Thunderbird not working after update
Reference: Thunderbird Segmentation Fault after update 11.03.2025 V128->V136
hi, when I list my extensions: I dont have the Top Bar Organizer!
But the thunderbird 136 is starting and opens a window. After that, it closes down.
Same effect as Zauberer Merlin
Edited with better prompt
$ gnome-extensions list --enabled
apps-menu@gnome-shell-extensions.gcampax.github.com
window-list@gnome-shell-extensions.gcampax.github.com
windowsNavigator@gnome-shell-extensions.gcampax.github.com
<small>Mod Edit: I've moved your post a dedicated topic. Please don't hijack other threads.</small>
Try to disable one extension after another.
And start thunderbird from a console after each try to see the output.
“Status Icons” would be my favorite one to try …
Thunderbird 136 introduces a new AppIcon … and GnomeShell is not working quite well with AppIcons
You need to try … you can disable all extentions upfront in the Gnome Extension Manager to see whether it will work
Sorry,
I deactivated all extensions… Thunderbird 136 still not able to launch after update
System is up to date (pacman -Syuv)
Any other help?
Steelcat> thunderbird
[ImapModuleLoader] Using nsImapService.cpp
console.error: (new UnknownCollectionError("Unknown Collection \"thunderbird/url-parser-default-unknown-schemes-interventions\"", "resource://services-settings/RemoteSettingsClient.sys.mjs", 189))
console.error: services.settings:
  Remote Settings startup changesets bundle could not be extracted (TypeError: serverInfo.capabilities.attachments is undefined)
  Message: UnknownCollectionError: Unknown Collection "thunderbird/remote-permissions"
  Stack:
    UnknownCollectionError@resource://services-settings/RemoteSettingsClient.sys.mjs:189:5
sync@resource://services-settings/RemoteSettingsClient.sys.mjs:635:13
Speicherzugriffsfehler (Speicherabzug geschrieben)
Try in safe mode thunderbird --safe-mode and see if you can start it that way (all you log besides the last line is normal).
I disabled all addons and reseted all toolbars and controls… no sucess
Additonal info:
I have AMD CPU AMD Ryzen 7 2700X Eight-Core Processor
I have ATi 470 driver for my nvidia grpahics card.
[Steelcat ~]$ thunderbird --safe-mode
  Stack:
_beforeUIStartup@resource:///modules/MailGlue.sys.mjs:586:19
observe@resource:///modules/MailGlue.sys.mjs:449:14
Crash Annotation GraphicsCriticalError: |[0][GFX1-]: RenderCompositorSWGL failed mapping default framebuffer, no dt (t=16.4367) [GFX1-]: RenderCompositorSWGL failed mapping default framebuffer, no dt
[Steelcat ~]$ [ImapModuleLoader] Using nsImapService.cpp
  Stack:
oh… only the last lane?
HW memory problem?
hmmm
I have no Clue.
What I did was to setup a new linux User, and start Gnome with that user to see whether it would be any gnome customization that crashes thunderbird.
And mv .thunderbird .thunderbird.backup to Backup your config and start with an empty profile
Probably a try for you as well.
After much trouble with thunderbird 136 ( extensions not working anymore ) i downgraded to thunderbird 128.8 and everything is ok again :slight_smile:
Version 128.8 is ESR = one year no extra trouble , so i hope.
linux Mint and fedora ship the ESR version of thunderbird. that is much more userfriendly
There is a thunderbird 128.8 in the AUR repository:
Paket-Details: thunderbird-esr-bin 128.8.0-1
Just learned how to force thunderbird to use an older /home/$USER/.thunderbird
config directory.
$USER in this code is john1:
thunderbird --allow-downgrade -P /home/john1/.thunderbird/
Hope that is usefull for someone else !
Just to remove any confusion, is that command for thunderbird-esr-bin v128.8.0-1 after it has replaced v136, or is it for thunderbird v136 to enable it to use an older version’s config directory?
The word “older” is somehow misleading in this context:
I have multiple Linux installations on my HD and don’t want to configure thunderbird over and over again !
In the past i copied /home/$USER/.thunderbird folder from a backup to “auto” config a new installed thunderbird. But now thunderbird does not use this backup configs and tells me to create a new account !
So i was thinking about how to tell thunderbird which existing config to use.
In terminal i had a look at
thunderbird -h
and there i found the two start parameter “–allow-downgrade” and “-P”
That did the trick. No more endless manual restoring of account layout settings and account configurations …
I wrote “old” because i restored the folder from backup without thinking of version differences.
I think its good to know how to achieve that “restoring” of thunderbird configs
no, that did not help , sorry
Well Manjaro is rolling release - if you don’t like that - switch to Linux Mint …
They even got the LMDE (Linux Mint Debian) for even longer package life …
And to be fair, it is only a few clicks if you want custom versions of any app, for example here click click Download — Thunderbird, beta, ESR, they are there too.
done a memtest on my system 32 GB ar OK, no problems
It crashed and created a core dump.
The
HW memory problem?
is your assumption
which is likely incorrect, according to:
What is the result of:
from a terminal?
Oh! A miracle.
I did several reboots and reinstalls of thunderbird and cleaning of pamac.
And now: It works… it started without problem…
So Sorry for this happy end…
strange, now it broken again…
How to debug?
same effect like written above
As you claim the issue isn’t solved, I have removed the marked Solution from the post above (you should have done this).
If running Thunderbird with --safe-mode gave some reprieve, then it’s quite possible a failing (or incompatible) Thunderbird addon may be the problem. Running Thunderbird in safe-mode disables all addons, but this is not a magical cure but a diagnostic tool.
Removing all addons/extensions, and replacing them one by one will help to find the actual addon that might be causing the issue. Yes, it’s a royal pain in the backside, but effective.
Naturally allow some time between adding each addon for the issue to arise. When it does, the last addon reintroduced would likely be the culprit.
From that point you should find an updated version of the addon (compatible with the new TB version) or find a replacement.
sorry for not marking unsolved
[panther@thunder ~]$ thunderbird --safe-mode
  Stack:
Crash Annotation GraphicsCriticalError: |[0][GFX1-]: RenderCompositorSWGL failed mapping default framebuffer, no dt (t=5.81199) [GFX1-]: RenderCompositorSWGL failed mapping default framebuffer, no dt
thunderbird --version
Mozilla Thunderbird 136.0
does this help to diagnose?
It’s not helpful to me.
Following the procedure I suggested may help isolate the problem. Please report back with the results of that.
If you choose to ignore that possibility, I can only wish you luck.
