I get these errors even after fresh install. How do i fix all these errors
journalctl -p 3 -b
Journal begins at Fri 2021-08-20 22:19:55 IST, ends at Tue 2021-08-24 14:17:04 IST. --
Aug 24 10:59:10 G5080 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GFX0._DSM.ECR1], AE_NOT_FOUND (20190816/psargs-330)
Aug 24 10:59:10 G5080 kernel: ACPI Error: Aborting method \_SB.PCI0.GFX0._DSM due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
Aug 24 10:59:11 G5080 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GFX0._DSM.ECR1], AE_NOT_FOUND (20190816/psargs-330)
Aug 24 10:59:11 G5080 kernel: ACPI Error: Aborting method \_SB.PCI0.GFX0._DSM due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
Aug 24 10:59:11 G5080 kernel: cgroup2: Unknown parameter 'memory_recursiveprot'
Aug 24 10:59:19 G5080 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GFX0._DSM.ECR1], AE_NOT_FOUND (20190816/psargs-330)
Aug 24 10:59:19 G5080 kernel: ACPI Error: Aborting method \_SB.PCI0.GFX0._DSM due to previous error (AE_NOT_FOUND) (20190816/psparse-529)
Aug 24 10:59:20 G5080 kernel: Bluetooth: hci0: unexpected event for opcode 0xfc2f
Aug 24 10:59:20 G5080 kernel: proc: Bad value for 'hidepid'
Aug 24 10:59:22 G5080 bluetoothd[663]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Unknown Command (0x01)
Aug 24 10:59:22 G5080 kernel: proc: Bad value for 'hidepid'
Aug 24 10:59:35 G5080 kernel: proc: Bad value for 'hidepid'
Aug 24 10:59:37 G5080 bluetoothd[663]: Failed to set mode: Blocked through rfkill (0x12)
Aug 24 10:59:46 G5080 gdm-password][1223]: gkr-pam: unable to locate daemon control file
Aug 24 10:59:55 G5080 gdm-launch-environment][723]: GLib-GObject: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Aug 24 10:59:58 G5080 systemd-coredump[1635]: [🡕] Process 979 (pulseaudio) of user 120 dumped core.
Stack trace of thread 979:
#0 0x00007f690189e467 _IceTransClose (libICE.so.6 + 0xa467)
#1 0x00007f69018a6251 _IceFreeConnection (libICE.so.6 + 0x12251)
#2 0x00007f69018a63da IceCloseConnection (libICE.so.6 + 0x123da)
#3 0x00007f690190f96f SmcCloseConnection (libSM.so.6 + 0x296f)
#4 0x00007f69019191aa n/a (module-x11-xsmp.so + 0x21aa)
#5 0x00007f6907c7dc85 n/a (libpulsecore-15.0.so + 0x7cc85)
#6 0x00007f6907b2c170 pa_mainloop_dispatch (libpulse.so.0 + 0x27170)
#7 0x00007f6907b2c719 pa_mainloop_iterate (libpulse.so.0 + 0x27719)
#8 0x00007f6907b2c7c1 pa_mainloop_run (libpulse.so.0 + 0x277c1)
#9 0x00005601fecc26da main (pulseaudio + 0x86da)
#10 0x00007f6907827b25 __libc_start_main (libc.so.6 + 0x27b25)
#11 0x00005601fecc394e n/a (pulseaudio + 0x994e)
Stack trace of thread 1116:
Welcome to Manjaro!
to give us more information so we can see what’s really going on.
