The system freezes for no apparent reason
Description:
  1. Periodically, the entire system freezes, and no buttons or panels work. At this time, the CPU load is 2-5%, the memory is used by 10-20%. Swapfs works.
    Only a hard reboot of the system helps - by holding down the shutdown key.
  2. And sometimes only the control panel hangs, restarting plasma helps (killall plasmashell && kstart5 plasmashell)
Steps to reproduce:
I did not find any dependencies for hanging both the panel and the entire system.
Info about system:
  • Laptop: Razer Blade Stealth 13 RZ09-0327 (2020 year)
  • Operating System: Manjaro Linux
  • KDE Plasma Version: 5.20.5
  • KDE Frameworks Version: 5.78.0
  • Qt Version: 5.15.2
  • Kernel Version: 5.10.7-3-MANJARO
  • OS Type: 64-bit
  • Processors: 8 × 11th Gen Intel® Core™ i7-1165G7 @ 2.80GHz
  • Memory: 15.4 Gb of RAM
  • Graphics Processors: Mesa Intel® Xe Graphics; NVIDIA GeForce GTX 1650 Ti Max-Q (4GB GDDR6 VRAM)
The system freezes (problem 1):
(journalctl -b -1 -p3)
The control panel hangs (problem 2):
(journalctl -b 0 -p3)
It might be the kernel. Version 5.10 is known to be buggy (https://forum.manjaro.org/t/kernel-5-10-7-freezes-after-some-time-not-nvidia-related/50158). I had a similar problem and it went away when I switched to 5.4.
