xfce 21, I logged on and when the desktop loaded the battery icon is just an outline on the left of the update icon. Any ideas appreciated.
I tried a number of times to upload a small 2.8 KiB image, but apparently this forum doesn’t allow image posting?
Hello,
Not for new members, all explained here and how you still can share links and images
Is that related to the icon theme used?
Ok using default settings Appearance Style “Match-sea” Icons “Papirus-Maia”
Wnindow Manager Theme “Matcha-sea”
On AC power the icon appears correct green and graphic level. However on battery power there is an empty space where the icon was. There is a shadow outline, no other details.
Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: HP product: HP ProBook 470 G3 v: N/A
Mobo: HP model: 8102 v: KBC Version 40.73 serial: <superuser required>
UEFI: HP v: N78 Ver. 01.53 date: 11/24/2021
ID-1: BAT0 charge: 32.7 Wh (67.8%) condition: 48.2/55.1 Wh (87.5%)
volts: 11.1 min: 10.7 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: discharging cycles: 427
RAM: total: 7.66 GiB used: 2.91 GiB (38.0%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: dual core model: Intel Core i7-6500U bits: 64 type: MT MCP
smt: enabled arch: Skylake rev: 3 cache: L1: 128 KiB L2: 512 KiB L3: 4 MiB
Speed (MHz): avg: 500 min/max: 400/3100 cores: 1: 500 2: 500 3: 500
4: 500 bogomips: 20810
dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase fxsr ht hwp
hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc
tsc_adjust tsc_deadline_timer vme x2apic xgetbv1 xsave xsavec xsaveopt
xsaves xtopology xtpr
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-9 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1916
class-ID: 0300
Device-2: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 M440/M445 530/535
620/625 Mobile] vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-3 pcie: speed: 2.5 GT/s lanes: 4 bus-ID: 01:00.0
chip-ID: 1002:6900 class-ID: 0380 temp: 37.0 C
Device-3: Cheng Uei Precision Industry (Foxlink) HP HD Camera type: USB
driver: uvcvideo bus-ID: 1-6:3 chip-ID: 05c8:0383 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver:
X: loaded: amdgpu,modesetting alternate: fbdev,vesa dri: iris,radeonsi
gpu: i915 display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: eDP-1 model: AU Optronics 0x219e res: 1600x900 hz: 60 dpi: 106
size: 382x214mm (15.04x8.43") diag: 438mm (17.2") modes: 1600x900
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d70
class-ID: 0403
Sound API: ALSA v: k5.15.60-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: speed: Unknown
lanes: 63 port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel pcie:
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24f3 class-ID: 0280
bus-ID: 1-7:4 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 931.51 GiB used: 9.96 GiB (1.1%)
ID-1: /dev/sda vendor: Samsung model: ST1000LM024 HN-M101MBB
size: 931.51 GiB speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0001 scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW DU8A6SH rev: DH61
dev-links: cdrom
ID-1: / size: 457.13 GiB used: 9.95 GiB (2.2%) fs: ext4 dev: /dev/sda3
label: N/A uuid: 91b091a0-b8ee-45e0-ab40-01db19c90a10
ID-2: /boot/efi size: 511 MiB used: 4.6 MiB (0.9%) fs: vfat
dev: /dev/sda1 label: N/A uuid: 998C-B80D
ID-1: /dev/sda2 size: 465.51 GiB fs: ext4 label: N/A
uuid: 00c9a817-60b9-4f86-8d1a-80054e350640
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-2:2 info: USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 0000:3825 class-ID: 0301
Device-2: 1-6:3 info: Cheng Uei Precision Industry (Foxlink) HP HD Camera
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05c8:0383 class-ID: 0e02
Device-3: 1-7:4 info: Intel Bluetooth wireless interface type: Bluetooth
Device-4: 1-8:5 info: Validity Sensors VFS495 Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 138a:003f class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 35.0 C pch: 36.5 C mobo: N/A gpu: amdgpu
temp: 36.0 C
Processes: 215 Uptime: 1h 56m wakeups: 1 Init: systemd v: 251
default: graphical Compilers: gcc: 12.2.0 clang: 14.0.6 Packages:
pm: pacman pkgs: 1095 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.22
First you may update your system. This comes always first . Reboot… .
…there should be only running one (default in xfce is PulseAudio).
…are you shure, you don’t want swap (not even a swapfile) ?
The problem is Matcha-light-sea style, panel dark mode. I need the light style [vision problems] to see the windows headings. I tried all the icon sets installed and cannot get the battery icon to display?
