Kernel 5.10.7 freezes after some time -- NOT nvidia related
Good morning,
Since the kernel 5.9 is marked as end of life, I installed 5.10 as well. When I boot on 5.10.7 (I did the last stable update), it often freezes completely after a while, nothing works including ctrl-alt-fX, the music loops over a few seconds, closing the lid doesn’t do anything, and the fan ramps up after a while. The only thing I can do is push on the power button for a long time. I do not have nvidia drivers or an nvidia card, so that’s not it either. It seems similar to Kernel 5.10 panic (maybe nvidia related) but the log seems completely different.
Here is the relevant time from the output from journalctl -p 3, the suspend line probably comes from closing the lid, and the wpa_supplicant lines are something that often appears on my laptop so they are probably unrelated.
jan 23 11:18:32 Nightingale kernel: Freezing of tasks failed after 20.005 seconds (1 tasks refusing to freeze, wq_busy=0):
jan 23 11:18:53 Nightingale kernel: Freezing of tasks failed after 20.005 seconds (1 tasks refusing to freeze, wq_busy=0):
jan 23 11:18:53 Nightingale systemd-sleep[7909]: Failed to suspend system. System resumed again: Device or resource busy
jan 23 11:18:53 Nightingale systemd[1]: Failed to start Suspend.
jan 23 11:18:53 Nightingale wpa_supplicant[756]: nl80211: kernel reports: Attribute failed policy validation
jan 23 11:18:53 Nightingale wpa_supplicant[756]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
jan 23 11:18:53 Nightingale wpa_supplicant[756]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
Is this a known issue? Can it be fixed or is it (for now) linked to an unstable kernel and I should just boot on 5.9?
Here is some more stuff that may or may not be useful:
Output of inxi -Fazy
  Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
  root=UUID=26505fa8-bb0c-4ae5-9de4-c22a5dcfa957 rw quiet apparmor=1
  Desktop: Xfce 4.16.0 wm: awesome 4.3 dm: LightDM 1.30.0
  Distro: Manjaro Linux
  Type: Laptop System: Dell product: Inspiron 15 5501 v: N/A serial: <filter>
  Chassis: type: 10 serial: <filter>
  Mobo: Dell model: 06TT8N v: A00 serial: <filter> UEFI: Dell v: 1.5.3
  date: 12/18/2020
  ID-1: BAT0 charge: 53.0 Wh condition: 53.0/53.0 Wh (100%) volts: 17.0/15.0
  model: SMP DELL 9077G07 type: Li-poly serial: <filter> status: Full
  Info: Quad Core model: Intel Core i7-1065G7 bits: 64 type: MT MCP
  arch: Ice Lake family: 6 model-id: 7E (126) stepping: 5 microcode: A0
  L2 cache: 8 MiB
  bogomips: 23968
  Speed: 1255 MHz min/max: 400/3900 MHz Core speeds (MHz): 1: 1255 2: 1300
  3: 1300 4: 1241 5: 614 6: 1302 7: 1300 8: 1301
  Device-1: Intel Iris Plus Graphics G7 vendor: Dell driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:8a52
  Device-2: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
  bus ID: 3-6:3 chip ID: 0bda:565a serial: <filter>
  Display: x11 server: X.Org 1.20.10 compositor: compton driver: loaded: intel
  unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5")
  diag: 389mm (15.3")
  OpenGL: renderer: Mesa Intel Iris Plus Graphics (ICL GT2) v: 4.6 Mesa 20.3.3
  direct render: Yes
  Device-1: Intel Smart Sound Audio vendor: Dell driver: snd_hda_intel
  v: kernel alternate: snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:34c8
  Sound Server: ALSA v: k5.9.16-1-MANJARO
  Device-1: Intel Killer Wi-Fi 6 AX1650i 160MHz Wireless Network Adapter
  driver: iwlwifi v: kernel port: 3000 bus ID: 00:14.3 chip ID: 8086:34f0
  Local Storage: total: 476.94 GiB used: 271.91 GiB (57.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba
  model: KBG40ZNS512G NVMe KIOXIA 512GB size: 476.94 GiB block size:
  physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter>
  rev: 10410104 temp: 29.9 C
  ID-1: / raw size: 99.5 GiB size: 97.44 GiB (97.93%) used: 51.44 GiB (52.8%)
  fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%)
  used: 308 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p9 maj-min: 259:9
  System Temperatures: cpu: 50.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
  Processes: 229 Uptime: 35m wakeups: 4916 Memory: 15.41 GiB
  used: 3.52 GiB (22.9%) Init: systemd v: 247 Compilers: gcc: 10.2.0
  clang: 11.0.1 Packages: pacman: 1855 lib: 437 flatpak: 0 Shell: Zsh v: 5.8
  running in: xfce4-terminal inxi: 3.2.02
Output of journalctl (only when it froze). I believe the first entry is when I unplugged my mouse after realizing it didn’t work.
jan 23 11:17:47 Nightingale kernel: usb 3-1: USB disconnect, device number 2
jan 23 11:17:54 Nightingale kernel: usb 3-1: new low-speed USB device number 5 using xhci_hcd
jan 23 11:17:54 Nightingale kernel: usb 3-1: New USB device found, idVendor=1241, idProduct=1166, bcdDevice= 2.70
jan 23 11:17:54 Nightingale kernel: usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
jan 23 11:17:54 Nightingale kernel: input: HID 1241:1166 as /devices/pci0000:00/0000:00:14.0/usb3/3-1/3-1:1.0/0003:1241:1166.0004/input/input27
jan 23 11:17:54 Nightingale kernel: hid-generic 0003:1241:1166.0004: input,hidraw1: USB HID v1.10 Mouse [HID 1241:1166] on usb-0000:00:14.0-1/input0
jan 23 11:17:54 Nightingale mtp-probe[7811]: checking bus 3, device 5: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1"
jan 23 11:17:54 Nightingale mtp-probe[7811]: bus: 3, device: 5 was not an MTP device
jan 23 11:17:54 Nightingale upowerd[972]: treating change event as add on /sys/devices/pci0000:00/0000:00:14.0/usb3/3-1
jan 23 11:17:54 Nightingale mtp-probe[7855]: checking bus 3, device 5: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-1"
jan 23 11:17:54 Nightingale mtp-probe[7855]: bus: 3, device: 5 was not an MTP device
jan 23 11:18:02 Nightingale systemd-logind[490]: Power key pressed.
jan 23 11:18:07 Nightingale systemd-logind[490]: Lid closed.
jan 23 11:18:07 Nightingale systemd-logind[490]: Suspending...
jan 23 11:18:07 Nightingale ModemManager[633]: <info>  [sleep-monitor] system is about to suspend
jan 23 11:18:07 Nightingale NetworkManager[486]: <info>  [1611397087.6015] manager: sleep: sleep requested (sleeping: no  enabled: yes)
jan 23 11:18:07 Nightingale NetworkManager[486]: <info>  [1611397087.6015] device (p2p-dev-wlp0s20f3): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
jan 23 11:18:07 Nightingale NetworkManager[486]: <info>  [1611397087.6018] manager: NetworkManager state is now ASLEEP
jan 23 11:18:07 Nightingale NetworkManager[486]: <info>  [1611397087.6019] device (wlp0s20f3): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
jan 23 11:18:07 Nightingale dbus-daemon[484]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=486 comm="/usr/bin/NetworkManager --no-daemon ")
jan 23 11:18:07 Nightingale systemd[1]: Starting Network Manager Script Dispatcher Service...
jan 23 11:18:07 Nightingale dbus-daemon[484]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
jan 23 11:18:07 Nightingale systemd[1]: Started Network Manager Script Dispatcher Service.
jan 23 11:18:07 Nightingale audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 11:18:07 Nightingale kernel: audit: type=1130 audit(1611397087.605:127): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 11:18:07 Nightingale kernel: wlp0s20f3: deauthenticating from 74:42:7f:1e:bb:bb by local choice (Reason: 3=DEAUTH_LEAVING)
jan 23 11:18:07 Nightingale wpa_supplicant[756]: wlp0s20f3: CTRL-EVENT-DISCONNECTED bssid=74:42:7f:1e:bb:bb reason=3 locally_generated=1
jan 23 11:18:07 Nightingale NetworkManager[486]: <info>  [1611397087.6742] device (wlp0s20f3): supplicant interface state: completed -> disconnected
jan 23 11:18:07 Nightingale NetworkManager[486]: <info>  [1611397087.6744] device (wlp0s20f3): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
jan 23 11:18:07 Nightingale avahi-daemon[482]: Withdrawing address record for fe80::4239:7826:1d1a:fa20 on wlp0s20f3.
jan 23 11:18:07 Nightingale avahi-daemon[482]: Leaving mDNS multicast group on interface wlp0s20f3.IPv6 with address fe80::4239:7826:1d1a:fa20.
jan 23 11:18:07 Nightingale avahi-daemon[482]: Interface wlp0s20f3.IPv6 no longer relevant for mDNS.
jan 23 11:18:07 Nightingale NetworkManager[486]: <info>  [1611397087.7000] dhcp4 (wlp0s20f3): canceled DHCP transaction
jan 23 11:18:07 Nightingale NetworkManager[486]: <info>  [1611397087.7000] dhcp4 (wlp0s20f3): state changed bound -> done
jan 23 11:18:07 Nightingale avahi-daemon[482]: Interface wlp0s20f3.IPv4 no longer relevant for mDNS.
jan 23 11:18:07 Nightingale avahi-daemon[482]: Leaving mDNS multicast group on interface wlp0s20f3.IPv4 with address 192.168.178.30.
jan 23 11:18:07 Nightingale avahi-daemon[482]: Withdrawing address record for 192.168.178.30 on wlp0s20f3.
jan 23 11:18:07 Nightingale NetworkManager[486]: <info>  [1611397087.7149] device (wlp0s20f3): set-hw-addr: set MAC address to 3E:A1:CA:33:33:8F (scanning)
jan 23 11:18:07 Nightingale avahi-daemon[482]: Joining mDNS multicast group on interface wlp0s20f3.IPv4 with address 192.168.178.30.
jan 23 11:18:07 Nightingale avahi-daemon[482]: New relevant interface wlp0s20f3.IPv4 for mDNS.
jan 23 11:18:07 Nightingale avahi-daemon[482]: Registering new address record for 192.168.178.30 on wlp0s20f3.IPv4.
jan 23 11:18:07 Nightingale NetworkManager[486]: <info>  [1611397087.9035] dns-mgr: Removing DNS information from /usr/bin/resolvconf
jan 23 11:18:07 Nightingale avahi-daemon[482]: Got SIGHUP, reloading.
jan 23 11:18:07 Nightingale avahi-daemon[482]: No service file found in /etc/avahi/services.
jan 23 11:18:07 Nightingale NetworkManager[486]: <info>  [1611397087.9282] device (wlp0s20f3): supplicant interface state: disconnected -> interface_disabled
jan 23 11:18:07 Nightingale NetworkManager[486]: <info>  [1611397087.9282] device (wlp0s20f3): supplicant interface state: interface_disabled -> disconnected
jan 23 11:18:07 Nightingale NetworkManager[486]: <info>  [1611397087.9283] device (wlp0s20f3): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
jan 23 11:18:07 Nightingale NetworkManager[486]: <info>  [1611397087.9432] device (wlp0s20f3): set-hw-addr: reset MAC address to 94:E7:0B:BD:2F:B3 (unmanage)
jan 23 11:18:08 Nightingale wpa_supplicant[756]: nl80211: deinit ifname=wlp0s20f3 disabled_11b_rates=0
jan 23 11:18:12 Nightingale systemd-logind[490]: Delay lock is active (UID 1000/vogu, PID 1090/light-locker) but inhibitor timeout is reached.
jan 23 11:18:12 Nightingale systemd[1]: Reached target Sleep.
jan 23 11:18:12 Nightingale systemd[1]: Starting Suspend...
jan 23 11:18:12 Nightingale systemd-sleep[7909]: Suspending system...
jan 23 11:18:12 Nightingale kernel: PM: suspend entry (s2idle)
jan 23 11:18:32 Nightingale kernel: Filesystems sync: 0.007 seconds
jan 23 11:18:32 Nightingale kernel: Freezing user space processes ...
jan 23 11:18:32 Nightingale kernel: task:Xorg            state:R  running task     stack:    0 pid:  583 ppid:   529 flags:0x00404084
jan 23 11:18:32 Nightingale kernel: Call Trace:
jan 23 11:18:32 Nightingale kernel:  ? irq_exit_rcu+0x4c/0xd0
jan 23 11:18:32 Nightingale kernel:  ? sysvec_apic_timer_interrupt+0x36/0x80
jan 23 11:18:32 Nightingale kernel:  ? asm_sysvec_apic_timer_interrupt+0x12/0x20
jan 23 11:18:32 Nightingale kernel:  ? sched_clock+0x5/0x10
jan 23 11:18:32 Nightingale kernel:  ? sched_clock_cpu+0xc/0xb0
jan 23 11:18:32 Nightingale kernel:  ? sysvec_reschedule_ipi+0x37/0x110
jan 23 11:18:32 Nightingale kernel:  ? asm_sysvec_reschedule_ipi+0x12/0x20
jan 23 11:18:32 Nightingale kernel:  ? __i915_active_wait+0x3f/0xf0 [i915]
jan 23 11:18:32 Nightingale kernel:  ? wait_for_completion+0xd2/0x100
jan 23 11:18:32 Nightingale kernel:  ? complete+0x18/0x40
jan 23 11:18:32 Nightingale kernel:  ? rcu_barrier+0x17a/0x200
jan 23 11:18:32 Nightingale kernel:  ? i915_gem_object_unbind+0x2b2/0x3a0 [i915]
jan 23 11:18:32 Nightingale kernel:  ? i915_gem_set_caching_ioctl+0x155/0x1a0 [i915]
jan 23 11:18:32 Nightingale kernel:  ? i915_gem_get_caching_ioctl+0x90/0x90 [i915]
jan 23 11:18:32 Nightingale kernel:  ? drm_ioctl_kernel+0xb2/0x100 [drm]
jan 23 11:18:32 Nightingale kernel:  ? drm_ioctl+0x215/0x390 [drm]
jan 23 11:18:32 Nightingale kernel:  ? __x64_sys_ioctl+0x83/0xb0
jan 23 11:18:32 Nightingale kernel:  ? do_syscall_64+0x33/0x40
jan 23 11:18:32 Nightingale kernel:  ? entry_SYSCALL_64_after_hwframe+0x44/0xa9
jan 23 11:18:32 Nightingale kernel: OOM killer enabled.
jan 23 11:18:32 Nightingale kernel: Restarting tasks ... done.
jan 23 11:18:32 Nightingale systemd-logind[490]: Lid opened.
jan 23 11:18:32 Nightingale audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 11:18:33 Nightingale systemd[1]: NetworkManager-dispatcher.service: Succeeded.
jan 23 11:18:33 Nightingale kernel: audit: type=1131 audit(1611397112.999:128): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 11:18:53 Nightingale kernel: PM: suspend exit
jan 23 11:18:53 Nightingale kernel: PM: suspend entry (s2idle)
jan 23 11:18:53 Nightingale kernel: Filesystems sync: 0.002 seconds
jan 23 11:18:53 Nightingale kernel: Freezing user space processes ...
jan 23 11:18:53 Nightingale kernel: task:Xorg            state:R  running task     stack:    0 pid:  583 ppid:   529 flags:0x00404084
jan 23 11:18:53 Nightingale kernel: Call Trace:
jan 23 11:18:53 Nightingale kernel:  ? sched_clock_cpu+0xc/0xb0
jan 23 11:18:53 Nightingale kernel:  ? irqtime_account_irq+0x32/0xa0
jan 23 11:18:53 Nightingale kernel:  ? irq_exit_rcu+0x4c/0xd0
jan 23 11:18:53 Nightingale kernel:  ? sysvec_thermal+0x36/0x80
jan 23 11:18:53 Nightingale kernel:  ? sched_clock+0x5/0x10
jan 23 11:18:53 Nightingale kernel:  ? sysvec_reschedule_ipi+0x37/0x110
jan 23 11:18:53 Nightingale kernel:  ? asm_sysvec_reschedule_ipi+0x12/0x20
jan 23 11:18:53 Nightingale kernel:  ? __i915_active_wait+0x3f/0xf0 [i915]
jan 23 11:18:53 Nightingale kernel:  ? rcu_barrier+0x17a/0x200
jan 23 11:18:53 Nightingale kernel:  ? i915_gem_object_unbind+0x2b2/0x3a0 [i915]
jan 23 11:18:53 Nightingale kernel:  ? i915_gem_set_caching_ioctl+0x155/0x1a0 [i915]
jan 23 11:18:53 Nightingale kernel:  ? i915_gem_get_caching_ioctl+0x90/0x90 [i915]
jan 23 11:18:53 Nightingale kernel:  ? drm_ioctl_kernel+0xb2/0x100 [drm]
jan 23 11:18:53 Nightingale kernel:  ? drm_ioctl+0x215/0x390 [drm]
jan 23 11:18:53 Nightingale kernel:  ? __x64_sys_ioctl+0x83/0xb0
jan 23 11:18:53 Nightingale kernel:  ? do_syscall_64+0x33/0x40
jan 23 11:18:53 Nightingale kernel:  ? entry_SYSCALL_64_after_hwframe+0x44/0xa9
jan 23 11:18:53 Nightingale kernel: OOM killer enabled.
jan 23 11:18:53 Nightingale rtkit-daemon[1105]: The canary thread is apparently starving. Taking action.
jan 23 11:18:53 Nightingale rtkit-daemon[1105]: Demoting known real-time threads.
jan 23 11:18:53 Nightingale rtkit-daemon[1105]: Successfully demoted thread 2580 of process 2464.
jan 23 11:18:53 Nightingale rtkit-daemon[1105]: Successfully demoted thread 2316 of process 2227.
jan 23 11:18:53 Nightingale rtkit-daemon[1105]: Successfully demoted thread 1218 of process 1216.
jan 23 11:18:53 Nightingale rtkit-daemon[1105]: Successfully demoted thread 1216 of process 1216.
jan 23 11:18:53 Nightingale rtkit-daemon[1105]: Successfully demoted thread 1214 of process 1213.
jan 23 11:18:53 Nightingale rtkit-daemon[1105]: Successfully demoted thread 1213 of process 1213.
jan 23 11:18:53 Nightingale rtkit-daemon[1105]: Successfully demoted thread 1222 of process 1079.
jan 23 11:18:53 Nightingale rtkit-daemon[1105]: Successfully demoted thread 1215 of process 1079.
jan 23 11:18:53 Nightingale rtkit-daemon[1105]: Successfully demoted thread 1079 of process 1079.
jan 23 11:18:53 Nightingale rtkit-daemon[1105]: Demoted 9 threads.
jan 23 11:18:53 Nightingale kernel: Restarting tasks ... done.
jan 23 11:18:53 Nightingale systemd[1]: systemd-suspend.service: Main process exited, code=exited, status=1/FAILURE
jan 23 11:18:53 Nightingale systemd[1]: systemd-suspend.service: Failed with result 'exit-code'.
jan 23 11:18:53 Nightingale systemd[1]: Dependency failed for Suspend.
jan 23 11:18:53 Nightingale audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
jan 23 11:18:53 Nightingale systemd[1]: suspend.target: Job suspend.target/start failed with result 'dependency'.
jan 23 11:18:53 Nightingale systemd[1]: Stopped target Sleep.
jan 23 11:18:53 Nightingale systemd-logind[490]: Operation 'sleep' finished.
jan 23 11:18:53 Nightingale ModemManager[633]: <info>  [sleep-monitor] system is resuming
jan 23 11:18:53 Nightingale NetworkManager[486]: <info>  [1611397133.2609] manager: sleep: wake requested (sleeping: yes  enabled: yes)
jan 23 11:18:53 Nightingale NetworkManager[486]: <info>  [1611397133.2610] device (wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
jan 23 11:18:53 Nightingale NetworkManager[486]: <info>  [1611397133.2621] device (p2p-dev-wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'managed')
jan 23 11:18:53 Nightingale NetworkManager[486]: <info>  [1611397133.2625] manager: NetworkManager state is now DISCONNECTED
jan 23 11:18:53 Nightingale kernel: audit: type=1130 audit(1611397133.259:129): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
jan 23 11:18:53 Nightingale wpa_supplicant[756]: P2P: Failed to enable P2P Device interface
jan 23 11:18:53 Nightingale wpa_supplicant[756]: dbus: fill_dict_with_properties dbus_interface=fi.w1.wpa_supplicant1.Interface.P2PDevice dbus_property=P2PDeviceConfig getter failed
jan 23 11:18:53 Nightingale NetworkManager[486]: <info>  [1611397133.3073] device (wlp0s20f3): supplicant interface state: internal-starting -> disconnected
jan 23 11:18:53 Nightingale NetworkManager[486]: <info>  [1611397133.3074] device (p2p-dev-wlp0s20f3): state change: unavailable -> unmanaged (reason 'removed', sys-iface-state: 'removed')
jan 23 11:18:53 Nightingale NetworkManager[486]: <info>  [1611397133.3083] Wi-Fi P2P device controlled by interface wlp0s20f3 created
jan 23 11:18:53 Nightingale NetworkManager[486]: <info>  [1611397133.3086] manager: (p2p-dev-wlp0s20f3): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/4)
jan 23 11:18:53 Nightingale NetworkManager[486]: <info>  [1611397133.3090] device (p2p-dev-wlp0s20f3): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
jan 23 11:18:53 Nightingale NetworkManager[486]: <info>  [1611397133.3102] device (wlp0s20f3): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
jan 23 11:18:53 Nightingale NetworkManager[486]: <info>  [1611397133.3111] device (p2p-dev-wlp0s20f3): state change: unavailable -> disconnected (reason 'none', sys-iface-state: 'managed')
jan 23 11:18:53 Nightingale NetworkManager[486]: <warn>  [1611397133.3121] sup-iface[87a95bc5d707888d,1,wlp0s20f3]: call-p2p-cancel: failed with P2P cancel failed
jan 23 11:18:55 Nightingale ModemManager[633]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.3': not supported by any plugin
jan 23 11:18:56 Nightingale wpa_supplicant[756]: wlp0s20f3: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=DE
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2051] policy: auto-activating connection 'FRITZ!Box 7530 PN' (545253f2-a886-4388-915a-f0969fc3881a)
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2054] device (wlp0s20f3): Activation: starting connection 'FRITZ!Box 7530 PN' (545253f2-a886-4388-915a-f0969fc3881a)
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2055] device (wlp0s20f3): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2058] manager: NetworkManager state is now CONNECTING
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2061] device (wlp0s20f3): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2063] device (wlp0s20f3): Activation: (wifi) access point 'FRITZ!Box 7530 PN' has security, but secrets are required.
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2063] device (wlp0s20f3): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2079] device (wlp0s20f3): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2082] device (wlp0s20f3): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2084] device (wlp0s20f3): Activation: (wifi) connection 'FRITZ!Box 7530 PN' has security, and secrets exist.  No new secrets needed.
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2084] Config: added 'ssid' value 'FRITZ!Box 7530 PN'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2084] Config: added 'scan_ssid' value '1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2084] Config: added 'bgscan' value 'simple:30:-70:86400'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2084] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2084] Config: added 'auth_alg' value 'OPEN'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2084] Config: added 'psk' value '<hidden>'
jan 23 11:18:59 Nightingale wpa_supplicant[756]: wlp0s20f3: SME: Trying to authenticate with 74:42:7f:1e:bb:ba (SSID='FRITZ!Box 7530 PN' freq=2437 MHz)
jan 23 11:18:59 Nightingale kernel: wlp0s20f3: authenticate with 74:42:7f:1e:bb:ba
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2163] device (wlp0s20f3): supplicant interface state: disconnected -> authenticating
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2163] device (p2p-dev-wlp0s20f3): supplicant management interface state: disconnected -> authenticating
jan 23 11:18:59 Nightingale kernel: wlp0s20f3: send auth to 74:42:7f:1e:bb:ba (try 1/3)
jan 23 11:18:59 Nightingale wpa_supplicant[756]: wlp0s20f3: Trying to associate with 74:42:7f:1e:bb:ba (SSID='FRITZ!Box 7530 PN' freq=2437 MHz)
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2431] device (wlp0s20f3): supplicant interface state: authenticating -> associating
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2431] device (p2p-dev-wlp0s20f3): supplicant management interface state: authenticating -> associating
jan 23 11:18:59 Nightingale kernel: wlp0s20f3: authenticated
jan 23 11:18:59 Nightingale kernel: wlp0s20f3: associate with 74:42:7f:1e:bb:ba (try 1/3)
jan 23 11:18:59 Nightingale kernel: wlp0s20f3: RX AssocResp from 74:42:7f:1e:bb:ba (capab=0x1431 status=0 aid=2)
jan 23 11:18:59 Nightingale wpa_supplicant[756]: wlp0s20f3: Associated with 74:42:7f:1e:bb:ba
jan 23 11:18:59 Nightingale wpa_supplicant[756]: wlp0s20f3: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
jan 23 11:18:59 Nightingale kernel: wlp0s20f3: associated
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2613] device (wlp0s20f3): supplicant interface state: associating -> 4way_handshake
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2613] device (p2p-dev-wlp0s20f3): supplicant management interface state: associating -> 4way_handshake
jan 23 11:18:59 Nightingale wpa_supplicant[756]: wlp0s20f3: WPA: Key negotiation completed with 74:42:7f:1e:bb:ba [PTK=CCMP GTK=CCMP]
jan 23 11:18:59 Nightingale wpa_supplicant[756]: wlp0s20f3: CTRL-EVENT-CONNECTED - Connection to 74:42:7f:1e:bb:ba completed [id=0 id_str=]
jan 23 11:18:59 Nightingale kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f3: link becomes ready
jan 23 11:18:59 Nightingale wpa_supplicant[756]: wlp0s20f3: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-71 noise=9999 txrate=0
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2820] device (wlp0s20f3): supplicant interface state: 4way_handshake -> completed
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2821] device (wlp0s20f3): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "FRITZ!Box 7530 PN"
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2821] device (p2p-dev-wlp0s20f3): supplicant management interface state: 4way_handshake -> completed
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2823] device (wlp0s20f3): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.2830] dhcp4 (wlp0s20f3): activation: beginning transaction (timeout in 45 seconds)
jan 23 11:18:59 Nightingale avahi-daemon[482]: Joining mDNS multicast group on interface wlp0s20f3.IPv6 with address fe80::4239:7826:1d1a:fa20.
jan 23 11:18:59 Nightingale avahi-daemon[482]: New relevant interface wlp0s20f3.IPv6 for mDNS.
jan 23 11:18:59 Nightingale avahi-daemon[482]: Registering new address record for fe80::4239:7826:1d1a:fa20 on wlp0s20f3.*.
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3057] dhcp4 (wlp0s20f3): option dhcp_lease_time      => '86400'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3058] dhcp4 (wlp0s20f3): option domain_name          => 'fritz.box'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3058] dhcp4 (wlp0s20f3): option domain_name_servers  => '192.168.178.1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3058] dhcp4 (wlp0s20f3): option expiry               => '1611483539'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3058] dhcp4 (wlp0s20f3): option ip_address           => '192.168.178.30'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3058] dhcp4 (wlp0s20f3): option next_server          => '192.168.178.1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3058] dhcp4 (wlp0s20f3): option ntp_servers          => '192.168.178.1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3059] dhcp4 (wlp0s20f3): option requested_broadcast_address => '1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3059] dhcp4 (wlp0s20f3): option requested_domain_name => '1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3059] dhcp4 (wlp0s20f3): option requested_domain_name_servers => '1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3059] dhcp4 (wlp0s20f3): option requested_domain_search => '1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3059] dhcp4 (wlp0s20f3): option requested_host_name  => '1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3059] dhcp4 (wlp0s20f3): option requested_interface_mtu => '1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3059] dhcp4 (wlp0s20f3): option requested_ms_classless_static_routes => '1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3060] dhcp4 (wlp0s20f3): option requested_nis_domain => '1'
jan 23 11:18:59 Nightingale avahi-daemon[482]: Joining mDNS multicast group on interface wlp0s20f3.IPv4 with address 192.168.178.30.
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3060] dhcp4 (wlp0s20f3): option requested_nis_servers => '1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3060] dhcp4 (wlp0s20f3): option requested_ntp_servers => '1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3060] dhcp4 (wlp0s20f3): option requested_rfc3442_classless_static_routes => '1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3060] dhcp4 (wlp0s20f3): option requested_root_path  => '1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3060] dhcp4 (wlp0s20f3): option requested_routers    => '1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3061] dhcp4 (wlp0s20f3): option requested_static_routes => '1'
jan 23 11:18:59 Nightingale avahi-daemon[482]: New relevant interface wlp0s20f3.IPv4 for mDNS.
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3061] dhcp4 (wlp0s20f3): option requested_subnet_mask => '1'
jan 23 11:18:59 Nightingale avahi-daemon[482]: Registering new address record for 192.168.178.30 on wlp0s20f3.IPv4.
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3061] dhcp4 (wlp0s20f3): option requested_time_offset => '1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3061] dhcp4 (wlp0s20f3): option requested_wpad       => '1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3061] dhcp4 (wlp0s20f3): option routers              => '192.168.178.1'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3061] dhcp4 (wlp0s20f3): option subnet_mask          => '255.255.255.0'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3062] dhcp4 (wlp0s20f3): state changed unknown -> bound
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3089] device (wlp0s20f3): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
jan 23 11:18:59 Nightingale dbus-daemon[484]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.4' (uid=0 pid=486 comm="/usr/bin/NetworkManager --no-daemon ")
jan 23 11:18:59 Nightingale systemd[1]: Starting Network Manager Script Dispatcher Service...
jan 23 11:18:59 Nightingale dbus-daemon[484]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
jan 23 11:18:59 Nightingale systemd[1]: Started Network Manager Script Dispatcher Service.
jan 23 11:18:59 Nightingale audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3154] device (wlp0s20f3): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3156] device (wlp0s20f3): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3159] manager: NetworkManager state is now CONNECTED_LOCAL
jan 23 11:18:59 Nightingale kernel: audit: type=1130 audit(1611397139.313:130): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3175] manager: NetworkManager state is now CONNECTED_SITE
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3176] policy: set 'FRITZ!Box 7530 PN' (wlp0s20f3) as default for IPv4 routing and DNS
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3178] dns-mgr: Writing DNS information to /usr/bin/resolvconf
jan 23 11:18:59 Nightingale kernel: wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 74:42:7f:1e:bb:ba
jan 23 11:18:59 Nightingale avahi-daemon[482]: Got SIGHUP, reloading.
jan 23 11:18:59 Nightingale avahi-daemon[482]: No service file found in /etc/avahi/services.
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.3446] device (wlp0s20f3): Activation: successful, device activated.
jan 23 11:18:59 Nightingale NetworkManager[486]: <info>  [1611397139.5038] manager: NetworkManager state is now CONNECTED_GLOBAL
jan 23 11:19:02 Nightingale systemd-logind[490]: Power key pressed.
jan 23 11:19:04 Nightingale systemd-logind[490]: Power key pressed.
jan 23 11:19:09 Nightingale systemd[1]: NetworkManager-dispatcher.service: Succeeded.
jan 23 11:19:09 Nightingale audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 11:19:09 Nightingale kernel: audit: type=1131 audit(1611397149.953:131): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jan 23 11:19:16 Nightingale systemd-logind[490]: Power key pressed.
Kernel 5.10 is unstable at the moment, there are a few posts about this.
Install 5.4 LTS for the time being.
Yeah, apparently lots of people we are having the same problem, with very different HWs. LTS kernel works fine at the moment.
the same issue
https://forum.manjaro.org/t/manjaro-freezes-randomly-everytime/50364
https://forum.manjaro.org/t/manjaro-freezes-several-times-a-day/50389
In both the posts Intel graphics and kernel 5.10 is mentioned, maybe the new kernel breaks with Intel graphics :thinking:
Might be related to my problem
So I am not the only one
Thanks, I’ll just avoid 5.10 for now then, good to know.
