My 3080 has a dynamic TDP of 140-165 watts, but in Manjaro for some reason it’s 115 watts. Tried Fedor 36, 165 watt always. How to fix?
post the output of
sudo nvidia-smi -q -d POWER
and also the basic-minimum infos required in this forum because none of us owes a functioning glass bowl
- Please read this:
[HowTo] Provide System Information
and press the three dots … below your post and press theto give us more information so we can see what’s really going on.
Now we know the symptom of the disease, but we need some more probing to know where the origin lies… - An
would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text.
Timestamp : Sat Jun 11 13:42:30 2022
Driver Version : 510.73.05
CUDA Version : 11.6
Attached GPUs : 1
GPU 00000000:01:00.0
Power Readings
Power Management : N/A
Power Draw : 16.64 W
Power Limit : N/A
Default Power Limit : N/A
Enforced Power Limit : N/A
Min Power Limit : N/A
Max Power Limit : N/A
Power Samples
Duration : Not Found
Number of Samples : Not Found
Max : Not Found
Min : Not Found
Avg : Not Found
Kernel: 5.18.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=a7eb2963-e8e8-4c1f-8679-09b363ffa917 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 82N6 v: Legion 7 16ACHg6
serial: <superuser required> Chassis: type: 10 v: Legion 7 16ACHg6
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: GKCN50WW date: 11/24/2021
ID-1: BAT0 charge: 79.3 Wh (100.0%) condition: 79.3/80.0 Wh (99.2%)
volts: 17.3 min: 15.4 model: Celxpert L20C4PC1 type: Li-poly
serial: <filter> status: full cycles: 40
RAM: total: 31.27 GiB used: 7.24 GiB (23.2%)
RAM Report:
Info: model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 3 gen: 4 built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x50 (80) stepping: 0 microcode: 0xA50000C
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 2840 high: 3269 min/max: 400/4463 boost: enabled
scaling: driver: amd-pstate governor: schedutil cores: 1: 3051 2: 2990
3: 3269 4: 2988 5: 2216 6: 2910 7: 3245 8: 2790 9: 2855 10: 3089 11: 2668
12: 2565 13: 2775 14: 2535 15: 2793 16: 2703 bogomips: 102241
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
STIBP: always-on, RSB filling
Device-1: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
vendor: Lenovo driver: nvidia v: 510.73.05 alternate: nouveau,nvidia_drm
non-free: 515.xx+ status: current (as of 2022-06) arch: Ampere
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:24dc class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 191 s-size: 340x221mm (13.39x8.70")
s-diag: 406mm (15.97")
Monitor-1: DP-4 res: 2560x1600 dpi: 4064 size: 16x10mm (0.63x0.39")
diag: 19mm (0.74") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3080 Laptop GPU/PCIe/SSE2
v: 4.6.0 NVIDIA 510.73.05 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
pcie: bus-ID: 3-1:3 chip-ID: 2a45:0128 gen: 3 class-ID: 0300 speed: 8 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: Meizu HiFi DAC Headphone Amplifier type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.18.0-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 1000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2725
class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-4:2
chip-ID: 8087:0032 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.84 TiB used: 824.1 GiB (43.7%)
model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 44.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:1 vendor: Samsung
model: MZVLB1T0HBLR-000L2 size: 953.87 GiB block-size: physical: 512 B
rev: 3L1QEXF7 temp: 41.9 C scheme: GPT
ID-1: / raw-size: 150.65 GiB size: 147.22 GiB (97.73%)
used: 40.29 GiB (27.4%) fs: ext4 dev: /dev/nvme1n1p6 maj-min: 259:9
label: N/A uuid: a7eb2963-e8e8-4c1f-8679-09b363ffa917
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 43.7 MiB (17.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:4
label: SYSTEM uuid: 081B-B6FA
ID-3: /run/media/david/BOOT raw-size: 1024 MiB size: 973.4 MiB (95.06%)
used: 254.8 MiB (26.2%) fs: ext4 dev: /dev/nvme1n1p4 maj-min: 259:7
label: BOOT uuid: 11c7cb73-d896-4b0f-a3b3-3365af030190
ID-4: /run/media/david/Windows-SSD raw-size: 800 GiB
size: 800 GiB (100.00%) used: 478.25 GiB (59.8%) fs: ntfs
dev: /dev/nvme1n1p3 maj-min: 259:6 label: Windows-SSD
uuid: 52C41E2AC41E1139
ID-5: /run/media/david/Диск raw-size: 931.5 GiB
size: 931.5 GiB (100.00%) used: 305.27 GiB (32.8%) fs: ntfs
dev: /dev/nvme0n1p2 maj-min: 259:3 label: \xd0\x94\xd0\xb8\xd1\x81\xd0\xba
uuid: F24A4A094A49CAD5
ID-1: /dev/nvme0n1p1 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme1n1p2 maj-min: 259:5 size: 16 MiB fs: <superuser required>
ID-3: /dev/nvme1n1p5 maj-min: 259:8 size: 1.95 GiB fs: ntfs
label: WinRE_DRV uuid: 90EC1E7DEC1E5E32
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 3 rev: 2.1 speed: 480 Mb/s
Device-1: 1-2.1:4 info: Kingston HyperX Pulsefire Dart type: Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s power: 98mA
chip-ID: 0951:16e1 class-ID: 0300 serial: <filter>
Device-2: 1-2.3:5
info: Razer USA RC30-0315 Gaming Mouse [Basilisk X HyperSpeed]
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:0083 class-ID: 0300
Device-3: 1-4:3 info: Integrated Express ITE Device(8258) type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:c968 class-ID: 0301
Hub-3: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-4: 2-2:2 info: Genesys Logic GL3523 Hub ports: 3 rev: 3.2
speed: 5 Gb/s chip-ID: 05e3:0620 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:3 info: Meizu HiFi DAC Headphone Amplifier type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 2a45:0128 class-ID: 0300
Device-2: 3-4:2 info: Intel AX210 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0032
class-ID: e001
Hub-6: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 45 C
Processes: 395 Uptime: 3h 2m wakeups: 1 Init: systemd v: 250
default: graphical tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1
Packages: 1268 pacman: 1263 lib: 338 flatpak: 5 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.17
Did I do everything right?
and now the output of
glxinfo | grep server
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
first things first: i will not give any advice for “tuning” (in other words wrecking) your cards. everything you’ll do is on your own risk and if you end up with a smoking pc it’s your fault.
if your interested in wrecking your card check the internet for “linux nvidia power limit” etc… the main software that nvidia delivers with to set your card options is named nvidia-smi, you can search also for this. be aware that different options are only avaiable to different cards, there is no guarantee to anything. if you wanna try to cook eggs there are better ways.
fingers crossed and good luck.
I tried like this, “Changing power management limit is not supported for GPU: 00000000:01:00.0.”
I have a hardware power switch for the video card, maybe it needs to be fixed programmatically?
if you have to setup your card-bios, changing whatever card-switches etc. is described at your cards manual and it’s up to you to change anything. but in my honest: check and read the manuals before you start trickeling and fiddeling ending up with broken hardware.
there is no further advice from me.
Is all of the “NA” and “Not found” output normal for a fully recognized video card? I really wonder about that.
if the nvidia-powermanagement is disabled/not active then no data is avaiable.
please check the nvidia-manuals of the nvidia-driver for further details. it’s nvidia-software not linux-related.
So this may be the actual issue. He should check this first.
no it isn’t, the power-draw is recognized. but it’s up to him to check and validate all issues. i expect a playchild and a broken card in the end, period.
