Theme issue with manjaro-kde-settings
ok, i reinstalled the pkg and did nothing else other than try to change title bar color - same result
/etc/xdg/kdeglobals…
[General]
shadeSortColumn=true
BrowserApplication=firefox
ColorScheme=Breath22021Light
Name=Breath2
fixed=Noto Mono,10,-1,0,50,0,0,0,0,0
font=Noto Sans,10,-1,5,50,0,0,0,0,0
menuFont=Noto Sans,10,-1,5,50,0,0,0,0,0
smallestReadableFont=Noto Sans,8,-1,5,50,0,0,0,0,0
toolBarFont=Noto Sans,9,-1,5,50,0,0,0,0,0
[Icons]
Theme=breath2
[KDE]
SingleClick=false
ChangeCursor=true
contrast=7
LookAndFeelPackage=org.manjaro.breath2-2021.desktop
DefaultLightLookAndFeel=org.manjaro.breath2-2021-light.desktop
DefaultDarkLookAndFeel=org.manjaro.breath2-2021-dark.desktop
widgetStyle=breeze
[Paths]
Trash=$HOME/Desktop/Trash/
[PreviewSettings]
MaximumSize=3145728
camera=true
file=true
fonts=true
[Directories]
dir_pixmap=/usr/share/pixmaps
[KFileDialog Settings]
Breadcrumb Navigation=true
I really don’t understand what’s going on. Have you tried downgrading your package?
no sir
all i can tell you is that this issue is not new - this seems to be a reoccurring problem that happens every once in a while and it’s the titlebar color thing that is reported - this happened to me maybe several months ago or more, and i’ve seen several other reports
if you want me to troubleshoot further, i’m willing, otherwise it’s not a problem that i can’t live with
at some point i like to nuke most of the dot files in /home and reinstall the OS because i’ve noticed that these kind of little issues tend to build up over time
To add to this, I seem to be having problems with manjaro-kde-settings that I posted about in another thread:
https://forum.manjaro.org/t/multi-monitor-setup-in-plasma-broke-after-stable-update-2021-07-28/76342/10?u=kevlyn
When updating manjaro-kde-settings my multi-monitor setup goes crazy and is unusable. I tried re-applying themes, etc. and the problem remains. The only fix I’ve had is reverting back to a previous version of manjaro-kde-settings.
(Posting here because that other thread doesn’t seem to be noticed and was tagged as a different issue)
perhaps not related, but i’m also on AMD…
KDE Plasma Version: 5.22.4
KDE Frameworks Version: 5.84.0
Qt Version: 5.15.2
Kernel Version: 5.13.8-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 8 × AMD Ryzen 5 3400G with Radeon Vega Graphics
Memory: 15.3 GiB of RAM
Graphics Processor: AMD Radeon™ Vega 11 Graphics
not sure if this helps or hinders, but i noticed by accident that changing the color of the titlebar does affect Pamac - which i think is GTK?
Breeze GTK follows KDE theme now what makes it even more strange. So only Qt-based apps are affected? Have you tried other KWin themes (which support colors like Oxygen)? Maybe it’s something with Breeze decorations?
yes, i think that’s correct - Pamac titlebar color can be changed but most apps (Dolphin, System Settings, Thunderbird, Firefox, Kate, etc.) the color cannot be changed
if you mean from the ‘plasma style’ settings, yes, i tried the Breath variant that supports colors and Oxygen, though it doesn’t say it supports colors
perhaps i should mention again that, like others have said, if i change the widget theme from Breeze to Plastic, then titlebar colors can be changed (but other small issues arise)
i just tried a bootable Artix Linux ISO - KDE/Plasma - same thing - couldn’t change titlebar color - the only setting i changed prior to color was i selected ‘dark theme’ when the settings manager first appeared
This issue arose for me upon updating all my packages today.
A week or so ago i updated all packages. i reboot every day. A couple days ago i changed color scheme (to the one with green active titlebar). Today i updated all packages again. During package updates my active green titlebar changed to grey. Then for the first time i edited, saved, and applyed a new color scheme, but the active titlebar color just wouldn’t change. Google led me here, and it’s strange this thread is from back in august! i just deleted(moved) /etc/xdg/kdeglobals. No immediate effect, will see after reboot…
It’s not the same issue. Can you please provide your ~/.config/kdeglobals?
i don’t see an ‘attach’ button, is there one? here ya go:
[$Version]
update_info=filepicker.upd:filepicker-remove-old-previews-entry,fonts_global.upd:Fonts_Global,fonts_global_toolbar.upd:Fonts_Global_Toolbar,icons_remove_effects.upd:IconsRemoveEffects,kwin.upd:animation-speed,style_widgetstyle_default_breeze.upd:StyleWidgetStyleDefaultBreeze
[ColorEffects:Disabled]
ChangeSelectionColor=
Color=56,56,56
ColorAmount=0
ColorEffect=0
ContrastAmount=0.65
ContrastEffect=1
Enable=
IntensityAmount=0.1
IntensityEffect=2
[ColorEffects:Inactive]
ChangeSelectionColor=true
Color=112,111,110
ColorAmount=0.025
ColorEffect=2
ContrastAmount=0.1
ContrastEffect=2
Enable=false
IntensityAmount=0
IntensityEffect=0
[Colors:Button]
BackgroundAlternate=30,87,116
BackgroundNormal=51,57,63
DecorationFocus=0,137,123
DecorationHover=0,152,134
ForegroundActive=61,174,233
ForegroundInactive=194,194,194
ForegroundLink=29,153,243
ForegroundNegative=218,68,83
ForegroundNeutral=246,116,0
ForegroundNormal=194,194,194
ForegroundPositive=39,174,96
ForegroundVisited=155,89,182
[Colors:Complementary]
BackgroundNormal=42,46,50
DecorationFocus=61,174,233
DecorationHover=61,174,233
ForegroundInactive=161,169,177
ForegroundNormal=252,252,252
[Colors:Header]
BackgroundAlternate=42,46,50
BackgroundNormal=49,54,59
[Colors:Header][Inactive]
BackgroundAlternate=49,54,59
[Colors:Selection]
BackgroundNormal=0,110,98
ForegroundActive=252,252,252
ForegroundInactive=252,252,252
ForegroundLink=253,188,75
[Colors:Tooltip]
BackgroundNormal=15,15,15
[Colors:View]
BackgroundAlternate=35,38,41
BackgroundNormal=24,25,29
[Colors:Window]
BackgroundNormal=40,46,51
[General]
ColorScheme=003333
Name=Breath2 2021 Light
toolBarFont=Noto Sans,10,-1,5,50,0,0,0,0,0
[Icons]
Theme=breeze
[KDE]
LookAndFeelPackage=org.manjaro.breath.desktop
contrast=4
widgetStyle=Oxygen
Allow Expansion=false
Automatically select filename extension=true
Decoration position=2
LocationCombo Completionmode=5
PathCombo Completionmode=5
Show Bookmarks=false
Show Full Path=false
Show Inline Previews=true
Show Preview=false
Show Speedbar=true
Show hidden files=false
Sort by=Name
Sort directories first=true
Sort reversed=false
Speedbar Width=138
View Style=DetailTree
[WM]
activeBackground=51,0,51
activeBlend=0,51,51
activeForeground=252,252,252
inactiveBackground=0,0,0
inactiveBlend=34,34,0
inactiveForeground=89,89,89
So if you apply your own color scheme it isn’t get applied? Or only header stays the same? Can you please try with other schemes also?
interesting, now if i edit a different color scheme, save, and apply, it works. But i still have two broken color schemes from a half hour ago, where the titlebar color is flatly ignored. Offhand i’d bet it might be because systemsettings5 had been running from before the update, and the update gave me a new version of systemsettings5 which works better now. Anyway thanks!
inability to change title bar colors has been a long-standing issue dating back possibly more than a year, at least when first selecting a dark theme (breeze), and the issue is present on a fresh install without restoring any kde-plasma stuff in /home
from reading other comments regarding this issue over the years, it seems that in some cases, after dumping various kdeglobals, etc., files in /home ~/.config /etc, one might be able to change the titlebar color once, but not a second time - this just happened to me now
what i just now figured out is that, if the titlebar color doesn’t change in systems settings → appearance → colors when saving the change and closing the color editor and applying the change, if i save the change in the color editor without closing the window, then click another menu item in the appearance window, the change will then be saved - all that is needed then is to switch to another theme in the colors window, then back again
It’s caused by Header colors defined in the theme: 433059 – "Active/Inactive Titlebar" colors are visible and editable but confusingly unused when Header colors are present
