I’m running gnome. I didn’t install anything extra (other than what I already have under Settings → Power). I’m new to Manjaro and linux in general. If you could guide me where to look and what to look I can dig and post back.
$ systemctl | grep power
power-profiles-daemon.service loaded active running Power Profiles daemon
upower.service loaded active running Daemon for power management
With tlp the battery life literally doubled from 4 hours to 8.5 hrs. So, I tried sudo systemctl disable power-profiles-daemon.service and then enabled tlp. Still no luck. After reboot I found power-profiles-daemon running and tlp not running.
