Hi all
My system are 65% of the time serving a black screen, after the kernel has been started through GRUB. I’m able to start tty2, and run systemctl restart sddm.service. Hereafter the login-screen shows up in the tty2 session.
But I’m searching for a bit of help, to get this fixed. There’s a few brilliant threads on this forum, too. But sadly I’ve not found the proper commands and insights. Therefore I’m trying with my own thread.
Problem
After selecting the kernel in GRUB (normal boot), it’s ending with a black screen, insted of searching the login-screen.
How it’s currently fixed
By opening tty2, I’m able to call system restart sddm.service and the login-screen shows, with no problem.
System information
System: Host: exetico-workstation Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.21.5 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: TUF Z390M-PRO GAMING (WI-FI) v: Rev X.0x serial: <superuser required>
UEFI: American Megatrends v: 2820 date: 01/06/2021
CPU: Info: 6-Core model: Intel Core i7-8700 bits: 64 type: MT MCP cache: L2: 12 MiB
Speed: 4296 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 4296 2: 4300 3: 4300 4: 4300 5: 4300 6: 4300 7: 4300
8: 4300 9: 4300 10: 4300 11: 4301 12: 4298
Graphics: Device-1: Intel UHD Graphics 630 driver: vfio-pci v: 0.2
Device-2: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] driver: amdgpu
v: kernel
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu resolution: 1: 2560x1440~60Hz 2: 2560x1440~60Hz
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.39.0 5.9.16-1-MANJARO LLVM 12.0.0) v: 4.6 Mesa 21.1.2
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
Sound Server-2: PipeWire v: 0.3.30 running: yes
Network: Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi
IF: wlo1 state: up mac: -removed-
Device-2: Intel Ethernet I219-V driver: e1000e
IF: eno2 state: down mac: -removed-
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb
Drives: Local Storage: total: 1.84 TiB used: 402.05 GiB (21.3%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 PRO 512GB size: 476.94 GiB
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 PRO 512GB size: 476.94 GiB
ID-3: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
Partition: ID-1: / size: 468.16 GiB used: 402.04 GiB (85.9%) fs: ext4 dev: /dev/nvme1n1p2
ID-2: /boot/efi size: 299.4 MiB used: 284 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 33.5 C mobo: 26.0 C gpu: amdgpu temp: 49.0 C
Fan Speeds (RPM): fan-1: 0 fan-2: 2136 fan-3: 983 fan-4: 0 fan-5: 0 fan-6: 1016 fan-7: 0 gpu: amdgpu fan: 0
Info: Processes: 358 Uptime: 4m Memory: 62.68 GiB used: 23.42 GiB (37.4%) Shell: fish inxi: 3.3.04
██████████████████ ████████ exetico@exetico-workstation
██████████████████ ████████ OS: Manjaro 21.0.7 Ornara
██████████████████ ████████ Kernel: x86_64 Linux 5.9.16-1-MANJARO
██████████████████ ████████ Uptime: 11m
████████ ████████ Packages: 1702
████████ ████████ ████████ Shell: fish 3.2.2
████████ ████████ ████████ Resolution: 5120x1440
████████ ████████ ████████ DE: KDE 5.82.0 / Plasma 5.21.5
████████ ████████ ████████ WM: KWin
████████ ████████ ████████ GTK Theme: Breath [GTK2/3]
████████ ████████ ████████ Icon Theme: Deepin Dark
████████ ████████ ████████ Disk: 404G / 502G (85%)
████████ ████████ ████████ CPU: Intel Core i7-8700 @ 12x 4.6GHz [48.0°C]
████████ ████████ ████████ GPU: AMD Radeon RX 5700 XT (NAVI10, DRM 3.39.0, 5.9.16-1-MANJARO, LLVM 12.0.0)
RAM: 26717MiB / 64185MiB
So, what can I do?
I would like to know that I can do, to fix this. The most wierd thing is, that’s it’s working on/off, I’d guess every 1/3 time or so (by booting normally, and login-screen shows on tty1, with no issues). By booting it multiple times, I’ve fixed it in the part - but normally it takes many reboots. Therefore I’m now going to tty2 instantly.
UPDATED: Solution
More details here:
Hi @megavolt Thanks for the answer!It’s a bit fun, cause I’ve thought about a timing issue myself. However, it just didn’t work out in my head, maybe use to the lack of knowledge related to boot-up procedure and service start-ups with GUI-based elements. I must say, I forgot to share the most important information… With that said, everything works great - except for the wierd maybe timing-related issue. More details My system are a bit of a mixed bag, cause my Intel Onboard-g…
