I have never compiled a kernel. I need to clone this repository and follow the instructions?
Quotes with my username in post #4 regarding setting default sink in PipeWire are not very helpful here when OP only has one sink available in PulseAudio
See also previous posts regarding audio issues with Matebook D15
I installed kernel version 5.17 but Huawei Matebook d15 sound card is not recognized - #46 by nikgnomic
My Huawei D15 don't sound at all. Comet Lake PCH-LP cAVS - #2 by nikgnomic
But reports to sofproject are probably relevant for Intel based laptops only
AMD systems usually require an Audio Co-Processor driver
all I can find relating to audio support for AMD Matebook system is this bug report:
Here are the config options you have to enable and a guide on how to compile.
But if you haven’t compiled a kernel before your system might get in trouble. Do a full backup first.
Thank you. I will study.
I just thought of something, have you tried switching the system to PipeWire and switch to kernel 6.4 or even 6.5 just to see if the support is there?
~ LC_ALL=C sudo pacman -S pipewire pipewire-alsa pipewire-pulse pipewire-jack pavucontrol
warning: pipewire-1:0.3.75-2 is up to date -- reinstalling
warning: pavucontrol-1:5.0+r64+geba9ca6-1 is up to date -- reinstalling
resolving dependencies...
:: There are 2 providers available for pipewire-session-manager:
:: Repository extra
1) pipewire-media-session 2) wireplumber
Enter a number (default=1):
~ uname -r ✔
6.4.6-1-MANJARO
~ systemctl --user enable --now pipewire.service pipewire.socket pipewire-pulse.service
Created symlink /home/alexey/.config/systemd/user/default.target.wants/pipewire.service → /usr/lib/systemd/user/pipewire.service.
Created symlink /home/alexey/.config/systemd/user/sockets.target.wants/pipewire.socket → /usr/lib/systemd/user/pipewire.socket.
Created symlink /home/alexey/.config/systemd/user/default.target.wants/pipewire-pulse.service → /usr/lib/systemd/user/pipewire-pulse.service.
Created symlink /home/alexey/.config/systemd/user/sockets.target.wants/pipewire-pulse.socket → /usr/lib/systemd/user/pipewire-pulse.socket.
There is no sound
~ alsa-utils ✔
zsh: correct 'alsa-utils' to '_alsa-utils' [nyae]? y
_arguments:comparguments:327: can only be called from completion function
~ _alsa-utils 1 ✘
Well, that is odd… Just out of curiosity, if you have the time and means, could you try out my Manjaro Spin, it has PipeWire installed by default, the kernel is 6.1 but for testing it should be fine. The ISO is a complete version of the desktop, no need to install.
the underlying problem in ALSA cannot be resolved by replacing software audio servers
Modprobe option snd-hda-intel dmic_detect=0
for Intel laptops was deprecated and replaced when kernel v5.8 was released
Some intel systems may need skylake driver, but AMD systems don’t
Intel systems need Sound Open Firmware drivers but this AMD system needs an AMD Audio CoProcessor driver for the ES8336 audio codec
(see links posted by @Xephon)
If the respin ISO does not include the ALSA patch for the onboard audio codec it is not likely to work any better than Manjaro (or any other Linux) ISOs
Well it was worth a shot…
Linux can already be installed on Apple without any problems. And it’s probably difficult to enable ES8336 support.
I did a little digging, it appears you have a semi rare audio card, some Asus notebooks also have this iisue. According to the link below, some have had success by running the following commands in a script.
#!/bin/bash
hda-verb /dev/snd/hwC0D0 0x20 0x500 0x1b
hda-verb /dev/snd/hwC0D0 0x20 0x477 0x4a4b
hda-verb /dev/snd/hwC0D0 0x20 0x500 0xf
hda-verb /dev/snd/hwC0D0 0x20 0x477 0x74
Original Link: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1850439
There 's about the snd_hda_codec_realtek driver . I have snd_hda_intel used.
AFAIK Apple systems use mostly Cirrus Logic audio codecs (CS4206/4207/4208)
Workaround using hda-verbs has been confirmed to work on Asus notebooks with Realtek ALC294 codec
Dual boot: Weird no sound behavior but devices are visible - #4 by nikgnomic
Headphone not working - #8 by nikgnomic
There have been no further issues reported with Asus ALC294 systems since April, so I suspect this audio codec has been patched in kernel by ALSA developers
