:32:05 miix520 kernel: smpboot: CPU 7 is now offline
ago 30 23:32:05 miix520 kernel: ACPI: Low-level resume complete
ago 30 23:32:05 miix520 kernel: ACPI: EC: EC started
ago 30 23:32:05 miix520 kernel: PM: Restoring platform NVS memory
ago 30 23:32:05 miix520 kernel: smpboot: Scheduler frequency invariance went wobbly, disabling!
ago 30 23:32:05 miix520 kernel: Enabling non-boot CPUs ...
ago 30 23:32:05 miix520 kernel: x86: Booting SMP configuration:
ago 30 23:32:05 miix520 kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
ago 30 23:32:05 miix520 kernel: CPU1 is up
ago 30 23:32:05 miix520 kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
ago 30 23:32:05 miix520 kernel: CPU2 is up
ago 30 23:32:05 miix520 kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
ago 30 23:32:05 miix520 kernel: CPU3 is up
ago 30 23:32:05 miix520 kernel: smpboot: Booting Node 0 Processor 4 APIC 0x1
ago 30 23:32:05 miix520 kernel: CPU4 is up
ago 30 23:32:05 miix520 kernel: smpboot: Booting Node 0 Processor 5 APIC 0x3
ago 30 23:32:05 miix520 kernel: CPU5 is up
ago 30 23:32:05 miix520 kernel: smpboot: Booting Node 0 Processor 6 APIC 0x5
ago 30 23:32:05 miix520 kernel: CPU6 is up
ago 30 23:32:05 miix520 kernel: smpboot: Booting Node 0 Processor 7 APIC 0x7
ago 30 23:32:05 miix520 kernel: CPU7 is up
ago 30 23:32:05 miix520 kernel: ACPI: Waking up from system sleep state S3
ago 30 23:32:05 miix520 kernel: ACPI: button: The lid device is not compliant to SW_LID.
ago 30 23:32:05 miix520 kernel: ACPI: EC: interrupt unblocked
ago 30 23:32:05 miix520 kernel: ACPI: EC: event unblocked
ago 30 23:32:05 miix520 kernel: nvme nvme0: 8/0/0 default/read/poll queues
ago 30 23:32:05 miix520 kernel: usb 1-4: reset full-speed USB device number 2 using xhci_hcd
ago 30 23:32:05 miix520 kernel: ata1: SATA link down (SStatus 4 SControl 300)
ago 30 23:32:05 miix520 kernel: OOM killer enabled.
ago 30 23:32:05 miix520 kernel: Restarting tasks ...
ago 30 23:32:05 miix520 kernel: Bluetooth: hci0: Bootloader revision 0.0 build 26 week 38 2015
ago 30 23:32:05 miix520 kernel: Bluetooth: hci0: Device revision is 16
ago 30 23:32:05 miix520 kernel: Bluetooth: hci0: Secure boot is enabled
ago 30 23:32:05 miix520 kernel: Bluetooth: hci0: OTP lock is enabled
ago 30 23:32:05 miix520 kernel: Bluetooth: hci0: API lock is enabled
ago 30 23:32:05 miix520 kernel: Bluetooth: hci0: Debug lock is disabled
ago 30 23:32:05 miix520 kernel: Bluetooth: hci0: Minimum firmware build 1 week 10 2014
ago 30 23:32:05 miix520 kernel: Bluetooth: hci0: Found device firmware: intel/ibt-12-16.sfi
ago 30 23:32:05 miix520 kernel: done.
ago 30 23:32:05 miix520 bluetoothd[647]: Endpoint unregistered: sender=:1.49 path=/MediaEndpoint/A2DPSink/sbc
ago 30 23:32:05 miix520 bluetoothd[647]: Endpoint unregistered: sender=:1.49 path=/MediaEndpoint/A2DPSource/sbc
ago 30 23:32:05 miix520 systemd[1]: Starting Load/Save RF Kill Switch Status...
ago 30 23:32:05 miix520 bluetoothd[647]: Endpoint unregistered: sender=:1.49 path=/MediaEndpoint/A2DPSink/sbc_xq_453
ago 30 23:32:05 miix520 bluetoothd[647]: Endpoint unregistered: sender=:1.49 path=/MediaEndpoint/A2DPSource/sbc_xq_453
ago 30 23:32:05 miix520 bluetoothd[647]: Endpoint unregistered: sender=:1.49 path=/MediaEndpoint/A2DPSink/sbc_xq_512
ago 30 23:32:05 miix520 bluetoothd[647]: Endpoint unregistered: sender=:1.49 path=/MediaEndpoint/A2DPSource/sbc_xq_512
ago 30 23:32:05 miix520 bluetoothd[647]: Endpoint unregistered: sender=:1.49 path=/MediaEndpoint/A2DPSink/sbc_xq_552
ago 30 23:32:05 miix520 bluetoothd[647]: Endpoint unregistered: sender=:1.49 path=/MediaEndpoint/A2DPSource/sbc_xq_552
ago 30 23:32:05 miix520 systemd-sleep[4006]: System resumed.
ago 30 23:32:05 miix520 kernel: PM: suspend exit
ago 30 23:32:05 miix520 upowerd[933]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb1/1-4
ago 30 23:32:05 miix520 systemd[1]: Stopped target Bluetooth Support.
ago 30 23:32:05 miix520 kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
ago 30 23:32:05 miix520 systemd[1]: Reached target Bluetooth Support.
ago 30 23:32:05 miix520 systemd[1]: Started Load/Save RF Kill Switch Status.
ago 30 23:32:05 miix520 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
ago 30 23:32:05 miix520 kernel: audit: type=1130 audit(1630362725.748:107): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
ago 30 23:32:06 miix520 kernel: ish-hid {33AECD58-B679-4E54-9BD9-A04D34F0C226}: [hid-ish]: enum_devices_done OK, num_hid_devices=1
ago 30 23:32:06 miix520 audit[363]: USYS_CONFIG pid=363 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=radio-control arg="wwan-enabled:on" pid=4292 uid=0 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
ago 30 23:32:06 miix520 NetworkManager[363]: <info> [1630362726.6478] audit: op="radio-control" arg="wwan-enabled:on" pid=4292 uid=0 result="success"
ago 30 23:32:06 miix520 kernel: audit: type=1111 audit(1630362726.645:108): pid=363 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=radio-control arg="wwan-enabled:on" pid=4292 uid=0 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
ago 30 23:32:06 miix520 systemd[1]: systemd-suspend.service: Deactivated successfully.
ago 30 23:32:06 miix520 systemd[1]: Finished System Suspend.
ago 30 23:32:06 miix520 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
ago 30 23:32:06 miix520 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
ago 30 23:32:06 miix520 systemd[1]: Stopped target Sleep.
ago 30 23:32:06 miix520 systemd[1]: Reached target Suspend.
ago 30 23:32:06 miix520 systemd[1]: Stopped target Suspend.
ago 30 23:32:06 miix520 systemd-logind[369]: Operation 'sleep' finished.
ago 30 23:32:06 miix520 kernel: audit: type=1130 audit(1630362726.825:109): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
ago 30 23:32:06 miix520 kernel: audit: type=1131 audit(1630362726.825:110): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
ago 30 23:32:06 miix520 ModemManager[423]: <info> [sleep-monitor] system is resuming
ago 30 23:32:06 miix520 NetworkManager[363]: <info> [1630362726.8309] manager: sleep: wake requested (sleeping: yes enabled: yes)
ago 30 23:32:06 miix520 NetworkManager[363]: <info> [1630362726.8309] device (wlp1s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
ago 30 23:32:06 miix520 NetworkManager[363]: <info> [1630362726.8320] device (p2p-dev-wlp1s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
ago 30 23:32:06 miix520 NetworkManager[363]: <info> [1630362726.8324] manager: NetworkManager state is now DISCONNECTED
ago 30 23:32:06 miix520 NetworkManager[363]: <info> [1630362726.9111] device (wlp1s0): supplicant interface state: internal-starting -> disconnected
ago 30 23:32:06 miix520 NetworkManager[363]: <info> [1630362726.9113] device (p2p-dev-wlp1s0): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
ago 30 23:32:06 miix520 NetworkManager[363]: <info> [1630362726.9126] Wi-Fi P2P device controlled by interface wlp1s0 created
ago 30 23:32:06 miix520 NetworkManager[363]: <info> [1630362726.9136] manager: (p2p-dev-wlp1s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
ago 30 23:32:06 miix520 NetworkManager[363]: <info> [1630362726.9143] device (p2p-dev-wlp1s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
ago 30 23:32:06 miix520 NetworkManager[363]: <info> [1630362726.9163] device (wlp1s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
ago 30 23:32:06 miix520 NetworkManager[363]: <info> [1630362726.9182] device (p2p-dev-wlp1s0): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
ago 30 23:32:07 miix520 kernel: Bluetooth: hci0: Waiting for firmware download to complete
ago 30 23:32:07 miix520 kernel: Bluetooth: hci0: Firmware loaded in 1608118 usecs
ago 30 23:32:07 miix520 kernel: Bluetooth: hci0: Waiting for device to boot
ago 30 23:32:07 miix520 kernel: Bluetooth: hci0: Device booted in 11910 usecs
ago 30 23:32:07 miix520 kernel: Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-12-16.ddc
ago 30 23:32:07 miix520 kernel: Bluetooth: hci0: Applying Intel DDC parameters completed
ago 30 23:32:07 miix520 kernel: Bluetooth: hci0: Reading supported features failed (-16)
ago 30 23:32:07 miix520 kernel: Bluetooth: hci0: Telemetry exception format not supported
ago 30 23:32:07 miix520 kernel: Bluetooth: hci0: Firmware revision 0.1 build 197 week 12 2021
ago 30 23:32:07 miix520 bluetoothd[647]: Endpoint registered: sender=:1.49 path=/MediaEndpoint/A2DPSink/sbc
ago 30 23:32:07 miix520 bluetoothd[647]: Endpoint registered: sender=:1.49 path=/MediaEndpoint/A2DPSource/sbc
ago 30 23:32:07 miix520 bluetoothd[647]: Endpoint registered: sender=:1.49 path=/MediaEndpoint/A2DPSink/sbc_xq_453
ago 30 23:32:07 miix520 bluetoothd[647]: Endpoint registered: sender=:1.49 path=/MediaEndpoint/A2DPSource/sbc_xq_453
ago 30 23:32:07 miix520 bluetoothd[647]: Endpoint registered: sender=:1.49 path=/MediaEndpoint/A2DPSink/sbc_xq_512
ago 30 23:32:07 miix520 bluetoothd[647]: Endpoint registered: sender=:1.49 path=/MediaEndpoint/A2DPSource/sbc_xq_512
ago 30 23:32:07 miix520 bluetoothd[647]: Endpoint registered: sender=:1.49 path=/MediaEndpoint/A2DPSink/sbc_xq_552
ago 30 23:32:07 miix520 bluetoothd[647]: Endpoint registered: sender=:1.49 path=/MediaEndpoint/A2DPSource/sbc_xq_552
ago 30 23:32:09 miix520 ModemManager[423]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.0/0000:01:00.0': not supported by any plugin
ago 30 23:32:10 miix520 wpa_supplicant[650]: wlp1s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=PT
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.1903] policy: auto-activating connection 'nprmm' (7945e840-703d-4c46-903a-1f26b726dff0)
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.1914] device (wlp1s0): Activation: starting connection 'nprmm' (7945e840-703d-4c46-903a-1f26b726dff0)
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.1916] device (wlp1s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.1922] manager: NetworkManager state is now CONNECTING
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.1926] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.1930] device (wlp1s0): Activation: (wifi) access point 'nprmm' has security, but secrets are required.
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.1930] device (wlp1s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2250] device (wlp1s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2252] device (wlp1s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2253] device (wlp1s0): Activation: (wifi) connection 'nprmm' has security, and secrets exist. No new secrets needed.
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2254] Config: added 'ssid' value 'nprmm'
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2254] Config: added 'scan_ssid' value '1'
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2254] Config: added 'bgscan' value 'simple:30:-70:86400'
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2254] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2254] Config: added 'auth_alg' value 'OPEN'
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2254] Config: added 'psk' value '<hidden>'
ago 30 23:32:10 miix520 wpa_supplicant[650]: wlp1s0: SME: Trying to authenticate with 0c:9d:92:4f:59:3c (SSID='nprmm' freq=5500 MHz)
ago 30 23:32:10 miix520 kernel: wlp1s0: authenticate with 0c:9d:92:4f:59:3c
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2424] device (wlp1s0): supplicant interface state: disconnected -> authenticating
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2424] device (p2p-dev-wlp1s0): supplicant management interface state: disconnected -> authenticating
ago 30 23:32:10 miix520 kernel: wlp1s0: send auth to 0c:9d:92:4f:59:3c (try 1/3)
ago 30 23:32:10 miix520 wpa_supplicant[650]: wlp1s0: Trying to associate with 0c:9d:92:4f:59:3c (SSID='nprmm' freq=5500 MHz)
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2479] device (wlp1s0): supplicant interface state: authenticating -> associating
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2479] device (p2p-dev-wlp1s0): supplicant management interface state: authenticating -> associating
ago 30 23:32:10 miix520 kernel: wlp1s0: authenticated
ago 30 23:32:10 miix520 kernel: wlp1s0: associate with 0c:9d:92:4f:59:3c (try 1/3)
ago 30 23:32:10 miix520 kernel: wlp1s0: RX AssocResp from 0c:9d:92:4f:59:3c (capab=0x1011 status=0 aid=2)
ago 30 23:32:10 miix520 wpa_supplicant[650]: wlp1s0: Associated with 0c:9d:92:4f:59:3c
ago 30 23:32:10 miix520 wpa_supplicant[650]: wlp1s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
ago 30 23:32:10 miix520 kernel: wlp1s0: associated
ago 30 23:32:10 miix520 kernel: wlp1s0: Limiting TX power to 30 (30 - 0) dBm as advertised by 0c:9d:92:4f:59:3c
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2599] device (wlp1s0): supplicant interface state: associating -> associated
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2599] device (p2p-dev-wlp1s0): supplicant management interface state: associating -> associated
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2721] device (wlp1s0): supplicant interface state: associated -> 4way_handshake
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2722] device (p2p-dev-wlp1s0): supplicant management interface state: associated -> 4way_handshake
ago 30 23:32:10 miix520 wpa_supplicant[650]: wlp1s0: WPA: Key negotiation completed with 0c:9d:92:4f:59:3c [PTK=CCMP GTK=CCMP]
ago 30 23:32:10 miix520 wpa_supplicant[650]: wlp1s0: CTRL-EVENT-CONNECTED - Connection to 0c:9d:92:4f:59:3c completed [id=0 id_str=]
ago 30 23:32:10 miix520 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp1s0: link becomes ready
ago 30 23:32:10 miix520 wpa_supplicant[650]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-33 noise=9999 txrate=6000
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2810] device (wlp1s0): supplicant interface state: 4way_handshake -> completed
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2811] device (wlp1s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "nprmm"
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2811] device (p2p-dev-wlp1s0): supplicant management interface state: 4way_handshake -> completed
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2812] device (wlp1s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.2818] dhcp4 (wlp1s0): activation: beginning transaction (timeout in 45 seconds)
ago 30 23:32:10 miix520 avahi-daemon[360]: Joining mDNS multicast group on interface wlp1s0.IPv6 with address fe80::7408:eaab:1f:8492.
ago 30 23:32:10 miix520 avahi-daemon[360]: New relevant interface wlp1s0.IPv6 for mDNS.
ago 30 23:32:10 miix520 avahi-daemon[360]: Registering new address record for fe80::7408:eaab:1f:8492 on wlp1s0.*.
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.3041] dhcp4 (wlp1s0): state changed unknown -> bound, address=192.168.1.21
ago 30 23:32:10 miix520 avahi-daemon[360]: Joining mDNS multicast group on interface wlp1s0.IPv4 with address 192.168.1.21.
ago 30 23:32:10 miix520 avahi-daemon[360]: New relevant interface wlp1s0.IPv4 for mDNS.
ago 30 23:32:10 miix520 avahi-daemon[360]: Registering new address record for 192.168.1.21 on wlp1s0.IPv4.
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.3082] device (wlp1s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.3122] device (wlp1s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.3126] device (wlp1s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.3136] manager: NetworkManager state is now CONNECTED_LOCAL
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.3155] manager: NetworkManager state is now CONNECTED_SITE
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.3157] policy: set 'nprmm' (wlp1s0) as default for IPv4 routing and DNS
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.3291] device (wlp1s0): Activation: successful, device activated.
ago 30 23:32:10 miix520 wpa_supplicant[650]: wlp1s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-34 noise=9999 txrate=866700
ago 30 23:32:10 miix520 NetworkManager[363]: <info> [1630362730.4578] manager: NetworkManager state is now CONNECTED_GLOBAL
ago 30 23:32:10 miix520 systemd[1]: systemd-rfkill.service: Deactivated successfully.
ago 30 23:32:10 miix520 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
ago 30 23:32:10 miix520 kernel: audit: type=1131 audit(1630362730.758:111): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
ago 30 23:32:11 miix520 audit[4435]: USER_AUTH pid=4435 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="nuno" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
ago 30 23:32:11 miix520 kernel: audit: type=1100 audit(1630362731.698:112): pid=4435 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="nuno" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
ago 30 23:32:12 miix520 systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
ago 30 23:32:12 miix520 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
ago 30 23:32:12 miix520 kernel: audit: type=1131 audit(1630362732.755:113): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
