whenever I have the touchpad on (I turn it on/off via settings, if that matters), it will not take my input the majority of the time - but it will move on its own very erratically. An excerpt from libinput debug-events:
event7 POINTER_SCROLL_FINGER +39.746s vert 0.00/0.0 horiz -7.51/0.0* (finger)
event7 POINTER_SCROLL_FINGER +39.773s vert 0.00/0.0 horiz -7.33/0.0* (finger)
event7 POINTER_SCROLL_FINGER +39.801s vert -2.92/0.0* horiz -0.19/0.0* (finger)
event7 POINTER_SCROLL_FINGER +39.830s vert -3.70/0.0* horiz -4.70/0.0* (finger)
event7 POINTER_SCROLL_FINGER +39.860s vert 0.00/0.0 horiz -6.39/0.0* (finger)
event7 POINTER_SCROLL_FINGER +39.990s vert 0.00/0.0* horiz 0.00/0.0* (finger)
event7 GESTURE_HOLD_BEGIN +40.182s 3
event7 GESTURE_HOLD_END +40.227s 3 cancelled
event7 GESTURE_HOLD_BEGIN +40.576s 3
event7 GESTURE_HOLD_END +40.926s 3 cancelled
event7 GESTURE_HOLD_BEGIN +41.252s 3
event7 GESTURE_HOLD_END +41.323s 3 cancelled
event7 GESTURE_SWIPE_BEGIN +41.323s 3
event7 GESTURE_SWIPE_UPDATE +41.323s 3 7.47/ 0.13 (15.15/ 0.26 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +41.348s 3 0.92/-4.76 ( 1.00/-5.19 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +41.375s 3 12.53/-10.92 (12.52/-10.91 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +41.404s 3 2.51/-7.54 ( 2.50/-7.53 unaccelerated)
event7 GESTURE_SWIPE_UPDATE +41.515s 3 4.03/ 0.00 ( 4.13/ 0.00 unaccelerated)
event7 GESTURE_SWIPE_END +41.643s 3 cancelled
event7 GESTURE_HOLD_BEGIN +41.915s 3
event7 GESTURE_HOLD_END +43.184s 3 cancelled
event7 GESTURE_HOLD_BEGIN +43.375s 4
event7 GESTURE_HOLD_END +43.634s 4 cancelled
event7 GESTURE_PINCH_BEGIN +43.664s 4
event7 GESTURE_PINCH_UPDATE +43.664s 4 -15.40/ 0.00 (-15.78/ 0.00 unaccelerated) 1.00 @ -2.10
event7 GESTURE_PINCH_UPDATE +43.694s 4 -22.19/-3.90 (-22.17/-3.90 unaccelerated) 1.02 @ -1.67
event7 GESTURE_PINCH_UPDATE +43.721s 4 -1.88/-0.58 (-1.88/-0.58 unaccelerated) 1.02 @ 0.11
event7 GESTURE_PINCH_UPDATE +43.750s 4 -1.07/-0.74 (-1.13/-0.78 unaccelerated) 1.03 @ -0.05
before this, I opened debug-events with the touchpad turned off, turned the touchpad on via settings, and clicked it a few times - this excerpt occurred after it registered a click, and I was no longer touching the pad at that time.
I have tried the following:
-installing synaptics - didnāt seem to do anything
-the following, which removed the touchpad from settings entirely and it did not come back until I restarted
sudo rmmod i2c_hid
sudo modprobe i2c_hid
the output of libinput list-devices for event7 is:
Device: FTCS1000:01 2808:0102 Touchpad
Kernel: /dev/input/event7
Group: 7
Seat: seat0, default
Capabilities: pointer gesture
Tap-to-click: disabled
Tap-and-drag: enabled
Tap drag lock: disabled
Left-handed: disabled
Nat.scrolling: disabled
Middle emulation: disabled
Calibration: n/a
Scroll methods: *two-finger edge
Click methods: *button-areas clickfinger
Disable-w-typing: enabled
Disable-w-trackpointing: enabled
Accel profiles: flat *adaptive
Rotation: n/a
notably, I turned off ādisable when typingā in gnome tweaks. not 100% sure of the implication there, but could be useful knowledge.
I just now checked if turning ādisable when typingā back on made any difference, which - it didnāt, but after turning off touchpad via settings with libinput debug-events still running, I was still getting events from event7 showing up in terminal even though the pad was disabled and no longer shaking my screen around like a snowglobe.
please let me know if anything needs better wording/you need further outputs, thank you for your help ![]()
(I put my cpu, gpu etc. in my user signup thing so hopefully you all can see it, but if not Iāll copy it in)
edit: output of inxi --admin --verbosity=7 --filter --no-host --width is as follows, apologies for missing that:
Kernel: 5.18.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=cf06b40d-92ee-41c9-91b8-89e64f1b0d3d rw quiet
resume=UUID=5428fe88-7ae0-4d6e-b532-3534ca569289 udev.log_priority=3
Desktop: GNOME v: 42.4 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Laptop System: Notebook product: NS5x_NS7xPU v: N/A
serial: <superuser required> Chassis: No Enclosure type: 10
Mobo: Notebook model: NS5x_NS7xPU serial: <superuser required>
UEFI: INSYDE v: 1.07.03 date: 03/27/2022
ID-1: BAT0 charge: 73.9 Wh (100.0%) condition: 73.9/73.9 Wh (100.0%)
volts: 8.7 min: 7.7 model: Notebook BAT type: Li-ion serial: <filter>
status: full
RAM: total: 31.06 GiB used: 4.8 GiB (15.4%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
arch: Alder Lake built: 2021 process: Intel 7 (10nm ESF) family: 6
model-id: 0x9A (154) stepping: 3 microcode: 0x421
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 1025 high: 2549 min/max: 400/4700:3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 434 2: 616 3: 2039
4: 1061 5: 1190 6: 813 7: 891 8: 666 9: 847 10: 1010 11: 616 12: 1238
13: 584 14: 758 15: 1088 16: 2549 bogomips: 79888
bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx
monitor movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P Integrated Graphics vendor: CLEVO/KAPOK
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:4626 class-ID: 0300
Device-2: Chicony USB2.0 Camera type: USB driver: uvcvideo bus-ID: 3-7:3
chip-ID: 04f2:b6f9 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x429d built: 2018 res: 1920x1080
dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46") diag: 438mm (17.3")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel Graphics (ADL GT2) v: 4.6 Mesa 22.1.6
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: CLEVO/KAPOK
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Sound Server-1: ALSA v: k5.18.17-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 2b:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp43s0 state: up mac: <filter>
vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 2d:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp45s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-10:4 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 953.87 GiB used: 130.02 GiB (13.6%)
model: MZVL21T0HCLR-00B00 size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: GXA7601Q temp: 33.9 C scheme: GPT
ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 12.23 GiB (12.8%)
fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: cf06b40d-92ee-41c9-91b8-89e64f1b0d3d
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 288 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
uuid: 87AF-20E6
ID-3: /home raw-size: 767.93 GiB size: 754.8 GiB (98.29%) used: 117.79 GiB
(15.6%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4 label: Home
uuid: b9bb9af4-0f93-4ea6-99c7-c81e6f3b2ba1
ID-1: swap-1 type: partition size: 87.99 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 5428fe88-7ae0-4d6e-b532-3534ca569289
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:5 info: Pixart Imaging Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 093a:2510 class-ID: 0301
Device-2: 3-7:3 info: Chicony USB2.0 Camera type: Video driver: uvcvideo
interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b6f9
Device-3: 3-10:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 41.0 C mobo: N/A
Processes: 338 Uptime: 15h 24m wakeups: 32973 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: pacman: 1099 lib: 338 flatpak: 0 Shell: Zsh v: 5.9
running-in: terminator inxi: 3.3.20
