Am I the only one experiencing seg faults when starting thunderbird after the update today?
V128 works - god made timeshift even before he did build the world I believe
I tried to
manually export the profile and import it into V136
start without extentions/themes
start in “safe mode”
I can open the profile manager, I can start thunderbird with a new empty profile, but as soon as I try to setup a new email account it is crashing with a segmentation fault.
Will continue to search for a solution ( later today or tomorrow - now I need to work with mail access), probably in any thunderbird forum, but I was just wondering whether I would be the only one experiencing this
I don’t know whether you’re the only one, but do believe that’s the AUR one or something and unsupported. Because mine works flawlessly, albeit without email account, and mine is installed from the extra repository, and is version 128.8.0esr:
$ pamac search thunderbird
thunderbird 136.0-1 [Installed] extra
Standalone mail and news reader from mozilla.org
$ pamac info thunderbird
Version : 128.8.0-1
$ pamac info firefox
Version : 136.0-1
Edit:
But seeing as we use the same version, after all, I think your problem is probably something in your profile, or an extension, or both. You can try removing the .thunderbird directory and see what happens:
sudo pacman -Syu ✔ 3s
:: Paketdatenbanken werden synchronisiert …
core ist aktuell
extra ist aktuell
multilib ist aktuell
:: Vollständige Systemaktualisierung wird gestartet …
Abhängigkeiten werden aufgelöst …
Nach in Konflikt stehenden Paketen wird gesucht …
Pakete (1) thunderbird-136.0-1
Gesamtgröße des Downloads: 65,74 MiB
Gesamtgröße der installierten Pakete: 240,14 MiB
Größendifferenz der Aktualisierung: 15,36 MiB
:: Installation fortsetzen? [J/n] n
pamac info thunderbird 1 ✘ 6s
Version : 128.8.0-1
I think adding a Thunderbird language pack might change the perceived version (language packs are currently @ 136.0-1); though I don’t understand why that should be the case.
pamac search thunderbird also reveals this on a recently built VM, and I know it was the “esr” (128.x.x) that I installed.
Edit:-
Pacman says differently, however:
pacman -Qs thunderbird
local/thunderbird 128.8.0-1
Maybe it’s a pamacquirk of some kind.
But to the main item on the agenda;
There have been many reports of segfaults in recent weeks attributable to nothing specific. It’s quite possible Thunderbird isn’t the culprit here; unfortunately, I don’t know what is.
