My Totem is playing back a blank screen regardless of video format (.mkv, .avi, .webm, etc.)
I’ve compiled mesa myself & appended the PKGBUILD below.
I do not suspect driver issue, though, because Pantheon Videos & VLC work properly.
I’ve emptied out ~/{.config,.cache,.local/share}/totem & reinstalled it, but no luck.
I have the following codecs installed
❯ pacman -Q | grep -E "gst-plugin"
gst-plugin-gtk 1.20.5-1
gst-plugin-pipewire 1:0.3.63-1
gst-plugins-bad 1.20.5-1
gst-plugins-bad-libs 1.20.5-1
gst-plugins-base 1.20.5-1
gst-plugins-base-libs 1.20.5-1
gst-plugins-good 1.20.5-1
Any clues as to what the issue might be?
mesa PKGBUILD
❯ cat PKGBUILD
# Maintainer: Laurent Carlier <lordheavym@gmail.com>
# Maintainer: Felix Yan <felixonmars@archlinux.org>
# Contributor: Jan de Groot <jgc@archlinux.org>
# Contributor: Andreas Radke <andyrtr@archlinux.org>
pkgbase=mesa
pkgname=('vulkan-mesa-layers' 'opencl-mesa' 'vulkan-intel' 'vulkan-radeon' 'vulkan-swrast' 'libva-mesa-driver' 'mesa-vdpau' 'mesa')
pkgdesc="An open-source implementation of the OpenGL specification"
pkgver=22.3.1
pkgrel=1
arch=('x86_64')
makedepends=('python-mako' 'libxml2' 'libx11' 'xorgproto' 'libdrm' 'libxshmfence' 'libxxf86vm'
'libxdamage' 'libvdpau' 'libva' 'wayland' 'wayland-protocols' 'zstd' 'elfutils' 'llvm'
'libomxil-bellagio' 'libclc' 'clang' 'libglvnd' 'libunwind' 'lm_sensors' 'libxrandr'
'systemd' 'valgrind' 'glslang' 'vulkan-icd-loader' 'directx-headers' 'cmake' 'meson')
makedepends+=('rust' 'rust-bindgen' 'spirv-tools' 'spirv-llvm-translator') # rusticl dependencies
url="https://www.mesa3d.org/"
license=('custom')
options=('!debug' '!lto')
source=(https://mesa.freedesktop.org/archive/mesa-${pkgver}.tar.xz{,.sig}
0001-anv-force-MEDIA_INTERFACE_DESCRIPTOR_LOAD-reemit-aft.patch
LICENSE)
sha512sums=('8a7aee67f6351de293d23425229eb7c42d6918fe9ffb46c6e5df9609f79633c98ab78e892507fe48055c51fa88bf103d7b7baa58e826b1758f66067048baed5b'
'SKIP'
'ccdc1e367262338073b078f80795143026d08fa3fb720afda968907e1b4fa3b12e44edb441d3e17f6836f631319d1f1c3112699bea67014c3cf911fb9a816a3b'
'8b6a2efe7156a14fe13beaa1280f757fbe897fdfed91641099b634200cf0ea38625a9e599b0bcfa7671e9fad1fdeacf8f64125b4446190cdc369ae6b8148d376')
validpgpkeys=('8703B6700E7EE06D7A39B8D6EDAE37B02CEB490D' # Emil Velikov <emil.l.velikov@gmail.com>
'946D09B5E4C9845E63075FF1D961C596A7203456' # Andres Gomez <tanty@igalia.com>
'E3E8F480C52ADD73B278EE78E1ECBE07D7D70895' # Juan Antonio Suárez Romero (Igalia, S.L.) <jasuarez@igalia.com>
'A5CC9FEC93F2F837CB044912336909B6B25FADFA' # Juan A. Suarez Romero <jasuarez@igalia.com>
'71C4B75620BC75708B4BDB254C95FAAB3EB073EC' # Dylan Baker <dylan@pnwbakers.com>
'57551DE15B968F6341C248F68D8E31AFC32428A6') # Eric Engestrom <eric@engestrom.ch>
prepare() {
cd mesa-$pkgver
# https://gitlab.freedesktop.org/mesa/mesa/-/issues/7111
# https://gitlab.freedesktop.org/mesa/mesa/-/merge_requests/17247
# https://github.com/HansKristian-Work/vkd3d-proton/issues/1200
patch -Np1 -i ../0001-anv-force-MEDIA_INTERFACE_DESCRIPTOR_LOAD-reemit-aft.patch
build() {
# Build only minimal debug info to reduce size
CFLAGS+=' -g1'
CXXFLAGS+=' -g1'
arch-meson mesa-$pkgver build \
-D b_ndebug=false \
-D b_lto=false \
-D platforms=x11,wayland \
-D gallium-drivers=r300,r600,radeonsi,nouveau,virgl,svga,swrast,i915,iris,crocus,zink,d3d12 \
-D vulkan-drivers=amd,intel,intel_hasvk,swrast \
-D vulkan-layers=device-select,intel-nullhw,overlay \
-D dri3=enabled \
-D egl=enabled \
-D gallium-extra-hud=true \
-D gallium-nine=true \
-D gallium-omx=bellagio \
-D gallium-opencl=icd \
-D gallium-va=enabled \
-D gallium-vdpau=enabled \
-D gallium-xa=enabled \
-D gallium-rusticl=true \
-D rust_std=2021 \
-D gbm=enabled \
-D gles1=disabled \
-D gles2=enabled \
-D glvnd=true \
-D glx=dri \
-D libunwind=enabled \
-D llvm=enabled \
-D lmsensors=enabled \
-D osmesa=true \
-D shared-glapi=enabled \
-D microsoft-clc=disabled \
-D video-codecs=vc1dec,h264dec,h264enc,h265dec,h265enc \
-D valgrind=enabled
# Print config
meson configure build
ninja -C build
meson compile -C build
# fake installation to be seperated into packages
# outside of fakeroot but mesa doesn't need to chown/mod
DESTDIR="${srcdir}/fakeinstall" meson install -C build
_install() {
local src f dir
for src; do
f="${src#fakeinstall/}"
dir="${pkgdir}/${f%/*}"
install -m755 -d "${dir}"
mv -v "${src}" "${dir}/"
done
package_vulkan-mesa-layers() {
pkgdesc="Mesa's Vulkan layers"
depends=('libdrm' 'libxcb' 'wayland' 'python')
conflicts=('vulkan-mesa-layer')
replaces=('vulkan-mesa-layer')
_install fakeinstall/usr/share/vulkan/explicit_layer.d
_install fakeinstall/usr/share/vulkan/implicit_layer.d
_install fakeinstall/usr/lib/libVkLayer_*.so
_install fakeinstall/usr/bin/mesa-overlay-control.py
install -m644 -Dt "${pkgdir}/usr/share/licenses/${pkgname}" LICENSE
package_opencl-mesa() {
pkgdesc="OpenCL support with clover and rusticl for mesa drivers"
depends=('libdrm' 'libclc' 'clang' 'expat')
optdepends=('opencl-headers: headers necessary for OpenCL development')
provides=('opencl-driver')
_install fakeinstall/etc/OpenCL
_install fakeinstall/usr/lib/lib*OpenCL*
_install fakeinstall/usr/lib/gallium-pipe
package_vulkan-intel() {
pkgdesc="Intel's Vulkan mesa driver"
depends=('wayland' 'libx11' 'libxshmfence' 'libdrm' 'zstd' 'systemd-libs')
optdepends=('vulkan-mesa-layers: additional vulkan layers')
provides=('vulkan-driver')
_install fakeinstall/usr/share/vulkan/icd.d/intel_*.json
_install fakeinstall/usr/lib/libvulkan_intel*.so
package_vulkan-radeon() {
pkgdesc="Radeon's Vulkan mesa driver"
depends=('wayland' 'libx11' 'libxshmfence' 'libelf' 'libdrm' 'llvm-libs' 'systemd-libs')
_install fakeinstall/usr/share/drirc.d/00-radv-defaults.conf
_install fakeinstall/usr/share/vulkan/icd.d/radeon_icd*.json
_install fakeinstall/usr/lib/libvulkan_radeon.so
package_vulkan-swrast() {
pkgdesc="Vulkan software rasteriser driver"
depends=('wayland' 'libx11' 'libxshmfence' 'libdrm' 'zstd' 'llvm-libs' 'systemd-libs' 'libunwind')
conflicts=('vulkan-mesa')
replaces=('vulkan-mesa')
_install fakeinstall/usr/share/vulkan/icd.d/lvp_icd*.json
_install fakeinstall/usr/lib/libvulkan_lvp.so
package_libva-mesa-driver() {
pkgdesc="VA-API implementation for gallium"
depends=('libdrm' 'libx11' 'llvm-libs' 'expat' 'libelf' 'libxshmfence')
depends+=('libexpat.so')
_install fakeinstall/usr/lib/dri/*_drv_video.so
package_mesa-vdpau() {
pkgdesc="Mesa VDPAU drivers"
_install fakeinstall/usr/lib/vdpau
package_mesa() {
depends=('libdrm' 'wayland' 'libxxf86vm' 'libxdamage' 'libxshmfence' 'libelf'
'libomxil-bellagio' 'libunwind' 'llvm-libs' 'lm_sensors' 'libglvnd'
'zstd' 'vulkan-icd-loader')
depends+=('libsensors.so' 'libexpat.so' 'libvulkan.so')
optdepends=('opengl-man-pages: for the OpenGL API man pages'
'mesa-vdpau: for accelerated video playback'
'libva-mesa-driver: for accelerated video playback')
provides=('mesa-libgl' 'opengl-driver')
conflicts=('mesa-libgl')
replaces=('mesa-libgl')
_install fakeinstall/usr/share/drirc.d/00-mesa-defaults.conf
_install fakeinstall/usr/share/glvnd/egl_vendor.d/50_mesa.json
# ati-dri, nouveau-dri, intel-dri, svga-dri, swrast, swr
_install fakeinstall/usr/lib/dri/*_dri.so
_install fakeinstall/usr/lib/bellagio
_install fakeinstall/usr/lib/d3d
_install fakeinstall/usr/lib/lib{gbm,glapi}.so*
_install fakeinstall/usr/lib/libOSMesa.so*
_install fakeinstall/usr/lib/libxatracker.so*
_install fakeinstall/usr/include
_install fakeinstall/usr/lib/pkgconfig
# libglvnd support
_install fakeinstall/usr/lib/libGLX_mesa.so*
_install fakeinstall/usr/lib/libEGL_mesa.so*
# indirect rendering
ln -s /usr/lib/libGLX_mesa.so.0 "${pkgdir}/usr/lib/libGLX_indirect.so.0"
# make sure there are no files left to install
find fakeinstall -depth -print0 | xargs -0 rmdir
inxi
❯ inxi -Fazy
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/vmlinuz-6.1-x86_64
root=UUID=f36cf003-435c-47d3-b53a-7c1f3c0bb874 rw rootflags=subvol=@ quiet
splash apparmor=1 security=apparmor fbcon=nodefer udev.log_priority=3
cryptdevice=UUID=2c2d558e-0115-4217-8831-cf8638136c0e:cr_root
root=/dev/mapper/cr_root resume=/dev/mapper/cr_swap
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: ASUSTeK product: ZenBook UX325SA_UM325SA v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: UX325SA v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: UX325SA.302 date: 11/09/2021
ID-1: BATT charge: 33.9 Wh (53.0%) condition: 64.0/67.1 Wh (95.4%)
volts: 15.9 min: 15.9 model: ASUSTeK UX325 type: Li-ion serial: <filter>
status: discharging cycles: 310
Info: model: AMD Ryzen 7 5800U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 16 MiB
desc: 1x16 MiB
Speed (MHz): avg: 1511 high: 1900 min/max: 1600/4505 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1600
3: 1397 4: 1347 5: 1600 6: 1900 7: 1330 8: 1600 9: 1377 10: 1600 11: 1600
12: 1460 13: 1600 14: 1600 15: 1383 16: 1397 bogomips: 60704
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5.1 code: Vega-2
process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:1638 class-ID: 0300
temp: 39.0 C
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 13d3:56eb class-ID: fe01 serial: <filter>
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 model: Samsung 0x4158 built: 2020 res: 1920x1080 dpi: 166
gamma: 1.2 size: 294x165mm (11.57x6.5") diag: 337mm (13.3") ratio: 16:9
modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.49 6.1.1-1-MANJARO) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x,snd_pci_acp5x,snd_pci_acp6x,snd_acp_pci,snd_rpl_pci_acp6x,snd_pci_ps,snd_sof_amd_renoir,snd_sof_amd_rembrandt
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: surfshark_ipv6 state: unknown speed: N/A duplex: N/A mac: <filter>
IF-ID-3: vboxnet0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
Local Storage: total: 1.16 TiB used: 285.66 GiB (24.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFM001TD3JX013N
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 41000C20 temp: 32.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB model: AMicro AM8180 NVME
size: 238.47 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 1.00 scheme: GPT
ID-1: / raw-size: 89.41 GiB size: 89.41 GiB (100.00%) used: 42.94 GiB (48.0%)
fs: btrfs dev: /dev/dm-0 maj-min: 254:0 mapped: cr_root
ID-2: /boot raw-size: 954 MiB size: 921.8 MiB (96.63%)
used: 263.8 MiB (28.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /boot/efi raw-size: 244 MiB size: 240.2 MiB (98.46%)
used: 29 MiB (12.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-4: /home raw-size: 788.77 GiB size: 788.77 GiB (100.00%)
used: 221.85 GiB (28.1%) fs: f2fs dev: /dev/dm-2 maj-min: 254:2
mapped: cr_home
ID-5: /var/log raw-size: 89.41 GiB size: 89.41 GiB (100.00%)
used: 42.94 GiB (48.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: cr_root
ID-1: swap-1 type: partition size: 14.89 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1 mapped: cr_swap
System Temperatures: cpu: 44.5 C mobo: N/A gpu: amdgpu temp: 40.0 C
Processes: 481 Uptime: 1d 15h 42m wakeups: 8229 Memory: 15.01 GiB
used: 7.39 GiB (49.3%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1241 libs: 368 tools: gnome-software,pamac,yay pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.24
