The system freezes for a while when turning on a video or when running a browser
After the update that was 05-03-2025, my Manjaro KDE Plasma system began to freeze for a while:
  • if a video player was open before;
  • if a tab was open in the browser where a video was playing or paused;
  • if open the audio in a browser or video player.
This problem does not appear immediately. For example, I turn on the computer in the morning, turn on background music on Youtube (in any browser). Then, in the evening or a little later, the system begins to freeze.
What do I do? For example, I pause the video and leave the computer for a few minutes.
Then I come back, turn on the video. The entire system freezes, but the sound plays. Only the picture freezes. Then, after 25 seconds (approximately), everything works fine.
I thought that this happened because of the kernel change to version 6.14. I deleted it and left 6.13rt5-3. But the same thing happens on this kernel.
When opening and starting to play a video in the VLC player, as well as Haruna, the same situation occurs. If I open an audio file, it also freezes. That is, it does not depend on the software (all browsers, all video players). However, in MPV (video player) this does not happen: both audio and video open without delay.
This problem can appear immediately after starting the PC, or after a few hours.
It is not clear what it depends on.
At the same time, the RAM is used at 40% maximum.
Disk activity is insignificant.
If I log out of the user profile or reboot the system, the system may not freeze for a while when playing video/audio.
KDE Plasma Version: 6.3.2
KDE Frameworks Version: 6.11.0
Qt Version: 6.8.2
Kernel Version: 6.13.0-3-rt5-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 4 × Intel® Core™ i3-9100F CPU @ 3.60GHz
Memory: 15.6 GiB of RAM
Graphics Processor: AMD Radeon RX 470 Graphics
The very basic system info you have provided won’t provide much assistance to the experts here. Could you please post the output of:
inxi -zv8
This gives more detailed, privacy-filtered information about your system.
Also, as you are using a separate graphics card, the output of:
mhwd -li
mhwd -l
may be useful.
Finally, please update your user profile by visiting this page: Forum Profile Preferences, as clicking on your forum profile avatar appears to show either outdated information about your system, or information about another system you are running:
Posted 28 mins ago
Joined Sep 14, 2020
Read 13h (2h recently)
Solutions 4
Branch: Stable
DE / WM: Kde
CPU: Intel 9550
GPU: Nvidia GT 1030
GPU Driver: Closed
Kernel: 6.1
GitHub Account: inverser-pro
inxi -zv8
  Kernel: 6.13.0-3-rt5-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.13-rt-x86_64
    root=UUID=00000-000-000-0000-0000 rw rootflags=subvol=@
    quiet splash resume=UUID=00000-0000-000-000-00000
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
  Type: Desktop Mobo: ASRock model: H310CM-HDV serial: <superuser required>
    uuid: <superuser required> UEFI-[Legacy]: American Megatrends v: P4.30
    date: 07/28/2021
  System RAM: total: 16 GiB available: 15.55 GiB used: 7.22 GiB (46.4%)
  Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 2133 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M378A1G43EB1-CPB serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous unbuffered
    part-no: M378A1K43BB1-CPB serial: <filter>
  Info: model: Intel Core i3-9100F bits: 64 type: MCP arch: Coffee Lake
    gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 4001 min/max: 800/4200 scaling: driver: intel_pstate
    governor: powersave cores: 1: 4001 2: 4001 3: 4001 4: 4001 bogomips: 28800
    smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    disabled
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: disabled;
  Device-1: Advanced Micro Devices [AMD/ATI] Ellesmere [Radeon RX
    470/480/570/570X/580/580X/590] vendor: Tul / PowerColor driver: amdgpu
    v: kernel arch: GCN-4 code: Arctic Islands process: GF 14nm built: 2016-20
    pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: HDMI-A-1 off: DVI-D-1
    empty: DP-1,DP-2,DP-3 bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
    temp: 53.0 C
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: DVI-D-1 model: Philips PHL 246E9Q serial: <filter> built: 2020
    res: 1920x1080 dpi: 93 gamma: 1.2 chroma: red: x: 0.663 y: 0.310 green:
    x: 0.275 y: 0.671 blue: x: 0.149 y: 0.051 white: x: 0.314 y: 0.329
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
    1280x720, 1024x768, 832x624, 800x600, 720x576, 720x480, 640x480, 720x400
  Monitor-2: HDMI-A-1 model: Philips 32M1C5500V serial: <filter> built: 2024
    res: mode: 2560x1440 hz: 144 scale: 100% (1) dpi: 93 gamma: 1.2 chroma: red:
    x: 0.675 y: 0.314 green: x: 0.282 y: 0.647 blue: x: 0.149 y: 0.063 white:
    x: 0.314 y: 0.329 size: 697x392mm (27.44x15.43") diag: 800mm (31.5")
    ratio: 16:9 modes: 2560x1440, 3840x2160, 1920x1200, 1920x1080, 1600x1200,
    1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 832x624,
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 96 2: parse_edid:
    unhandled CEA mode 97
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 470 Graphics
    (radeonsi polaris10 LLVM 19.1.7 DRM 3.59 6.13.0-3-rt5-MANJARO)
    device-ID: 1002:67df memory: 3.91 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.304 layers: N/A device: 0 type: discrete-gpu name: AMD
    Radeon RX 470 Graphics (RADV POLARIS10) driver: N/A device-ID: 1002:67df
    surfaces: xcb,xlib,wayland
  Device-1: Intel 200 Series PCH HD Audio vendor: ASRock driver: snd_hda_intel
    v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:a2f0
    class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Ellesmere HDMI Audio [Radeon
    RX 470/480 / 570/580/590] vendor: Tul / PowerColor driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 1002:aaf0 class-ID: 0403
  API: ALSA v: k6.13.0-3-rt5-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  IP v6: <filter> type: noprefixroute scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  Info: services: NetworkManager,nginx
  Local Storage: total: 7.51 TiB used: 3.46 TiB (46.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: GOODRAM model: SSDPR-CX400-128-G2
    size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 117D scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD8004FRYZ-01VAEB0 size: 7.28 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 1H01 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Apacer model: AS350 128GB
    tech: SSD serial: <filter> fw-rev: 1A0 scheme: GPT
  ID-1: / raw-size: 118.23 GiB size: 118.23 GiB (100.00%)
    used: 56.4 GiB (47.7%) fs: btrfs dev: /dev/sdc3 maj-min: 8:35 label: N/A
    uuid: 00000-0000-000-0000-00000
  ID-2: /home raw-size: 118.23 GiB size: 118.23 GiB (100.00%)
  ID-3: /run/media/u/hdd raw-size: 7.18 TiB size: 7.12 TiB (99.20%)
    used: 3.4 TiB (47.8%) fs: ext4 dev: /dev/sdb3 maj-min: 8:19 label: hdd
    uuid: 387b4c95-81fb-4242-b4f8-226a55fae1cb
  ID-4: /var/cache raw-size: 118.23 GiB size: 118.23 GiB (100.00%)
  ID-5: /var/log raw-size: 118.23 GiB size: 118.23 GiB (100.00%)
  ID-1: swap-1 type: partition size: 1024 MiB used: 256 KiB (0.0%)
    priority: -2 dev: /dev/sdc2 maj-min: 8:34 label: N/A
    uuid: 36296a83-f3de-4c61-8adf-55423bf98b29
  ID-1: /dev/sda1 maj-min: 8:1 size: 8 MiB fs: <superuser required> label: N/A
    uuid: N/A
  ID-2: /dev/sdb1 maj-min: 8:17 size: 104.49 GiB fs: ext4 label: N/A
    uuid: e405ed98-e8df-459f-a1d2-652bf1426f76
  ID-3: /dev/sdc1 maj-min: 8:33 size: 9 MiB fs: <superuser required>
    label: N/A uuid: N/A
  Device-1: 1-1:2 info: USB OPTICAL MOUSE type: mouse,keyboard
    chip-ID: 4e53:5406 class-ID: 0301
  Device-2: 1-8:3 info: China Resource Semico USB Keyboard
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 500mA
    chip-ID: 1a2c:4c5e class-ID: 0301
  Hub-2: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 38.0 C mobo: N/A gpu: amdgpu temp: 53.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 1128
  Packages: pm: pacman pkgs: 1355 libs: 342 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
Processes:
  CPU top: 5 of 334
  1: cpu: 24.0% command: java pid: 9171 mem: 3348.7 MiB (21.0%)
  2: cpu: 12.1% command: zsh pid: 26853 mem: 8.86 MiB (0.0%)
  3: cpu: 6.3% command: kwin_wayland pid: 796 mem: 443.0 MiB (2.7%)
  4: cpu: 3.1% command: plasmashell pid: 1018 mem: 488.0 MiB (3.0%)
  5: cpu: 2.2% command: opera pid: 1710 mem: 238.8 MiB (1.4%)
  Memory top: 5 of 334
  1: mem: 3348.7 MiB (21.0%) command: java pid: 9171 cpu: 24.0%
  2: mem: 596.6 MiB (3.7%) command: opera pid: 1462 cpu: 1.0%
  3: mem: 488.0 MiB (3.0%) command: plasmashell pid: 1018 cpu: 3.1%
  4: mem: 443.0 MiB (2.7%) command: kwin_wayland pid: 796 cpu: 6.3%
  5: mem: 426.8 MiB (2.6%) command: opera pid: 3290 cpu: 1.7%
  Processes: 334 Power: uptime: 2h 46m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.37
mhwd -li
> Installed PCI configs:
           video-linux            2024.05.06                true            PCI
mhwd -l
> 0000:02:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
         network-r8168            2023.09.12                true            PCI
> 0000:01:00.0 (0300:1002:67df) Display controller ATI Technologies Inc:
Hello, I have the same Problem:
inxi -zv8
  Kernel: 6.14.0-rc4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64
    root=UUID=9ec17962-f5b1-48ad-856c-bb8b27c22eee rw quiet
    udev.log_priority=3 preempt=full amd_pstate=passive
    cpufreq.default_governor=performance
  Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING PLUS (MS-7C37) v: 2.0
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: A.L0 date: 06/29/2023
  System RAM: total: 64 GiB available: 62.71 GiB used: 8.01 GiB (12.8%)
    (unregistered) size: 16 GiB speed: 3600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
    part-no: F4-3600C16-16GTZNC serial: N/A
  Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
  Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
    desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 4273 min/max: 550/5724 boost: enabled scaling:
    driver: amd-pstate governor: performance cores: 1: 4273 2: 4273 3: 4273
    4: 4273 5: 4273 6: 4273 7: 4273 8: 4273 9: 4273 10: 4273 11: 4273 12: 4273
    13: 4273 14: 4273 15: 4273 16: 4273 17: 4273 18: 4273 19: 4273 20: 4273
    21: 4273 22: 4273 23: 4273 24: 4273 bogomips: 205210
    xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600
    XT / 5700/5700 XT] vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-1
    code: Navi-1x process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2,HDMI-A-1 empty: DP-3
    bus-ID: 2f:00.0 chip-ID: 1002:731f class-ID: 0300
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 4480x3600 display-ID: 0
  Monitor-1: DP-1 pos: middle-r model: LG (GoldStar) ULTRAGEAR
    serial: <filter> built: 2022 res: mode: 2560x1440 hz: 165 scale: 100% (1)
    dpi: 93 gamma: 1.2 chroma: red: x: 0.686 y: 0.310 green: x: 0.263 y: 0.671
    blue: x: 0.149 y: 0.055 white: x: 0.314 y: 0.329
    size: 697x392mm (27.44x15.43") diag: 800mm (31.5") ratio: 16:9
    modes: 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024,
    1440x900, 1280x800, 1280x720, 1024x768, 800x600, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112
  Monitor-2: DP-2 pos: primary,top-left model: Samsung SMB2430L
    serial: <filter> built: 2011 res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 94 gamma: 1.2 chroma: red: x: 0.647 y: 0.333 green: x: 0.282 y: 0.608
    blue: x: 0.149 y: 0.071 white: x: 0.314 y: 0.329
    size: 521x293mm (20.51x11.54") diag: 598mm (23.5") ratio: 16:9
    modes: 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x960,
    1280x800, 1152x864, 1280x720, 1024x768, 832x624, 800x600, 720x576,
  Monitor-3: HDMI-A-1 pos: bottom-l model: Acer VG270 serial: <filter>
    built: 2021 res: mode: 1920x1080 hz: 75 scale: 100% (1) dpi: 82 gamma: 1.2
    chroma: red: x: 0.639 y: 0.337 green: x: 0.314 y: 0.624 blue: x: 0.149
    y: 0.055 white: x: 0.314 y: 0.329 size: 598x336mm (23.54x13.23")
    diag: 686mm (27") ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024,
    1440x900, 1280x800, 1152x864, 1280x720, 1024x768, 800x600, 720x576,
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 XT (radeonsi
    navi10 LLVM 19.1.7 DRM 3.61 6.14.0-rc4-1-MANJARO) device-ID: 1002:731f
    memory: 7.81 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.304 layers: 8 device: 0 type: discrete-gpu name: AMD
    Radeon RX 5700 XT (RADV NAVI10) driver: N/A device-ID: 1002:731f
    de: kscreen-console,kscreen-doctor gpu: amdgpu_top, corectrl, radeontop
    wl: wayland-info,wlr-randr x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio
    bus-ID: 2f:00.1 chip-ID: 1002:ab38 class-ID: 0403
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: M-Audio AIR 192 6 driver: snd-usb-audio type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2.4:3 chip-ID: 0763:410c
    class-ID: fe01
  API: ALSA v: k6.14.0-rc4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
    vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Microsoft Xbox Wireless Adapter for Windows driver: xone-dongle
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-3.3:6
    chip-ID: 045e:02fe class-ID: 0000 serial: <filter>
  Info: services: NetworkManager, sshd, systemd-timesyncd
  Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
    v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-6.3:4
    chip-ID: 0a12:0001 class-ID: e001
  Report: btmgmt ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
    rfk-block: hardware: no software: no address: <filter> bt-v: 4.0 lmp-v: 6
    status: discoverable: no pairing: no
  Message: Unable to run lvs. Root privileges required.
  Local Storage: total: 10.32 TiB used: 7.73 TiB (74.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 34.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Lexar model: SSD NM790 4TB
    size: 3.73 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 12237 temp: 44.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: DB6Q scheme: GPT
  SMART Message: Unknown smartctl error. Unable to generate data.
  ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 1TB
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD40EZRZ-00GXCB0 size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 0A80 scheme: GPT
  ID-1: / raw-size: 500 GiB size: 491.08 GiB (98.22%) used: 127.75 GiB (26.0%)
    fs: ext4 block-size: 4096 B dev: /dev/sdb1 maj-min: 8:17 label: N/A
    uuid: 9ec17962-f5b1-48ad-856c-bb8b27c22eee
    used: 26 MiB (27.0%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
    label: N/A uuid: 525E-1D41
  ID-3: /home raw-size: 3.73 TiB size: 3.73 TiB (100.00%)
    used: 3.51 TiB (94.1%) fs: btrfs block-size: 4096 B dev: /dev/dm-1
    maj-min: 254:1 mapped: HomeVG-HomeVerzeichnissLV label: N/A uuid: N/A
  ID-4: /home/<filter>/Media/SSD-Daten raw-size: 431.51 GiB
    size: 431.51 GiB (100.00%) used: 392.4 GiB (90.9%) fs: btrfs
    block-size: 4096 B dev: /dev/sdb2 maj-min: 8:18 label: SSD-Daten
    uuid: 5a3ce656-e9f5-48d2-8d6e-eb33522ea780
  ID-5: /run/media/michael/Backup raw-size: 3.64 TiB
    size: 3.64 TiB (100.00%) used: 2.12 TiB (58.1%) fs: btrfs block-size: 4096 B
    dev: /dev/sdc1 maj-min: 8:33 label: Backup
    uuid: 00e350f6-9781-43f7-8fcd-e196715de067
  ID-6: /run/media/michael/Work raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 1.6 TiB (87.7%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
    maj-min: 254:0 mapped: WorkSSDVG-WorkLV label: N/A uuid: N/A
  ID-1: /dev/sda2 maj-min: 8:2 size: 128 MiB fs: <superuser required>
  ID-2: /dev/sda3 maj-min: 8:3 size: 231.18 GiB fs: ntfs label: N/A
    uuid: 48B8D690B8D67C3E
  ID-3: /dev/sda4 maj-min: 8:4 size: 553 MiB fs: ntfs label: N/A
    uuid: 7A5ACBEA5ACBA0ED
  ID-4: /dev/sda5 maj-min: 8:5 size: 511 MiB fs: ntfs label: N/A
    uuid: A8E8DF48E8DF1382
  ID-5: /dev/sda6 maj-min: 8:6 size: 450 MiB fs: ntfs label: N/A
    uuid: 846851C56851B720
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-2: 1-2:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2822
  Device-1: 1-2.4:3 info: M-Audio AIR 192 6 type: audio
    driver: snd-usb-audio interfaces: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0763:410c class-ID: fe01
  Hub-3: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-4: 2-2:2 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0822
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-1:2 info: Corsair K55 RGB PRO XT Gaming Keyboard
    type: keyboard,HID driver: usbfs interfaces: 3 rev: 1.1
    chip-ID: 1b1c:1ba1 class-ID: 0300 serial: <filter>
  Device-2: 3-2:3 info: HP LaserJet P1102 type: printer driver: usblp
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 98mA chip-ID: 03f0:002a class-ID: 0701 serial: <filter>
  Hub-6: 3-5:4 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 3-5.1:6 info: Genesys Logic SD Card Reader and Writer
    type: mass storage driver: usb-storage interfaces: 1 rev: 2.1
    chip-ID: 05e3:0749 class-ID: 0806 serial: <filter>
  Device-2: 3-6:5 info: Seiko Epson XP-235 Series type: printer
    driver: usblp interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 2mA chip-ID: 04b8:1102 class-ID: 0701 serial: <filter>
  Hub-7: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-8: 5-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 5-5:2 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c37 class-ID: 0300
    serial: <filter>
  Hub-9: 5-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 5-6.3:4 info: Cambridge Silicon Radio Bluetooth Dongle (HCI
    mode) type: bluetooth driver: btusb interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a12:0001
    class-ID: e001
  Hub-10: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-11: 7-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-12: 7-3:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
  Hub-13: 7-3.2:4 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
  Hub-14: 7-3.2.2:7 info: Genesys Logic Hub ports: 4 rev: 2.1
  Device-1: 7-3.2.3:8 info: Logitech G502 SE HERO Gaming Mouse
    type: mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 300mA
    chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
  Hub-15: 7-3.2.4:9 info: Realtek RTS5411 Hub ports: 3 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Device-1: 7-3.2.4.3:10 info: LG USA 27UP850 - WK.AEUDCSN External Monitor
    4K type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 043e:9a39
  Device-2: 7-3.3:6 info: Microsoft Xbox Wireless Adapter for Windows
    type: WiFi driver: xone-dongle interfaces: 1 rev: 2.0
  Hub-16: 7-4:3 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
  Hub-17: 7-4.4:5 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
  Hub-18: 8-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-19: 8-3:3 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 2109:0822
  Hub-20: 8-3.2:5 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2
  Hub-21: 8-3.2.2:6 info: Genesys Logic Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
  Hub-22: 8-3.2.4:7 info: Realtek Hub ports: 3 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
  Hub-23: 8-4:2 info: Realtek Hub ports: 4 rev: 3.2
  Hub-24: 8-4.4:4 info: Realtek Hub ports: 4 rev: 3.2
  System Temperatures: cpu: 33.4 C mobo: N/A gpu: amdgpu temp: 53.0 C
    mem: 54.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 0
  Packages: pm: pacman pkgs: 2698 libs: 554 tools: octopi,pamac,yay pm: rpm
    pkgs: 0 pm: flatpak pkgs: 0
  Active pacman repo servers in: /etc/pacman.conf
    1: https://arch.osamc.de/$repo/$arch
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    3: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    4: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
Processes:
  CPU top: 5 of 516
  1: cpu: 21.0% command: brave pid: 4332 mem: 1107.8 MiB (1.7%)
  2: cpu: 9.9% command: brave pid: 12345 mem: 243.2 MiB (0.3%)
  3: cpu: 4.0% command: plasmashell pid: 2818 mem: 754.5 MiB (1.1%)
  4: cpu: 2.9% command: brave pid: 11961 mem: 300.6 MiB (0.4%)
  5: cpu: 1.8% command: kwin_wayland pid: 2548 mem: 390.8 MiB (0.6%)
  Memory top: 5 of 516
  1: mem: 1119.7 MiB (1.7%) command: telegram-desktop pid: 3241 cpu: 0.3%
  2: mem: 1107.8 MiB (1.7%) command: brave pid: 4332 cpu: 21.0%
  3: mem: 992.7 MiB (1.5%) command: thunderbird pid: 9129 cpu: 1.2%
  4: mem: 754.5 MiB (1.1%) command: plasmashell pid: 2818 cpu: 4.0%
  5: mem: 676.6 MiB (1.0%) command: brave pid: 3844 cpu: 1.5%
  Processes: 516 Power: uptime: 1h 57m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25.06 GiB services: org_kde_powerdevil,upowerd
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: fish v: 4.0.0
mhwd -li
mhwd -l
> 0000:2f:00.0 (0300:1002:731f) Display controller ATI Technologies Inc:
> 0000:27:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
After a restart, everything works fine again, up to the point when I am away from the computer for a while and the screen saver comes on or the monitors switch off. When I then reactivate the computer, the problem occurs. I have also noticed that I can no longer adjust the brightness of the monitors via Plasma. Restarting the computer is the only way to solve the problem temporarily.
Playing a lot of YouTube videos quickly starts to eat up RAM and start to invade swap; in your cases having very little (only 1G) and none at all. (Although in @Inko 's case, I’d expect it to take rather longer for RAM to become swamped).
I regularly have to restart the browser to free up RAM; periodic reboots are also required to clean out the rest.
I did try out a script posted elsewhere which is meant to clear out the cache, but haven’t got it to work for me yet.
When these freezes start to occur, check
free -h
and perhaps also
htop
↑ You might have to install this first but I, for one, much prefer it over the default top ↑
… and you might be surprised at the results. :wink:
Thanks for your reply, I’ll keep an eye on it the next time it occurs.
I’m just surprised that it never happened until the last update and I haven’t changed anything else on my system except that I switched from chrome to brave.
Thank you very much for your reply.
However, the freeze occurs not only in the browser and not only on the YouTube page. Any page containing audio or video in the browser can cause the freeze effect.
Also, regardless of the browser, when playing video or audio in the VLC player, Haruna - also freezes. But in mpv there is no such thing.
I described the situation in great detail. My RAM is not full. swap is used for some percentage and sometimes.
The reason I mentioned YouTube is that’s the site I mostly use; the same applies to other sites with embedded videos etc. which may use the same or a similar “engine” for video streaming.
Are these also streamed videos, rather than locally stored? Same for mpv? :thinking:
Hello, I have now looked in journalctl during the existence of the error and have attached here all the messages that I bring in connection with the error.
I have also looked at the RAM, but it looks good, there is still enough free.
 ~  free -h        Fr 14 Mär 2025 14:56:57 CET
              gesamt       benutzt     frei      gemns.  Puffer/Cache verfĂĽgbar
Speicher:       62Gi       4,3Gi        42Gi       145Mi        16Gi        58Gi
Swap:             0B          0B          0B
journalctl
Mär 14 14:48:59 Aegir brave[8933]: [8933:1:0314/144859.564905:ERROR:command_buffer_proxy_impl.cc(289)] GPU state invalid after WaitForTokenInRange.
Mär 14 14:48:59 Aegir brave[8446]: [8446:8446:0314/144859.571920:ERROR:gpu_process_host.cc(953)] GPU process exited unexpectedly: exit_code=512
Mär 14 14:48:59 Aegir brave[9421]: [9421:9421:0314/144859.727737:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
Mär 14 14:49:03 Aegir brave[8446]: [8446:8470:0314/144903.464449:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedesktop/PowerManagement/Inhibit: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Mär 14 14:49:03 Aegir brave[8446]: [8446:8470:0314/144903.464463:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Mär 14 14:49:28 Aegir brave[8446]: [8446:8470:0314/144928.469674:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedesktop/PowerManagement/Inhibit: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Mär 14 14:49:28 Aegir brave[8446]: [8446:8470:0314/144928.469688:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Mär 14 14:49:44 Aegir brave[8446]: [8446:8446:0314/144944.708542:ERROR:gpu_process_host.cc(953)] GPU process exited unexpectedly: exit_code=512
Mär 14 14:49:44 Aegir brave[8933]: [8933:18:0314/144944.783928:ERROR:command_buffer_proxy_impl.cc(125)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
Mär 14 14:49:44 Aegir brave[8933]: [8933:7:0314/144944.784550:ERROR:command_buffer_proxy_impl.cc(125)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
Mär 14 14:49:44 Aegir brave[9617]: [9617:9659:0314/144944.853560:ERROR:shared_image_manager.cc(509)] SharedImageManager::ProduceMemory: Trying to Produce a Memory representation from a non-existent mailbox.
Mär 14 14:49:44 Aegir brave[9617]: [9617:9659:0314/144944.853627:ERROR:shared_image_manager.cc(509)] SharedImageManager::ProduceMemory: Trying to Produce a Memory representation from a non-existent mailbox.
Mär 14 14:49:44 Aegir brave[9617]: [9617:9659:0314/144944.853669:ERROR:shared_image_manager.cc(509)] SharedImageManager::ProduceMemory: Trying to Produce a Memory representation from a non-existent mailbox.
Mär 14 14:49:53 Aegir brave[8446]: [8446:8470:0314/144953.499533:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.ScreenSaver.Inhibit: object_path= /org/freedesktop/ScreenSaver: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Mär 14 14:49:53 Aegir brave[8446]: [8446:8470:0314/144953.499549:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Mär 14 14:50:18 Aegir brave[8446]: [8446:8470:0314/145018.524034:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedesktop/PowerManagement/Inhibit: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.t receive a reply. Possible causes include: the remote application did
Mär 14 14:50:18 Aegir brave[8446]: [8446:8470:0314/145018.524053:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Mär 14 14:50:43 Aegir brave[8446]: [8446:8470:0314/145043.552657:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.ScreenSaver.Inhibit: object_path= /org/freedesktop/ScreenSaver: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Mär 14 14:50:43 Aegir brave[8446]: [8446:8470:0314/145043.552672:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Mär 14 14:50:43 Aegir kwin_wayland[2509]: kwin_wayland_drm: The main thread was hanging temporarily!
Mär 14 14:51:08 Aegir brave[8446]: [8446:8470:0314/145108.557472:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedesktop/PowerManagement/Inhibit: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Mär 14 14:51:08 Aegir brave[8446]: [8446:8470:0314/145108.557487:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Mär 14 14:51:08 Aegir brave[8446]: [8446:8470:0314/145108.558829:ERROR:feed_fetcher.cc(200)] Bad response from brave news feed.json. Status: 200
Mär 14 14:51:09 Aegir brave[8446]: [8446:8470:0314/145109.173026:ERROR:topics_fetcher.cc(111)] Failed to get topics: 0,
Mär 14 14:57:16 Aegir kwin_wayland[2509]: kf.windowsystem: static bool KX11Extras::mapViewport() may only be used on X11
Mär 14 14:57:16 Aegir kwin_wayland[2509]: kwin_scene_opengl: 0x2: GL_INVALID_VALUE in glTexStorage2D(width, height or depth < 1)
Mär 14 14:57:16 Aegir kwin_wayland[2509]: kwin_scene_opengl: Invalid framebuffer status:  "GL_FRAMEBUFFER_INCOMPLETE_ATTACHMENT"
Mär 14 14:57:16 Aegir kwin_wayland[2509]: kwin_scene_opengl: 0x2: GL_INVALID_OPERATION in glBindFramebuffer(non-gen name)
Mär 14 14:57:16 Aegir kwin_wayland[2509]: kwin_scene_opengl: 0x2: GL_INVALID_FRAMEBUFFER_OPERATION in glClear(incomplete framebuffer)
Mär 14 14:57:16 Aegir brave[10798]: [10798:10798:0314/145716.299465:ERROR:profile_attributes_storage.cc(1011)] Failed to PNG encode the image.
Mär 14 14:57:24 Aegir brave[10849]: [10849:10849:0314/145724.404385:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
Mär 14 14:57:32 Aegir brave[10849]: [10849:10849:0314/145732.217060:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
Mär 14 14:57:34 Aegir brave-browser.desktop[11578]: Wird in einer aktuellen Browsersitzung geöffnet.
Mär 14 14:57:34 Aegir brave[10849]: [10849:10849:0314/145734.085928:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
Mär 14 14:57:35 Aegir brave[10798]: [10798:10798:0314/145735.279345:ERROR:interface_endpoint_client.cc(725)] Message 0 rejected by interface blink.mojom.WidgetHost
Mär 14 14:58:16 Aegir brave[10798]: [10798:10819:0314/145816.973171:ERROR:topics_fetcher.cc(111)] Failed to get topics: 0,
Mär 14 14:58:17 Aegir brave[10798]: [10798:10819:0314/145817.105864:ERROR:feed_v2_builder.cc(180)] Finished feed generation (no eligible content groups or no articles)
Mär 14 14:58:57 Aegir brave[10798]: [10798:10819:0314/145857.423436:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.ScreenSaver.Inhibit: object_path= /org/freedesktop/ScreenSaver: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Mär 14 14:58:57 Aegir brave[10798]: [10798:10819:0314/145857.423476:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Mär 14 14:58:57 Aegir kwin_wayland[2509]: kwin_wayland_drm: The main thread was hanging temporarily!
Mär 14 14:59:22 Aegir brave[10798]: [10798:10819:0314/145922.448293:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedesktop/PowerManagement/Inhibit: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Mär 14 14:59:22 Aegir brave[10798]: [10798:10819:0314/145922.448307:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
Mär 14 14:59:47 Aegir brave[10798]: [10798:10819:0314/145947.473776:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedesktop/PowerManagement/Inhibit: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Mär 14 15:06:16 Aegir brave[10967]: [10967:10:0314/150616.183897:ERROR:command_buffer_proxy_impl.cc(325)] GPU state invalid after WaitForGetOffsetInRange.
Mär 14 15:06:16 Aegir brave[10798]: [10798:10798:0314/150616.187910:ERROR:gpu_process_host.cc(953)] GPU process exited unexpectedly: exit_code=512
Mär 14 15:06:16 Aegir brave[12336]: [12336:12336:0314/150616.388833:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
Mär 14 15:06:16 Aegir brave[12336]: [12336:12336:0314/150616.400619:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
Mär 14 15:06:16 Aegir brave[12336]: [12336:12336:0314/150616.460665:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
Mär 14 15:06:50 Aegir brave[10798]: [10798:10819:0314/150650.676684:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.PowerManagement.Inhibit.Inhibit: object_path= /org/freedesktop/PowerManagement/Inhibit: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Mär 14 15:06:50 Aegir brave[10798]: [10798:10819:0314/150650.676699:ERROR:power_save_blocker_linux.cc(342)] No response to Inhibit() request!
The error also occurs when I watch a video with VLC.
@Inko Looking at that last log, what I’d suggest is to turn off Screen Locking via System Settings; also in Power Management, set Suspend Session to “Do Nothing”.
@inverser It would be good for you to post the same. If the errors look like these, I’d suggest the same.
I can’t say for sure about YouTube. Most likely, we are talking about regular VP9/AV1 videos.
As for VLC and haruna, we are talking about local files.
Yes, intuitively, it seems to me too that this is somehow connected
Hello, under my energy settings it was already set to “do nothing” under “When inactive”. I only switch off my screens after the set time. See screenshot.
I’d suggest setting the first one to “Never” rather than 15 min. and see what happens. :wink:
I’ve encountered (but not documented, silly me) a case where I had to select a different option, in order to switch back and actually use the option in a Manjaro GUI window. The underlying reason was that the previously selected option no longer existed, and the “Inactive” button was automatically selected in the GUI, blocking me from actually setting it to “Inactive”.
So as BG405 mentioned, it might be worthwhile to switch the energy settings to something else, and then back to “do nothing”.
I have had this before as well.
In addition; sometimes, after an update (particularly a major one, as with the Plasma6 upgrade some time back) one has to log-out of Plasma to do such updates and clear out the old cache/config etc, :wink:
It’s often recommended to do upgrades whilst completely logged out of your Plasma GUI and use a TTY instead for the process.
Oh ah uhm, just noticed, I experienced this on XFCE :grinning:
journalctl --since today --reverse
Mar 17 21:53:45 uu org_kde_powerdevil[1074]: [  1074] Unexpected error DDCRC_LOCKED from unlock_display_by_dpath(Display_Path[/dev/i2c-4])
Mar 17 21:53:45 uu org_kde_powerdevil[1074]: [  1074] Attempting to unlock display lock owned by different thread
Mar 17 21:53:45 uu org_kde_powerdevil[1074]: [  1074] Watch thread terminated.
Mar 17 21:53:45 uu org_kde_powerdevil[1074]: [  1315] recheck thread terminating because watch thread terminated
Mar 17 21:53:45 uu org_kde_powerdevil[1074]: library quiesced, ddca_close_display temporarily unavailable
Mar 17 21:53:45 uu org_kde_powerdevil[1074]: [  1074] Display redetection starting.
Mar 17 21:53:45 uu org_kde_powerdevil[1074]: org.kde.powerdevil: [DDCutilDisplay]: ddca_close_display -3032
Mar 17 21:53:45 uu org_kde_powerdevil[1074]: [  1074] Error queiscing libdducitl API. 1 active API calls outstanding.
Mar 17 21:53:45 uu org_kde_powerdevil[1074]: Error queiscing libdducitl API. 1 active API calls outstanding.
Mar 17 21:53:42 uu org_kde_powerdevil[1074]: [  1074] Quiescing libddcutil API...
Mar 17 21:53:42 uu org_kde_powerdevil[1074]: [  1316] Started 1 event callback thread(s)
Mar 17 21:53:42 uu org_kde_powerdevil[1074]: [  1316] libddcutil callback thread 0x722010015af0 started
Mar 17 21:53:42 uu org_kde_powerdevil[1074]: [  1316] Emitting DDCA_Display_Status_Event[389.772:  DDCA_EVENT_DISPLAY_CONNECTED, card1-HDMI-A-1, dref: DDCA_Display_Ref[3], io_path:/dev/i2c-3, ddc working: true]
By the way, after this error happened, I can’t enter the power saving settings
Try:
systemctl --user restart plasma-powerdevil
The good news is that, on my Testing branch system, a lot of the powerdevil crashing issues that I was having on Plasma 6 seem to have been fixed in 6.3.3. So, hopefully 6.3.3 isn’t too far away from Stable. In my case, it was crashing every time my system put itself to sleep (but not when I manually put it to sleep). So I had to frequently run the above command to get my brightness settings back. Hopefully it should do the same for your power settings.
You can check the status of the powerdevil service by running:
systemctl --user status plasma-powerdevil
works for me too, thanks
