Now on Kernel 6.3.3 the USB-ports on my Dell monitor (connected via USB-C) are’nt working anymore. Can’t find any errors in dmesg or journal.
PS: The ports (and the connected devices) appear, when I re-plug the monitor USB-C cable after login.
Could you post some usb related stuff from dmesg -w
? While connecting/disconnecting your monitor?
[250274.309020] usb 3-1: USB disconnect, device number 2
[250274.309025] usb 3-1.3: USB disconnect, device number 3
[250274.357699] xhci_hcd 0000:39:00.0: xHCI host controller not responding, assume dead
[250274.357712] xhci_hcd 0000:39:00.0: HC died; cleaning up
[250274.459373] xhci_hcd 0000:39:00.0: remove, state 4
[250274.459393] usb usb4: USB disconnect, device number 1
[250274.459767] xhci_hcd 0000:39:00.0: USB bus 4 deregistered
[250274.459776] xhci_hcd 0000:39:00.0: remove, state 1
[250274.459780] usb usb3: USB disconnect, device number 1
[250274.499058] usb 3-1.4: USB disconnect, device number 4
[250274.577769] usb 3-1.5: USB disconnect, device number 5
[250274.668446] xhci_hcd 0000:39:00.0: Host halt failed, -19
[250274.668476] xhci_hcd 0000:39:00.0: Host not accessible, reset failed.
[250274.668935] xhci_hcd 0000:39:00.0: USB bus 3 deregistered
[250274.672480] pci_bus 0000:02: Allocating resources
[250274.672539] pcieport 0000:02:01.0: bridge window [io 0x1000-0x0fff] to [bus 04-38] add_size 1000
[250274.672555] pcieport 0000:02:02.0: bridge window [io 0x1000-0x0fff] to [bus 39] add_size 1000
[250274.672567] pcieport 0000:02:02.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 39] add_size 200000 add_align 100000
[250274.672595] pcieport 0000:01:00.0: bridge window [io 0x1000-0x0fff] to [bus 02-39] add_size 2000
[250274.672623] pcieport 0000:01:00.0: BAR 13: no space for [io size 0x2000]
[250274.672632] pcieport 0000:01:00.0: BAR 13: failed to assign [io size 0x2000]
[250274.672642] pcieport 0000:01:00.0: BAR 13: no space for [io size 0x2000]
[250274.672650] pcieport 0000:01:00.0: BAR 13: failed to assign [io size 0x2000]
[250274.672682] pcieport 0000:02:02.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[250274.672690] pcieport 0000:02:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[250274.672712] pcieport 0000:02:01.0: BAR 13: no space for [io size 0x1000]
[250274.672719] pcieport 0000:02:01.0: BAR 13: failed to assign [io size 0x1000]
[250274.672726] pcieport 0000:02:02.0: BAR 13: no space for [io size 0x1000]
[250274.672733] pcieport 0000:02:02.0: BAR 13: failed to assign [io size 0x1000]
[250274.672759] pcieport 0000:02:02.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[250274.672766] pcieport 0000:02:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[250274.672774] pcieport 0000:02:02.0: BAR 13: no space for [io size 0x1000]
[250274.672795] pcieport 0000:02:02.0: BAR 13: failed to assign [io size 0x1000]
[250274.672803] pcieport 0000:02:01.0: BAR 13: no space for [io size 0x1000]
[250274.672811] pcieport 0000:02:01.0: BAR 13: failed to assign [io size 0x1000]
[250280.032483] pci 0000:39:00.0: [8086:15b5] type 00 class 0x0c0330
[250280.032513] pci 0000:39:00.0: reg 0x10: [mem 0xd9f00000-0xd9f0ffff]
[250280.032599] pci 0000:39:00.0: enabling Extended Tags
[250280.032731] pci 0000:39:00.0: supports D1 D2
[250280.032734] pci 0000:39:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[250280.032842] pci 0000:39:00.0: 8.000 Gb/s available PCIe bandwidth, limited by 2.5 GT/s PCIe x4 link at 0000:02:02.0 (capable of 31.504 Gb/s with 8.0 GT/s PCIe x4 link)
[250280.033119] pci_bus 0000:02: Allocating resources
[250280.033139] pcieport 0000:02:01.0: bridge window [io 0x1000-0x0fff] to [bus 04-38] add_size 1000
[250280.033145] pcieport 0000:02:02.0: bridge window [io 0x1000-0x0fff] to [bus 39] add_size 1000
[250280.033149] pcieport 0000:02:02.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 39] add_size 200000 add_align 100000
[250280.033155] pcieport 0000:01:00.0: bridge window [io 0x1000-0x0fff] to [bus 02-39] add_size 2000
[250280.033161] pcieport 0000:01:00.0: BAR 13: no space for [io size 0x2000]
[250280.033165] pcieport 0000:01:00.0: BAR 13: failed to assign [io size 0x2000]
[250280.033168] pcieport 0000:01:00.0: BAR 13: no space for [io size 0x2000]
[250280.033170] pcieport 0000:01:00.0: BAR 13: failed to assign [io size 0x2000]
[250280.033175] pcieport 0000:02:02.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[250280.033177] pcieport 0000:02:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[250280.033179] pcieport 0000:02:01.0: BAR 13: no space for [io size 0x1000]
[250280.033181] pcieport 0000:02:01.0: BAR 13: failed to assign [io size 0x1000]
[250280.033183] pcieport 0000:02:02.0: BAR 13: no space for [io size 0x1000]
[250280.033185] pcieport 0000:02:02.0: BAR 13: failed to assign [io size 0x1000]
[250280.033188] pcieport 0000:02:02.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[250280.033190] pcieport 0000:02:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[250280.033192] pcieport 0000:02:02.0: BAR 13: no space for [io size 0x1000]
[250280.033194] pcieport 0000:02:02.0: BAR 13: failed to assign [io size 0x1000]
[250280.033196] pcieport 0000:02:01.0: BAR 13: no space for [io size 0x1000]
[250280.033198] pcieport 0000:02:01.0: BAR 13: failed to assign [io size 0x1000]
[250280.033493] xhci_hcd 0000:39:00.0: xHCI Host Controller
[250280.033500] xhci_hcd 0000:39:00.0: new USB bus registered, assigned bus number 3
[250280.034653] xhci_hcd 0000:39:00.0: hcc params 0x200077c1 hci version 0x110 quirks 0x0000000200009810
[250280.034981] xhci_hcd 0000:39:00.0: xHCI Host Controller
[250280.034988] xhci_hcd 0000:39:00.0: new USB bus registered, assigned bus number 4
[250280.034994] xhci_hcd 0000:39:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[250280.035096] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.03
[250280.035101] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[250280.035103] usb usb3: Product: xHCI Host Controller
[250280.035105] usb usb3: Manufacturer: Linux 6.3.3-1-MANJARO xhci-hcd
[250280.035107] usb usb3: SerialNumber: 0000:39:00.0
[250280.035412] hub 3-0:1.0: USB hub found
[250280.035435] hub 3-0:1.0: 2 ports detected
[250280.036468] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.03
[250280.036473] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[250280.036476] usb usb4: Product: xHCI Host Controller
[250280.036479] usb usb4: Manufacturer: Linux 6.3.3-1-MANJARO xhci-hcd
[250280.036481] usb usb4: SerialNumber: 0000:39:00.0
[250280.036694] hub 4-0:1.0: USB hub found
[250280.036709] hub 4-0:1.0: 2 ports detected
[250280.287249] usb 3-1: new high-speed USB device number 2 using xhci_hcd
[250280.427589] usb 3-1: New USB device found, idVendor=413c, idProduct=8442, bcdDevice= 1.00
[250280.427607] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[250280.427614] usb 3-1: SerialNumber: 92080869BE36
[250280.432440] hub 3-1:1.0: USB hub found
[250280.432499] hub 3-1:1.0: 6 ports detected
[250280.713886] usb 3-1.3: new full-speed USB device number 3 using xhci_hcd
[250280.880272] usb 3-1.3: New USB device found, idVendor=047f, idProduct=c056, bcdDevice= 2.10
[250280.880287] usb 3-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[250280.880290] usb 3-1.3: Product: Plantronics Blackwire 3220 Series
[250280.880292] usb 3-1.3: Manufacturer: Plantronics
[250280.880295] usb 3-1.3: SerialNumber: AF09DBDB8D01394AB2148199A6267379
[250281.720507] usb 3-1.3: Warning! Unlikely big volume range (=8192), cval->res is probably wrong.
[250281.720519] usb 3-1.3: [11] FU [Sidetone Playback Volume] ch = 1, val = 0/8192/1
[250282.345600] input: Plantronics Plantronics Blackwire 3220 Series as /devices/pci0000:00/0000:00:1c.0/0000:01:00.0/0000:02:02.0/0000:39:00.0/usb3/3-1/3-1.3/3-1.3:1.3/0003:047F:C056.000F/input/input37
[250282.400846] plantronics 0003:047F:C056.000F: input,hiddev98,hidraw4: USB HID v1.11 Device [Plantronics Plantronics Blackwire 3220 Series] on usb-0000:39:00.0-1.3/input3
[250282.477108] usb 3-1.4: new high-speed USB device number 4 using xhci_hcd
[250283.324346] usb 3-1.4: New USB device found, idVendor=045e, idProduct=0840, bcdDevice= 2.15
[250283.324352] usb 3-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[250283.324354] usb 3-1.4: Product: Microsoft Modern Webcam
[250283.324356] usb 3-1.4: Manufacturer: Microsoft
[250283.324358] usb 3-1.4: SerialNumber: 0C33FR4215001N0
[250283.325501] usb 3-1.4: Found UVC 1.00 device Microsoft Modern Webcam (045e:0840)
[250283.705811] hid-generic 0003:045E:0840.0010: hiddev99,hidraw5: USB HID v1.11 Device [Microsoft Microsoft Modern Webcam] on usb-0000:39:00.0-1.4/input2
[250283.780342] usb 3-1.5: new high-speed USB device number 5 using xhci_hcd
[250283.870567] usb 3-1.5: New USB device found, idVendor=0451, idProduct=82ff, bcdDevice= 2.00
[250283.870574] usb 3-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[250283.872606] hid-generic 0003:0451:82FF.0011: hiddev100,hidraw6: USB HID v1.11 Device [HID 0451:82ff] on usb-0000:39:00.0-1.5/input0
[250285.134015] pci_bus 0000:02: Allocating resources
[250285.134035] pcieport 0000:02:01.0: bridge window [io 0x1000-0x0fff] to [bus 04-38] add_size 1000
[250285.134040] pcieport 0000:02:02.0: bridge window [io 0x1000-0x0fff] to [bus 39] add_size 1000
[250285.134043] pcieport 0000:02:02.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 39] add_size 200000 add_align 100000
[250285.134047] pcieport 0000:01:00.0: bridge window [io 0x1000-0x0fff] to [bus 02-39] add_size 2000
[250285.134052] pcieport 0000:01:00.0: BAR 13: no space for [io size 0x2000]
[250285.134054] pcieport 0000:01:00.0: BAR 13: failed to assign [io size 0x2000]
[250285.134057] pcieport 0000:01:00.0: BAR 13: no space for [io size 0x2000]
[250285.134059] pcieport 0000:01:00.0: BAR 13: failed to assign [io size 0x2000]
[250285.134064] pcieport 0000:02:02.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[250285.134066] pcieport 0000:02:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[250285.134068] pcieport 0000:02:01.0: BAR 13: no space for [io size 0x1000]
[250285.134070] pcieport 0000:02:01.0: BAR 13: failed to assign [io size 0x1000]
[250285.134072] pcieport 0000:02:02.0: BAR 13: no space for [io size 0x1000]
[250285.134074] pcieport 0000:02:02.0: BAR 13: failed to assign [io size 0x1000]
[250285.134077] pcieport 0000:02:02.0: BAR 15: no space for [mem size 0x00200000 64bit pref]
[250285.134079] pcieport 0000:02:02.0: BAR 15: failed to assign [mem size 0x00200000 64bit pref]
[250285.134081] pcieport 0000:02:02.0: BAR 13: no space for [io size 0x1000]
[250285.134083] pcieport 0000:02:02.0: BAR 13: failed to assign [io size 0x1000]
[250285.134085] pcieport 0000:02:01.0: BAR 13: no space for [io size 0x1000]
[250285.134086] pcieport 0000:02:01.0: BAR 13: failed to assign [io size 0x1000]
This is disconnect and connect. These “no space to assign” and “BAR n” messages I remember since 2018. These should be normal.
