Mickey
2 December 2020 17:06
1
After being able to circumvent the fn-keys issue with my Thinkpad E14 (AMD)
Hello,
I just installed Manjaro on my thinkpad E14 Gen 2, tried it with KDE and XFCE both works fine, only one issue I got. The FN-Keys are not working and the caps lock key also does not show the light when it was pressed. Laptop lid on close does also not work.
After the first time I suspend my laptop and I log in again everything works fine.
FN-Keys, the light on keyboard and lid on close.
I am currently using Kernel 5.9. On other Kernels I got the same issue, I didn’t tested if it works …
an annoying defect came up. Somentimes the randomly freezes at an irregular interval and you have to hard shutdown the laptop by long pressing the shutdown button. Music playback continues but the display only shows a frozen picture. Keyboard input does not seems to continue working. Lately it happens about once or twice a day.
Has anyone who owns a Thinkpad E14 / E15 experienced this?
Any hints to get more detailed information about this issue using logs, … are greatly appreciated. (I used journalctl
but did not find anything special.
Mickey
10 December 2020 17:48
2
It just happened again, here is the journalctl
output. Would be great if someone could search for any hint, I have not found anything.
Dez 10 18:43:15 thinkfreax blueman-mechanism[1794]: Unable to init server: Could not connect: Connection refused
Dez 10 18:43:15 thinkfreax blueman-mechani[1794]: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
Dez 10 18:43:15 thinkfreax dbus-daemon[931]: [system] Successfully activated service 'org.blueman.Mechanism'
Dez 10 18:43:15 thinkfreax audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 10 18:43:15 thinkfreax systemd[1]: Started Bluetooth management mechanism.
Dez 10 18:43:15 thinkfreax dbus-daemon[1433]: [session uid=1000 pid=1433] Activating via systemd: service name='org.gnome.evolution.dataserver.Calendar8' unit='evolution-calendar-factory.service' requested by ':1.51' (uid=1000 pid=1609 c>
Dez 10 18:43:15 thinkfreax systemd[1411]: Starting Evolution calendar service...
Dez 10 18:43:15 thinkfreax dbus-daemon[1433]: [session uid=1000 pid=1433] Activating via systemd: service name='org.bluez.obex' unit='dbus-org.bluez.obex.service' requested by ':1.52' (uid=1000 pid=1595 comm="/usr/bin/python /usr/bin/blu>
Dez 10 18:43:15 thinkfreax systemd[1411]: Starting Bluetooth OBEX service...
Dez 10 18:43:15 thinkfreax obexd[1819]: OBEX daemon 5.55
Dez 10 18:43:15 thinkfreax dbus-daemon[1433]: [session uid=1000 pid=1433] Successfully activated service 'org.bluez.obex'
Dez 10 18:43:15 thinkfreax systemd[1411]: Started Bluetooth OBEX service.
Dez 10 18:43:15 thinkfreax dbus-daemon[1433]: [session uid=1000 pid=1433] Successfully activated service 'org.gnome.evolution.dataserver.Calendar8'
Dez 10 18:43:15 thinkfreax systemd[1411]: Started Evolution calendar service.
Dez 10 18:43:15 thinkfreax dbus-daemon[1433]: [session uid=1000 pid=1433] Activating via systemd: service name='org.gtk.vfs.Metadata' unit='gvfs-metadata.service' requested by ':1.20' (uid=1000 pid=1537 comm="/usr/bin/caja " label="uncon>
Dez 10 18:43:15 thinkfreax systemd[1411]: Starting Virtual filesystem metadata service...
Dez 10 18:43:16 thinkfreax dbus-daemon[1433]: [session uid=1000 pid=1433] Successfully activated service 'org.gtk.vfs.Metadata'
Dez 10 18:43:16 thinkfreax systemd[1411]: Started Virtual filesystem metadata service.
Dez 10 18:43:16 thinkfreax dbus-daemon[1433]: [session uid=1000 pid=1433] Activating via systemd: service name='org.gnome.evolution.dataserver.AddressBook10' unit='evolution-addressbook-factory.service' requested by ':1.59' (uid=1000 pid>
Dez 10 18:43:16 thinkfreax systemd[1411]: Starting Evolution address book service...
Dez 10 18:43:16 thinkfreax dbus-daemon[1433]: [session uid=1000 pid=1433] Successfully activated service 'org.gnome.evolution.dataserver.AddressBook10'
Dez 10 18:43:16 thinkfreax systemd[1411]: Started Evolution address book service.
Dez 10 18:43:16 thinkfreax notification-ar[1634]: Status Notifier Item with bus name ':1.35' and object path '/org/ayatana/NotificationItem/redshift' is already registered
Dez 10 18:43:16 thinkfreax notification-ar[1634]: Status Notifier Item with bus name ':1.58' and object path '/org/ayatana/NotificationItem/blueman' is already registered
Dez 10 18:43:16 thinkfreax telegram-desktop[1570]: qt.svg: Error while inflating gzip file: SVG format check failed
Dez 10 18:43:16 thinkfreax notification-ar[1634]: Status Notifier Item with bus name ':1.65' and object path '/org/ayatana/NotificationItem/Signal1' is already registered
Dez 10 18:43:17 thinkfreax audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 10 18:43:17 thinkfreax systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1]: Stopping User Manager for UID 972...
Dez 10 18:43:24 thinkfreax systemd[1285]: Stopped target Main User Target.
Dez 10 18:43:24 thinkfreax systemd[1285]: Stopping Accessibility services bus...
Dez 10 18:43:24 thinkfreax systemd[1285]: Stopping D-Bus User Message Bus...
Dez 10 18:43:24 thinkfreax systemd[1285]: Stopping Virtual filesystem service...
Dez 10 18:43:24 thinkfreax systemd[1285]: at-spi-dbus-bus.service: Killing process 1374 (gmain) with signal SIGKILL.
Dez 10 18:43:24 thinkfreax systemd[1285]: at-spi-dbus-bus.service: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1285]: Stopped Accessibility services bus.
Dez 10 18:43:24 thinkfreax systemd[1285]: dbus.service: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1285]: Stopped D-Bus User Message Bus.
Dez 10 18:43:24 thinkfreax systemd[1]: run-user-972-gvfs.mount: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1411]: run-user-972-gvfs.mount: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1285]: run-user-972-gvfs.mount: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1285]: gvfs-daemon.service: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1285]: Stopped Virtual filesystem service.
Dez 10 18:43:24 thinkfreax systemd[1285]: Stopped target Basic System.
Dez 10 18:43:24 thinkfreax systemd[1285]: Stopped target Paths.
Dez 10 18:43:24 thinkfreax systemd[1285]: Stopped target Sockets.
Dez 10 18:43:24 thinkfreax systemd[1285]: Stopped target Timers.
Dez 10 18:43:24 thinkfreax systemd[1285]: dbus.socket: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1285]: Closed D-Bus User Message Bus Socket.
Dez 10 18:43:24 thinkfreax systemd[1285]: dirmngr.socket: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1285]: Closed GnuPG network certificate management daemon.
Dez 10 18:43:24 thinkfreax systemd[1285]: gpg-agent-browser.socket: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1285]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Dez 10 18:43:24 thinkfreax systemd[1285]: gpg-agent-extra.socket: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1285]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Dez 10 18:43:24 thinkfreax systemd[1285]: gpg-agent-ssh.socket: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1285]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Dez 10 18:43:24 thinkfreax systemd[1285]: gpg-agent.socket: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1285]: Closed GnuPG cryptographic agent and passphrase cache.
Dez 10 18:43:24 thinkfreax systemd[1285]: p11-kit-server.socket: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1285]: Closed p11-kit server.
Dez 10 18:43:24 thinkfreax systemd[1285]: pipewire.socket: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1285]: Closed Multimedia System.
Dez 10 18:43:24 thinkfreax systemd[1285]: pulseaudio.socket: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1285]: Closed Sound System.
Dez 10 18:43:24 thinkfreax systemd[1285]: Reached target Shutdown.
Dez 10 18:43:24 thinkfreax systemd[1285]: systemd-exit.service: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1285]: Finished Exit the Session.
Dez 10 18:43:24 thinkfreax systemd[1285]: Reached target Exit the Session.
Dez 10 18:43:24 thinkfreax systemd[1286]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
Dez 10 18:43:24 thinkfreax systemd[1]: user@972.service: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1]: Stopped User Manager for UID 972.
Dez 10 18:43:24 thinkfreax audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@972 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 10 18:43:24 thinkfreax kernel: kauditd_printk_skb: 23 callbacks suppressed
Dez 10 18:43:24 thinkfreax kernel: audit: type=1131 audit(1607622204.276:108): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@972 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=>
Dez 10 18:43:24 thinkfreax systemd[1]: Stopping User Runtime Directory /run/user/972...
Dez 10 18:43:24 thinkfreax systemd[1411]: run-user-972.mount: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1]: run-user-972.mount: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1]: user-runtime-dir@972.service: Succeeded.
Dez 10 18:43:24 thinkfreax systemd[1]: Stopped User Runtime Directory /run/user/972.
Dez 10 18:43:24 thinkfreax audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@972 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Dez 10 18:43:24 thinkfreax systemd[1]: Removed slice User Slice of UID 972.
Dez 10 18:43:24 thinkfreax kernel: audit: type=1131 audit(1607622204.286:109): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@972 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? ter>
Dez 10 18:43:27 thinkfreax wpa_supplicant[1077]: wlp3s0: AP-STA-CONNECTED f8:a9:d0:4b:11:99
Dez 10 18:43:27 thinkfreax dnsmasq-dhcp[1405]: DHCPDISCOVER(wlp3s0) f8:a9:d0:4b:11:99
Dez 10 18:43:27 thinkfreax dnsmasq-dhcp[1405]: DHCPOFFER(wlp3s0) 10.42.0.18 f8:a9:d0:4b:11:99
Dez 10 18:43:27 thinkfreax dnsmasq-dhcp[1405]: DHCPREQUEST(wlp3s0) 10.42.0.18 f8:a9:d0:4b:11:99
Dez 10 18:43:27 thinkfreax dnsmasq-dhcp[1405]: DHCPACK(wlp3s0) 10.42.0.18 f8:a9:d0:4b:11:99 android-cf852b1d8e116b94
Dez 10 18:43:30 thinkfreax audit[2022]: USER_AUTH pid=2022 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="kunruh" exe="/usr/bin/sudo" hostname=? addr=? terminal=/d>
Dez 10 18:43:30 thinkfreax kernel: audit: type=1100 audit(1607622210.293:110): pid=2022 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="kunruh" exe="/usr/bin/sudo" >
Dez 10 18:43:30 thinkfreax dbus-daemon[931]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.90' (uid=0 pid=2022 comm="sudo journalctl " label="unconfined")
Dez 10 18:43:30 thinkfreax dbus-daemon[931]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Dez 10 18:43:30 thinkfreax sudo[2022]: pam_systemd_home(sudo:account): systemd-homed is not available: Unit dbus-org.freedesktop.home1.service not found.
Dez 10 18:43:30 thinkfreax kernel: audit: type=1101 audit(1607622210.296:111): pid=2022 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="kunruh" exe="/usr/bin/sudo" hostname=? addr=? ter>
Dez 10 18:43:30 thinkfreax kernel: audit: type=1110 audit(1607622210.296:112): pid=2022 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? a>
Dez 10 18:43:30 thinkfreax audit[2022]: USER_ACCT pid=2022 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:accounting grantors=pam_permit,pam_time acct="kunruh" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res=success'
Dez 10 18:43:30 thinkfreax audit[2022]: CRED_REFR pid=2022 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res>
Dez 10 18:43:30 thinkfreax sudo[2022]: kunruh : TTY=pts/0 ; PWD=/home/kunruh ; USER=root ; COMMAND=/usr/bin/journalctl
Dez 10 18:43:30 thinkfreax sudo[2022]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0)
Dez 10 18:43:30 thinkfreax audit[2022]: USER_START pid=2022 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/0 res>
Dez 10 18:43:30 thinkfreax kernel: audit: type=1105 audit(1607622210.299:113): pid=2022 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? ad>
lines 219583-219635/219635 (END)
